Since around four or five days I can't connect to sweddish servers (uppsala)
Eddie's informations are good:  decent latency and 5 stars , but I've tried all servers from sweden and it doesn't work (
Did you try other Protocols like TCP? I have problems connecting to a bunch of Servers when using UDP.
With TCP , I can now connect to sweden but its very slooowww alas, thank you anyway
Please append the full logs. You can also check the status of any server on the Status page here on the site .
All is Ok again,  I'm in Stockholm drinking a good beer at a terrasse café , young girls are dancing in front of me in their coloured dresses; the sky is blue and sun is burning my last hairs , connection is perfect and life is quite enjoyable .
Thaqnk you Mr LZ1
Not working , here are my logs
I 2017.03.28 12:29:31 - Eddie client version: 2.11.15 / linux_x86, System: Linux, Name: Linux Mint 17.3 Rosa \n \l, Mono/.Net Framework: v4.0.30319
. 2017.03.28 12:29:31 - Reading options from /home/jaycee/.airvpn/AirVPN.xml
. 2017.03.28 12:29:32 - Data path: /home/jaycee/.airvpn
. 2017.03.28 12:29:32 - Application path: /usr/lib/AirVPN
. 2017.03.28 12:29:32 - Executable path: /usr/lib/AirVPN/AirVPN.exe
. 2017.03.28 12:29:32 - Command line arguments (1): path="/home/jaycee/.airvpn"
. 2017.03.28 12:29:32 - Operating System: Unix 3.16.0.38 - Linux jaycee-GT680R-GX680R-GT683R 3.16.0-38-generic #52~14.04.1-Ubuntu SMP Fri May 8 09:44:48 UTC 2015 i686 i686 i686 GNU/Linux
I 2017.03.28 12:29:32 - OpenVPN Driver - Found, /dev/net/tun
I 2017.03.28 12:29:32 - OpenVPN - Version: 2.3.2 -  (/usr/sbin/openvpn)
I 2017.03.28 12:29:32 - SSH - Version: OpenSSH_6.6.1p1 Ubuntu-2ubuntu2.8, OpenSSL 1.0.1f 6 Jan 2014 (/usr/bin/ssh)
I 2017.03.28 12:29:32 - SSL - Version: stunnel 4.53 (/usr/bin/stunnel4)
! 2017.03.28 12:29:32 - Ready
. 2017.03.28 12:29:32 - Updating systems & servers data ...
. 2017.03.28 12:29:36 - Systems & servers data update completed
! 2017.03.28 12:29:38 - Activation of Network Lock - Linux IPTables
I 2017.03.28 12:30:16 - Session starting.
. 2017.03.28 12:30:17 - Unable to understand if IPv6 is active.
I 2017.03.28 12:30:17 - Checking authorization ...
! 2017.03.28 12:30:17 - Connecting to Zaniah (Sweden, Uppsala)
. 2017.03.28 12:30:17 - OpenVPN > OpenVPN 2.3.2 i686-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec  1 2014
. 2017.03.28 12:30:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.28 12:30:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.03.28 12:30:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 12:30:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 12:30:17 - OpenVPN > Socket Buffers: R=[163840->327680] S=[163840->327680]
. 2017.03.28 12:30:17 - OpenVPN > UDPv4 link local: [undef]
. 2017.03.28 12:30:17 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.136:443
. 2017.03.28 12:30:17 - OpenVPN > write UDPv4: Operation not permitted (code=1)
. 2017.03.28 12:30:49 - Above log line repeated 4 times more
. 2017.03.28 12:30:49 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.03.28 12:30:49 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.28 12:30:54 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.03.28 12:30:55 - Disconnecting
. 2017.03.28 12:30:55 - Connection terminated.
I 2017.03.28 12:30:56 - Cancel requested.
! 2017.03.28 12:30:56 - Session terminated.
I 2017.03.28 12:31:05 - Session starting.
. 2017.03.28 12:31:05 - Unable to understand if IPv6 is active.
I 2017.03.28 12:31:05 - Checking authorization ...
