justi
Eddie Android does not work in the work profile.
I have an Android phone on which I have Eddie installed. I also have a work profile. Eddie does not work in the work profile.It works in the normal profile. In the work profile, however, when I open it, it immediately closes. And If I do it  several times, I get the message: "Eddie - AirVPn GUI keeps stopping... Send bug report to Mi for analysis? bla bla". However, if I click on "View summary" or "Report", nothing happens.
I am pretty sure it worked a few days ago, but nothing changed and now it does not work. I have cleared storage/cache and uninstalled/re-installed.Installed from google play store.
I am using Android 13. Xiaomi HyperOS.
WG-Tunnel, from F-Droid, is also having the same problem. So this is probably not something AirVPN related. God damn it.
EDIT1: Mullvad works though...
EDIT2: Rethink, on F-Droid, also works. I managed to run AirVPN wireguard there.
Edited ... by justi
I know it worked on Android 11 in the work profile (different manufacturer) and it works on Android 15, Samsung in the work profile and private folder.
The automatic closing is a crash that I experience on Android 15. Don't click the big auto-connect button, instead go to individual servers, select to connect to one from there.
@justi
This is exactly a specific Go-related problem triggered by Eddie that must be resolved by Eddie 4.1.0, can you please test the preview version if possible and report back at your convenience?
https://airvpn.org/forums/topic/80641-eddie-desktop-edition-226-beta-released/
There is no 4.1.0 for Android, as far as I can see? I have 4.0.1, and that is the version that is giving the error.
Is there a preview version for Android? I could not find it anywhere.
Yes, 4.1.0 preview is available, but <c> tag for I parameters is still included. However, after having considered that <c> was documented a year ago but it is still (at the time of this writing) unsupported, it was decided that <c> will be not used on the next Eddie Android edition 4.1.0 beta 2. Please see here: https://airvpn.org/forums/topic/80787-eddie-android-edition-410-preview-available/
I installed that version (4.1.0 beta 1), and I am still having the same error, i.e., I open it and it immediately closes.
Edited ... by justi
Would it be possible to see the logcat? We know that you can't generate it through Eddie as it crashes as soon as you launch it, but maybe you can access it via adb (available on most systems)? https://developer.android.com/tools/logcat
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
