Not connected, Your IP: 216.73.216.183
notinmylifetime
air vpn not working with mac ethernet connection
hello
i have been using air vpn with wifi and have no issues
when i try to connect with ethernet (no wifi) it seems to work, but i get readings of 0bit/s u and d
any idea why this is happening or how to optimize?
my ethernet is much faster than wifi and i would prefer to have it set up this way
I 2017.04.15 01:53:03 - Eddie client version: 2.12.4 / macos_x64, System: MacOS, Name: 10.9.5, Mono/.Net Framework: v4.0.30319
. 2017.04.15 01:53:03 - Reading options from /Users/lucasmascatello/.airvpn/AirVPN.xml
. 2017.04.15 01:53:04 - Data path: /Users/lucasmascatello/.airvpn
. 2017.04.15 01:53:04 - Application path: /Applications/Eddie.app/Contents/MacOS
. 2017.04.15 01:53:04 - Executable path: /Applications/Eddie.app/Contents/MacOS/Eddie
. 2017.04.15 01:53:04 - Command line arguments (0):
. 2017.04.15 01:53:04 - Operating System: Unix 13.4.0.0 - Darwin Lucass-MacBook-Pro.local 13.4.0 Darwin Kernel Version 13.4.0: Sun Aug 17 19:50:11 PDT 2014; root:xnu-2422.115.4~1/RELEASE_X86_64 x86_64
I 2017.04.15 01:53:04 - OpenVPN Driver - Expected
I 2017.04.15 01:53:04 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09 (/Applications/Eddie.app/Contents/MacOS/openvpn)
I 2017.04.15 01:53:04 - SSH - Version: OpenSSH_6.2p2, OSSLShim 0.9.8r 8 Dec 2011 (/usr/bin/ssh)
I 2017.04.15 01:53:04 - SSL - Version: stunnel 5.40 (/Applications/Eddie.app/Contents/MacOS/stunnel)
I 2017.04.15 01:53:04 - curl - Version: 7.30.0 (/usr/bin/curl)
I 2017.04.15 01:53:04 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/../Resources/cacert.pem
! 2017.04.15 01:53:04 - Ready
. 2017.04.15 01:53:04 - Updating systems & servers data ...
. 2017.04.15 01:53:05 - Systems & servers data update completed
I 2017.04.15 01:53:19 - Checking login ...
! 2017.04.15 01:53:19 - Logged in.
I 2017.04.15 01:53:23 - Session starting.
. 2017.04.15 01:53:23 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2017.04.15 01:53:23 - IPv6 disabled on network adapter (Ethernet)
. 2017.04.15 01:53:23 - IPv6 disabled on network adapter (FireWire)
. 2017.04.15 01:53:23 - IPv6 disabled on network adapter (Wi-Fi)
. 2017.04.15 01:53:23 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2017.04.15 01:53:24 - Checking authorization ...
! 2017.04.15 01:53:24 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2017.04.15 01:53:24 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.04.15 01:53:24 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.04.15 01:53:24 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.04.15 01:53:24 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.15 01:53:24 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.15 01:53:24 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.226:443
. 2017.04.15 01:53:24 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.04.15 01:53:24 - OpenVPN > UDP link local: (not bound)
. 2017.04.15 01:53:24 - OpenVPN > UDP link remote: [AF_INET]184.75.223.226:443
. 2017.04.15 01:53:24 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.226:443, sid=800a1be6 2329dd65
. 2017.04.15 01:53:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.04.15 01:53:24 - OpenVPN > Validating certificate key usage
. 2017.04.15 01:53:24 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.04.15 01:53:24 - OpenVPN > VERIFY KU OK
. 2017.04.15 01:53:24 - OpenVPN > Validating certificate extended key usage
. 2017.04.15 01:53:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.04.15 01:53:24 - OpenVPN > VERIFY EKU OK
. 2017.04.15 01:53:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.04.15 01:53:25 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.04.15 01:53:25 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.226:443
. 2017.04.15 01:53:26 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.04.15 01:53:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.83.131 255.255.0.0'
. 2017.04.15 01:53:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.04.15 01:53:26 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.04.15 01:53:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.04.15 01:53:26 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.04.15 01:53:26 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.04.15 01:53:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.04.15 01:53:26 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.15 01:53:26 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.15 01:53:26 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.15 01:53:26 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.15 01:53:26 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=en0 HWADDR=00:26:08:08:1f:d8
