lemontree10 2 Posted ... After reinstalling Kubuntu 14.04 and reinstalling the updated Eddie Client today i find that the software is unable to connect to any servers as it appears that it is going through the list of servers from start to finish, as it gets an error message when connecting it trys the next one on the list with the same result, I have pasted the log file I saved into the following spoiler. 2017.01.31 15:21:58 - OpenVPN > /sbin/ip route add 213.152.162.78/32 via 192.168.1.1. 2017.01.31 15:21:58 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:21:58 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:21:58 - Starting Management Interface. 2017.01.31 15:21:58 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:21:58 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:21:58 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:21:58 - Checking routeE 2017.01.31 15:21:58 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:21:58 - Checking route (2° try)E 2017.01.31 15:21:59 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:21:59 - Checking route (3° try)E 2017.01.31 15:22:02 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:22:02 - Routing checking failed.. 2017.01.31 15:22:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:22:02 - Disconnecting. 2017.01.31 15:22:02 - Management - Send 'signal SIGTERM'. 2017.01.31 15:22:02 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:22:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:22:02 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:22:07 - OpenVPN > /sbin/ip route del 213.152.162.78/32. 2017.01.31 15:22:07 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:22:07 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:22:07 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:22:07 - OpenVPN > /sbin/ip addr del dev tun0 10.4.99.234/16. 2017.01.31 15:22:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:22:07 - Connection terminated.. 2017.01.31 15:22:07 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:22:10 - Checking authorization ...! 2017.01.31 15:22:11 - Connecting to Alzirr (Netherlands, Alblasserdam). 2017.01.31 15:22:11 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:22:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:22:11 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:22:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:11 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:22:11 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:22:11 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.14:443. 2017.01.31 15:22:11 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.14:443, sid=1eed87ad ed47d93b. 2017.01.31 15:22:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:22:11 - OpenVPN > Validating certificate key usage. 2017.01.31 15:22:11 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:22:11 - OpenVPN > VERIFY KU OK. 2017.01.31 15:22:11 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:22:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:22:11 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:22:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:22:11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:11 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:11 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:11 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:22:11 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.14:443. 2017.01.31 15:22:13 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:22:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.64.4 255.255.0.0'. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:22:13 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:22:13 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:22:13 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:22:13 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:22:13 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:22:13 - OpenVPN > /sbin/ip addr add dev tun0 10.4.64.4/16 broadcast 10.4.255.255. 2017.01.31 15:22:18 - OpenVPN > /sbin/ip route add 109.202.107.14/32 via 192.168.1.1. 2017.01.31 15:22:18 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:22:18 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:22:18 - Starting Management Interface. 2017.01.31 15:22:18 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:22:18 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:22:18 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:22:18 - Checking routeE 2017.01.31 15:22:18 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:22:18 - Checking route (2° try)E 2017.01.31 15:22:19 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:22:19 - Checking route (3° try)E 2017.01.31 15:22:22 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:22:22 - Routing checking failed.. 2017.01.31 15:22:22 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:22:22 - Disconnecting. 2017.01.31 15:22:22 - Management - Send 'signal SIGTERM'. 2017.01.31 15:22:22 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:22:22 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:22:22 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:22:27 - OpenVPN > /sbin/ip route del 109.202.107.14/32. 2017.01.31 15:22:27 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:22:27 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:22:27 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:22:27 - OpenVPN > /sbin/ip addr del dev tun0 10.4.64.4/16. 2017.01.31 15:22:27 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:22:27 - Connection terminated.. 2017.01.31 15:22:27 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:22:30 - Checking authorization ...! 2017.01.31 15:22:30 - Connecting to Hyadum (Netherlands, Alblasserdam). 2017.01.31 15:22:30 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:22:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:22:30 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:22:30 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:30 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:30 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:22:30 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:22:30 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443. 2017.01.31 15:22:30 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=6065636a ad1a2422. 2017.01.31 15:22:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:22:31 - OpenVPN > Validating certificate key usage. 2017.01.31 15:22:31 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:22:31 - OpenVPN > VERIFY KU OK. 2017.01.31 15:22:31 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:22:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:22:31 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:22:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:22:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:31 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:22:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443. 