Not connected, Your IP: 3.133.151.199
drummer45
Stuck at Checking Route...Again!
​I seem to be experiencing the same issue that plagued all mac OSX users a week or two ago with the Eddie client getting stuck at "checking route" before disconnecting into an endless loop. I've done the previous work around of disabling this check along with the dns check to use Eddie temporarily until this gets resolved again. Why is this still happening? It was working last night before I went to bed and when I woke up this issue, which was supposed to be fixed, had returned.
​I 2016.08.01 14:08:44 - AirVPN client version: 2.10.3 / x86, System: OSX, Name: 10.11.6 / x64
. 2016.08.01 14:08:44 - Reading options from /Users/drummer45/.airvpn/AirVPN.xml
. 2016.08.01 14:08:45 - Data Path: /Users/drummer45/.airvpn
. 2016.08.01 14:08:45 - App Path: /Applications/AirVPN.app/Contents/MacOS
. 2016.08.01 14:08:45 - Executable Path: /Applications/AirVPN.app/Contents/MacOS/AirVPN
. 2016.08.01 14:08:45 - Command line arguments (0):
. 2016.08.01 14:08:45 - Updating systems & servers data ...
. 2016.08.01 14:08:45 - Operating System: Unix 15.6.0.0 - Darwin d3aDp03T1c.local 15.6.0 Darwin Kernel Version 15.6.0: Thu Jun 23 18:25:34 PDT 2016; root:xnu-3248.60.10~1/RELEASE_X86_64 x86_64
I 2016.08.01 14:08:45 - OpenVPN Driver - Expected
I 2016.08.01 14:08:45 - OpenVPN - Version: OpenVPN 2.3.8 (/Applications/AirVPN.app/Contents/MacOS/openvpn)
I 2016.08.01 14:08:45 - SSH - Version: OpenSSH_6.9p1, LibreSSL 2.1.8 (/usr/bin/ssh)
I 2016.08.01 14:08:45 - SSL - Version: stunnel 5.17 (/Applications/AirVPN.app/Contents/MacOS/stunnel)
W 2016.08.01 14:08:45 - Recovery. Unexpected crash?
I 2016.08.01 14:08:45 - DNS of a network adapter restored to original settings (SAMSUNG_Android)
I 2016.08.01 14:08:45 - DNS of a network adapter restored to original settings (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 14:08:45 - DNS of a network adapter restored to original settings (SAMSUNG Modem)
I 2016.08.01 14:08:45 - DNS of a network adapter restored to original settings (Bluetooth DUN 2)
I 2016.08.01 14:08:45 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet)
I 2016.08.01 14:08:45 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.01 14:08:45 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.01 14:08:45 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.01 14:08:45 - IPv6 restored on network adapter (SAMSUNG_Android)
I 2016.08.01 14:08:45 - IPv6 restored on network adapter (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 14:08:45 - IPv6 restored on network adapter (SAMSUNG Modem)
I 2016.08.01 14:08:45 - IPv6 restored on network adapter (Bluetooth DUN 2)
I 2016.08.01 14:08:45 - IPv6 restored on network adapter (Thunderbolt Ethernet)
I 2016.08.01 14:08:45 - IPv6 restored on network adapter (Wi-Fi)
I 2016.08.01 14:08:45 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.08.01 14:08:45 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2016.08.01 14:08:45 - Session starting.
I 2016.08.01 14:08:45 - IPv6 disabled on network adapter (SAMSUNG_Android)
I 2016.08.01 14:08:45 - IPv6 disabled on network adapter (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 14:08:45 - IPv6 disabled on network adapter (SAMSUNG Modem)
. 2016.08.01 14:08:45 - Systems & servers data update completed
I 2016.08.01 14:08:45 - IPv6 disabled on network adapter (Bluetooth DUN 2)
I 2016.08.01 14:08:45 - IPv6 disabled on network adapter (Thunderbolt Ethernet)
I 2016.08.01 14:08:45 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.08.01 14:08:45 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.08.01 14:08:45 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.08.01 14:08:49 - Checking authorization ...
! 2016.08.01 14:08:50 - Connecting to Sargas (Canada, Toronto, Ontario)
. 2016.08.01 14:08:50 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.01 14:08:50 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.01 14:08:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107
. 2016.08.01 14:08:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.01 14:08:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:08:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:08:50 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.01 14:08:50 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.01 14:08:50 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.194:443
. 2016.08.01 14:08:50 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.194:443, sid=9d22ff19 b199ada3
. 2016.08.01 14:08:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.01 14:08:50 - OpenVPN > Validating certificate key usage
. 2016.08.01 14:08:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 14:08:50 - OpenVPN > VERIFY KU OK
. 2016.08.01 14:08:50 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 14:08:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 14:08:50 - OpenVPN > VERIFY EKU OK
. 2016.08.01 14:08:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.01 14:08:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 14:08:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:08:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 14:08:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:08:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.01 14:08:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.194:443
. 2016.08.01 14:08:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.01 14:08:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.115 255.255.0.0'
. 2016.08.01 14:08:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.01 14:08:52 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.01 14:08:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.01 14:08:52 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.01 14:08:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.01 14:08:52 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.01 14:08:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.01 14:08:52 - OpenVPN > Opened utun device utun0
. 2016.08.01 14:08:52 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.01 14:08:52 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.01 14:08:52 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.01 14:08:52 - OpenVPN > /sbin/ifconfig utun0 10.4.1.115 10.4.1.115 netmask 255.255.0.0 mtu 1500 up
. 2016.08.01 14:08:52 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.115 255.255.0.0
. 2016.08.01 14:08:52 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.115
. 2016.08.01 14:08:52 - OpenVPN > /sbin/route add -net 184.75.223.194 192.168.1.1 255.255.255.255
. 2016.08.01 14:08:52 - OpenVPN > add net 184.75.223.194: gateway 192.168.1.1
. 2016.08.01 14:08:52 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 14:08:52 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 14:08:53 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 14:08:53 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 14:08:53 - Starting Management Interface
. 2016.08.01 14:08:53 - OpenVPN > Initialization Sequence Completed
I 2016.08.01 14:08:53 - DNS of a network adapter forced (SAMSUNG_Android)
I 2016.08.01 14:08:53 - DNS of a network adapter forced (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 14:08:53 - DNS of a network adapter forced (SAMSUNG Modem)
I 2016.08.01 14:08:53 - DNS of a network adapter forced (Bluetooth DUN 2)
I 2016.08.01 14:08:53 - DNS of a network adapter forced (Thunderbolt Ethernet)
I 2016.08.01 14:08:53 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.01 14:08:53 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.01 14:08:53 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.01 14:08:53 - Flushing DNS
I 2016.08.01 14:08:53 - Checking route
W 2016.08.01 14:09:23 - The request timed out
! 2016.08.01 14:09:23 - Disconnecting
. 2016.08.01 14:09:23 - Management - Send 'signal SIGTERM'
. 2016.08.01 14:09:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.01 14:09:23 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.01 14:09:23 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.01 14:09:23 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.08.01 14:09:28 - OpenVPN > /sbin/route delete -net 184.75.223.194 192.168.1.1 255.255.255.255
. 2016.08.01 14:09:28 - OpenVPN > delete net 184.75.223.194: gateway 192.168.1.1
. 2016.08.01 14:09:28 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 14:09:28 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 14:09:28 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 14:09:28 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 14:09:28 - OpenVPN > Closing TUN/TAP interface
. 2016.08.01 14:09:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.01 14:09:28 - Connection terminated.
