Staff
Eddie macOS - Unable to start (Client not allowed: Remote executable not signed)
If you encounter exactly this error under macOS:
run from terminal (adjust the path if different)
sudo rm /Applications/Eddie.app/Contents/Resources/mono_crash*
This issue is resolved in Eddie version 2.21.5 and above.
Issue details
Eddie checks the integrity of Eddie installation every time it is started. The following command:
/usr/bin/codesign -v --verify /Applications/Eddie.app/Contents/MacOS/Eddie
must return
/Applications/Eddie.app/Contents/MacOS/Eddie: valid on disk
/Applications/Eddie.app/Contents/MacOS/Eddie: satisfies its Designated Requirement
but when a crash occurs it generates a dump file that causes failed validation:
/Applications/Eddie.app/Contents/MacOS/Eddie: a sealed resource is missing or invalid
file added: /Applications/Eddie.app/Contents/Resources/mono_crash.11b738480.0.json
Removing dump files with the below command reverts to a successful validation:
Just curious if this is ALL versions of Mac?
Can occur in all version, but it's rare to hit this issue