2017.01.31 15:22:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:22:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.99.186 255.255.0.0'. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:22:33 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:22:33 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:22:33 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:22:33 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:22:33 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:22:33 - OpenVPN > /sbin/ip addr add dev tun0 10.4.99.186/16 broadcast 10.4.255.255. 2017.01.31 15:22:38 - OpenVPN > /sbin/ip route add 213.152.161.34/32 via 192.168.1.1. 2017.01.31 15:22:38 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:22:38 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:22:39 - Starting Management Interface. 2017.01.31 15:22:39 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:22:39 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:22:39 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:22:39 - Checking routeE 2017.01.31 15:22:39 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:22:39 - Checking route (2° try)E 2017.01.31 15:22:40 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:22:40 - Checking route (3° try)E 2017.01.31 15:22:42 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:22:42 - Routing checking failed.. 2017.01.31 15:22:42 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:22:42 - Disconnecting. 2017.01.31 15:22:42 - Management - Send 'signal SIGTERM'. 2017.01.31 15:22:42 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:22:42 - OpenVpn Management > SUCCESS: signal SIGTERM thrown. 2017.01.31 15:22:42 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:22:42 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:22:47 - OpenVPN > /sbin/ip route del 213.152.161.34/32. 2017.01.31 15:22:47 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:22:47 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:22:47 - Connection terminated.. 2017.01.31 15:22:47 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:22:47 - DNS of the system restored to original settings (Rename method). 2017.01.31 15:22:47 - OpenVPN > /sbin/ip addr del dev tun0 10.4.99.186/16. 2017.01.31 15:22:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exitingI 2017.01.31 15:22:51 - Checking authorization ...! 2017.01.31 15:22:51 - Connecting to Gianfar (Netherlands, Alblasserdam). 2017.01.31 15:22:51 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:22:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:22:51 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:22:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:51 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:22:51 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:22:51 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.100:443. 2017.01.31 15:22:51 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.100:443, sid=1a861762 e5b652cd. 2017.01.31 15:22:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:22:51 - OpenVPN > Validating certificate key usage. 2017.01.31 15:22:51 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:22:51 - OpenVPN > VERIFY KU OK. 2017.01.31 15:22:51 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:22:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:22:51 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:22:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:22:54 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:54 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:54 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:54 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:54 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:22:54 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.100:443. 2017.01.31 15:22:56 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:22:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.100.85 255.255.0.0'. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:22:56 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:22:56 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:22:56 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:22:56 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:22:56 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:22:56 - OpenVPN > /sbin/ip addr add dev tun0 10.4.100.85/16 broadcast 10.4.255.255. 2017.01.31 15:23:01 - OpenVPN > /sbin/ip route add 213.152.161.100/32 via 192.168.1.1. 2017.01.31 15:23:01 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:01 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:01 - Starting Management Interface. 2017.01.31 15:23:01 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:23:01 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:23:02 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:23:02 - Checking routeE 2017.01.31 15:23:02 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:02 - Checking route (2° try)E 2017.01.31 15:23:03 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:03 - Checking route (3° try)E 2017.01.31 15:23:05 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:23:05 - Routing checking failed.. 2017.01.31 15:23:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:23:05 - Disconnecting. 2017.01.31 15:23:05 - Management - Send 'signal SIGTERM'. 2017.01.31 15:23:05 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:23:05 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:23:05 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:23:10 - OpenVPN > /sbin/ip route del 213.152.161.100/32. 2017.01.31 15:23:11 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:23:11 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:23:11 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:23:11 - OpenVPN > /sbin/ip addr del dev tun0 10.4.100.85/16. 2017.01.31 15:23:11 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:23:11 - Connection terminated.. 2017.01.31 15:23:11 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:23:14 - Checking authorization ...! 2017.01.31 15:23:14 - Connecting to Zibal (Netherlands, Alblasserdam). 2017.01.31 15:23:14 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:23:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:23:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:23:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:14 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:23:14 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:23:14 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.148:443. 2017.01.31 15:23:14 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.148:443, sid=898ef960 b3b442d0. 