urbanconcrete 14 Posted ... Short question, probably short answer...Can i use the ssh tunnel port 22 protocol with a dd-wrt router? Thanks! Quote Share this post Link to post
A340 2 Posted ... I will also like to know the answer to this question.. much appreciated.. A340 Quote Share this post Link to post
go558a83nk 380 Posted ... If you can get something like optware installed then you should be able to run it. I have optware installed on my asus ac68 with merlin firmware onto a USB memory stick. I had to install bash and openssh with ipkg. Bash runs the script, openssh is called therein. So far no problems connecting and with stability, but speeds are much slower than "naked" openvpn run with the same router. Not slower because of CPU usage but because it's a TCP connection I surmise. If the staff are watching, is TCP required for ssh tunnel setup? sorry if a dumb question. Quote Share this post Link to post
Staff 10307 Posted ... If the staff are watching, is TCP required for ssh tunnel setup? sorry if a dumb question. Hello! Yes, it is mandatory, no UDP support by SSH as you can imagine. So you have overhead by additional SSH tunnel and on top of that OpenVPN forced to work in TCP mode (which, for how OpenVPN works, will be slower and less efficient than UDP). You should never use this mode unless you absolutely need it for some reason (for example to bypass OpenVPN disruption or extreme shaping). Kind regards Quote Share this post Link to post
go558a83nk 380 Posted ... If the staff are watching, is TCP required for ssh tunnel setup? sorry if a dumb question. Hello! Yes, it is mandatory, no UDP support by SSH as you can imagine. So you have overhead by additional SSH tunnel and on top of that OpenVPN forced to work in TCP mode (which, for how OpenVPN works, will be slower and less efficient than UDP). You should never use this mode unless you absolutely need it for some reason (for example to bypass OpenVPN disruption or extreme shaping). Kind regards LOL, so it was a dumb question. But, I'm no expert.... Here in Thailand they have apparently made VPN usage illegal because they want to monitor heavily. Thus my attempt to hide my use of openvpn by ssh tunnel. if my routing to the singapore servers was proper I think the ssh tunnel would work just fine because the latency would be low. But, the lowest latency server to me is 240ms and up and depends on the time of day. TCP just doesn't work well at those latencies. Quote Share this post Link to post
Staff 10307 Posted ... Here in Thailand they have apparently made VPN usage illegal because they want to monitor heavily. Thus my attempt to hide my use of openvpn by ssh tunnel. Hello! That's the right decision then. Try OpenVPN over SSL as well. It might work better than over SSH, because from other reports from Thailand it is possible that SSH is shaped much more than SSL to port 443. Also try the Hong Kong server, just in case. Kind regards Quote Share this post Link to post
9pF7d2BTMF3hZ1i1NonmpfRnH 1 Posted ... Is there a way to setup SSL VPN on DD-WRT? Quote Share this post Link to post
go558a83nk 380 Posted ... Is there a way to setup SSL VPN on DD-WRT? yes, with optware and installing stunnel. Quote Share this post Link to post
urbanconcrete 14 Posted ... yes, with optware and installing stunnel.Links are sometimes helpful... https://www.datenzone.de/blog/2012/01/installing-stunnel-on-openwrt/ Do you only have to install stunnel and download the ssh-vpn file? Quote Share this post Link to post
go558a83nk 380 Posted ... yes, with optware and installing stunnel.Links are sometimes helpful... https://www.datenzone.de/blog/2012/01/installing-stunnel-on-openwrt/ Do you only have to install stunnel and download the ssh-vpn file? for stunnel it's the ssl configuration. it's pretty simple and ipkg should install any dependencies (for stunnel) that aren't already installed. you just have to use the proper ovpn config for openvpn in conjunction. Quote Share this post Link to post
