Staff
Eddie Desktop Edition 2.26 beta released
We are glad to announce that Eddie 2.26.0 beta has been released and is now available for public testing.
UPDATE 2026-08-21: Eddie 2.26.2 has been released. Please move here.
https://airvpn.org/forums/topic/81129-eddie-desktop-edition-2262-released/
This release is mostly about maintenance, security fixes, and compatibility work.
It includes several security hardening changes, updates to OpenVPN 2.7.3 and WireGuard for Windows 1.0, improved OpenVPN driver handling on Windows, and a general cleanup of old or unused code paths.
To test it:
  • Go to the download page for your operating system.
  • Click “Switch to EXPERIMENTAL”.
  • Download and install Eddie 2.26.0 beta.
Eddie 2.26.0 beta is available for Windows, Linux, and macOS.
We are also continuing the larger work of modernizing Eddie Desktop, also with a new modern UI.
We know that many requested features are still waiting, including dark mode, split tunneling, Amnezia support, and more.
They are not forgotten. For this release, the focus was on fixes and updates that needed to reach users first.
We expect this beta to move to stable soon.
Thank you for testing, and as always for your support.
Main changelog:
Version 2.26.0 (Mon, 29 Jun 2026 14:29:16 +0000)
  • [change] [all] Updated the app to .NET 10
  • [change] [all] Updated the legacy interface to .NET Framework 4.8.1
  • [change] [windows] Removed Windows 7 support
  • [fix] [all] Cleaned WireGuard configuration generation by removing unsupported entries
  • [change] [windows] Improved OpenVPN driver setup and adapter management on Windows
  • [change] [windows] Removed outdated Windows driver options
  • [change] [windows] Removed the old Windows Firewall Network Lock mode and migrated existing profiles.
  • [change] [linux/macos/bsd] Removed unused filesystem protection handling from the elevated helper.
  • [change] [all] Restricted elevated helper tool discovery to trusted application folders.
  • [change] [all] Added limits to elevated helper replies to protect client memory use.
  • [change] [all] Removed the Tor control cookie path option
  • [fix] [all] Various security hardening fixes
  • [fix] [windows] Fixed Windows elevated launches with long command lines
  • [change] [windows] Improved Windows elevated argument handling to prevent extra arguments from being injected into helper tools
  • [fix] [windows] Fixed Windows OpenVPN routing with TAP adapters
  • [change] [windows] Updated WireGuard for Windows to version 1.0
  • [change] [all] Updated OpenVPN to 2.7.3
  • [fix] [linux] Fixed Linux AppImage cleanup. Credits GitHub #147 and #152. Thanks to ThienBienBlue.
  • [fix] [linux] Fixed Network Lock detection on clean systems where optional nftables or iptables tools are not installed.
  • [change] [all] Removed custom OpenVPN and Hummingbird executable path options.
  • [change] [linux] Removed the Linux dependency on the system ICU library
  • [change] [all] Misc fixes and general cleanup
Kind regards & datalove
AirVPN Staff
This version will not connect on Arch Linux and tries multiple times exceeding the account connection limit. There is a notification "Exception: Executable 'service' not found" . I reverted to 2.25.1 for now.
Using either the Arch package from the Eddie website or the eddie-ui-git AUR package is the same.
Edited ... by MarkDubya
I'm running into the same issue and exception on Arch Linux. Downgrading Eddie back fixed it for me as well.
I opened a support ticket yesterday, and the staff mentioned they've passed the ticket along to the Eddie developer.
Hi guys.
I'm going to ask since I haven't heard anything about it in the changelog, do you plan to update Eddie to fully support macOS Silicon?
I keep getting the warning in the image attached, I believe Apple will behave as usual and kinda kill whatever is not running on Silicon by the next OS release at the end of this year.
Problems here too
as for previous version it does not keep "Don't ask elevation every run"
the Gui is not able to connect and keep retrying...
Version 2.26.1 (Sat, 04 Jul 2026 17:30:39 +0000)
  • [fix] [linux] Fix nftables netlock ipv4 mangle OUTPUT chain priority typo
  • [change] [linux] Store network lock rule backups in root-only state directory
  • [fix] [all] Fix TOCTOU race
  • [fix] [linux] Sanitize VPN DNS addresses written to /etc/resolv.conf
  • [fix] [linux] Fixed connection on Arch (no SysV service command)
  • [change] [all] Improved security of how the VPN configuration is handled by the privileged helper
  • [fix] [all] Block OpenVPN directives that write files as root
On 7/2/2026 at 7:47 PM, Overkill said:
Hi guys.
For now, we ask you to ignore that message.
It is caused by the fact that the current macOS UI is written in Xamarin, which does not support arm64 compilation.
One of our goals is to release a new modern UI, natively compiled for arm64, before this restriction becomes a problem.
On 7/3/2026 at 8:17 AM, harold.lewis said:
Problems here too
Please test the latest version, and open a ticket. Please report macOS version, package (zip? dmg?), and a logs > lifebelt report link (with the upload report feature).