. 2017.04.15 01:53:26 - OpenVPN > Opened utun device utun0
. 2017.04.15 01:53:26 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.04.15 01:53:26 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.04.15 01:53:26 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.04.15 01:53:26 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.04.15 01:53:26 - OpenVPN > /sbin/ifconfig utun0 10.4.83.131 10.4.83.131 netmask 255.255.0.0 mtu 1500 up
. 2017.04.15 01:53:26 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.83.131 255.255.0.0
. 2017.04.15 01:53:26 - OpenVPN > add net 10.4.0.0: gateway 10.4.83.131
. 2017.04.15 01:53:26 - OpenVPN > /sbin/route add -net 184.75.223.226 192.168.0.1 255.255.255.255
. 2017.04.15 01:53:26 - OpenVPN > add net 184.75.223.226: gateway 192.168.0.1
. 2017.04.15 01:53:26 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.15 01:53:26 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.04.15 01:53:26 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.15 01:53:26 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.04.15 01:53:26 - Starting Management Interface
. 2017.04.15 01:53:26 - OpenVPN > Initialization Sequence Completed
. 2017.04.15 01:53:26 - DNS of a network adapter forced (Bluetooth DUN, from Automatic to 10.4.0.1)
. 2017.04.15 01:53:26 - DNS of a network adapter forced (Ethernet, from Automatic to 10.4.0.1)
. 2017.04.15 01:53:26 - DNS of a network adapter forced (FireWire, from Automatic to 10.4.0.1)
! 2017.04.15 01:53:26 - Disconnecting
. 2017.04.15 01:53:26 - Management - Send 'signal SIGTERM'
. 2017.04.15 01:53:26 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.04.15 01:53:26 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.4.0.1)
. 2017.04.15 01:53:27 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.4.0.1)
. 2017.04.15 01:53:27 - Flushing DNS
. 2017.04.15 01:53:27 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.04.15 01:53:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.04.15 01:53:27 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.04.15 01:53:31 - OpenVPN > /sbin/route delete -net 184.75.223.226 192.168.0.1 255.255.255.255
. 2017.04.15 01:53:31 - OpenVPN > delete net 184.75.223.226: gateway 192.168.0.1
. 2017.04.15 01:53:31 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.15 01:53:31 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.04.15 01:53:31 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.15 01:53:31 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.04.15 01:53:31 - OpenVPN > Closing TUN/TAP interface
. 2017.04.15 01:53:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.04.15 01:53:31 - Connection terminated.
. 2017.04.15 01:53:31 - DNS of a network adapter restored to original settings (Bluetooth DUN, to Automatic)
. 2017.04.15 01:53:31 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2017.04.15 01:53:31 - DNS of a network adapter restored to original settings (FireWire, to Automatic)
. 2017.04.15 01:53:31 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2017.04.15 01:53:31 - DNS of a network adapter restored to original settings (Bluetooth PAN, to Automatic)
I 2017.04.15 01:53:31 - Cancel requested.
. 2017.04.15 01:53:31 - IPv6 restored on network adapter (Bluetooth DUN)
. 2017.04.15 01:53:31 - IPv6 restored on network adapter (Ethernet)
. 2017.04.15 01:53:32 - IPv6 restored on network adapter (FireWire)
. 2017.04.15 01:53:32 - IPv6 restored on network adapter (Wi-Fi)
. 2017.04.15 01:53:32 - IPv6 restored on network adapter (Bluetooth PAN)
! 2017.04.15 01:53:32 - Session terminated.
I 2017.04.15 01:53:46 - Session starting.
. 2017.04.15 01:53:46 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2017.04.15 01:53:46 - IPv6 disabled on network adapter (Ethernet)
. 2017.04.15 01:53:47 - IPv6 disabled on network adapter (FireWire)
. 2017.04.15 01:53:47 - IPv6 disabled on network adapter (Wi-Fi)
. 2017.04.15 01:53:47 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2017.04.15 01:53:47 - Checking authorization ...
