Not connected, Your IP: 18.116.13.113
highchilled
WebRTC-Leaks not shown by ipleak.net
I found an issue...
When using the Testpage of AirVPN for DNS- and WebRTC-Leaks (www.ipleak.net) it's actually not showing WebRTC-Leaks, although they are there!
Under circumstances this can cause serious trouble for the VPN-Users, because when they don't see any leaks, most of them will be sure that there are no leaks - but that can be very false!
I discovered clear WebRTC-Leaks on a Windows7-machine + up-to-date Firefox; but ipleak.net only showed me the internal IP leaks! (which are actually not dangerous)
I opened 2 Firefox-Windows while connected to a AirVPN-Server and while ipleak.net didn't show real-IP leaks, at the same moment another site clearly showed these WebRTC-leaks (GitHub)!
As you can see on the screenshot ipleak.net doesn't show anything suspicious, but Github shows all the leaks including my real Provider-IP + all internal Network IP's;
so actually EVERYTHING was leaking and totally broke the anonymity of AirVPN in my Browser!
Now I want to know why ipleak.net provides WebRTC-leak-detecion, when it actually not working at all (also tested on Linux!)
Try it yourself and you will see what I mean:
1. https://ipleak.net/
2. https://diafygi.github.io/webrtc-ips/
Please also check my screenshot below!
Btw. you can fix that leak easily in your Firefox-Settings!
Answers are welcome!
regards,
me
Were you using Eddie and Network Lock? Also, is there a reason you didn't just disable media peerconnection?
Thanks for your reply, but...
I think you didn't understand the question
Although it doesn't has to do with my actual question: Ofc I usually have media.peerconnection disabled (but you have to do it manually, Firefox has it enabled if fresh installed - so many people will have leaks here, becuase they don't even know about it - so I enabled it to make it visible
And they don't know (and now we come to reason of my post) BECAUSE ipleak.net doesn't show it to them!
My question was, why ipleak.net (AirVPN) offers WebRTC-Leak detection, but can't detect them properly ?
Do you understand young jedi? ;D
You have NoScript enabled on ipleak but not on Github.
Run the same tests with the same rules, or without 3d party blockers at all.
The test is exactly the same, and is using the same Mozilla STUN servers in
order to determine your IPs.
Ipleak:
// Get the IP addresses associated with an account
	// Thanks: https://github.com/diafygi/webrtc-ips
	rtcDetectionDo: function(callback)
			// Based on work by https://github.com/diafygi/webrtc-ips
	    var ip_dups = {};
	    var RTCPeerConnection = IpLeak.rtcGetPeerConnection();
	    var mediaConstraints =
	        optional: [{RtpDataChannels: true}]
	    //firefox already has a default stun server in about:config
	    //    media.peerconnection.default_iceservers =
	    //    [{"url": "stun:stun.services.mozilla.com"}]
	    var servers = undefined;
	    //add same stun server for chrome
	    if(window.webkitRTCPeerConnection)
	        servers = {iceServers: [{urls: "stun:stun.services.mozilla.com"}]};
Diafygi Github:
                    var win = iframe.contentWindow;
                    RTCPeerConnection = win.RTCPeerConnection
                        || win.mozRTCPeerConnection
                        || win.webkitRTCPeerConnection;
                    useWebKit = !!win.webkitRTCPeerConnection;
                //minimal requirements for data connection
                var mediaConstraints = {
                var servers = {iceServers: [{urls: "stun:stun.services.mozilla.com"}]};
He was credited on IPleak for the original work as well.
No dude, No-Script allows both Top-Domains and blocks the same Sub-Domains at the same moment - so that can't be the solution!
Please check the meaning of No-Script signs again.
The question mark in NS only means, that there are some !sub-domains! not allowed ;D
And these sub-domains are from google not from you - and GitHub also doens't need sub-domains; so... ?!
It's just a thing I found out and was wondering about; that's why I posted it
Confirming there a little issue that started because of a small API change of predefined Mozilla STUN addresses in Firefox 41:
https://bugzilla.mozilla.org/show_bug.cgi?id=1143827
The test on diafygi's page made a workaround for this issue here:
https://github.com/diafygi/webrtc-ips/commit/a95b3613e3ee83d2d51cfb184d334767cf71e486
In any case, the main idea of telling you if WebRTC is enabled or not was working, it just did not
show the external address under certain conditions.
Wait for the ipleak developer for more comments.
That's what I wanted to hear - thank you man!
At all... I like ipleak.net - but that was strange ;D
thanks zhang and everybody. ipleak.net maintainers are now aware of the issue.
1 month free VPN please
You'd get a year for being nice. This is not nice.
Ah ok.. next time I stfu and go to Github
