zendata
Can't connect through Wireguard on Ubuntu
I have been attempting to connect to AirVPN servers through Wireguard on Ubuntu 24.04.1 LTS, but after I connect I cannot access the Internet. I followed the directions here: https://airvpn.org/linux/wireguard/terminal/ On the Config Generator, I selected Linux, then the Wireguard UDP protocol, then downloaded the Europe config. I renamed it to wg_europe.conf and placed it in a folder named airvpn. Then I ran:
sudo wg-quick up /home/myuser/airvpn/wg_europe.conf
which worked successfully. From here on out, I cannot access the Internet. Going to google.com or anything else in Firefox results in a Server Not Found. ping 1.1.1.1 and ping 8.8.8.8 both fail, but I CAN ping the IP address under [Interface] in the wg_europe.conf file. When I run `sudo wg` in a terminal, I get this output:
interface: wg_europe
  public key: <redacted>
  private key: (hidden)
  listening port: 46776
  fwmark: 0xca6c
peer: <redacted>
  preshared key: (hidden)
  endpoint: 213.152.162.76:1637
  allowed ips: 0.0.0.0/0, ::/0
  latest handshake: 3 minutes, 49 seconds ago
  transfer: 23.30 KiB received, 88.00 KiB sent
  persistent keepalive: every 15 seconds
When I run `wg-quick down /home/myuser/airvpn/wg_europe.conf`, I still cannot connect to the Internet and I have to restart my computer every time to start over. Some help would be greatly appreciated!
Please test again with ufw disabled to quickly discern whether an ufw custom rule is the "culprit". From a terminal enter the following command:
sudo ufw disable
You can later re-enable ufw if needed with
 sudo ufw enable