I 2016.08.01 14:09:28 - DNS of a network adapter restored to original settings (SAMSUNG_Android)
I 2016.08.01 14:09:28 - DNS of a network adapter restored to original settings (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 14:09:28 - DNS of a network adapter restored to original settings (SAMSUNG Modem)
I 2016.08.01 14:09:28 - DNS of a network adapter restored to original settings (Bluetooth DUN 2)
I 2016.08.01 14:09:28 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet)
I 2016.08.01 14:09:28 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.01 14:09:28 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.01 14:09:28 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.01 14:09:31 - Checking authorization ...
! 2016.08.01 14:09:32 - Connecting to Chara (Netherlands, Alblasserdam)
. 2016.08.01 14:09:32 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.01 14:09:32 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.01 14:09:32 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107
. 2016.08.01 14:09:32 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.01 14:09:32 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:09:32 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:09:32 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.01 14:09:32 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.01 14:09:32 - OpenVPN > UDPv4 link remote: [AF_INET]109.232.227.132:443
. 2016.08.01 14:09:32 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.132:443, sid=5934c05c 53c88743
. 2016.08.01 14:09:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.01 14:09:32 - OpenVPN > Validating certificate key usage
. 2016.08.01 14:09:32 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 14:09:32 - OpenVPN > VERIFY KU OK
. 2016.08.01 14:09:32 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 14:09:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 14:09:32 - OpenVPN > VERIFY EKU OK
. 2016.08.01 14:09:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.01 14:09:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 14:09:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:09:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 14:09:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:09:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.01 14:09:38 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.232.227.132:443
. 2016.08.01 14:09:40 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.01 14:09:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.51.7 255.255.0.0'
. 2016.08.01 14:09:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.01 14:09:41 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.01 14:09:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.01 14:09:41 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.01 14:09:41 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.01 14:09:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.01 14:09:41 - OpenVPN > Opened utun device utun0
. 2016.08.01 14:09:41 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.01 14:09:41 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.01 14:09:41 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.01 14:09:41 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.01 14:09:41 - OpenVPN > /sbin/ifconfig utun0 10.4.51.7 10.4.51.7 netmask 255.255.0.0 mtu 1500 up
. 2016.08.01 14:09:41 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.51.7 255.255.0.0
. 2016.08.01 14:09:41 - OpenVPN > add net 10.4.0.0: gateway 10.4.51.7
. 2016.08.01 14:09:41 - OpenVPN > /sbin/route add -net 109.232.227.132 192.168.1.1 255.255.255.255
. 2016.08.01 14:09:41 - OpenVPN > add net 109.232.227.132: gateway 192.168.1.1
. 2016.08.01 14:09:41 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 14:09:41 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 14:09:41 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 14:09:41 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 14:09:41 - Starting Management Interface
. 2016.08.01 14:09:41 - OpenVPN > Initialization Sequence Completed
I 2016.08.01 14:09:41 - DNS of a network adapter forced (SAMSUNG_Android)
I 2016.08.01 14:09:41 - DNS of a network adapter forced (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 14:09:41 - DNS of a network adapter forced (SAMSUNG Modem)
I 2016.08.01 14:09:41 - DNS of a network adapter forced (Bluetooth DUN 2)
I 2016.08.01 14:09:41 - DNS of a network adapter forced (Thunderbolt Ethernet)
I 2016.08.01 14:09:41 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.01 14:09:41 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.01 14:09:41 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.01 14:09:41 - Flushing DNS
I 2016.08.01 14:09:41 - Checking route
W 2016.08.01 14:10:12 - The request timed out
! 2016.08.01 14:10:12 - Disconnecting
. 2016.08.01 14:10:12 - Management - Send 'signal SIGTERM'
. 2016.08.01 14:10:12 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.01 14:10:12 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.01 14:10:12 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.01 14:10:17 - OpenVPN > /sbin/route delete -net 109.232.227.132 192.168.1.1 255.255.255.255
. 2016.08.01 14:10:17 - OpenVPN > delete net 109.232.227.132: gateway 192.168.1.1
. 2016.08.01 14:10:17 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 14:10:17 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 14:10:17 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 14:10:17 - Connection terminated.
I 2016.08.01 14:10:17 - DNS of a network adapter restored to original settings (SAMSUNG_Android)
. 2016.08.01 14:10:17 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 14:10:17 - OpenVPN > Closing TUN/TAP interface
. 2016.08.01 14:10:17 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2016.08.01 14:10:17 - DNS of a network adapter restored to original settings (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 14:10:17 - DNS of a network adapter restored to original settings (SAMSUNG Modem)
I 2016.08.01 14:10:17 - DNS of a network adapter restored to original settings (Bluetooth DUN 2)
I 2016.08.01 14:10:17 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet)
I 2016.08.01 14:10:17 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.01 14:10:17 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.01 14:10:17 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.01 14:10:18 - Cancel requested.
I 2016.08.01 14:10:18 - IPv6 restored on network adapter (SAMSUNG_Android)
I 2016.08.01 14:10:18 - IPv6 restored on network adapter (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 14:10:19 - IPv6 restored on network adapter (SAMSUNG Modem)
I 2016.08.01 14:10:19 - IPv6 restored on network adapter (Bluetooth DUN 2)
I 2016.08.01 14:10:19 - IPv6 restored on network adapter (Thunderbolt Ethernet)
I 2016.08.01 14:10:19 - IPv6 restored on network adapter (Wi-Fi)
I 2016.08.01 14:10:19 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.08.01 14:10:19 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.08.01 14:10:19 - Session terminated.
. 2016.08.01 14:10:37 - Updating systems & servers data ...
. 2016.08.01 14:10:38 - Systems & servers data update completed
I 2016.08.01 14:10:42 - Session starting.
I 2016.08.01 14:10:42 - IPv6 disabled on network adapter (SAMSUNG_Android)
I 2016.08.01 14:10:42 - IPv6 disabled on network adapter (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 14:10:42 - IPv6 disabled on network adapter (SAMSUNG Modem)
I 2016.08.01 14:10:42 - IPv6 disabled on network adapter (Bluetooth DUN 2)
I 2016.08.01 14:10:42 - IPv6 disabled on network adapter (Thunderbolt Ethernet)
I 2016.08.01 14:10:42 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.08.01 14:10:42 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.08.01 14:10:42 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.08.01 14:10:43 - Checking authorization ...
