MortenM 3 Posted ... Hi, I have recently been unable to connect to any airvpn servers with the network lock enabled. Any Suggestions? Win 7 pro.Example;I 2018.07.27 12:50:47 - AirVPN client version: 2.8.8, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Architecture: x86. 2018.07.27 12:50:47 - Reading options from C:\Users\Morten\AppData\Local\AirVPN\AirVPN.xml. 2018.07.27 12:50:48 - Data Path: C:\Users\Morten\AppData\Local\AirVPN. 2018.07.27 12:50:48 - App Path: C:\Program Files\AirVPN. 2018.07.27 12:50:48 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2018.07.27 12:50:48 - Command line arguments (1): path="home". 2018.07.27 12:50:48 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1I 2018.07.27 12:50:48 - OpenVPN Driver - TAP-Windows Adapter V9I 2018.07.27 12:50:48 - OpenVPN - Version: OpenVPN 2.3.6 (C:\Program Files\AirVPN\openvpn.exe)I 2018.07.27 12:50:48 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2018.07.27 12:50:48 - SSL - Version: stunnel 5.09 (C:\Program Files\AirVPN\stunnel.exe)I 2018.07.27 12:50:48 - IPV6: Available! 2018.07.27 12:50:48 - Activation of Network Lock - Windows Firewall! 2018.07.27 12:50:50 - ReadyI 2018.07.27 12:51:36 - Session starting.I 2018.07.27 12:51:36 - Installing tunnel driverI 2018.07.27 12:51:37 - Checking authorization .... 2018.07.27 12:51:37 - Checking authorization ..., 1° try failed (Kan ikke koble til den eksterne serveren). 2018.07.27 12:51:37 - Checking authorization ..., 2° try failed (Kan ikke koble til den eksterne serveren). 2018.07.27 12:51:37 - Checking authorization ..., 3° try failed (Kan ikke koble til den eksterne serveren). 2018.07.27 12:51:37 - Checking authorization ..., 4° try failed (Kan ikke koble til den eksterne serveren)W 2018.07.27 12:51:37 - Authorization check failed, continue anyway ({1])! 2018.07.27 12:51:37 - Connecting to Ain (Sweden, Stockholm). 2018.07.27 12:51:37 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015. 2018.07.27 12:51:37 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08. 2018.07.27 12:51:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.07.27 12:51:38 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2018.07.27 12:51:38 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.07.27 12:51:38 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.07.27 12:51:38 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]. 2018.07.27 12:51:38 - OpenVPN > UDPv4 link local: [undef]. 2018.07.27 12:51:38 - OpenVPN > UDPv4 link remote: [AF_INET]128.127.104.79:443. 2018.07.27 12:52:10 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2018.07.27 12:52:10 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.07.27 12:52:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2018.07.27 12:52:15 - Disconnecting. 2018.07.27 12:52:15 - Connection terminated.I 2018.07.27 12:52:18 - Checking authorization .... 2018.07.27 12:52:18 - Checking authorization ..., 1° try failed (Kan ikke koble til den eksterne serveren). 2018.07.27 12:52:18 - Checking authorization ..., 2° try failed (Kan ikke koble til den eksterne serveren). 2018.07.27 12:52:18 - Checking authorization ..., 3° try failed (Kan ikke koble til den eksterne serveren). 2018.07.27 12:52:18 - Checking authorization ..., 4° try failed (Kan ikke koble til den eksterne serveren)W 2018.07.27 12:52:18 - Authorization check failed, continue anyway ({1])! 2018.07.27 12:52:18 - Connecting to Tarazed (Netherlands, Alblasserdam). 2018.07.27 12:52:19 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015. 2018.07.27 12:52:19 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08. 2018.07.27 12:52:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.07.27 12:52:19 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2018.07.27 12:52:19 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.07.27 12:52:19 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.07.27 12:52:19 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]. 2018.07.27 12:52:19 - OpenVPN > UDPv4 link local: [undef]. 2018.07.27 12:52:19 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.132:443. 2018.07.27 12:52:51 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2018.07.27 12:52:51 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.07.27 12:52:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2018.07.27 12:52:56 - Disconnecting. 2018.07.27 12:52:56 - Connection terminated.I 2018.07.27 12:52:59 - Checking authorization .... 2018.07.27 12:52:59 - Checking authorization ..., 1° try failed (Kan ikke koble til den eksterne serveren). 2018.07.27 12:52:59 - Checking authorization ..., 2° try failed (Kan ikke koble til den eksterne serveren). 2018.07.27 12:52:59 - Checking authorization ..., 3° try failed (Kan ikke koble til den eksterne serveren). 2018.07.27 12:52:59 - Checking authorization ..., 4° try failed (Kan ikke koble til den eksterne serveren)W 2018.07.27 12:52:59 - Authorization check failed, continue anyway ({1])! 2018.07.27 12:52:59 - Connecting to Tarazed (Netherlands, Alblasserdam). 2018.07.27 12:52:59 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015. 2018.07.27 12:52:59 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08. 2018.07.27 12:52:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.07.27 12:52:59 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2018.07.27 12:52:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.07.27 12:52:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.07.27 12:52:59 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]. 2018.07.27 12:52:59 - OpenVPN > UDPv4 link local: [undef]. 2018.07.27 12:52:59 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.132:443. 2018.07.27 12:53:31 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2018.07.27 12:53:31 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.07.27 12:53:36 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2018.07.27 12:53:36 - Disconnecting. 2018.07.27 12:53:36 - Connection terminated.I 2018.07.27 12:53:37 - Cancel requested.! 2018.07.27 12:53:37 - Session terminated.! 2018.07.27 12:53:51 - Deactivation of Network Lock Quote Share this post Link to post
Staff 9764 Posted ... Hello! Your Eddie version (2.8.8) was released in 2015 so it's time to upgrade. It's possible that latest Eddie version resolves the problem, but if not please feel free to open a ticket. Latest Eddie stable release for Windows can be downloaded here:https://airvpn.org/windows Kind regards Quote Share this post Link to post
MortenM 3 Posted ... Seems like that solved the problem!Thank You! Quote Share this post Link to post
