Staff 10556 Posted ... Hello! We're very glad to inform you that we have just released Hummingbird 1.1.0 beta 1, featuring: SystemV-style init support for Linux update to the latest OpenVPN3-AirVPN and asio libraries Hummingbird is AirVPN's free and open source OpenVPN 3 client based on AirVPN's OpenVPN 3 library fork. Hummingbird is available for: Linux x86-64 Linux ARM 32 (example: Raspbian for Raspberry Pi) Linux ARM 64 macOS (Mojave or higher version required) For a thorough Hummingbird overview please consult https://airvpn.org/hummingbird/readme/ Hummingbird 1.1.0 adds support to Linux systems based on SystemV-style init https://en.wikipedia.org/wiki/Init#SYSV, while the previous versions supported Linux systemd based systems only.Therefore, we gladly achieve compatibility with 35 additional Linux distributions:https://distrowatch.com/search.php?ostype=All&category=All&origin=All&basedon=All¬basedon=None&desktop=All&architecture=All&package=All&rolling=All&isosize=All&netinstall=All&language=All&defaultinit=SysV&status=Active#simple We think it's important to support Init Freedom:https://devuan.org/os/init-freedom because systemd is POSIX incompatible and because, as the UNIX Veteran Admin collective noticed in 2014 when they announced a Debian fork: This situation prospects a lock in systemd dependencies which is de-facto threatening freedom of development and has serious consequences for Debian, its upstream and its downstream. Download URLs follow.Linux x86-64:https://gitlab.com/AirVPN/hummingbird/-/blob/master/binary/hummingbird-linux-x86_64-1.1.0-beta-1.tar.gzhttps://gitlab.com/AirVPN/hummingbird/-/blob/master/binary/hummingbird-linux-x86_64-1.1.0-beta-1.tar.gz.sha512Linux armv7l (ARM 32 bit):https://gitlab.com/AirVPN/hummingbird/-/blob/master/binary/hummingbird-linux-armv7l-1.0.3.tar.gz.sha512https://gitlab.com/AirVPN/hummingbird/-/blob/master/binary/hummingbird-linux-armv7l-1.1.0-beta-1.tar.gzLinux aarch64 (ARM 64 bit):https://gitlab.com/AirVPN/hummingbird/-/blob/master/binary/hummingbird-linux-aarch64-1.1.0-beta-1.tar.gzhttps://gitlab.com/AirVPN/hummingbird/-/blob/master/binary/hummingbird-linux-aarch64-1.1.0-beta-1.tar.gz.sha512macOS (please note: beta version is not notarized):https://gitlab.com/AirVPN/hummingbird/-/blob/master/binary/hummingbird-macos-1.1.0-beta-1.tar.gzhttps://gitlab.com/AirVPN/hummingbird/-/blob/master/binary/hummingbird-macos-1.1.0-beta-1.tar.gz.sha512 Kind regards & datalove AirVPN Staff 2 colorman and eburom reacted to this Share this post Link to post
eburom 16 Posted ... 24 minutes ago, Staff said: SystemV-style init support for Linux Nice! I can see that only the binaries have been deployed.. Is that because of this version being in beta stage yet? Share this post Link to post
inc 3 Posted ... Lets hope this version finally corrects the handshake error. Share this post Link to post
Maggie144 12 Posted ... Thanks for your work. Is it possible to use this version with Eddie (saw an option in Advanced Settings) to take advantage of the latest OpenVPN3-AirVPN? Share this post Link to post
Staff 10556 Posted ... @Maggie144+ Hello and thank you! Yes, of course: from Eddie's main window select "Preferences" > "Advanced" tick "Use Hummingbird if available" click "Save" copy Hummingbird binary file in a directory included in the commands path (you will need root privileges to do so) Re-start Eddie to apply the changes and use Hummingbird via Eddie. Kind regards Share this post Link to post
Maggie144 12 Posted ... So I copied Hummingbird (1.1.0 beta 1) to /usr/local/bin I can use it via command line - no problem. Activated using Hummingbird in Eddie (2.19.2) and restarted, but it's using Hummingbird 1.0.2 (which is located in the Eddie packet) Tried to replace said version with the current beta, but then Eddie won't start up at all with the following error: Unable to obtain elevated privileges (required): Object reference not set to an instance of an object It's only able to start again when using the original version which shipped with Eddie 2.19.2 Share this post Link to post
colorman 31 Posted ... 2 hours ago, Maggie144 said: So I copied Hummingbird (1.1.0 beta 1) to /usr/local/bin I can use it via command line - no problem. Activated using Hummingbird in Eddie (2.19.2) and restarted, but it's using Hummingbird 1.0.2 (which is located in the Eddie packet) Tried to replace said version with the current beta, but then Eddie won't start up at all with the following error: Unable to obtain elevated privileges (required): Object reference not set to an instance of an object It's only able to start again when using the original version which shipped with Eddie 2.19.2 First i have Hummingbird copied to /usr/lib/eddie-ui/ I use openSUSE leap 15.1 Hummingbird must have root rights in that directory! Hope this helps you something Share this post Link to post
Maggie144 12 Posted ... Sorry forgot to mention - I'm on macOS Catalina 10.15.5 (which should be named Vista - a complete shit-show this version) I did use root to copy to /usr/local/bin - so terminal works. I also used root to replace the "old" version with the new in /Applications/Eddie.app/Contents/MacOS folder - but still said Error message shows up.. Looks like I'll have to wait till Eddie 2.19.3 - which hopefully ships with a newer Hummingbird version Share this post Link to post
Clodo 178 Posted ... We hope to release 2.19.3 probably tomorrow, it fixes the "Unable to obtain elevated privileges (required): Object reference not set to an instance of an object" issue. Of course with Hummingbird updated. Please be patient, thx. Share this post Link to post
Clodo 178 Posted ... @Maggie144 has a specific macOS bug that will be fixed soon.@colorman, Linux, If you tick Preferences -> Advanced -> Use Hummingbird, Eddie will search for Hummingbird executable in environment paths. Otherwise a path can be set with option "--tools.hummingbird.path=/path/to/...". Sorry, no UI right now, it will be available in 2.19.3.But remember: you need to ensure "chmod +x /path/to/hummingbird" AND "chown root /path/to/hummingbird". An Eddie security protection requires root ownership. Share this post Link to post
colorman 31 Posted ... @Clodo Hummingbird works in eddie, no problems here. checked in log files Share this post Link to post
inc 3 Posted ... I still have the sporadic ongoing handshake error, I have tried changing the ovpn file to initiate the handshake instead of server with a reneg-sec 1200 entry but results are variable certainly not consistent. I have tried individual servers but sometimes just use the the country (UK) opvn file. This morning the connection seems slow so I did a speed test with VPN connected to Naos 15Mbps disconnected 63Mbps, disappointing. Share this post Link to post
