Omnomnom 0 Posted ... Hello, I am new to airVPN and VPN's in general. In the Eddie Client (linux portable experimental version), every time I try to connect to an specific or recommended server I get the same error log which ends with: OpenVPN > Linux ifconfig failed: could not execute external programOpenVPN > Exiting due to fatal error... Thanks in advance Regards Quote Share this post Link to post
LZ1 663 Posted ... Hello! Welcome to AirVPN. It would be preferable if you append the entire log Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Omnomnom 0 Posted ... Here is the entire log: 2016.09.26 07:41:36 - Eddie client version: 2.11.3 / x64, System: Linux, Name: This is \n.\O (\s \m \r) \t / x64 . 2016.09.26 07:41:36 - Reading options from /home/random/Downloads/airvpn_linux_x64_portable/AirVPN.xml . 2016.09.26 07:41:37 - Data Path: /home/random/Downloads/airvpn_linux_x64_portable . 2016.09.26 07:41:37 - App Path: /home/random/Downloads/airvpn_linux_x64_portable . 2016.09.26 07:41:37 - Executable Path: /home/random/Downloads/airvpn_linux_x64_portable/airvpn . 2016.09.26 07:41:37 - Command line arguments (0): . 2016.09.26 07:41:37 - Operating System: Unix 4.6.0.0 - Linux gratz 4.6.0-sabayon #1 SMP Fri Jul 15 18:12:46 UTC 2016 x86_64 Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz GenuineIntel GNU/Linux I 2016.09.26 07:41:37 - OpenVPN Driver - Found, /dev/net/tun I 2016.09.26 07:41:37 - OpenVPN - Version: OpenVPN 2.3.11 (/home/random/Downloads/airvpn_linux_x64_portable/openvpn) I 2016.09.26 07:41:37 - SSH - Version: OpenSSH_7.2p2, OpenSSL 1.0.2h 3 May 2016 (/usr/bin/ssh) I 2016.09.26 07:41:37 - SSL - Version: stunnel 5.32 (/home/random/Downloads/airvpn_linux_x64_portable/stunnel) ! 2016.09.26 07:41:37 - Ready . 2016.09.26 07:41:37 - Updating systems & servers data ... . 2016.09.26 07:41:40 - Systems & servers data update completed I 2016.09.26 07:41:55 - Checking login ... ! 2016.09.26 07:41:55 - Logged in. I 2016.09.26 07:43:05 - Session starting. W 2016.09.26 07:43:05 - Unable to understand if IPv6 is active. I 2016.09.26 07:43:05 - Checking authorization ... ! 2016.09.26 07:43:05 - Connecting to Diphda (Netherlands, Alblasserdam) . 2016.09.26 07:43:05 - OpenVPN > OpenVPN 2.3.11 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on May 19 2016 . 2016.09.26 07:43:05 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.09.26 07:43:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.09.26 07:43:05 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.09.26 07:43:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:05 - OpenVPN > Socket Buffers: R=[212992->425984] S=[212992->425984] . 2016.09.26 07:43:05 - OpenVPN > UDPv4 link local: [undef] . 2016.09.26 07:43:05 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.164:443 . 2016.09.26 07:43:05 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.164:443, sid=b5689c67 be833c50 . 2016.09.26 07:43:05 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.09.26 07:43:05 - OpenVPN > Validating certificate key usage . 2016.09.26 07:43:05 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.09.26 07:43:05 - OpenVPN > VERIFY KU OK . 2016.09.26 07:43:05 - OpenVPN > Validating certificate extended key usage . 2016.09.26 07:43:05 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.09.26 07:43:05 - OpenVPN > VERIFY EKU OK . 2016.09.26 07:43:05 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.09.26 07:43:05 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.09.26 07:43:05 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:05 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.09.26 07:43:05 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:05 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.09.26 07:43:05 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.164:443 . 2016.09.26 07:43:08 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.09.26 07:43:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.81.124 255.255.0.0' . 2016.09.26 07:43:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.09.26 07:43:08 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.09.26 07:43:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.09.26 07:43:08 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.09.26 07:43:08 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.09.26 07:43:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.09.26 07:43:08 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 IFACE=eno1 HWADDR=54:04:a6:2a:7d:33 . 2016.09.26 07:43:08 - OpenVPN > TUN/TAP device tun0 opened . 2016.09.26 07:43:08 - OpenVPN > TUN/TAP TX queue length set to 100 . 2016.09.26 07:43:08 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.09.26 07:43:08 - OpenVPN > /sbin/ifconfig tun0 10.4.81.124 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255 . 2016.09.26 07:43:08 - OpenVPN > Linux ifconfig failed: could not execute external program . 2016.09.26 07:43:08 - OpenVPN > Exiting due to fatal error ! 2016.09.26 07:43:08 - Disconnecting . 2016.09.26 07:43:08 - Connection terminated. I 2016.09.26 07:43:11 - Checking authorization ... ! 2016.09.26 07:43:11 - Connecting to Diphda (Netherlands, Alblasserdam) . 2016.09.26 07:43:11 - OpenVPN > OpenVPN 2.3.11 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on May 19 2016 . 2016.09.26 07:43:11 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.09.26 07:43:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.09.26 07:43:11 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.09.26 07:43:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:11 - OpenVPN > Socket Buffers: R=[212992->425984] S=[212992->425984] . 2016.09.26 07:43:11 - OpenVPN > UDPv4 link local: [undef] . 2016.09.26 07:43:11 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.164:443 . 2016.09.26 07:43:11 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.164:443, sid=76b0f92d 7f535a18 . 