2017.01.31 15:23:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:23:15 - OpenVPN > Validating certificate key usage. 2017.01.31 15:23:15 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:23:15 - OpenVPN > VERIFY KU OK. 2017.01.31 15:23:15 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:23:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:23:15 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:23:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:23:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:17 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:23:17 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.148:443. 2017.01.31 15:23:19 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:23:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.100.146 255.255.0.0'. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:23:19 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:23:19 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:23:19 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:23:19 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:23:20 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:23:20 - OpenVPN > /sbin/ip addr add dev tun0 10.4.100.146/16 broadcast 10.4.255.255. 2017.01.31 15:23:24 - OpenVPN > /sbin/ip route add 213.152.161.148/32 via 192.168.1.1. 2017.01.31 15:23:24 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:24 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:24 - Starting Management Interface. 2017.01.31 15:23:24 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:23:24 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:23:24 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:23:24 - Checking routeE 2017.01.31 15:23:24 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:24 - Checking route (2° try)E 2017.01.31 15:23:25 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:25 - Checking route (3° try)E 2017.01.31 15:23:27 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:23:27 - Routing checking failed.. 2017.01.31 15:23:27 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:23:27 - Disconnecting. 2017.01.31 15:23:27 - Management - Send 'signal SIGTERM'. 2017.01.31 15:23:27 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:23:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:23:27 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:23:32 - OpenVPN > /sbin/ip route del 213.152.161.148/32. 2017.01.31 15:23:32 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:23:32 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:23:32 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:23:32 - Connection terminated.. 2017.01.31 15:23:32 - OpenVPN > /sbin/ip addr del dev tun0 10.4.100.146/16. 2017.01.31 15:23:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:23:32 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:23:35 - Checking authorization ...! 2017.01.31 15:23:35 - Connecting to Pleione (Netherlands, Alblasserdam). 2017.01.31 15:23:35 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:23:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:23:36 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:23:36 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:36 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:36 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:23:36 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:23:36 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.148:443. 2017.01.31 15:23:36 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.148:443, sid=0b715930 45b0adf1. 2017.01.31 15:23:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:23:36 - OpenVPN > Validating certificate key usage. 2017.01.31 15:23:36 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:23:36 - OpenVPN > VERIFY KU OK. 2017.01.31 15:23:36 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:23:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:23:36 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:23:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:23:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:38 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:23:38 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.148:443. 2017.01.31 15:23:40 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:23:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.87.11 255.255.0.0'. 2017.01.31 15:23:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:23:41 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:23:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:23:41 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:23:41 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:23:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:23:41 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:23:41 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:23:41 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:23:41 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:23:41 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:23:41 - OpenVPN > /sbin/ip addr add dev tun0 10.4.87.11/16 broadcast 10.4.255.255. 2017.01.31 15:23:45 - OpenVPN > /sbin/ip route add 213.152.162.148/32 via 192.168.1.1. 2017.01.31 15:23:45 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:45 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:45 - Starting Management Interface. 2017.01.31 15:23:45 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:23:45 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:23:45 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:23:45 - Checking routeE 2017.01.31 15:23:45 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:45 - Checking route (2° try)E 2017.01.31 15:23:46 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:46 - Checking route (3° try)E 2017.01.31 15:23:49 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:23:49 - Routing checking failed.. 2017.01.31 15:23:49 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:23:49 - Disconnecting. 2017.01.31 15:23:49 - Management - Send 'signal SIGTERM'. 2017.01.31 15:23:49 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:23:49 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:23:49 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:23:54 - OpenVPN > /sbin/ip route del 213.152.162.148/32. 2017.01.31 15:23:54 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:23:54 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:23:55 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:23:55 - OpenVPN > /sbin/ip addr del dev tun0 10.4.87.11/16. 2017.01.31 15:23:55 - Connection terminated.. 2017.01.31 15:23:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:23:55 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:23:58 - Checking authorization ...! 2017.01.31 15:23:58 - Connecting to Asellus (Netherlands, Alblasserdam). 