! 2016.08.01 14:10:43 - Connecting to Cephei (Canada, Toronto, Ontario)
. 2016.08.01 14:10:43 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.01 14:10:43 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.01 14:10:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107
. 2016.08.01 14:10:43 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.01 14:10:43 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:10:43 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:10:43 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.01 14:10:43 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.01 14:10:43 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.214.162:443
. 2016.08.01 14:10:43 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.214.162:443, sid=5dc742ef 866681aa
. 2016.08.01 14:10:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.01 14:10:43 - OpenVPN > Validating certificate key usage
. 2016.08.01 14:10:43 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 14:10:43 - OpenVPN > VERIFY KU OK
. 2016.08.01 14:10:43 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 14:10:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 14:10:43 - OpenVPN > VERIFY EKU OK
. 2016.08.01 14:10:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.01 14:10:43 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 14:10:43 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:10:43 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 14:10:43 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:10:43 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.01 14:10:43 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.214.162:443
. 2016.08.01 14:10:45 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.01 14:10:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.60 255.255.0.0'
. 2016.08.01 14:10:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.01 14:10:45 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.01 14:10:45 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.01 14:10:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.01 14:10:45 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.01 14:10:45 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.01 14:10:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.01 14:10:46 - OpenVPN > Opened utun device utun0
. 2016.08.01 14:10:46 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.01 14:10:46 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.01 14:10:46 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.01 14:10:46 - OpenVPN > /sbin/ifconfig utun0 10.4.7.60 10.4.7.60 netmask 255.255.0.0 mtu 1500 up
. 2016.08.01 14:10:46 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.7.60 255.255.0.0
. 2016.08.01 14:10:46 - OpenVPN > add net 10.4.0.0: gateway 10.4.7.60
. 2016.08.01 14:10:46 - OpenVPN > /sbin/route add -net 184.75.214.162 192.168.1.1 255.255.255.255
. 2016.08.01 14:10:46 - OpenVPN > add net 184.75.214.162: gateway 192.168.1.1
. 2016.08.01 14:10:46 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 14:10:46 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 14:10:46 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 14:10:46 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 14:10:46 - Starting Management Interface
. 2016.08.01 14:10:46 - OpenVPN > Initialization Sequence Completed
I 2016.08.01 14:10:46 - DNS of a network adapter forced (SAMSUNG_Android)
I 2016.08.01 14:10:46 - DNS of a network adapter forced (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 14:10:46 - DNS of a network adapter forced (SAMSUNG Modem)
I 2016.08.01 14:10:46 - DNS of a network adapter forced (Bluetooth DUN 2)
I 2016.08.01 14:10:46 - DNS of a network adapter forced (Thunderbolt Ethernet)
I 2016.08.01 14:10:46 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.01 14:10:46 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.01 14:10:46 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.01 14:10:46 - Flushing DNS
! 2016.08.01 14:10:46 - Connected.
. 2016.08.01 14:10:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.01 14:10:46 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3107
Sounds like I'm having the same problem. It was working yesterday. Though I have upgraded from 2.8 to 2.10.3 right now, so who knows, that might be it. It does seem to work after disabling "check route" and "check dns" (as per https://airvpn.org/topic/18694-cant-connect-to-many-servers-nl-se/page-2) so it sound a lot like it is the same problem from two weeks ago.
can you specify your exact OS X version and also tell us whether the problem occurs with Network Lock enabled, disabled or in both cases (with route check enabled, of course)? It has nothing to do with any problem on our side you cite. Instead, we start to suspect it could be a problem of Eddie under specific settings in a specific OS X version.
​I'm running OSX 10.11.6 El Capitan. I'm also running Eddie 2.10.3 since whenever you guys pushed out that update, I think almost 2 months ago. Nothing has changed for me within the last 12 hours. It was working perfectly last night, but today I'm experiencing the same problem as two weeks ago, so I doubt it's on my end. I re-enabled route check and tried connecting with the network lock on and off and it still gets stuck at Checking Route, disconnects and starts the process all over.
. 2016.08.01 14:39:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #530904 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #530908 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #530909 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #530910 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #530911 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #530899 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #530900 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #530906 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #530896 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #530902 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:52 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #606442 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:52 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #606443 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:52 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #606444 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:52 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #606445 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:52 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #606446 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:52 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #606440 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:39:52 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #606438 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754628 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754626 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754629 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754630 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754631 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754632 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754633 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754634 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754635 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754646 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754627 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754640 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754641 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754642 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754643 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754644 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754645 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754647 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #754648 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:31 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #814625 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:40:52 - Updating systems & servers data ...
. 2016.08.01 14:40:53 - Systems & servers data update completed
. 2016.08.01 14:41:48 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1243191 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818453 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818447 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818449 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818452 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818441 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818442 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818577 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818571 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818568 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818588 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818590 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818574 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818567 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818579 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818593 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818582 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818583 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818611 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818613 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818584 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818585 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818614 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818595 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818596 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818581 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818578 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818576 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818597 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818598 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818580 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818599 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818563 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818610 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818600 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818586 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818601 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818607 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:32 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1818592 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846515 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846517 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846518 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846522 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846519 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846520 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846521 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846523 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846524 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846525 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:37 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1846514 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869342 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869312 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869319 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869346 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869316 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869317 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869318 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869321 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869320 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869322 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869313 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869323 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869324 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869325 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869327 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869328 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869329 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869330 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869331 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869332 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869333 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869334 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869335 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869336 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869337 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869338 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869339 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869340 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869341 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869343 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869344 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869345 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869347 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869348 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869349 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869350 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869351 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869354 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869355 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 14:43:41 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1869356 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 15:10:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.01 15:10:43 - OpenVPN > Validating certificate key usage
. 2016.08.01 15:10:43 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 15:10:43 - OpenVPN > VERIFY KU OK
. 2016.08.01 15:10:43 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 15:10:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 15:10:43 - OpenVPN > VERIFY EKU OK
. 2016.08.01 15:10:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.01 15:10:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 15:10:46 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 15:10:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 15:10:46 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 15:10:46 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.01 15:11:03 - Updating systems & servers data ...
. 2016.08.01 15:11:04 - Systems & servers data update completed
. 2016.08.01 15:41:14 - Updating systems & servers data ...
. 2016.08.01 15:41:16 - Systems & servers data update completed
. 2016.08.01 16:04:40 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3789040 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
I 2016.08.01 16:10:42 - Renewing TLS key
. 2016.08.01 16:10:42 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.08.01 16:10:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.01 16:10:46 - OpenVPN > Validating certificate key usage
. 2016.08.01 16:10:46 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 16:10:46 - OpenVPN > VERIFY KU OK
. 2016.08.01 16:10:46 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 16:10:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 16:10:46 - OpenVPN > VERIFY EKU OK
. 2016.08.01 16:10:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.01 16:10:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 16:10:46 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:10:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 16:10:46 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:10:46 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.01 16:11:27 - Updating systems & servers data ...
. 2016.08.01 16:11:28 - Systems & servers data update completed
. 2016.08.01 16:13:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #160666 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:13:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #160667 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:13:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #160668 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:13:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #160669 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:13:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #160670 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:13:39 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #160665 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:18:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518008 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:18:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518009 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:18:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518010 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:18:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518011 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:18:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518012 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:18:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #518007 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653622 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653623 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653624 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653625 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653626 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653627 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653628 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653629 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653630 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653631 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653632 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653633 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653634 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653635 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653636 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653620 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653637 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653638 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653639 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653640 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653641 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653642 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653643 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653644 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653645 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653646 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653647 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653648 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653649 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653650 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653651 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653652 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653654 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653655 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653656 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653657 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653658 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653659 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653660 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653661 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653662 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653663 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653664 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:19:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #653665 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:20:16 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #690704 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:20:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #716024 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:20:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #716020 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:22:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #871442 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:24:31 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1035834 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:24:31 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1035830 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:24:31 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1035832 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.08.01 16:31:44 - Updating systems & servers data ...
. 2016.08.01 16:31:45 - Systems & servers data update completed
! 2016.08.01 16:31:47 - Disconnecting
. 2016.08.01 16:31:47 - Management - Send 'signal SIGTERM'
. 2016.08.01 16:31:47 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.01 16:31:47 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.01 16:31:52 - OpenVPN > /sbin/route delete -net 184.75.214.162 192.168.1.1 255.255.255.255
. 2016.08.01 16:31:52 - OpenVPN > delete net 184.75.214.162: gateway 192.168.1.1
. 2016.08.01 16:31:52 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:31:52 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:31:52 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:31:52 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:31:52 - OpenVPN > Closing TUN/TAP interface
. 2016.08.01 16:31:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.01 16:31:52 - Connection terminated.
