staudt 0 Posted ... I downloaded and extracted the airvpn portable in documents (Mint) but when I double click the airvpn file nothing happens. How can I start this app? What is wrong, it used to work fine. Quote Share this post Link to post
Tech Jedi Alex 1585 Posted ... Shall we guess which OS you use? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Tech Jedi Alex 1585 Posted ... Mark it as executable. Maybe it works by entering its preferences and ticking "enable execution" or something. Through terminal (if you're in the same directory as the unpacked binary): sudo chmod +x airvpn Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
LZ1 686 Posted ... Hello! Which version did you download? If you download the .deb and then click the download, that's normally most of the way towards installing it. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Staff 10717 Posted ... I downloaded and extracted the airvpn portable in documents (Mint) but when I double click the airvpn file nothing happens. How can I start this app? What is wrong, it used to work fine. Hello! 1) Make sure to download only Eddie 2.11.9beta (Eddie 2.10.3 stable is not compatible with Mono 4 and will not install in Mint 18).https://airvpn.org/topic/18625-eddie-211beta-available/ 2) If you downloaded the .deb package, right-click on it and select "Open with" > "Installer" (menu item names may slightly change according to your file manager). Alternatively install it with dpkg (and resolve dependencies with apt-get) or install it in one pass with gdebi. If you downloaded a tarball extract everything in one single directory you created for the purpose. Kind regards Quote Share this post Link to post