2017.01.31 15:23:58 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:23:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:23:58 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:23:58 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:58 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:58 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:23:58 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:23:58 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.19:443. 2017.01.31 15:23:58 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.19:443, sid=0963c419 cf251520. 2017.01.31 15:23:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:23:58 - OpenVPN > Validating certificate key usage. 2017.01.31 15:23:58 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:23:58 - OpenVPN > VERIFY KU OK. 2017.01.31 15:23:58 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:23:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:23:58 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:23:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:23:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:59 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:23:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.19:443. 2017.01.31 15:24:01 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:24:01 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.62.1 255.255.0.0'. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:24:01 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:24:01 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:24:01 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:24:01 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:24:01 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:24:01 - OpenVPN > /sbin/ip addr add dev tun0 10.4.62.1/16 broadcast 10.4.255.255. 2017.01.31 15:24:07 - OpenVPN > /sbin/ip route add 109.202.107.19/32 via 192.168.1.1. 2017.01.31 15:24:07 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:24:07 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:24:07 - Starting Management Interface. 2017.01.31 15:24:07 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:24:07 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:24:07 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:24:07 - Checking routeE 2017.01.31 15:24:07 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:24:07 - Checking route (2° try)E 2017.01.31 15:24:08 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:24:08 - Checking route (3° try)E 2017.01.31 15:24:10 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:24:10 - Routing checking failed.. 2017.01.31 15:24:10 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:24:10 - Disconnecting. 2017.01.31 15:24:10 - Management - Send 'signal SIGTERM'. 2017.01.31 15:24:10 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:24:10 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:24:10 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:24:15 - OpenVPN > /sbin/ip route del 109.202.107.19/32. 2017.01.31 15:24:15 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:24:15 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:24:15 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:24:15 - OpenVPN > /sbin/ip addr del dev tun0 10.4.62.1/16. 2017.01.31 15:24:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:24:15 - Connection terminated.. 2017.01.31 15:24:15 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:24:19 - Checking authorization ...! 2017.01.31 15:24:19 - Connecting to Alcyone (Netherlands, Alblasserdam). 2017.01.31 15:24:19 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:24:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:24:19 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:24:19 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:24:19 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:24:19 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:24:19 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:24:19 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.116:443. 2017.01.31 15:24:19 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.116:443, sid=b86a3f9d 24c4df60. 2017.01.31 15:24:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:24:19 - OpenVPN > Validating certificate key usage. 2017.01.31 15:24:19 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:24:19 - OpenVPN > VERIFY KU OK. 2017.01.31 15:24:19 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:24:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:24:19 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:24:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:24:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:24:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:24:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:24:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:24:19 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:24:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.116:443. 2017.01.31 15:24:21 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:24:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.98.11 255.255.0.0'. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:24:21 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:24:21 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:24:21 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:24:21 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:24:22 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:24:22 - OpenVPN > /sbin/ip addr add dev tun0 10.4.98.11/16 broadcast 10.4.255.255 I am guessing that it is a problem my end and not with Airvpn. any help would be appreciated. lemontree10 Share this post Link to post
LZ1 685 Posted ... Hello! You need to edit your post. There's no logfile . Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
lemontree10 2 Posted ... Logfile fixed sorry for the mix up in the first post. lemontree10 Share this post Link to post
LZ1 685 Posted ... Which client version are you using?You can try to switch to the TCP protocol and turn off checking route, in Eddie. Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
lemontree10 2 Posted ... I am using the up to date Eddie Client 2.11.15 lemontree10 Share this post Link to post
