Staff
Road to OpenVPN 2.6 and DCO
We're glad to inform you that we have just released:
UPDATE 2026-03-12
After careful evaluation and considering that:
  • DCO for OpenVPN 2.6 is now considered obsolete
  • the new DCO is aimed at OpenVPN 2.7 only
  • DCO kernel module is included on mainline Linux kernel starting from 6.16
  • AirVPN VPN infrastructure is based on kernel 6.12 and OpenVPN 2.6 (typical setup of Debian 13, RHEL 10 etc.)
  • OpenVPN usage declined dramatically: today only 24% of connections are based on OpenVPN, and the decline continues at a steady pace
  • the combination of WireGuard and AmneziaWG is more effective than OpenVPN over TCP at bypassing blocks
  • valuable packet payload padding (against encrypted traffic pattern analysis) is offered by AmneziaWG and not DCO:
the plan has been momentarily frozen. It can be re-activated when the VPN infrastructure moves to kernel 6.16 (or higher version) and OpenVPN 2.7. Our priority goes to wider AmneziaWG support, on the client software first and then on the server side too (important especially for padding).
UPDATE 2026-06-03
We're very glad to inform you that OpenVPN DCO deployment entered its final stage. DCO module and OpenVPN 2.7 are being deployed on all VPN servers. We discarded DCO for OpenVPN 2.6 and aimed at offering OpenVPN 2.7 + DCO directly.
As announced in 2023, when DCO was in an embryonic state, we confirm that DCO support implies necessarily end of AES-CBC cipher support, both on Data and Control Channel, because the DCO module does not support it. AES-CBC support, even as a fallback only, would casue the OpenVPN daemons to de-activate DCO globally. Please make sure you run an OpenVPN version that can support AES-GCM on both channels, typically OpenVPN 2.4 or higher versions, linked against an SSL library that includes AES-GCM / CHACHA20-POLY1305 support.
UPDATE 2026-10-27
The migration is complete: all AirVPN VPN servers now run OpenVPN 2.7 with the DCO kernel module.
  • The default profile of the Configuration Generator is now DCO compatible. It uses only AEAD ciphers (AES-GCM, CHACHA20-POLY1305) on the Data Channel and no longer contains any compression directive. Continent, country and server selection work with every profile.
  • The OpenVPN profile menu (Advanced) now offers "Default (OpenVPN 2.5 or higher)", "Default without DCO (OpenVPN 2.6 or higher)" and "OpenVPN 2.4". The "2.6 DCO" entry mentioned in the previous update no longer exists, because every server supports DCO.
  • If your OpenVPN client warns that 'comp-lzo' was deprecated (for example Tunnelblick with OpenVPN 2.7), simply generate your configuration files again with default settings.
  • Clarification to the previous update: the AES-CBC restriction applies to the Data Channel, which is the part handled by DCO.
  • OpenVPN 2.3 and older versions can no longer connect. If your device is stuck on an old OpenVPN version (for example an old router or NAS firmware), please consider WireGuard, supported on all our servers.
The page https://airvpn.org/road_to_openvpn26/ has been rewritten as "OpenVPN 2.7 and DCO": advantages of DCO, compatibility, Configuration Generator, client-side notes for Linux, Windows and FreeBSD / pfSense / OPNsense, and how to check whether DCO is in use.
Kind regards & datalove
AirVPN Staff
Did some testing from my pfsense+ box.  So far it works very well.  It's lovely to see all the openvpn work being done in kernel here and 600mbit/s from this great distance seems very respectable.
@bnrrteterstnjrsj45
The wintun driver is not for DCO. Are you running Eddie 2.23? If so, please check the caveats in the "Road to OpenVPN 2.6" page, specifically:
Quote
Eddie will use wintun as driver by default, and will not currently install ovpn-dco driver or create adapter.
During the Beta Testing Phase, run the official OpenVPN Installer (which installs the driver and create the adapter) and in Eddie specify in Preferences  Advanced  Driver the value ovpn-dco
Future releases in the beta phase will install and manage automatically ovpn-dco driver and network adapter (WIP).
I wish I had seen this earlier... really hoping some in the USA soon
  library versions: OpenSSL 1.1.1u 30 May 2023, LZO 2.10
  Notice   OpenVPN 2.6.4 amd64-portbld-freebsd13.1 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD]
well see how it goes, staying connected and speed wise
I'm confirm, now twitch opens while on wg. But tested only once, I mean not several times checked.
And thanks for "post-quantum resistence" on new dco server Marsic, but it is wg, not about dco.
Excellent job!
Testing OpenVPN + DCO with pfSense 23.05 with IPsec-MB Crypto: Yes (active), on fiber 1000/300.
- Router/Firewall pfSense 25.11.1 (11th Gen Intel(R) Core(TM) i5-11320H @ 3.20GHz)
- Switch Cisco SG350-10 /Zyxel XGS1210-12
- AP Netgear RAX200 (Stock FW)
- NAS Synology DS1621+ (5 x 8TB WD Red)
- ISP: Fiber 1000/300 (PPPoE)
@StaffCan you deploy a server in Canada or US for this test-phase?(if possible)
Reason: Max speed qbit(~60-80MB/s) to Marsic(Mars I see). Need another server to compare speed-wise(etc).