I 2016.08.01 16:31:52 - DNS of a network adapter restored to original settings (SAMSUNG_Android)
I 2016.08.01 16:31:52 - DNS of a network adapter restored to original settings (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 16:31:52 - DNS of a network adapter restored to original settings (SAMSUNG Modem)
I 2016.08.01 16:31:52 - DNS of a network adapter restored to original settings (Bluetooth DUN 2)
I 2016.08.01 16:31:52 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet)
I 2016.08.01 16:31:52 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.01 16:31:52 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.01 16:31:52 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.01 16:31:56 - Checking authorization ...
! 2016.08.01 16:31:56 - Connecting to Sharatan (Canada, Toronto, Ontario)
. 2016.08.01 16:31:56 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.01 16:31:56 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.01 16:31:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107
. 2016.08.01 16:31:56 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.01 16:31:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:31:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:31:56 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.01 16:31:56 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.01 16:31:56 - OpenVPN > UDPv4 link remote: [AF_INET]104.254.90.194:443
. 2016.08.01 16:31:56 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.194:443, sid=cfd04bd1 a3abb143
. 2016.08.01 16:31:56 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.01 16:31:56 - OpenVPN > Validating certificate key usage
. 2016.08.01 16:31:56 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 16:31:56 - OpenVPN > VERIFY KU OK
. 2016.08.01 16:31:56 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 16:31:56 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 16:31:56 - OpenVPN > VERIFY EKU OK
. 2016.08.01 16:31:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.01 16:31:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 16:31:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:31:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 16:31:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:31:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.01 16:31:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.194:443
. 2016.08.01 16:31:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.01 16:31:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.23.192 255.255.0.0'
. 2016.08.01 16:31:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.01 16:31:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.01 16:31:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.01 16:31:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.01 16:31:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.01 16:31:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.01 16:31:58 - OpenVPN > Opened utun device utun0
. 2016.08.01 16:31:58 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.01 16:31:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.01 16:31:58 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.01 16:31:58 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.01 16:31:58 - OpenVPN > /sbin/ifconfig utun0 10.4.23.192 10.4.23.192 netmask 255.255.0.0 mtu 1500 up
. 2016.08.01 16:31:58 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.23.192 255.255.0.0
. 2016.08.01 16:31:58 - OpenVPN > add net 10.4.0.0: gateway 10.4.23.192
. 2016.08.01 16:31:58 - OpenVPN > /sbin/route add -net 104.254.90.194 192.168.1.1 255.255.255.255
. 2016.08.01 16:31:58 - OpenVPN > add net 104.254.90.194: gateway 192.168.1.1
. 2016.08.01 16:31:58 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:31:58 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:31:58 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:31:58 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:31:58 - Starting Management Interface
. 2016.08.01 16:31:58 - OpenVPN > Initialization Sequence Completed
I 2016.08.01 16:31:58 - DNS of a network adapter forced (SAMSUNG_Android)
I 2016.08.01 16:31:59 - DNS of a network adapter forced (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 16:31:59 - DNS of a network adapter forced (SAMSUNG Modem)
I 2016.08.01 16:31:59 - DNS of a network adapter forced (Bluetooth DUN 2)
I 2016.08.01 16:31:59 - DNS of a network adapter forced (Thunderbolt Ethernet)
I 2016.08.01 16:31:59 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.01 16:31:59 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.01 16:31:59 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.01 16:31:59 - Flushing DNS
I 2016.08.01 16:31:59 - Checking route
W 2016.08.01 16:32:30 - The request timed out
! 2016.08.01 16:32:30 - Disconnecting
. 2016.08.01 16:32:30 - Management - Send 'signal SIGTERM'
. 2016.08.01 16:32:30 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.01 16:32:30 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.01 16:32:30 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.01 16:32:35 - OpenVPN > /sbin/route delete -net 104.254.90.194 192.168.1.1 255.255.255.255
. 2016.08.01 16:32:35 - OpenVPN > delete net 104.254.90.194: gateway 192.168.1.1
. 2016.08.01 16:32:35 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:32:35 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:32:35 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:32:35 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:32:35 - OpenVPN > Closing TUN/TAP interface
. 2016.08.01 16:32:35 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.01 16:32:35 - Connection terminated.
I 2016.08.01 16:32:35 - DNS of a network adapter restored to original settings (SAMSUNG_Android)
I 2016.08.01 16:32:35 - DNS of a network adapter restored to original settings (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 16:32:35 - DNS of a network adapter restored to original settings (SAMSUNG Modem)
I 2016.08.01 16:32:35 - DNS of a network adapter restored to original settings (Bluetooth DUN 2)
I 2016.08.01 16:32:35 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet)
I 2016.08.01 16:32:35 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.01 16:32:35 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.01 16:32:35 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.01 16:32:38 - IPv6 restored on network adapter (SAMSUNG_Android)
I 2016.08.01 16:32:38 - IPv6 restored on network adapter (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 16:32:38 - IPv6 restored on network adapter (SAMSUNG Modem)
I 2016.08.01 16:32:38 - IPv6 restored on network adapter (Bluetooth DUN 2)
I 2016.08.01 16:32:38 - IPv6 restored on network adapter (Thunderbolt Ethernet)
I 2016.08.01 16:32:38 - IPv6 restored on network adapter (Wi-Fi)
I 2016.08.01 16:32:38 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.08.01 16:32:38 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.08.01 16:32:38 - Session terminated.
! 2016.08.01 16:32:41 - Activation of Network Lock - OS X - PF
. 2016.08.01 16:32:41 - OS X - PF rules updated, reloading
. 2016.08.01 16:32:46 - Updating systems & servers data ...
. 2016.08.01 16:32:46 - Systems & servers data update completed
I 2016.08.01 16:32:49 - Session starting.
I 2016.08.01 16:32:49 - IPv6 disabled on network adapter (SAMSUNG_Android)
I 2016.08.01 16:32:49 - IPv6 disabled on network adapter (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 16:32:49 - IPv6 disabled on network adapter (SAMSUNG Modem)
I 2016.08.01 16:32:49 - IPv6 disabled on network adapter (Bluetooth DUN 2)
I 2016.08.01 16:32:49 - IPv6 disabled on network adapter (Thunderbolt Ethernet)
I 2016.08.01 16:32:49 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.08.01 16:32:50 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.08.01 16:32:50 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.08.01 16:32:50 - Checking authorization ...
