gevero
ANSWERED Not connecting to several bittorrent trackers
I have issues connecting to several bittorrent trackers, using Virginis Server. Some of the trackers are:
http://tracker.publichd.eu/announce
udp://tracker.1337x.org:80/announce
http://tracker.openbittorrent.com/announce
http://tracker.publicbt.com/announce
and also others...
only
http://fr33dom.h33t.com:3310/announce and http://exodus.desync.com/announce seem to be working
The error message from transmission is "Connection failed", "Could not connect to tracker"
Best Regards
Thank you for the information.
We need to investigate and check. In the meantime enable DHT+PEX, you really don't need trackers.
Probably I am mistaken but it was my understanding that I would get more peers with a Tracker+DHT+PEX configuration than with a DHT+PEX only configuration
Best Regards
no, don't worry. Torrent trackers are anyway useful for private services who need to quickly gather statistics and IP addresses (including copyright enforcement agencies - we remind you that such usage is strictly forbidden on our service according to the ToS), restrict the service according to seed/leech ratios, restrict the service to members and similar cases.
Brief update. Now I can connect to no tracker at all...this is a bit annoying.
Best Regards
first of all you should take note that the first three trackers you cite are no more working in http since a long ago, they only work in udp (for a very good reason). Actually, apart from the fact that using a tracker does not make any sense except for very special needs, there is not much sense in running an http tracker, due to efficiency reasons.
We have checked the three trackers you reported as non-working in your first message right now (BUT in udp, of course) and we confirm they are perfectly reachable and working from Virginis.
About "fr33dom" we don't know if it's still available in http, anyway an udp check was fully successful. It might be that the tracker is temporarily unavailable in http, or maybe it does not support http anymore, we don't know.
The problem is therefore non-existent, we mark this thread solved but do not hesitate to contact us for any further information or issue.