On 6/30/2023 at 2:41 PM, airvpnforumuser said:
I am honestly still confused by this whole ovpn-dco thing and maybe @staff can answer a few questions?
Although they don't mention Wireguard in their blog post it seems to me after years of stagnation they've finally figured that in-kernel is the _only_ way to get the performance needed with higher bandwidth use-cases - Wireguard offers the best speeds in the business so it's nice to see them catching up.
However, there are a few caveats
1: It does not appear they are planning to submit a patch to DavidM to include this into Linux natively? They mention they build against net-next but the github page has been very sparse for a few months, It surely is a waste of time to make an out-of-tree kernel module? If their code is so good either submit the patch to net-next or it's a joke, surely? Won't this mean constantly having to test/rebase as the kernel updates every few months? When it's part of the tree you get 'free' support as the code is effectively maintained forever (hence the appeal of Wireguard, it's part of Linux forever now).
2: It seems the restrictions are quite strict: each server needs dco, and that breaks compatibility. I implore staff to keep old servers around without dco, many, many people will not upgrade to latest eddie (on any platform) for various reasons. It would be massive mistake to force dco in next few years. Add it to servers, sure, but keep servers that work on older clients. You should support as many older eddies (within reason with regards to security) as possible. Breaking users is a huge no-go.
It seems there is limited support for Linux (ironically, you need to build a module yourself and not many are going to do that, or know how!) and Android, which makes this effort feel...less impactful. I don't understand the benefits of dco directly - will this match wireguard in terms of performance? I am interested in AirVPN's tests as to how good dco is in their experience on multiple platforms (windows, routers, raspberry pi etc etc). I have yet to see the justification for dco that would make users update to latest eddie and be a breaking change.
 It's probably a worthwhile effort in the long run but absolutely not worthwhile breaking the user. It remains sad that AirVPN needs to maintain its own fork of OpenVPN as they were too arrogant to accept legitimate patches sent to them by ProMind. I wonder if their code would even be accepted by David M anyhow :)
1. I don't personally see this as much of an issue but I agree with you that it would benefit from being in the kernel. Just being in the Linux tree doesn't provide near as universal benefits as are made out, because whilst true you might get some bug fixes that come down the line through testing - and the testing that goes on is largely automated tested testing, it doesn't ensure that anybody is really going to actively maintain it in relation to feature sets or utilities or any meaningful development. I can point to a variety of in-kernel stuff which is just like that, hasn't received any meaningful updates in years and likely won't receive any (because the dev has long abandoned it)
2. I was under the impression that the two could co-exist, we've had reports of others in various threads connecting to OVPN servers whilst having DCO supported clients but not supported servers and everything working fine.
RE: performance - from benchmarks others have done, it appears that OVPN will be significantly faster than wireguard. I don't know how they are accomplishing this but I think it will likely be due to the ciphers that are being used. Making use of the AES-NI ciphers, AES-256-GCM, AES-128-GCM are likely how they are reaching those performance values.
Finally on your last point, cant you fork their fork and merge it back? or whoever else who wants to? It sounds to me like you want people to actively maintain something in a manner that you see fit, which just seems silly. AirVPN have made various posts on various changes they made and the performance gains they had as a result or use case scenarios that benefitted them.
15 minutes ago, go558a83nk said:
implementation at this time?
From the article/link Yes I read that BTW:
"Some features are not compatible with DCO or are not relevant with DCO."
Now which one is it "compatible or relevant"?
And this is the part that confused the most:
"Per-peer data usage is not tracked properly"
yeah so usually your openvpn peers will show a total upload/download when looking at openvpn status.  but DCO clients currently do not.
Yup.
Nope.
Yup. Nope.
146.70.111.21:443 36 KiB 37 KiB
that's for sure.  I boot up my backup router.  SG3100.    and couldn't figure out why the numbers were not increasing..
its just doesn't change on the status page
21 hours ago, go558a83nk said:
BTW, I think the really speedy stuff with DCO is coming from machines that have QAT available not from AES-NI.
pfSense Plus software supports ChaCha20-Poly1305 with OpenVPN DCO, but currently only IPsec-MB can accelerate that algorithm. At this time, neither AES-NI nor QAT can accelerate ChaCha20-Poly1305. Some newer QAT hardware may be capable of accelerating ChaCha20-Poly1305, but the current QAT drivers do not yet include support for that encryption algorithm.
In pfSense+ I found using ChaCha20-Poly1305 and enabling IPsec-MB be faster than wireguard.
it wasn't clear but my comment was in reference to AES-128-GCM being fast with DCO.  and even faster if you have a QAT machine.
On 7/4/2023 at 1:59 PM, Flx said:
No matter what cipher you pick the CPU load stays the same?
difficult to say but it seemed like CPU load is less with AES than with chacha yet chacha was a little faster.  pfsense and using IPsec-MB
