Not connected, Your IP: 216.73.216.112
zanon321
ANSWERED if i want to run ssh on pc2 and connect to it from pc3 (while pc2 is sshing into pc1) it fails.
Hi
I created a port forwarding  on my  pc1 at port eg 3***** and running eddie on it, i can connect to it from pc2 via ssh over the internet.
but the moment i  activate eddie and route my home pc traffic via eddie on home pc as eg 1********
and then try to reach my office vis ssh, i get the below error
ssh: connect to host ubuntu.airdns.org port 34445: Network is unreachable
then i have to delete the home port in my control panel at airvpn, and wait for hours for connection to reset on its own or chache to clear so that i can connect from home to office.
Basically airdns works great with just one active port.
Any help on this pl.
@zanon321
We can reach your SSH server from the Internet, so the setup of sshd on the office PC is just fine.
You have a single key pair and a single port. When you connect your home PC to a VPN server, the DNS record of the domain name <your name>.airdns.org is updated to the exit IP address of the VPN server the home PC connected to, so the address of the office PC (behind the VPN server) is lost. In this case this setup could work only if the office PC is the last one to connect, so it's not a reliable scenario.
You need to create a new key pair and use a unique key on each computer. Then, link DDNS and port <your port> to only one of the key pairs (in this case, the office PC key pair). Finally make sure that you connect PCs to different VPN servers.
ALTERNATIVELY, just don't use DDNS but point ssh directly to the exit-IP address of the VPN server the office PC is connected to and make sure you connect each device to a different VPN server.
How to manage key pairs and certificates:
https://airvpn.org/forums/topic/26209-how-to-manage-client-certificatekey-pairs/