! 2016.08.01 16:32:50 - Connecting to Dheneb (Canada, Toronto, Ontario)
. 2016.08.01 16:32:50 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.01 16:32:50 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.01 16:32:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107
. 2016.08.01 16:32:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.01 16:32:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:32:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:32:50 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.01 16:32:50 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.01 16:32:50 - OpenVPN > UDPv4 link remote: [AF_INET]199.21.149.44:443
. 2016.08.01 16:32:50 - OpenVPN > TLS: Initial packet from [AF_INET]199.21.149.44:443, sid=47ec4a76 748c54d5
. 2016.08.01 16:32:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.01 16:32:50 - OpenVPN > Validating certificate key usage
. 2016.08.01 16:32:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 16:32:50 - OpenVPN > VERIFY KU OK
. 2016.08.01 16:32:50 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 16:32:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 16:32:50 - OpenVPN > VERIFY EKU OK
. 2016.08.01 16:32:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.01 16:32:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 16:32:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:32:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 16:32:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:32:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.01 16:32:51 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.21.149.44:443
. 2016.08.01 16:32:53 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.01 16:32:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.189 255.255.0.0'
. 2016.08.01 16:32:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.01 16:32:53 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.01 16:32:53 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.01 16:32:53 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.01 16:32:53 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.01 16:32:53 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.01 16:32:53 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.01 16:32:53 - OpenVPN > Opened utun device utun0
. 2016.08.01 16:32:53 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.01 16:32:53 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.01 16:32:53 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.01 16:32:53 - OpenVPN > /sbin/ifconfig utun0 10.4.6.189 10.4.6.189 netmask 255.255.0.0 mtu 1500 up
. 2016.08.01 16:32:53 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.6.189 255.255.0.0
. 2016.08.01 16:32:53 - OpenVPN > add net 10.4.0.0: gateway 10.4.6.189
. 2016.08.01 16:32:53 - OpenVPN > /sbin/route add -net 199.21.149.44 192.168.1.1 255.255.255.255
. 2016.08.01 16:32:53 - OpenVPN > add net 199.21.149.44: gateway 192.168.1.1
. 2016.08.01 16:32:53 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:32:53 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:32:53 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:32:53 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:32:53 - Starting Management Interface
. 2016.08.01 16:32:53 - OpenVPN > Initialization Sequence Completed
I 2016.08.01 16:32:53 - DNS of a network adapter forced (SAMSUNG_Android)
I 2016.08.01 16:32:53 - DNS of a network adapter forced (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 16:32:53 - DNS of a network adapter forced (SAMSUNG Modem)
I 2016.08.01 16:32:54 - DNS of a network adapter forced (Bluetooth DUN 2)
I 2016.08.01 16:32:54 - DNS of a network adapter forced (Thunderbolt Ethernet)
I 2016.08.01 16:32:54 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.01 16:32:54 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.01 16:32:54 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.01 16:32:54 - Flushing DNS
. 2016.08.01 16:32:54 - OS X - PF rules updated, reloading
I 2016.08.01 16:32:54 - Checking route
W 2016.08.01 16:33:24 - The request timed out
! 2016.08.01 16:33:25 - Disconnecting
. 2016.08.01 16:33:25 - Management - Send 'signal SIGTERM'
. 2016.08.01 16:33:25 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.01 16:33:25 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.01 16:33:25 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.01 16:33:30 - OpenVPN > /sbin/route delete -net 199.21.149.44 192.168.1.1 255.255.255.255
. 2016.08.01 16:33:30 - OpenVPN > delete net 199.21.149.44: gateway 192.168.1.1
. 2016.08.01 16:33:30 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:33:30 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:33:30 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:33:30 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:33:30 - OpenVPN > Closing TUN/TAP interface
. 2016.08.01 16:33:30 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.01 16:33:30 - Connection terminated.
I 2016.08.01 16:33:30 - DNS of a network adapter restored to original settings (SAMSUNG_Android)
I 2016.08.01 16:33:30 - DNS of a network adapter restored to original settings (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 16:33:30 - DNS of a network adapter restored to original settings (SAMSUNG Modem)
I 2016.08.01 16:33:30 - DNS of a network adapter restored to original settings (Bluetooth DUN 2)
I 2016.08.01 16:33:30 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet)
I 2016.08.01 16:33:30 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.01 16:33:30 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.01 16:33:30 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.01 16:33:33 - Checking authorization ...
! 2016.08.01 16:33:34 - Connecting to Sharatan (Canada, Toronto, Ontario)
. 2016.08.01 16:33:34 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.01 16:33:34 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.01 16:33:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107
. 2016.08.01 16:33:34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.01 16:33:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:33:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:33:34 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.01 16:33:34 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.01 16:33:34 - OpenVPN > UDPv4 link remote: [AF_INET]104.254.90.194:443
. 2016.08.01 16:33:34 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.194:443, sid=77f7e830 0abd084b
. 2016.08.01 16:33:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.01 16:33:34 - OpenVPN > Validating certificate key usage
. 2016.08.01 16:33:34 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 16:33:34 - OpenVPN > VERIFY KU OK
. 2016.08.01 16:33:34 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 16:33:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 16:33:34 - OpenVPN > VERIFY EKU OK
. 2016.08.01 16:33:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.01 16:33:34 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 16:33:34 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:33:34 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 16:33:34 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 16:33:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.01 16:33:34 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.194:443
. 2016.08.01 16:33:36 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.01 16:33:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.23.192 255.255.0.0'
. 2016.08.01 16:33:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.01 16:33:36 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.01 16:33:36 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.01 16:33:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.01 16:33:36 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.01 16:33:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.01 16:33:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.01 16:33:36 - OpenVPN > Opened utun device utun0
. 2016.08.01 16:33:36 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.01 16:33:36 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.01 16:33:36 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.01 16:33:36 - OpenVPN > /sbin/ifconfig utun0 10.4.23.192 10.4.23.192 netmask 255.255.0.0 mtu 1500 up
. 2016.08.01 16:33:36 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.23.192 255.255.0.0
. 2016.08.01 16:33:36 - OpenVPN > add net 10.4.0.0: gateway 10.4.23.192
. 2016.08.01 16:33:36 - OpenVPN > /sbin/route add -net 104.254.90.194 192.168.1.1 255.255.255.255
. 2016.08.01 16:33:36 - OpenVPN > add net 104.254.90.194: gateway 192.168.1.1
. 2016.08.01 16:33:37 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:33:37 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:33:37 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:33:37 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:33:37 - Starting Management Interface
. 2016.08.01 16:33:37 - OpenVPN > Initialization Sequence Completed
I 2016.08.01 16:33:37 - DNS of a network adapter forced (SAMSUNG_Android)
I 2016.08.01 16:33:37 - DNS of a network adapter forced (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 16:33:37 - DNS of a network adapter forced (SAMSUNG Modem)
I 2016.08.01 16:33:37 - DNS of a network adapter forced (Bluetooth DUN 2)
I 2016.08.01 16:33:37 - DNS of a network adapter forced (Thunderbolt Ethernet)
I 2016.08.01 16:33:37 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.01 16:33:37 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.01 16:33:37 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.01 16:33:38 - Flushing DNS
I 2016.08.01 16:33:38 - Checking route
W 2016.08.01 16:34:28 - The request timed out
! 2016.08.01 16:34:28 - Disconnecting
. 2016.08.01 16:34:28 - Management - Send 'signal SIGTERM'
. 2016.08.01 16:34:28 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.01 16:34:28 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.01 16:34:28 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.01 16:34:33 - OpenVPN > /sbin/route delete -net 104.254.90.194 192.168.1.1 255.255.255.255
. 2016.08.01 16:34:33 - OpenVPN > delete net 104.254.90.194: gateway 192.168.1.1
. 2016.08.01 16:34:33 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:34:33 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:34:33 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.01 16:34:33 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.01 16:34:33 - OpenVPN > Closing TUN/TAP interface
. 2016.08.01 16:34:33 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.01 16:34:34 - Connection terminated.
I 2016.08.01 16:34:34 - DNS of a network adapter restored to original settings (SAMSUNG_Android)
I 2016.08.01 16:34:34 - DNS of a network adapter restored to original settings (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 16:34:34 - DNS of a network adapter restored to original settings (SAMSUNG Modem)
I 2016.08.01 16:34:34 - DNS of a network adapter restored to original settings (Bluetooth DUN 2)
I 2016.08.01 16:34:34 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet)
I 2016.08.01 16:34:34 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.01 16:34:34 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.01 16:34:34 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.01 16:34:34 - Cancel requested.
I 2016.08.01 16:34:34 - IPv6 restored on network adapter (SAMSUNG_Android)
I 2016.08.01 16:34:34 - IPv6 restored on network adapter (SAMSUNG_Android_SGH-I747M)
I 2016.08.01 16:34:34 - IPv6 restored on network adapter (SAMSUNG Modem)
I 2016.08.01 16:34:34 - IPv6 restored on network adapter (Bluetooth DUN 2)
I 2016.08.01 16:34:34 - IPv6 restored on network adapter (Thunderbolt Ethernet)
I 2016.08.01 16:34:34 - IPv6 restored on network adapter (Wi-Fi)
I 2016.08.01 16:34:35 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.08.01 16:34:35 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.08.01 16:34:35 - Session terminated.