! 2017.03.28 12:31:05 - Connecting to Serpentis (Sweden, Uppsala)
. 2017.03.28 12:31:05 - OpenVPN > OpenVPN 2.3.2 i686-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec  1 2014
. 2017.03.28 12:31:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.28 12:31:05 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.03.28 12:31:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 12:31:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 12:31:05 - OpenVPN > Socket Buffers: R=[163840->327680] S=[163840->327680]
. 2017.03.28 12:31:05 - OpenVPN > UDPv4 link local: [undef]
. 2017.03.28 12:31:05 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.139:443
. 2017.03.28 12:31:05 - OpenVPN > write UDPv4: Operation not permitted (code=1)
. 2017.03.28 12:31:37 - Above log line repeated 4 times more
. 2017.03.28 12:31:37 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.03.28 12:31:37 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.28 12:31:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.03.28 12:31:43 - Disconnecting
. 2017.03.28 12:31:43 - Connection terminated.
I 2017.03.28 12:31:45 - Cancel requested.
! 2017.03.28 12:31:45 - Session terminated.
I 2017.03.28 12:31:51 - Session starting.
. 2017.03.28 12:31:51 - Unable to understand if IPv6 is active.
I 2017.03.28 12:31:51 - Checking authorization ...
! 2017.03.28 12:31:51 - Connecting to Pherkad (Sweden, Uppsala)
. 2017.03.28 12:31:51 - OpenVPN > OpenVPN 2.3.2 i686-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec  1 2014
. 2017.03.28 12:31:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.28 12:31:51 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.03.28 12:31:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 12:31:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 12:31:51 - OpenVPN > Socket Buffers: R=[163840->327680] S=[163840->327680]
. 2017.03.28 12:31:51 - OpenVPN > UDPv4 link local: [undef]
. 2017.03.28 12:31:51 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.134:443
. 2017.03.28 12:31:51 - OpenVPN > write UDPv4: Operation not permitted (code=1)
. 2017.03.28 12:32:24 - Above log line repeated 4 times more
. 2017.03.28 12:32:24 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.03.28 12:32:24 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.28 12:32:29 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.03.28 12:32:29 - Disconnecting
. 2017.03.28 12:32:29 - Connection terminated.
I 2017.03.28 12:32:30 - Cancel requested.
! 2017.03.28 12:32:30 - Session terminated.
I 2017.03.28 12:32:36 - Session starting.
. 2017.03.28 12:32:36 - Unable to understand if IPv6 is active.
I 2017.03.28 12:32:36 - Checking authorization ...
! 2017.03.28 12:32:39 - Connecting to Muphrid (Sweden, Uppsala)
. 2017.03.28 12:32:39 - OpenVPN > OpenVPN 2.3.2 i686-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec  1 2014
. 2017.03.28 12:32:39 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.28 12:32:39 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.03.28 12:32:39 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 12:32:39 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 12:32:39 - OpenVPN > Socket Buffers: R=[163840->327680] S=[163840->327680]
. 2017.03.28 12:32:39 - OpenVPN > UDPv4 link local: [undef]
. 2017.03.28 12:32:39 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.146:443
. 2017.03.28 12:32:39 - OpenVPN > write UDPv4: Operation not permitted (code=1)
. 2017.03.28 12:33:11 - Above log line repeated 4 times more
. 2017.03.28 12:33:11 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.03.28 12:33:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.28 12:33:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.03.28 12:33:16 - Disconnecting
. 2017.03.28 12:33:16 - Connection terminated.
I 2017.03.28 12:33:17 - Cancel requested.
! 2017.03.28 12:33:17 - Session terminated.
UDP packets and/or certain IP addresses of our servers are blocked in your system. Please check your firewall rules. Also consider to enable Network Lock to replace your rules while Eddie is running (your rules will be restored). Upgrade to Eddie 2.12.4 as well.
Thank you for your fast reply ) when I'M USING Eddie Network Lock is always enabled and I've just upgrade Eddie 2.12.4 with no more success . Sweden is the only one contry I can't reach . Nothing particular in my firewall rules . I will procced to more investgations , with my magnifying glass and Sherlock Holmes hat.