! 2017.04.15 01:53:47 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2017.04.15 01:53:47 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.04.15 01:53:47 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.04.15 01:53:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.04.15 01:53:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.15 01:53:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.15 01:53:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.226:443
. 2017.04.15 01:53:47 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.04.15 01:53:47 - OpenVPN > UDP link local: (not bound)
. 2017.04.15 01:53:47 - OpenVPN > UDP link remote: [AF_INET]184.75.223.226:443
. 2017.04.15 01:53:47 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.226:443, sid=4429dae8 9c58bb55
. 2017.04.15 01:53:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.04.15 01:53:48 - OpenVPN > Validating certificate key usage
. 2017.04.15 01:53:48 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.04.15 01:53:48 - OpenVPN > VERIFY KU OK
. 2017.04.15 01:53:48 - OpenVPN > Validating certificate extended key usage
. 2017.04.15 01:53:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.04.15 01:53:48 - OpenVPN > VERIFY EKU OK
. 2017.04.15 01:53:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.04.15 01:53:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.04.15 01:53:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.226:443
. 2017.04.15 01:53:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.04.15 01:53:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.83.131 255.255.0.0'
. 2017.04.15 01:53:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.04.15 01:53:49 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.04.15 01:53:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.04.15 01:53:49 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.04.15 01:53:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.04.15 01:53:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.04.15 01:53:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.15 01:53:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.15 01:53:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.15 01:53:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.15 01:53:49 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=en0 HWADDR=00:26:08:08:1f:d8
. 2017.04.15 01:53:49 - OpenVPN > Opened utun device utun0
. 2017.04.15 01:53:49 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.04.15 01:53:49 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.04.15 01:53:49 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.04.15 01:53:49 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.04.15 01:53:49 - OpenVPN > /sbin/ifconfig utun0 10.4.83.131 10.4.83.131 netmask 255.255.0.0 mtu 1500 up
. 2017.04.15 01:53:49 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.83.131 255.255.0.0
. 2017.04.15 01:53:49 - OpenVPN > add net 10.4.0.0: gateway 10.4.83.131
. 2017.04.15 01:53:49 - OpenVPN > /sbin/route add -net 184.75.223.226 192.168.0.1 255.255.255.255
. 2017.04.15 01:53:49 - OpenVPN > add net 184.75.223.226: gateway 192.168.0.1
. 2017.04.15 01:53:49 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.15 01:53:49 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.04.15 01:53:49 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.15 01:53:49 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.04.15 01:53:49 - Starting Management Interface
. 2017.04.15 01:53:49 - OpenVPN > Initialization Sequence Completed
. 2017.04.15 01:53:49 - DNS of a network adapter forced (Bluetooth DUN, from Automatic to 10.4.0.1)
. 2017.04.15 01:53:49 - DNS of a network adapter forced (Ethernet, from Automatic to 10.4.0.1)
. 2017.04.15 01:53:50 - DNS of a network adapter forced (FireWire, from Automatic to 10.4.0.1)
. 2017.04.15 01:53:50 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.4.0.1)
. 2017.04.15 01:53:50 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.4.0.1)
. 2017.04.15 01:53:50 - Flushing DNS
I 2017.04.15 01:53:50 - Checking route
I 2017.04.15 01:53:51 - Checking DNS
! 2017.04.15 01:53:51 - Connected.
. 2017.04.15 01:53:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.04.15 01:53:51 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
hello
I was having the the exact same problem except that I could connect via ethernet but not via wifi.
I was going to post a topic to see if anyone could figure out why but ended up solving it myself from the info under "Eddie can't connect or is very slow, what can I do?" found at https://airvpn.org/topic/18339-guide-to-getting-started-links-for-advanced-users/
Your problem might be that you are using manual entries for your ethernet settings instead of using the automatic "Using DHCP" (step 9 below).
This is what I did:
  1. On the Eddie AirVPN, clicked on "Disconnect"
  2. Disconnected my ethernet cable from my Mac (not sure if this was necessary but wanted to make sure I was only using Wi-Fi to connect)
  3. Opened my Mac's System Preferences.
  4. Clicked on "Network".
  5. Clicked on the "Turn Wi-Fi On" button.
  6. Selected my Wi-Fi network next to "Network Name".
  7. Clicked on the "Advanced" button.
  8. Clicked on the "TCP/IP" tab.
  9. Selected "Using DHCP" next to "Configure IPv4".
10. Clicked on the "DNS" tab.
11. Under "DNS Servers", click on the "+" button and entered "10.4.0.1".
12. Clicked the "OK" button.
13. Clicked on the "Apply" button on the bottom right hand side of the Network preference window.
On the Eddie AirVPN window, I was then able to choose a server and connect to it via Wi-Fi.