Staff 10687 Posted ... After reinstalling Kubuntu 14.04 and reinstalling the updated Eddie Client today i find that the software is unable to connect to any servers as it appears that it is going through the list of servers from start to finish, as it gets an error message when connecting it trys the next one on the list with the same result, I have pasted the log file I saved into the following spoiler. 2017.01.31 15:21:58 - OpenVPN > /sbin/ip route add 213.152.162.78/32 via 192.168.1.1. 2017.01.31 15:21:58 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:21:58 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:21:58 - Starting Management Interface. 2017.01.31 15:21:58 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:21:58 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:21:58 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:21:58 - Checking routeE 2017.01.31 15:21:58 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:21:58 - Checking route (2° try)E 2017.01.31 15:21:59 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:21:59 - Checking route (3° try)E 2017.01.31 15:22:02 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:22:02 - Routing checking failed.. 2017.01.31 15:22:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:22:02 - Disconnecting. 2017.01.31 15:22:02 - Management - Send 'signal SIGTERM'. 2017.01.31 15:22:02 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:22:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:22:02 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:22:07 - OpenVPN > /sbin/ip route del 213.152.162.78/32. 2017.01.31 15:22:07 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:22:07 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:22:07 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:22:07 - OpenVPN > /sbin/ip addr del dev tun0 10.4.99.234/16. 2017.01.31 15:22:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:22:07 - Connection terminated.. 2017.01.31 15:22:07 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:22:10 - Checking authorization ...! 2017.01.31 15:22:11 - Connecting to Alzirr (Netherlands, Alblasserdam). 2017.01.31 15:22:11 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:22:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:22:11 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:22:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:11 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:22:11 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:22:11 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.14:443. 2017.01.31 15:22:11 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.14:443, sid=1eed87ad ed47d93b. 2017.01.31 15:22:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:22:11 - OpenVPN > Validating certificate key usage. 2017.01.31 15:22:11 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:22:11 - OpenVPN > VERIFY KU OK. 2017.01.31 15:22:11 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:22:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:22:11 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:22:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:22:11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:11 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:11 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:11 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:22:11 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.14:443. 2017.01.31 15:22:13 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:22:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.64.4 255.255.0.0'. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:22:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:22:13 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:22:13 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:22:13 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:22:13 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:22:13 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:22:13 - OpenVPN > /sbin/ip addr add dev tun0 10.4.64.4/16 broadcast 10.4.255.255. 2017.01.31 15:22:18 - OpenVPN > /sbin/ip route add 109.202.107.14/32 via 192.168.1.1. 2017.01.31 15:22:18 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:22:18 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:22:18 - Starting Management Interface. 2017.01.31 15:22:18 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:22:18 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:22:18 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:22:18 - Checking routeE 2017.01.31 15:22:18 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:22:18 - Checking route (2° try)E 2017.01.31 15:22:19 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:22:19 - Checking route (3° try)E 2017.01.31 15:22:22 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:22:22 - Routing checking failed.. 2017.01.31 15:22:22 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:22:22 - Disconnecting. 2017.01.31 15:22:22 - Management - Send 'signal SIGTERM'. 2017.01.31 15:22:22 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:22:22 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:22:22 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:22:27 - OpenVPN > /sbin/ip route del 109.202.107.14/32. 2017.01.31 15:22:27 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:22:27 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:22:27 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:22:27 - OpenVPN > /sbin/ip addr del dev tun0 10.4.64.4/16. 2017.01.31 15:22:27 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:22:27 - Connection terminated.. 2017.01.31 15:22:27 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:22:30 - Checking authorization ...! 2017.01.31 15:22:30 - Connecting to Hyadum (Netherlands, Alblasserdam). 2017.01.31 15:22:30 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:22:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:22:30 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:22:30 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:30 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:30 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:22:30 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:22:30 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443. 2017.01.31 15:22:30 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=6065636a ad1a2422. 2017.01.31 15:22:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:22:31 - OpenVPN > Validating certificate key usage. 2017.01.31 15:22:31 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:22:31 - OpenVPN > VERIFY KU OK. 2017.01.31 15:22:31 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:22:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:22:31 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:22:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:22:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:31 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:22:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443. 2017.01.31 15:22:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:22:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.99.186 255.255.0.0'. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:22:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:22:33 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:22:33 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:22:33 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:22:33 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:22:33 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:22:33 - OpenVPN > /sbin/ip addr add dev tun0 10.4.99.186/16 broadcast 10.4.255.255. 