Melcaly 0 Posted ... I have Eddie set to the following: Connect at startupStart with WindowsActivate Network Lock at startup However, I'm finding that the Network Lock isn't working at startup. There's a delay before Eddie starts up and I'm able to access the internet. Any solutions? Quote Share this post Link to post
go558a83nk 352 Posted ... I have Eddie set to the following: Connect at startupStart with WindowsActivate Network Lock at startup However, I'm finding that the Network Lock isn't working at startup. There's a delay before Eddie starts up and I'm able to access the internet. Any solutions? network lock can't turn on until Eddie starts up. if you really must not have any network activity outside the VPN tunnel then turn off your wifi or unplug your ethernet until Eddie is running and network lock is activated. Quote Share this post Link to post
Melcaly 0 Posted ... I have Eddie set to the following: Connect at startupStart with WindowsActivate Network Lock at startup However, I'm finding that the Network Lock isn't working at startup. There's a delay before Eddie starts up and I'm able to access the internet. Any solutions? network lock can't turn on until Eddie starts up. if you really must not have any network activity outside the VPN tunnel then turn off your wifi or unplug your ethernet until Eddie is running and network lock is activated. Will do. My primary concern was my torrent client starting up with Windows, but I've switched that setting off. Thanks! Quote Share this post Link to post
LZ1 662 Posted ... I have Eddie set to the following: Connect at startupStart with WindowsActivate Network Lock at startup However, I'm finding that the Network Lock isn't working at startup. There's a delay before Eddie starts up and I'm able to access the internet. Any solutions? network lock can't turn on until Eddie starts up. if you really must not have any network activity outside the VPN tunnel then turn off your wifi or unplug your ethernet until Eddie is running and network lock is activated. Will do. My primary concern was my torrent client starting up with Windows, but I've switched that setting off. Thanks!Hello! If I'm not mistaken, that can be mitigated by binding the torrent client in question - I'm thinking of qBittorent here - to a tun0 interface. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