@drummer45
OS X 10.11.6 is available since July the 18th but it's possible that upgrade from 10.11.5 has been applied only recently on several systems. Thank you for the report.
Can you please now test with Network Lock on and route check off?
To disable route check please untick "Check if the tunnel works" in "AirVPN" > "Preferences" > "Advanced" (in Eddie 2.11.3).
I have this issue (I believe) with client 2.10.3 on Debian 7.11
After Checking route, it immediately disconnects and goes into a loop.
This happens connecting to Dheneb. But for example to Virginis it connects fine.
Happens with both Network Lock active and inactive, and also with "Check if tunnel effectively works" unchecked.
I 2016.08.01 14:07:58 - AirVPN client version: 2.10.3 / x86, System: Linux, Name: Debian GNU/Linux 7 \n \l / x86
. 2016.08.01 14:07:58 - Reading options from /home/user1/.airvpn/AirVPN.xml
. 2016.08.01 14:07:59 - Data Path: /home/user1/.airvpn
. 2016.08.01 14:07:59 - App Path: /usr/lib/AirVPN
. 2016.08.01 14:07:59 - Executable Path: /usr/lib/AirVPN/AirVPN.exe
. 2016.08.01 14:07:59 - Command line arguments (1): path="/home/user1/.airvpn"
. 2016.08.01 14:07:59 - Updating systems & servers data ...
. 2016.08.01 14:07:59 - Operating System: Unix 3.2.0.4 - Linux debian1 3.2.0-4-686-pae #1 SMP Debian 3.2.81-1 i686 GNU/Linux
I 2016.08.01 14:07:59 - OpenVPN Driver - Found, /dev/net/tun
I 2016.08.01 14:07:59 - OpenVPN - Version: OpenVPN 2.2.1 (/usr/sbin/openvpn)
I 2016.08.01 14:07:59 - SSH - Version: OpenSSH_6.0p1 Debian-4+deb7u5, OpenSSL 1.0.1e 11 Feb 2013 (/usr/bin/ssh)
I 2016.08.01 14:07:59 - SSL - Version: stunnel 4.53 (/usr/bin/stunnel4)
! 2016.08.01 14:07:59 - Ready
. 2016.08.01 14:08:04 - Systems & servers data update completed
! 2016.08.01 14:08:09 - Activation of Network Lock - Linux IPTables
I 2016.08.01 14:08:17 - Session starting.
I 2016.08.01 14:08:17 - Checking authorization ...
! 2016.08.01 14:08:18 - Connecting to Dheneb (Canada, Toronto, Ontario)
. 2016.08.01 14:08:18 - OpenVPN > OpenVPN 2.2.1 i486-linux-gnu [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Dec  1 2014
. 2016.08.01 14:08:18 - OpenVPN > RESOLVE: NOTE: localhost resolves to 2 addresses
. 2016.08.01 14:08:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.01 14:08:18 - OpenVPN > NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
. 2016.08.01 14:08:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.01 14:08:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:08:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:08:18 - OpenVPN > LZO compression initialized
. 2016.08.01 14:08:18 - OpenVPN > Control Channel MTU parms [ L:1558 D:166 EF:66 EB:0 ET:0 EL:0 ]
. 2016.08.01 14:08:18 - OpenVPN > Socket Buffers: R=[163840->262142] S=[163840->262142]
. 2016.08.01 14:08:18 - OpenVPN > Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
. 2016.08.01 14:08:18 - OpenVPN > Local Options hash (VER=V4): '9e7066d2'
. 2016.08.01 14:08:18 - OpenVPN > Expected Remote Options hash (VER=V4): '162b04de'
. 2016.08.01 14:08:18 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.01 14:08:18 - OpenVPN > UDPv4 link remote: [AF_INET]199.21.149.44:443
. 2016.08.01 14:08:18 - OpenVPN > TLS: Initial packet from [AF_INET]199.21.149.44:443, sid=907dddc0 0f4824b9
. 2016.08.01 14:08:18 - OpenVPN > VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
. 2016.08.01 14:08:18 - OpenVPN > Validating certificate key usage
. 2016.08.01 14:08:18 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 14:08:18 - OpenVPN > VERIFY KU OK
. 2016.08.01 14:08:18 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 14:08:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 14:08:18 - OpenVPN > VERIFY EKU OK
. 2016.08.01 14:08:18 - OpenVPN > VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
. 2016.08.01 14:08:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 14:08:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:08:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 14:08:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 14:08:19 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.08.01 14:08:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.21.149.44:443
. 2016.08.01 14:08:22 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.01 14:08:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.4.102 255.255.0.0'
. 2016.08.01 14:08:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.01 14:08:22 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.01 14:08:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.01 14:08:22 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.01 14:08:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.01 14:08:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.01 14:08:22 - OpenVPN > ROUTE default_gateway=10.0.2.2
. 2016.08.01 14:08:22 - OpenVPN > TUN/TAP device tun0 opened
. 2016.08.01 14:08:22 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.08.01 14:08:22 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.01 14:08:22 - OpenVPN > /sbin/ifconfig tun0 10.4.4.102 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.08.01 14:08:27 - OpenVPN > /sbin/route add -net 199.21.149.44 netmask 255.255.255.255 gw 10.0.2.2
. 2016.08.01 14:08:27 - OpenVPN > /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.08.01 14:08:27 - OpenVPN > /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.08.01 14:08:27 - Starting Management Interface
. 2016.08.01 14:08:27 - OpenVPN > Initialization Sequence Completed
I 2016.08.01 14:08:27 - /etc/resolv.conf renamed to /etc/resolv.conf.airvpn as backup
I 2016.08.01 14:08:27 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2016.08.01 14:08:27 - Flushing DNS
I 2016.08.01 14:08:27 - Checking route
W 2016.08.01 14:08:29 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
! 2016.08.01 14:08:29 - Disconnecting
. 2016.08.01 14:08:29 - Management - Send 'signal SIGTERM'
. 2016.08.01 14:08:29 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.01 14:08:29 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.08.01 14:08:29 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.01 14:08:29 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.01 14:08:34 - OpenVPN > TCP/UDP: Closing socket
. 2016.08.01 14:08:34 - OpenVPN > /sbin/route del -net 199.21.149.44 netmask 255.255.255.255
. 2016.08.01 14:08:34 - OpenVPN > /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
. 2016.08.01 14:08:34 - OpenVPN > /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
. 2016.08.01 14:08:34 - OpenVPN > Closing TUN/TAP interface
. 2016.08.01 14:08:34 - OpenVPN > /sbin/ifconfig tun0 0.0.0.0
. 2016.08.01 14:08:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.01 14:08:34 - Connection terminated.
I 2016.08.01 14:08:34 - DNS of the system restored to original settings (Rename method)
I 2016.08.01 14:08:36 - Cancel requested.
! 2016.08.01 14:08:36 - Session terminated.
@drummer45
I have the same version of OS X and Eddie as @drummer45, and I have the same problem as him. I did what you said, but it does not work, I am getting stuck at "Checking DNS" after applying these settings.
I can confirm what both of them said, disabling check route makes the client hang on "Check DNS" instead. Worked perfectly until today, problem occurs with Eddie 2.11.1 and (upgraded just now) 2.11.3.
@drummer45
I did the test with Network Lock on and route check off, and it works fine. I performed that test with and without the Network Lock and it will only connect with the route check and dns check turned off. I don't understand how this could have changed in the 12 hours I last used it. And is there a new version of Eddie I should be using. You mentioned 2.11.3, but my version is 2.10.3.
