Old Fella 10 Posted ... Almost every time I go to shut down or restart Linux Mint 18.3 the Eddie Window is unresponsive; I can display it but I am unable to click anything on it. Initially I just shut the system down regardless but if I don't want to sign out I have to shut down all *vpn processes manually, usually with htop cos its quicker. Just what might the issue be? It isn't new, I've had this happen for a long time, just not as often. 1 auser17 reacted to this Hide Old Fella's signature Hide all signatures I sign nothing, much Still getting older.... Share this post Link to post
chexmix 0 Posted ... I have the same issue Eddie becomes unresponsive at least once every dayLinux mint 18.3 inxi -F System: Host: b Kernel: 4.10.0-42-generic x86_64 (64 bit) Desktop: Cinnamon 3.6.7 Distro: Linux Mint 18.3 Sylvia Machine: Mobo: ASUSTeK model: RAMPAGE IV BLACK EDITION v: Rev 1.xx Bios: American Megatrends v: 0801 date: 07/04/2014 CPU: Hexa core Intel Core i7-4930K (-HT-MCP-) cache: 12288 KB clock speeds: max: 2500 MHz 1: 1199 MHz 2: 1199 MHz 3: 1199 MHz 4: 1503 MHz 5: 1199 MHz 6: 1562 MHz 7: 1199 MHz 8: 1199 MHz 9: 1331 MHz 10: 1199 MHz 11: 1199 MHz 12: 1199 MHz Graphics: Card: NVIDIA GK104 [GeForce GTX 760] Display Server: X.Org 1.18.4 drivers: nvidia (unloaded: fbdev,vesa,nouveau) Resolution: 1920x1080@60.00hz GLX Renderer: GeForce GTX 760/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 384.90 Audio: Card-1 NVIDIA GK104 HDMI Audio Controller driver: snd_hda_intel Card-2 Intel C600/X79 series High Definition Audio Controller driver: snd_hda_intel Sound: Advanced Linux Sound Architecture v: k4.10.0-42-generic Network: Card: Intel 82574L Gigabit Network Connection driver: e1000e IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: Drives: HDD Total Size: ID-1: /dev/sda model: WDC_WD6002FZWX size: 6001.2GB Partition: ID-1: / size: 46G used: 12G (27%) fs: ext4 dev: /dev/sdd2 ID-2: /home size: 871G used: 239G (29%) fs: ext4 dev: /dev/sdd3 RAID: No RAID devices: /proc/mdstat, md_mod kernel module present Sensors: System Temperatures: cpu: 23.0C mobo: N/A Fan Speeds (in rpm): cpu: 0 Info: Processes: 319 Uptime: 30 min Memory: 2242.3/32112.7MB Client: Shell (bash) inxi: 2.2.35 Share this post Link to post
go558a83nk 389 Posted ... Same, here. My mint 18.3 is a virtualbox guest. Share this post Link to post
LZ1 686 Posted ... Hello! It's not helpful to declare this, if you don't also at least state which Eddie you're experiencing this on . So I urge you all to upgrade to the experimental Eddie client and see how you do. Instructions can be found in my signature if you don't know how to download the experimental client. Then if you run into any problems, you can post about them in the feedback thread designed specifically for the experimental client and thus help make Eddie better. Thank you. Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