When I'm using EsDdie Network lock is always enabled , and
Partially solved by replacing UDP protocol by TCP protocols (but speed is 10% slower ...not vey important)
thank you, here are my new logs
I 2017.03.28 13:47:40 - Eddie client version: 2.12.4 / linux_x86, System: Linux, Name: Linux Mint 17.3 Rosa \n \l, Mono/.Net Framework: v4.0.30319
. 2017.03.28 13:47:40 - Reading options from /home/jaycee/.airvpn/AirVPN.xml
. 2017.03.28 13:47:41 - Data path: /home/jaycee/.airvpn
. 2017.03.28 13:47:41 - Application path: /usr/lib/AirVPN
. 2017.03.28 13:47:41 - Executable path: /usr/lib/AirVPN/AirVPN.exe
. 2017.03.28 13:47:41 - Command line arguments (1): path="/home/jaycee/.airvpn"
. 2017.03.28 13:47:41 - Operating System: Unix 3.16.0.38 - Linux jaycee-GT680R-GX680R-GT683R 3.16.0-38-generic #52~14.04.1-Ubuntu SMP Fri May 8 09:44:48 UTC 2015 i686 i686 i686 GNU/Linux
I 2017.03.28 13:47:41 - OpenVPN Driver - Found, /dev/net/tun
I 2017.03.28 13:47:41 - OpenVPN - Version: 2.3.2 -  (/usr/sbin/openvpn)
I 2017.03.28 13:47:41 - SSH - Version: OpenSSH_6.6.1p1 Ubuntu-2ubuntu2.8, OpenSSL 1.0.1f 6 Jan 2014 (/usr/bin/ssh)
I 2017.03.28 13:47:41 - SSL - Version: stunnel 4.53 (/usr/bin/stunnel4)
I 2017.03.28 13:47:41 - curl - Version: 7.35.0 (/usr/bin/curl)
I 2017.03.28 13:47:41 - Certification Authorities: /usr/share/AirVPN/cacert.pem
! 2017.03.28 13:47:41 - Ready
. 2017.03.28 13:47:41 - Updating systems & servers data ...
. 2017.03.28 13:47:41 - Systems & servers data update completed
I 2017.03.28 13:48:02 - Session starting.
. 2017.03.28 13:48:02 - Unable to understand if IPv6 is active.
I 2017.03.28 13:48:02 - Checking authorization ...
! 2017.03.28 13:48:03 - Connecting to Pherkad (Sweden, Uppsala)
. 2017.03.28 13:48:03 - OpenVPN > OpenVPN 2.3.2 i686-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec  1 2014
. 2017.03.28 13:48:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.28 13:48:03 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.03.28 13:48:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 13:48:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 13:48:03 - OpenVPN > Socket Buffers: R=[87380->327680] S=[16384->327680]
. 2017.03.28 13:48:03 - OpenVPN > Attempting to establish TCP connection with [AF_INET]62.102.148.134:443 [nonblock]
. 2017.03.28 13:48:04 - OpenVPN > TCP connection established with [AF_INET]62.102.148.134:443
. 2017.03.28 13:48:04 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2017.03.28 13:48:04 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]62.102.148.134:443
. 2017.03.28 13:48:04 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.134:443, sid=e3c7b267 109dddab
. 2017.03.28 13:48:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.28 13:48:04 - OpenVPN > Validating certificate key usage
. 2017.03.28 13:48:04 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.03.28 13:48:04 - OpenVPN > VERIFY KU OK
. 2017.03.28 13:48:04 - OpenVPN > Validating certificate extended key usage
. 2017.03.28 13:48:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.28 13:48:04 - OpenVPN > VERIFY EKU OK
. 2017.03.28 13:48:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.28 13:48:06 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.28 13:48:06 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 13:48:06 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.28 13:48:06 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 13:48:06 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2017.03.28 13:48:06 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.134:443
. 2017.03.28 13:48:09 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.28 13:48:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.8.226 255.255.0.0'
. 2017.03.28 13:48:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.28 13:48:09 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.03.28 13:48:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.28 13:48:09 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.28 13:48:09 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.28 13:48:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.28 13:48:09 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=dc:a9:71:04:ec:41
. 2017.03.28 13:48:09 - OpenVPN > TUN/TAP device tun0 opened
. 2017.03.28 13:48:09 - OpenVPN > TUN/TAP TX queue length set to 100
. 2017.03.28 13:48:09 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.03.28 13:48:09 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2017.03.28 13:48:09 - OpenVPN > /sbin/ip addr add dev tun0 10.5.8.226/16 broadcast 10.5.255.255
. 2017.03.28 13:48:14 - OpenVPN > /sbin/ip route add 62.102.148.134/32 via 192.168.1.1
. 2017.03.28 13:48:14 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.5.0.1
. 2017.03.28 13:48:14 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.5.0.1
. 2017.03.28 13:48:14 - Starting Management Interface
. 2017.03.28 13:48:14 - OpenVPN > Initialization Sequence Completed
. 2017.03.28 13:48:14 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup
. 2017.03.28 13:48:14 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2017.03.28 13:48:14 - Checking route
I 2017.03.28 13:48:15 - Checking DNS
! 2017.03.28 13:48:16 - Connected.