2017.01.31 15:22:38 - OpenVPN > /sbin/ip route add 213.152.161.34/32 via 192.168.1.1. 2017.01.31 15:22:38 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:22:38 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:22:39 - Starting Management Interface. 2017.01.31 15:22:39 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:22:39 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:22:39 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:22:39 - Checking routeE 2017.01.31 15:22:39 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:22:39 - Checking route (2° try)E 2017.01.31 15:22:40 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:22:40 - Checking route (3° try)E 2017.01.31 15:22:42 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:22:42 - Routing checking failed.. 2017.01.31 15:22:42 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:22:42 - Disconnecting. 2017.01.31 15:22:42 - Management - Send 'signal SIGTERM'. 2017.01.31 15:22:42 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:22:42 - OpenVpn Management > SUCCESS: signal SIGTERM thrown. 2017.01.31 15:22:42 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:22:42 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:22:47 - OpenVPN > /sbin/ip route del 213.152.161.34/32. 2017.01.31 15:22:47 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:22:47 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:22:47 - Connection terminated.. 2017.01.31 15:22:47 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:22:47 - DNS of the system restored to original settings (Rename method). 2017.01.31 15:22:47 - OpenVPN > /sbin/ip addr del dev tun0 10.4.99.186/16. 2017.01.31 15:22:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exitingI 2017.01.31 15:22:51 - Checking authorization ...! 2017.01.31 15:22:51 - Connecting to Gianfar (Netherlands, Alblasserdam). 2017.01.31 15:22:51 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:22:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:22:51 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:22:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:51 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:22:51 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:22:51 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.100:443. 2017.01.31 15:22:51 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.100:443, sid=1a861762 e5b652cd. 2017.01.31 15:22:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:22:51 - OpenVPN > Validating certificate key usage. 2017.01.31 15:22:51 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:22:51 - OpenVPN > VERIFY KU OK. 2017.01.31 15:22:51 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:22:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:22:51 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:22:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:22:54 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:54 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:54 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:22:54 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:22:54 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:22:54 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.100:443. 2017.01.31 15:22:56 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:22:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.100.85 255.255.0.0'. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:22:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:22:56 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:22:56 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:22:56 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:22:56 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:22:56 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:22:56 - OpenVPN > /sbin/ip addr add dev tun0 10.4.100.85/16 broadcast 10.4.255.255. 2017.01.31 15:23:01 - OpenVPN > /sbin/ip route add 213.152.161.100/32 via 192.168.1.1. 2017.01.31 15:23:01 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:01 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:01 - Starting Management Interface. 2017.01.31 15:23:01 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:23:01 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:23:02 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:23:02 - Checking routeE 2017.01.31 15:23:02 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:02 - Checking route (2° try)E 2017.01.31 15:23:03 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:03 - Checking route (3° try)E 2017.01.31 15:23:05 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:23:05 - Routing checking failed.. 2017.01.31 15:23:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:23:05 - Disconnecting. 2017.01.31 15:23:05 - Management - Send 'signal SIGTERM'. 2017.01.31 15:23:05 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:23:05 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:23:05 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:23:10 - OpenVPN > /sbin/ip route del 213.152.161.100/32. 2017.01.31 15:23:11 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:23:11 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:23:11 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:23:11 - OpenVPN > /sbin/ip addr del dev tun0 10.4.100.85/16. 2017.01.31 15:23:11 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:23:11 - Connection terminated.. 2017.01.31 15:23:11 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:23:14 - Checking authorization ...! 2017.01.31 15:23:14 - Connecting to Zibal (Netherlands, Alblasserdam). 2017.01.31 15:23:14 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:23:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:23:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:23:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:14 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:23:14 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:23:14 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.148:443. 2017.01.31 15:23:14 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.148:443, sid=898ef960 b3b442d0. 2017.01.31 15:23:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:23:15 - OpenVPN > Validating certificate key usage. 2017.01.31 15:23:15 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:23:15 - OpenVPN > VERIFY KU OK. 2017.01.31 15:23:15 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:23:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:23:15 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:23:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:23:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:17 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:23:17 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.148:443. 