Thanks.
Unfortunately, with version 2.26.1, just as with version 2.26.0, the deb package is not compatible with distributions that use sysvinit.
The buggy script prerm:
#!/bin/sh
set -e
/usr/lib/eddie-ui/eddie-cli-elevated service=uninstall
exit 0
The buggy script postinst:
#!/bin/sh
set -e
/usr/lib/eddie-ui/eddie-cli-elevated service=install
exit 0
Please port it to sysvinit,
using for the script prerm something like:
#!/bin/sh
is_systemd_init() {
	# Try /proc/1/comm first
	if [ -f /proc/1/comm ] && [ "$(cat /proc/1/comm)" = "systemd" ]; then
		return 0
	fi
	# Fallback: check /run/systemd/system
	if [ -d /run/systemd/system ]; then
		return 0
	fi
	# Fallback: check /sys/fs/cgroup
	if [ -f /proc/version ] && grep -q "systemd" /proc/version 2>/dev/null; then
		return 0
	fi
	return 1
is_systemd_init || exit 0
set -e
exit 0
and for the script postinst something like:
#!/bin/sh
is_systemd_init() {
		return 0
	fi
		return 0
	fi
		return 0
	fi
	return 1
set -e
exit 0
Thanks in advance for the fix.
Confirmed, will be fixed in 2.26.2 (with test on Devuan).
I think to avoid changes on current postinst/prerm, "eddie-cli-elevated service=install" will return 0 it that case and avoid the break.
Version 2.26.2 (Thu, 09 Jul 2026 11:19:55 +0000)
  • [fix] [linux] Fix elevated startup on distros without systemctl (e.g. Devuan/sysvinit)
  • [fix] [all] Emit disable-dco in generated OpenVPN config when startup options are incompatible with data channel offload
  • [fix] [windows] Harden elevated named pipe against pipe-name squatting (FIRST_PIPE_INSTANCE, single instance)
To recover from a broken APT in version 2.26.0/2.26.1 in a distro without systemctl, use this workaround:
rm -rf /var/lib/dpkg/info/eddie-ui.prerm
rm -rf /var/lib/dpkg/info/eddie-ui.postinst
dpkg -P --force-all eddie-ui
and then reinstall the latest 2.26.2.
Thanks for the patience.
Mac Mojave, here's what I get:
This same thing has been going on with everything after 2.23.1, but even that is unusable because it fixes MTU in Wireguard protocol to 1320 (making YouTube unplayable). The only thing usable is 2.21.8 since it doesn't fix MTU at all. But recently I'll have to amend "usable" to "barely usable" since as of 3 weeks ago I'm down from showing 48 US servers to 30; and then last week it dropped to 25 US servers. I can only assume if the trend continues I'll soon be down to just a few servers.
With each new Eddie release I keep crossing my fingers that the developers will address these issues for pre-Catalina Mac users.
Hi, we updated (without changing 2.26.2 version) only the pre-Catalina x64 build with a -i hope- small fix, please redownload and test if continue to throw this NetworkInformation error.
About MTU, there is an option in Preferences > WireGuard to revert to default WireGuard MTU, please try that.
Thank you. It no longer throws the error. So at least we're headed in the right direction. Also, I'm now seeing all 48 US servers. However, I can't connect to any server either by selecting a specific server or "Connect to a recommended server". It just rapidly attempts to connect, check authorization, disconnect, and cycles to the next server, repeating indefinitely.
I see that. Excellent! But where do I select Wireguard protocol? It's no longer shown in Protocols. Only OpenVPN.
FYI I did run  rm ~/.config/eddie/* in Terminal and it made no difference.
https://eddie.website/report/71231bcd/
Protocols > unchecked Automatic and tried several OpenVPN protocols. They all work and connect fairly quickly. Tried checking Automatic again and errant behavior reappears. Unfortunately OpenVPN is incredibly slow compared to Wireguard -- at least half the speed and often one-third. Wireguard is a protocol option in 2.21.8. Just wondering why it's not available in 2.26.2?
Yes, there is a Wireguard setting. See the picture.
That's just the MTU settings when running Wireguard protocol. To run Wireguard (instead of OpenVPN) you first have to select it in Protocols. It doesn't appear there anymore for me in 2.26.2. Does it for you?
Sorry, but we had to update WireGuard, and it is WireGuard itself that only supports macOS 12.0 and later. Eddie correctly detects that it is unavailable and filters it out of the protocol choices.
You can still use the latest Eddie version with OpenVPN.
https://apps.apple.com/us/app/wireguard/id1451685025?mt=12 — Requires macOS 12.0 or later
https://git.zx2c4.com/wireguard-apple/commit/?id=901fe1cf58dc40e551088cac3bf00d68e3e86db3
For what it's worth, I recently purchased a new Mac with Apple Silicon, installed fresh apps for what I need and none other than Eddie requires Rosetta. So far I've decided to use hummingbird from the command line. It's not as convenient as Eddie especially  since I use the VPN from time to time so a GUI is more convenient.
