mith_y2k 6 Posted ... I installed V1 of the Eddie client for Android on my Fire TV. I also activated an ovpn file. I kept the default configuration plus a whitelist of just a couple of apps to test. The client starts normally and connects, I can see in the little stats box that there is some minimum traffic, but after a few seconds, probably 30 or 60 at most it says the VPN tunnel has been locked. When I look in the logs it says there was an error and that it changed state to Lock VPN. I think it says it's event 14. The only way to get out of the lock is to disconnect and reconnect, but a few seconds later the error happens again. For what it's worth I use this other client successfully: http://plai.de/android/ Being a fire tv I'm not even sure how to export full logs. Any ideas? Quote Share this post Link to post
Staff 9762 Posted ... Hello! Can you please send us Eddie log taken just after one of those errors occurred? What is the Android version of your FireTV? Kind regards Quote Share this post Link to post