2017.01.31 15:23:19 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:23:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.100.146 255.255.0.0'. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:23:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:23:19 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:23:19 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:23:19 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:23:19 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:23:20 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:23:20 - OpenVPN > /sbin/ip addr add dev tun0 10.4.100.146/16 broadcast 10.4.255.255. 2017.01.31 15:23:24 - OpenVPN > /sbin/ip route add 213.152.161.148/32 via 192.168.1.1. 2017.01.31 15:23:24 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:24 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:24 - Starting Management Interface. 2017.01.31 15:23:24 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:23:24 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:23:24 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:23:24 - Checking routeE 2017.01.31 15:23:24 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:24 - Checking route (2° try)E 2017.01.31 15:23:25 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:25 - Checking route (3° try)E 2017.01.31 15:23:27 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:23:27 - Routing checking failed.. 2017.01.31 15:23:27 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:23:27 - Disconnecting. 2017.01.31 15:23:27 - Management - Send 'signal SIGTERM'. 2017.01.31 15:23:27 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:23:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:23:27 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:23:32 - OpenVPN > /sbin/ip route del 213.152.161.148/32. 2017.01.31 15:23:32 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:23:32 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:23:32 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:23:32 - Connection terminated.. 2017.01.31 15:23:32 - OpenVPN > /sbin/ip addr del dev tun0 10.4.100.146/16. 2017.01.31 15:23:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:23:32 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:23:35 - Checking authorization ...! 2017.01.31 15:23:35 - Connecting to Pleione (Netherlands, Alblasserdam). 2017.01.31 15:23:35 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:23:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:23:36 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:23:36 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:36 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:36 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:23:36 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:23:36 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.148:443. 2017.01.31 15:23:36 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.148:443, sid=0b715930 45b0adf1. 2017.01.31 15:23:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:23:36 - OpenVPN > Validating certificate key usage. 2017.01.31 15:23:36 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:23:36 - OpenVPN > VERIFY KU OK. 2017.01.31 15:23:36 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:23:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:23:36 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:23:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:23:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:38 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:23:38 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.148:443. 2017.01.31 15:23:40 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:23:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.87.11 255.255.0.0'. 2017.01.31 15:23:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:23:41 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:23:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:23:41 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:23:41 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:23:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:23:41 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:23:41 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:23:41 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:23:41 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:23:41 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:23:41 - OpenVPN > /sbin/ip addr add dev tun0 10.4.87.11/16 broadcast 10.4.255.255. 2017.01.31 15:23:45 - OpenVPN > /sbin/ip route add 213.152.162.148/32 via 192.168.1.1. 2017.01.31 15:23:45 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:45 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:23:45 - Starting Management Interface. 2017.01.31 15:23:45 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:23:45 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:23:45 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:23:45 - Checking routeE 2017.01.31 15:23:45 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:45 - Checking route (2° try)E 2017.01.31 15:23:46 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:23:46 - Checking route (3° try)E 2017.01.31 15:23:49 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:23:49 - Routing checking failed.. 2017.01.31 15:23:49 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:23:49 - Disconnecting. 2017.01.31 15:23:49 - Management - Send 'signal SIGTERM'. 2017.01.31 15:23:49 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:23:49 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:23:49 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:23:54 - OpenVPN > /sbin/ip route del 213.152.162.148/32. 2017.01.31 15:23:54 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:23:54 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:23:55 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:23:55 - OpenVPN > /sbin/ip addr del dev tun0 10.4.87.11/16. 2017.01.31 15:23:55 - Connection terminated.. 2017.01.31 15:23:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:23:55 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:23:58 - Checking authorization ...! 2017.01.31 15:23:58 - Connecting to Asellus (Netherlands, Alblasserdam). 2017.01.31 15:23:58 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:23:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:23:58 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:23:58 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:58 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:58 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:23:58 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:23:58 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.19:443. 