Thank you for fixing the Debian installer for systems running sysvinit.
Unfortunately, on Devuan 6, there is a bug that prevents privilege escalation.
I tried in vain to figure out the source of the problem by comparing the working version 2.25.1 with the buggy version 2.26.2.
On Devuan 6:
When eddie-ui 2.25.1 is installed, if you type the command `eddie-ui` as a regular user in a graphical terminal (XFCE4), pkexec successfully launches an eddie-ui process as root, and `/var/log/auth.log` shows:
2026-07-20T02:33:16.418617+02:00 localhost polkitd[2153]: Operator of unix-session:2 successfully authenticated as unix-user:demo to gain ONE-SHOT authorization for action org.airvpn.eddie.ui.elevated.policy for unix-process:14322:94375 [./eddie-ui --path.resources=/usr/share/eddie-ui] (owned by unix-user:demo)
2026-07-20T02:33:16.420629+02:00 localhost pkexec: pam_unix(polkit-1:session): session opened for user root(uid=0) by demo(uid=1000)
2026-07-20T02:33:16.421022+02:00 localhost pkexec[14346]: demo: Executing command [USER=root] [TTY=/dev/pts/3] [CWD=/usr/lib/eddie-ui] [COMMAND=/usr/lib/eddie-ui/eddie-cli-elevated mode=spot spot_port=64376 service_port=9350]
After upgrading eddie-ui to version 2.26.2, the terminal's error output shows:
demo@devuan6:~$ eddie-ui
. 2026.07.20 05:33:38 - Eddie version: 2.26.2 / linux_x64, System: Linux, Name: Devuan GNU/Linux 6 (excalibur), Version: 6 (excalibur), Framework: 6.8.0.96 (tarball Wed Jan 15 10:20:48 UTC 2020); Framework: v4.0.30319
. 2026.07.20 05:33:38 - Command line arguments (1): path.resources="/usr/share/eddie-ui"
. 2026.07.20 05:33:38 - Raise system privileges
F 2026.07.20 05:33:47 - Unable to obtain elevated privileges (required): Unable to start (already exit). Look https://eddie.website/support/elevation/ to address this issue.
. 2026.07.20 05:33:49 - Shutdown in progress
. 2026.07.20 05:33:49 - Shutdown complete
An eddie-ui dialog box displays the same message "Unable to obtain elevated privileges (required): Unable to start (already exit). Look https://eddie.website/support/elevation/ to address this issue."
And /var/log/auth.log shows:
2026-07-20T05:33:41.633721+02:00 localhost polkitd[2171]: Operator of unix-session:1 successfully authenticated as unix-user:demo to gain ONE-SHOT authorization for action org.airvpn.eddie.ui.elevated.policy for unix-process:12659:80823 [./eddie-ui --path.resources=/usr/share/eddie-ui] (owned by unix-user:demo)
2026-07-20T05:33:41.635647+02:00 localhost pkexec: pam_unix(polkit-1:session): session opened for user root(uid=0) by demo(uid=1000)
2026-07-20T05:33:41.636197+02:00 localhost pkexec[12683]: demo: Executing command [USER=root] [TTY=/dev/pts/1] [CWD=/usr/lib/eddie-ui] [COMMAND=/usr/lib/eddie-ui/eddie-cli-elevated mode=spot spot_port=36624 service_port=9350 spot_client_pid=12659]
I don't know if this is related to the issue, but I see that compared to version 2.25.1 of eddie-ui, version 2.26.2 adds the argument `spot_client_pid=XXXXX` to the command `/usr/lib/eddie-ui/eddie-cli-elevated`.
In any case, I tend to think that the eddie-ui and/or eddie-cli-elevated process still behaves as if a systemd daemon were running in memory.
Note: The web page https://eddie.website/support/elevation/, which is linked in the error message, refers to the eddie-cli program, which is not part of the current eddie-ui deb package.
Nevertheless, when applying the workaround specified for the eddie-cli-elevated program:
root@devuan6:~# chmod u+s /usr/lib/eddie-ui/eddie-cli-elevated
root@devuan6:~# ls -l /usr/lib/eddie-ui/eddie-cli-elevated
-rwsr-xr-x 1 root root 458488  9 juil. 13:22 /usr/lib/eddie-ui/eddie-cli-elevated
then the privilege escalation fails in the same way.
Thank you in advance for resolving this issue.
Thanks for replying on this matter.
I think your UI for macOS already looks pretty good. No idea if there is a goal for UI improvements on Android, but that should a priority, it looks very outdated. "Material You" would give a nice touch.
Interesting. Why then can I run the Wireguard.app itself (1.0.15) with no problem using AirVPN config generator? Totally stable. But Wireguard.app lacks 2 key features I've come to rely on from  Eddie:
Network Lock
Routes/split tunneling
Understood; and at least the latest version doesn't exhibit the problems I'd mentioned previously (e.g. only showing 25 US servers instead of 48). But as I've also mentioned OpenVPN is often painfully slow compared to Wireguard protocol.
