tranquivox69 39 Posted ... Unless I'm mistaken (and I'd gladly be), if I connect with a second client (smartphone, for instance) portforwarding stops working. This is what I've experienced at least. Would it be possible to keep port forwarding working bound to a specific client somehow? Quote Share this post Link to post
zhang888 1067 Posted ... The reserved ports are forwarded to your internal (10.x) tunneled IP address, which you get after you connect.If you have multiple devices, there will be a little race condition in terms of which IP should "receive" the connectionson your forwarded port. Since forwarding the same port to multiple IPs does not make sense, there is no way forAir to know to which IP you actually want to receive your connections. Anything beyond that would require additional logging - for example: a table of premium users, their internal IPs anddesired ports, on each server.Usually premium users who forward ports use routers and do not use more than 1 connections, since individual devicesare behind NAT in most cases, so port forwarding on them is an additional challenge. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
Staff 10721 Posted ... Unless I'm mistaken (and I'd gladly be), if I connect with a second client (smartphone, for instance) portforwarding stops working. This is what I've experienced at least. Would it be possible to keep port forwarding working bound to a specific client somehow? Please make sure to connect each device to a different VPN server to prevent any conflict or race condition in packets forwarding. Kind regards Quote Share this post Link to post
wbynum 3 Posted ... Has AirVPN implemented any option to prevent multiple clients from connecting to the same server when using "Connect to a recommended server" in Eddie or when using a country/continent endpoint from the configurator page? Seems like this could be implemented at AirVPN's end without additional info/logging since AirVPN knows what servers a given account is connected to at any given time, as seen in the "Overview" page in the client area of the website. Quote Share this post Link to post
Staff 10721 Posted ... Has AirVPN implemented any option to prevent multiple clients from connecting to the same server when using "Connect to a recommended server" in Eddie or when using a country/continent endpoint from the configurator page? Seems like this could be implemented at AirVPN's end without additional info/logging since AirVPN knows what servers a given account is connected to at any given time, as seen in the "Overview" page in the client area of the website. We approached the problem differently. Instead of limitations you now have additional options. Please see here:https://airvpn.org/topic/26209-how-to-manage-client-certificatekey-pairs/ Kind regards Quote Share this post Link to post
wbynum 3 Posted ... Has AirVPN implemented any option to prevent multiple clients from connecting to the same server when using "Connect to a recommended server" in Eddie or when using a country/continent endpoint from the configurator page? Seems like this could be implemented at AirVPN's end without additional info/logging since AirVPN knows what servers a given account is connected to at any given time, as seen in the "Overview" page in the client area of the website. We approached the problem differently. Instead of limitations you now have additional options. Please see here:https://airvpn.org/topic/26209-how-to-manage-client-certificatekey-pairs/ Kind regards Thanks you for the info. I have setup a different key for each of my devices. I am unclear on how this works with port forwarding though. Can you please explain. Quote Share this post Link to post
go558a83nk 389 Posted ... Has AirVPN implemented any option to prevent multiple clients from connecting to the same server when using "Connect to a recommended server" in Eddie or when using a country/continent endpoint from the configurator page? Seems like this could be implemented at AirVPN's end without additional info/logging since AirVPN knows what servers a given account is connected to at any given time, as seen in the "Overview" page in the client area of the website. We approached the problem differently. Instead of limitations you now have additional options. Please see here:https://airvpn.org/topic/26209-how-to-manage-client-certificatekey-pairs/ Kind regards Thanks you for the info. I have setup a different key for each of my devices. I am unclear on how this works with port forwarding though. Can you please explain. You had a mini-necro bump there so I think Staff were not replying regarding port fowarding but only regarding what you had in your post, which doesn't mention port forwarding. Quote Share this post Link to post