2016.09.26 07:43:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.09.26 07:43:11 - OpenVPN > Validating certificate key usage . 2016.09.26 07:43:11 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.09.26 07:43:11 - OpenVPN > VERIFY KU OK . 2016.09.26 07:43:11 - OpenVPN > Validating certificate extended key usage . 2016.09.26 07:43:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.09.26 07:43:11 - OpenVPN > VERIFY EKU OK . 2016.09.26 07:43:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.09.26 07:43:12 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.09.26 07:43:12 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:12 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.09.26 07:43:12 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:12 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.09.26 07:43:12 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.164:443 . 2016.09.26 07:43:14 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.09.26 07:43:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.81.124 255.255.0.0' . 2016.09.26 07:43:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.09.26 07:43:14 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.09.26 07:43:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.09.26 07:43:14 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.09.26 07:43:14 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.09.26 07:43:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.09.26 07:43:14 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 IFACE=eno1 HWADDR=54:04:a6:2a:7d:33 . 2016.09.26 07:43:14 - OpenVPN > TUN/TAP device tun0 opened . 2016.09.26 07:43:14 - OpenVPN > TUN/TAP TX queue length set to 100 . 2016.09.26 07:43:14 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.09.26 07:43:14 - OpenVPN > /sbin/ifconfig tun0 10.4.81.124 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255 . 2016.09.26 07:43:14 - OpenVPN > Linux ifconfig failed: could not execute external program . 2016.09.26 07:43:14 - OpenVPN > Exiting due to fatal error ! 2016.09.26 07:43:14 - Disconnecting . 2016.09.26 07:43:14 - Connection terminated. I 2016.09.26 07:43:17 - Checking authorization ... ! 2016.09.26 07:43:17 - Connecting to Diphda (Netherlands, Alblasserdam) . 2016.09.26 07:43:17 - OpenVPN > OpenVPN 2.3.11 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on May 19 2016 . 2016.09.26 07:43:17 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.09.26 07:43:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.09.26 07:43:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.09.26 07:43:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:17 - OpenVPN > Socket Buffers: R=[212992->425984] S=[212992->425984] . 2016.09.26 07:43:17 - OpenVPN > UDPv4 link local: [undef] . 2016.09.26 07:43:17 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.164:443 . 2016.09.26 07:43:17 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.164:443, sid=4fcfef6f 510aa8a2 . 2016.09.26 07:43:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.09.26 07:43:17 - OpenVPN > Validating certificate key usage . 2016.09.26 07:43:17 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.09.26 07:43:17 - OpenVPN > VERIFY KU OK . 2016.09.26 07:43:17 - OpenVPN > Validating certificate extended key usage . 2016.09.26 07:43:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.09.26 07:43:17 - OpenVPN > VERIFY EKU OK . 2016.09.26 07:43:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.09.26 07:43:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.09.26 07:43:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.09.26 07:43:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.09.26 07:43:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.09.26 07:43:17 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.164:443 . 2016.09.26 07:43:20 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.09.26 07:43:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.81.124 255.255.0.0' . 2016.09.26 07:43:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.09.26 07:43:20 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.09.26 07:43:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.09.26 07:43:20 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.09.26 07:43:20 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.09.26 07:43:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.09.26 07:43:20 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 IFACE=eno1 HWADDR=54:04:a6:2a:7d:33 . 2016.09.26 07:43:20 - OpenVPN > TUN/TAP device tun0 opened . 2016.09.26 07:43:20 - OpenVPN > TUN/TAP TX queue length set to 100 . 2016.09.26 07:43:20 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.09.26 07:43:20 - OpenVPN > /sbin/ifconfig tun0 10.4.81.124 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255 . 2016.09.26 07:43:20 - OpenVPN > Linux ifconfig failed: could not execute external program . 2016.09.26 07:43:20 - OpenVPN > Exiting due to fatal error ! 2016.09.26 07:43:20 - Disconnecting . 2016.09.26 07:43:20 - Connection terminated. I 2016.09.26 07:43:21 - Cancel requested. ! 2016.09.26 07:43:21 - Session terminated. Quote Share this post Link to post
Staff 9777 Posted ... Can you help me on this? Hello! Can you please check whether "ifconfig" is in /sbin ? OpenVPN should use "ip" on systems without ifconfig. If you don't have ifconfig, check whether some package containing ifconfig for your distribution (for example net-tools) is available for a quick solution. Kind regards Quote Share this post Link to post
Omnomnom 0 Posted ... There is a "ifcfg" file in /sbin, net-tools is also installed. Quote Share this post Link to post
Omnomnom 0 Posted ... Solved the ifconfig problem. Had to create symlinks in /sbin/ pointing to /bin/ifconfig and /bin/route But if I go to ipleak.net it shows my real IPv6 adress, but IPv6 is disabled in the client? Edit: Solved it with activating network lock Quote Share this post Link to post