2017.01.31 15:23:58 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.19:443, sid=0963c419 cf251520. 2017.01.31 15:23:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:23:58 - OpenVPN > Validating certificate key usage. 2017.01.31 15:23:58 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:23:58 - OpenVPN > VERIFY KU OK. 2017.01.31 15:23:58 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:23:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:23:58 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:23:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:23:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:23:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:23:59 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:23:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.19:443. 2017.01.31 15:24:01 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:24:01 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.62.1 255.255.0.0'. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:24:01 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:24:01 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:24:01 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:24:01 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:24:01 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:24:01 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:24:01 - OpenVPN > /sbin/ip addr add dev tun0 10.4.62.1/16 broadcast 10.4.255.255. 2017.01.31 15:24:07 - OpenVPN > /sbin/ip route add 109.202.107.19/32 via 192.168.1.1. 2017.01.31 15:24:07 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.31 15:24:07 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.31 15:24:07 - Starting Management Interface. 2017.01.31 15:24:07 - OpenVPN > Initialization Sequence Completed. 2017.01.31 15:24:07 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup. 2017.01.31 15:24:07 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)I 2017.01.31 15:24:07 - Checking routeE 2017.01.31 15:24:07 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:24:07 - Checking route (2° try)E 2017.01.31 15:24:08 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure. 2017.01.31 15:24:08 - Checking route (3° try)E 2017.01.31 15:24:10 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailureE 2017.01.31 15:24:10 - Routing checking failed.. 2017.01.31 15:24:10 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100! 2017.01.31 15:24:10 - Disconnecting. 2017.01.31 15:24:10 - Management - Send 'signal SIGTERM'. 2017.01.31 15:24:10 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.31 15:24:10 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.31 15:24:10 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.31 15:24:15 - OpenVPN > /sbin/ip route del 109.202.107.19/32. 2017.01.31 15:24:15 - OpenVPN > /sbin/ip route del 0.0.0.0/1. 2017.01.31 15:24:15 - OpenVPN > /sbin/ip route del 128.0.0.0/1. 2017.01.31 15:24:15 - OpenVPN > Closing TUN/TAP interface. 2017.01.31 15:24:15 - OpenVPN > /sbin/ip addr del dev tun0 10.4.62.1/16. 2017.01.31 15:24:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.31 15:24:15 - Connection terminated.. 2017.01.31 15:24:15 - DNS of the system restored to original settings (Rename method)I 2017.01.31 15:24:19 - Checking authorization ...! 2017.01.31 15:24:19 - Connecting to Alcyone (Netherlands, Alblasserdam). 2017.01.31 15:24:19 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec 1 2014. 2017.01.31 15:24:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.01.31 15:24:19 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.31 15:24:19 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:24:19 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:24:19 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]. 2017.01.31 15:24:19 - OpenVPN > UDPv4 link local: [undef]. 2017.01.31 15:24:19 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.116:443. 2017.01.31 15:24:19 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.116:443, sid=b86a3f9d 24c4df60. 2017.01.31 15:24:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.31 15:24:19 - OpenVPN > Validating certificate key usage. 2017.01.31 15:24:19 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.31 15:24:19 - OpenVPN > VERIFY KU OK. 2017.01.31 15:24:19 - OpenVPN > Validating certificate extended key usage. 2017.01.31 15:24:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.31 15:24:19 - OpenVPN > VERIFY EKU OK. 2017.01.31 15:24:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.31 15:24:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:24:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:24:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.31 15:24:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.31 15:24:19 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2017.01.31 15:24:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.116:443. 2017.01.31 15:24:21 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.31 15:24:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.98.11 255.255.0.0'. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.31 15:24:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.31 15:24:21 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=18:cf:5e:90:da:7f. 2017.01.31 15:24:21 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.31 15:24:21 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.31 15:24:21 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.31 15:24:22 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500. 2017.01.31 15:24:22 - OpenVPN > /sbin/ip addr add dev tun0 10.4.98.11/16 broadcast 10.4.255.255 I am guessing that it is a problem my end and not with Airvpn. any help would be appreciated. lemontree10 Hello! Can you please send us the output of the command:sudo iptables-save issued just after the problem has occurred? Kind regards Share this post Link to post
lemontree10 2 Posted ... HiHere is the requested iptable-save hope it helps. I have tried to connect again this evening and still having the same problem, so this is the iptables from this latest attempt to connect. Chain INPUT (policy ACCEPT)target prot opt source destinationChain FORWARD (policy ACCEPT)target prot opt source destinationChain OUTPUT (policy ACCEPT)target prot opt source destination-HP-15-Notebook-PC:~$ sudo iptables-save# Generated by iptables-save v1.4.21 on Tue Jan 31 19:57:52 2017*filter:INPUT ACCEPT [3533:491462]:FORWARD ACCEPT [0:0]:OUTPUT ACCEPT [3595:256817]COMMIT# Completed on Tue Jan 31 19:57:52 2017 lemontree10 Share this post Link to post
Staff 10687 Posted ... Hello!Thank you very much. The problem is reproducible. Please let's continue here:https://airvpn.org/topic/21642-error-getting-response-stream-write-the-authentication-or-decryption-has-failed-sendfailure/ Kind regards Share this post Link to post
