Flx11
ANSWERED Guide - Fix for TAP adapter in Windows
Instead of reseting it manually every now and then, now you can do this automatically. And stay/be connected 24/7 through the VPN.
The issue then when trying to connect remotely (e.g. office/other location) to the home computer that's connected to AirVPN.
Your client IP will be reset to 10.3.0.1 or 169.x.x.x. In that case OpenVPN-GUI will still show Connected, but in fact it's not.
1)This small batch file(see below) will ensure that the TAP-adapter will not disconnect.
---------------------------------dhcp.tap.adapter.bat-------------------------------------------
@ECHO OFF
:LOOP
ECHO Waiting for 300 seconds....
timeout /t 300
netsh interface ip set address tapadapter DHCP
netsh int ip set dns name = "tapadapter" source = dhcp
ipconfig /all
GOTO LOOP
---------------------------------dhcp.tap-adapter.bat-------------------------------------------
2)After the connection has been established to AirVPN(UDP/TCP or OpenVPN over SSL/SSH) run the above file dhcp.tap.adapter.bat.
Run as Admin if elevation is required.
Regards,
Flex
Thanks for this post
@ECHO OFF
:LOOP
timeout /t 300
ipconfig /all
GOTO LOOP
Regards,
Flex
Thanks for this post... this does describe the problem I've been having. My tunnel seems to collapse at 11:59 am and pm with at lest one more random time during the day.
I've done as instructed with the .bat file, now there is a cmd window open and counting down from 300, with "press any key to continue...." do I need to leave that open?
Thanks again, I hope this keeps my connection on 24/7 with the client.
I left it running for about 6 hours, but eventually, the tunnel collapsed and the VPN client still thought it was connected. I still have to manually uninstall the tap and then run the VPN client and let it reinstall the tap.
Hello !
@OP
Good stuff. Maybe you should change to title to include the word "Guide" somewhere, to make it more clear for people.
@3vSIM
Are you using the Eddie client by any chance and perhaps with Network Lock? Just curious.
Yes it will. Now you can also change the timeout /t 300. I now have it set to 100 seconds and it works.
That will happen sometimes. If OpenVPN is diconnected it will just reconnect.
Then just disable the TAP adapter and Enable it again then reconnect.
You can minimize it ....let it run in the background.
Yes you need that to stay open.
As another choice would be to set DNS as static.......for the VPN tunnel.
@ECHO OFF
:LOOP
timeout /t 60
@ECHO DISABLING IPV6/FLUSH DNS/DISABLE TCP TIMESTAMP(S)
netsh interface ip set address tapname DHCP
netsh int ip set dns name = "tapname" static 89.233.43.71(choose own DNS1)
netsh interface ip add dns name="tapname" 91.239.100.100(choose own DNS2) index=2
ipconfig /flushdns
ipconfig /all
@ECHO Waiting for 60...................... seconds...................................
GOTO LOOP
"Waiting for 300 seconds....
Waiting for 283 seconds, press a key to continue ...
The filename, directory name, or volume label syntax is incorrect.
The filename, directory name, or volume label syntax is incorrect."
from "dhcp.tap.adapter.bat"
I ran the batch file from desktop as administrater.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety". Benjamin Franklin
@trott3r
Have you changed the name of your TAP-adapter from "Local Area Network 2" to say "tap"? then modify the .bat file to
@ECHO OFF
:LOOP
timeout /t 60
netsh interface ip set address tap DHCP
netsh int ip set dns name = "tap" source = dhcp
ipconfig /flushdns
ipconfig /all
GOTO LOOP
The batch script works in Windows 7/8/8.1/10 etc.
tap.zip
The new file uploaded is based on 4 tap adapters by the name quad/quad1/quad2/quad3....main connection named as lan.
Details:
This ensures 4 udp/tcp vpn connections keep-alive/and keep running...thx to the new introduced fancy Devices/Keys.
I run 4 UDP connections side by side.
Each connection has its own new key created under Devices/Keys.
You can modify the file any way you like according to your own configuration.
Regards and happy browsing,
Flx
for your torrent client an extra step will be needed
In Comodo Firewall-Rulesets block.lan.wifi.ipv6. BY mac and iP.
Example
1.
2.
The 2 "examples" that you see above either one will work just fine.
You can expand the list depending on your config/system.
Regards,
Flx
OP do you think this would work for when:
OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.02.07 18:55:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
Yup....in Global Rules...add this at the top of your Rules already defined....image example
Quote
where quad.mac is the mac address of your quad tap adapter found in Network Zones->quad.mac.
and where tap.mac or tapall.mac in Network Zones->tap.mac or tapall.mac zone which contains all your tap adapter mac addresses.
@LZ1 this should fix/resolve your problem.
Regards,
Flx
Don't know if it helps... but I'm using this .bat on my connection with lot of disconnects and client/TAP adapters hangs with great success
Replace VPN with the name of your TAP inteface
This is the script that runs on VPN down
@echo off
netsh interface set interface VPN admin=disable
timeout /t 2 /nobreak
netsh interface set interface VPN admin=enable
taskkill /IM AirVpn.exe /F
taskkill /IM openvpn.exe /F
timeout /t 5 /nobreak
start "" "C:\Program Files\AirVPN\AirVPN.exe" & exit
Your connection client to the AirVPN server just drops and tries to do a reconnect....in Eddie?
@echo off
netsh interface ip set address VPN DHCP
netsh int ip set dns name = "VPN" source = dhcp
Just make sure that VPN/TAP adapter is in DHCP mode.(See above)
Edited ... by Flx
you may also consider this as an extra partial choice:
netsh int tcp set global timestamps=disabled
netsh interface ipv6 set privacy state=disable
netsh interface ipv6 6to4 set state state=disabled
netsh interface ipv6 isatap set state state=disabled
netsh interface ipv6 set teredo disabled
Regards,
Flx
Windows 10 breaking the tap adapter:
1.If you have Comodo A/V Firewall and Windows OS as your config...turn WIndows Firewall OFF.
Windows Defender can run side by side with Comodo.(Your choice)
2.Before/After you manage to connect to an AirVPN server.
Use one of the scripts provided to fix this TAP issue.
You can use Eddie app or native OpenVPN(2 or more connections/sessions).
The batch scripts do exactly that(e.g. Prevent WIndows to break the VPN connection/tap adapter)
3.Disable in gpedit.msc anything you do not need (Store/maps/Telemetry etc)
4.Comodo-Rules.Set a local rule...
Block/Prevent any app/wermgr.exe/System/WIndows Operating System process to send data to (e.g. Microsoft) for port 80/443/ etc.
5.In Network Zone-->>Blocked Zones---->Block the default gateway(e.g. xxx.xxx.2.1) from main adapter before/after you connect.
6.Set a master password in/for Comodo. Only the person that knows the password set will be able to do any actual changes (e.g. Disable the Firewall etc.)
Regards,
Flx
FOR------------svchost.exe----------------
where svc.block contains the blocked ports 80/443/others
SET dllhost.exe/dashost.exe/explorer.exe/etc. as local (above example how to do so)
Comodo Global Rules https://airvpn.org/topic/3405-windows-comodo-prevent-leaks/ is only the minimum/beginner needed.
Regards,
Flex