When I installed the pkg version it doesn't work but I've just installed the tar.gz bundle and now it's worked.
Upgraded client to version 2.11.3 but the issue still exists. Seems to be server specific.
Connection to Sabik fails, while connection to Virginis is successful.
I 2016.08.01 15:53:31 - Eddie client version: 2.11.3 / x86, System: Linux, Name: Debian GNU/Linux 7 \n \l / x86
. 2016.08.01 15:53:31 - Reading options from /home/user1/.airvpn/AirVPN.xml
. 2016.08.01 15:53:32 - Data Path: /home/user1/.airvpn
. 2016.08.01 15:53:32 - App Path: /usr/lib/AirVPN
. 2016.08.01 15:53:32 - Executable Path: /usr/lib/AirVPN/AirVPN.exe
. 2016.08.01 15:53:32 - Command line arguments (1): path="/home/user1/.airvpn"
. 2016.08.01 15:53:32 - Operating System: Unix 3.2.0.4 - Linux debian1 3.2.0-4-686-pae #1 SMP Debian 3.2.81-1 i686 GNU/Linux
I 2016.08.01 15:53:32 - OpenVPN Driver - Found, /dev/net/tun
I 2016.08.01 15:53:32 - OpenVPN - Version: OpenVPN 2.2.1 (/usr/sbin/openvpn)
I 2016.08.01 15:53:32 - SSH - Version: OpenSSH_6.0p1 Debian-4+deb7u5, OpenSSL 1.0.1e 11 Feb 2013 (/usr/bin/ssh)
I 2016.08.01 15:53:32 - SSL - Version: stunnel 4.53 (/usr/bin/stunnel4)
! 2016.08.01 15:53:32 - Ready
. 2016.08.01 15:53:32 - Updating systems & servers data ...
. 2016.08.01 15:53:38 - Systems & servers data update completed
! 2016.08.01 15:53:52 - Activation of Network Lock - Linux IPTables
I 2016.08.01 15:53:59 - Session starting.
I 2016.08.01 15:53:59 - Checking authorization ...
! 2016.08.01 15:53:59 - Connecting to Sabik (United States, Los Angeles)
. 2016.08.01 15:53:59 - OpenVPN > OpenVPN 2.2.1 i486-linux-gnu [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Dec  1 2014
. 2016.08.01 15:53:59 - OpenVPN > RESOLVE: NOTE: localhost resolves to 2 addresses
. 2016.08.01 15:53:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.01 15:53:59 - OpenVPN > NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
. 2016.08.01 15:53:59 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.01 15:53:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 15:53:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 15:53:59 - OpenVPN > LZO compression initialized
. 2016.08.01 15:53:59 - OpenVPN > Control Channel MTU parms [ L:1558 D:166 EF:66 EB:0 ET:0 EL:0 ]
. 2016.08.01 15:53:59 - OpenVPN > Socket Buffers: R=[163840->131072] S=[163840->131072]
. 2016.08.01 15:53:59 - OpenVPN > Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
. 2016.08.01 15:53:59 - OpenVPN > Local Options hash (VER=V4): '9e7066d2'
. 2016.08.01 15:53:59 - OpenVPN > Expected Remote Options hash (VER=V4): '162b04de'
. 2016.08.01 15:53:59 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.01 15:53:59 - OpenVPN > UDPv4 link remote: [AF_INET]199.241.147.34:443
. 2016.08.01 15:54:00 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.34:443, sid=7be8de5b 26b725da
. 2016.08.01 15:54:00 - OpenVPN > VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
. 2016.08.01 15:54:00 - OpenVPN > Validating certificate key usage
. 2016.08.01 15:54:00 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 15:54:00 - OpenVPN > VERIFY KU OK
. 2016.08.01 15:54:00 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 15:54:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 15:54:00 - OpenVPN > VERIFY EKU OK
. 2016.08.01 15:54:00 - OpenVPN > VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
. 2016.08.01 15:54:03 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 15:54:03 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 15:54:03 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 15:54:03 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 15:54:03 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.08.01 15:54:03 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.34:443
. 2016.08.01 15:54:05 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.01 15:54:05 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.10.33 255.255.0.0'
. 2016.08.01 15:54:05 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.01 15:54:05 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.01 15:54:05 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.01 15:54:05 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.01 15:54:05 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.01 15:54:05 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.01 15:54:05 - OpenVPN > ROUTE default_gateway=10.0.2.2
. 2016.08.01 15:54:05 - OpenVPN > TUN/TAP device tun0 opened
. 2016.08.01 15:54:05 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.08.01 15:54:05 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.01 15:54:05 - OpenVPN > /sbin/ifconfig tun0 10.4.10.33 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.08.01 15:54:10 - OpenVPN > /sbin/route add -net 199.241.147.34 netmask 255.255.255.255 gw 10.0.2.2
. 2016.08.01 15:54:10 - OpenVPN > /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.08.01 15:54:10 - OpenVPN > /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.08.01 15:54:10 - Starting Management Interface
. 2016.08.01 15:54:10 - OpenVPN > Initialization Sequence Completed
I 2016.08.01 15:54:10 - /etc/resolv.conf renamed to /etc/resolv.conf.airvpn as backup
I 2016.08.01 15:54:10 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2016.08.01 15:54:10 - Flushing DNS
I 2016.08.01 15:54:10 - Checking route
W 2016.08.01 15:54:11 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
! 2016.08.01 15:54:11 - Disconnecting
. 2016.08.01 15:54:11 - Management - Send 'signal SIGTERM'
. 2016.08.01 15:54:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.01 15:54:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.01 15:54:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.01 15:54:11 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.08.01 15:54:16 - OpenVPN > TCP/UDP: Closing socket
. 2016.08.01 15:54:16 - OpenVPN > /sbin/route del -net 199.241.147.34 netmask 255.255.255.255
. 2016.08.01 15:54:16 - OpenVPN > /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
. 2016.08.01 15:54:16 - OpenVPN > /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
. 2016.08.01 15:54:16 - OpenVPN > Closing TUN/TAP interface
. 2016.08.01 15:54:16 - OpenVPN > /sbin/ifconfig tun0 0.0.0.0
. 2016.08.01 15:54:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.01 15:54:16 - Connection terminated.
I 2016.08.01 15:54:16 - DNS of the system restored to original settings (Rename method)
I 2016.08.01 15:54:18 - Cancel requested.
! 2016.08.01 15:54:18 - Session terminated.
I 2016.08.01 15:54:22 - Session starting.
I 2016.08.01 15:54:22 - Checking authorization ...
