supermanvthanos
Slow Speeds, even on wireguard.
I maxed out buffer size.  I unchecked automatic and selected default wireguard port.  Tested the best rated for speed as well as the ones closest to me.  I then immediately do a speed test, and the best I can get is about half my full DL speed.  I can turn VPN off and get full speed.  I can even connect back to Mullvad(I have 1month left) and I get full speed.  Can't get this working with AirVPN.  I am using Eddie client.
I may need a refund if I can't fix this.
Suggestions?
Edited ... by supermanvthanos
@supermanvthanos
Set the link MTU size identical to the size set by Mullvad and then increase at little steps. 20 bytes by 20 bytes. Consider that:
  • Mullvad software forces the MTU size to 1280 bytes (at least some time ago, we don't know whether they changed it recently)
  • Eddie 2.21.8 lets WireGuard set the MTU size and it does not offer an option to change it. If WireGuard makes a wrong choice Eddie 2.21 can't fix it
  • Eddie 2.23.x sets MTU size to 1320 bytes but also lets you change it in Preferences > WireGuard window, a new feature. If you want to test it: https://airvpn.org/forums/topic/56428-eddie-desktop-223-beta-released/
  • if you run native WireGuard utilities you can change MTU size by entering the directive MTU = n, where n is in bytes, in the [Interface] section of the configuration file. You can edit it with any text editor
  • each time you change MTU size you must re-start the connection to apply the change. Perform the speed tests to fine tune and find the optimal MTU size for your network.
Rationale: too small and too big MTU sizes deeply impair performance. In the first case there's a waste of room in the frame, in the second case a whole packet must be re-sent for each packet too large for the frame.
Feel free to open a ticket if you need support directly from the AirVPN support team.
Quote
This is the community forum so it's not the proper place as the community can't do anything about it obviously. If you decide for a refund you will need to open a ticket (click "Contact us" on the web site or write to support@airvpn.org).