. 2017.03.28 13:48:16 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.03.28 13:48:16 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2017.03.28 13:48:31 - Disconnecting
. 2017.03.28 13:48:31 - Management - Send 'signal SIGTERM'
. 2017.03.28 13:48:31 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.28 13:48:31 - OpenVPN > /sbin/ip route del 62.102.148.134/32
. 2017.03.28 13:48:31 - OpenVPN > /sbin/ip route del 0.0.0.0/1
. 2017.03.28 13:48:31 - OpenVPN > /sbin/ip route del 128.0.0.0/1
. 2017.03.28 13:48:31 - OpenVPN > Closing TUN/TAP interface
. 2017.03.28 13:48:31 - OpenVPN > /sbin/ip addr del dev tun0 10.5.8.226/16
. 2017.03.28 13:48:31 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2017.03.28 13:48:31 - Connection terminated.
. 2017.03.28 13:48:31 - DNS of the system restored to original settings (Rename method)
! 2017.03.28 13:48:31 - Session terminated.
! 2017.03.28 13:48:39 - Activation of Network Lock - Linux IPTables
I 2017.03.28 13:48:52 - Session starting.
. 2017.03.28 13:48:52 - Unable to understand if IPv6 is active.
I 2017.03.28 13:48:52 - Checking authorization ...
! 2017.03.28 13:48:52 - Connecting to Gacrux (Sweden, Uppsala)
. 2017.03.28 13:48:52 - OpenVPN > OpenVPN 2.3.2 i686-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec  1 2014
. 2017.03.28 13:48:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.28 13:48:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.03.28 13:48:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 13:48:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 13:48:52 - OpenVPN > Socket Buffers: R=[87380->327680] S=[16384->327680]
. 2017.03.28 13:48:52 - OpenVPN > Attempting to establish TCP connection with [AF_INET]62.102.148.137:443 [nonblock]
. 2017.03.28 13:48:53 - OpenVPN > TCP connection established with [AF_INET]62.102.148.137:443
. 2017.03.28 13:48:53 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2017.03.28 13:48:53 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]62.102.148.137:443
. 2017.03.28 13:48:53 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.137:443, sid=fc194d94 c8eee413
. 2017.03.28 13:48:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.28 13:48:54 - OpenVPN > Validating certificate key usage
. 2017.03.28 13:48:54 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.03.28 13:48:54 - OpenVPN > VERIFY KU OK
. 2017.03.28 13:48:54 - OpenVPN > Validating certificate extended key usage
. 2017.03.28 13:48:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.28 13:48:54 - OpenVPN > VERIFY EKU OK
. 2017.03.28 13:48:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.28 13:48:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.28 13:48:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 13:48:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.28 13:48:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.28 13:48:56 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2017.03.28 13:48:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.137:443
. 2017.03.28 13:48:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.28 13:48:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.8.112 255.255.0.0'
. 2017.03.28 13:48:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.28 13:48:59 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.03.28 13:48:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.28 13:48:59 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.28 13:48:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.28 13:48:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.28 13:48:59 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=dc:a9:71:04:ec:41
. 2017.03.28 13:48:59 - OpenVPN > TUN/TAP device tun0 opened
. 2017.03.28 13:48:59 - OpenVPN > TUN/TAP TX queue length set to 100
. 2017.03.28 13:48:59 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.03.28 13:48:59 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2017.03.28 13:48:59 - OpenVPN > /sbin/ip addr add dev tun0 10.5.8.112/16 broadcast 10.5.255.255
. 2017.03.28 13:49:04 - OpenVPN > /sbin/ip route add 62.102.148.137/32 via 192.168.1.1
. 2017.03.28 13:49:04 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.5.0.1
. 2017.03.28 13:49:04 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.5.0.1
. 2017.03.28 13:49:04 - Starting Management Interface
. 2017.03.28 13:49:04 - OpenVPN > Initialization Sequence Completed
. 2017.03.28 13:49:04 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup
. 2017.03.28 13:49:04 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2017.03.28 13:49:04 - Checking route
I 2017.03.28 13:49:05 - Checking DNS
! 2017.03.28 13:49:06 - Connected.
. 2017.03.28 13:49:06 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.03.28 13:49:06 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