! 2016.08.01 15:54:23 - Connecting to Virginis (Switzerland, Bern)
. 2016.08.01 15:54:23 - OpenVPN > OpenVPN 2.2.1 i486-linux-gnu [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Dec  1 2014
. 2016.08.01 15:54:23 - OpenVPN > RESOLVE: NOTE: localhost resolves to 2 addresses
. 2016.08.01 15:54:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.01 15:54:23 - OpenVPN > NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
. 2016.08.01 15:54:23 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.01 15:54:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 15:54:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 15:54:23 - OpenVPN > LZO compression initialized
. 2016.08.01 15:54:23 - OpenVPN > Control Channel MTU parms [ L:1558 D:166 EF:66 EB:0 ET:0 EL:0 ]
. 2016.08.01 15:54:23 - OpenVPN > Socket Buffers: R=[163840->131072] S=[163840->131072]
. 2016.08.01 15:54:23 - OpenVPN > Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
. 2016.08.01 15:54:23 - OpenVPN > Local Options hash (VER=V4): '9e7066d2'
. 2016.08.01 15:54:23 - OpenVPN > Expected Remote Options hash (VER=V4): '162b04de'
. 2016.08.01 15:54:23 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.01 15:54:23 - OpenVPN > UDPv4 link remote: [AF_INET]46.19.137.114:443
. 2016.08.01 15:54:23 - OpenVPN > TLS: Initial packet from [AF_INET]46.19.137.114:443, sid=5196781d 79e728f6
. 2016.08.01 15:54:24 - OpenVPN > VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
. 2016.08.01 15:54:24 - OpenVPN > Validating certificate key usage
. 2016.08.01 15:54:24 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.01 15:54:24 - OpenVPN > VERIFY KU OK
. 2016.08.01 15:54:24 - OpenVPN > Validating certificate extended key usage
. 2016.08.01 15:54:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.01 15:54:24 - OpenVPN > VERIFY EKU OK
. 2016.08.01 15:54:24 - OpenVPN > VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
. 2016.08.01 15:54:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 15:54:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 15:54:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.01 15:54:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.01 15:54:31 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.08.01 15:54:31 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.19.137.114:443
. 2016.08.01 15:54:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.01 15:54:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.22.19 255.255.0.0'
. 2016.08.01 15:54:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.01 15:54:33 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.01 15:54:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.01 15:54:33 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.01 15:54:33 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.01 15:54:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.01 15:54:33 - OpenVPN > ROUTE default_gateway=10.0.2.2
. 2016.08.01 15:54:33 - OpenVPN > TUN/TAP device tun0 opened
. 2016.08.01 15:54:33 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.08.01 15:54:33 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.01 15:54:33 - OpenVPN > /sbin/ifconfig tun0 10.4.22.19 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.08.01 15:54:38 - OpenVPN > /sbin/route add -net 46.19.137.114 netmask 255.255.255.255 gw 10.0.2.2
. 2016.08.01 15:54:38 - OpenVPN > /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.08.01 15:54:38 - OpenVPN > /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.08.01 15:54:38 - Starting Management Interface
. 2016.08.01 15:54:38 - OpenVPN > Initialization Sequence Completed
I 2016.08.01 15:54:38 - /etc/resolv.conf renamed to /etc/resolv.conf.airvpn as backup
I 2016.08.01 15:54:38 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2016.08.01 15:54:38 - Flushing DNS
I 2016.08.01 15:54:38 - Checking route
I 2016.08.01 15:54:40 - Checking DNS
! 2016.08.01 15:54:46 - Connected.
. 2016.08.01 15:54:46 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.08.01 15:54:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
Same with me.  Everything was working fine last night.  I log in today and it hangs up on 'Checking route.'  I disable that feature and then it hangs up on 'Checking DNS.'  I disable that feature and it connects, but I still did not have internet access.  I disabled Network Lock, reconnect with check dns and route feature off, and voila, it works!  But I still want the network lock feature and don't enjoy using the vpn without that security feature.   By the way, I'm on OS X Yosemite.
So to sum up for other mac users, disable network lock, disable the check dns and route feature, and it'll work.  This is a temporary fix as I still would like the network lock feature!  Also, everything works fine on my windows pc with all of the features/lock enabled.
I have the same problem as of today. Running client 2.10.3 in OS X 10.11.6. Tried with Network Lock on and off; also with "Check if the tunnel effectively works" on and off. My ISP is Verizon FiOS.
The thing that I can add is that the problem only exists when I attempt a connection to certain AirVPN servers. The servers that I've tried:
Failed: Rasalas, Miaplacidus, Azha, Sabik, Nunki, Persei, Marfic, Minkar, Algedi, Cursa, Benetnasch, Menkab, Arkab, Dheneb
Succeeded: Merope, Bellatrix, Dabih, Furud, Thuban, Angetenar, Chort, Lesath
Another unhappy OSX (Maveicks 10.9.5) user.
Problem (Same as other posters):
- Latest version is 2.10.3
- Worked perfectly until last night while I was switching servers.
- Stuck at Checking Route with both Network Lock active and inactive
- Disabling check route makes the client hang on "Check DNS" instead.
- Still no solution here
- I did report this to the support team.
Thanks to previous posters as all I had to do was copy / paste. (The statement "It has nothing to do with any problem on our side you cite." is rubbish. Months of uninterrupted use and suddenly many users have same issue at the same time.)
For others wondering if the latest version will help:
Version "2.11.3" has to be a typo. It made me go check. Have to install it before it gives up this nugget of info. Version 2.10.3 is the latest for OSX.
I also have the same problem. It started last night and I've not been able to connect at all since.
I 2016.08.02 13:50:45 - AirVPN client version: 2.10.3 / x86, System: OSX, Name: 10.11.6 / x64
. 2016.08.02 13:50:45 - Reading options from /Users/bollusaurum/.airvpn/AirVPN.xml
. 2016.08.02 13:50:45 - Data Path: /Users/bollusaurum/.airvpn
. 2016.08.02 13:50:45 - App Path: /Applications/AirVPN.app/Contents/MacOS
. 2016.08.02 13:50:45 - Executable Path: /Applications/AirVPN.app/Contents/MacOS/AirVPN
. 2016.08.02 13:50:45 - Command line arguments (0):
. 2016.08.02 13:50:46 - Updating systems & servers data ...
. 2016.08.02 13:50:46 - Operating System: Unix 15.6.0.0 - Darwin BollusAurums-iMac.local 15.6.0 Darwin Kernel Version 15.6.0: Thu Jun 23 18:25:34 PDT 2016; root:xnu-3248.60.10~1/RELEASE_X86_64 x86_64
I 2016.08.02 13:50:46 - OpenVPN Driver - Expected
I 2016.08.02 13:50:46 - OpenVPN - Version: OpenVPN 2.3.8 (/Applications/AirVPN.app/Contents/MacOS/openvpn)
I 2016.08.02 13:50:46 - SSH - Version: OpenSSH_6.9p1, LibreSSL 2.1.8 (/usr/bin/ssh)
I 2016.08.02 13:50:46 - SSL - Version: stunnel 5.17 (/Applications/AirVPN.app/Contents/MacOS/stunnel)
W 2016.08.02 13:50:46 - Recovery. Unexpected crash?
I 2016.08.02 13:50:46 - IPv6 restored on network adapter (Bluetooth DUN)
I 2016.08.02 13:50:46 - IPv6 restored on network adapter (Ethernet)
I 2016.08.02 13:50:46 - IPv6 restored on network adapter (Wi-Fi)
I 2016.08.02 13:50:46 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.08.02 13:50:46 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.08.02 13:50:46 - Ready
. 2016.08.02 13:50:53 - Systems & servers data update completed
I 2016.08.02 13:51:04 - Session starting.
I 2016.08.02 13:51:04 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2016.08.02 13:51:04 - IPv6 disabled on network adapter (Ethernet)
I 2016.08.02 13:51:04 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.08.02 13:51:04 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.08.02 13:51:04 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.08.02 13:51:04 - Checking authorization ...
! 2016.08.02 13:51:05 - Connecting to Algieba (Sweden, Uppsala)
. 2016.08.02 13:51:05 - SSH > OpenSSH_6.9p1, LibreSSL 2.1.8
. 2016.08.02 13:51:05 - SSH > debug1: Reading configuration data /etc/ssh/ssh_config
. 2016.08.02 13:51:05 - SSH > debug1: /etc/ssh/ssh_config line 21: Applying options for *
. 2016.08.02 13:51:05 - SSH > debug1: Connecting to 62.102.148.142 [62.102.148.142] port 22.
. 2016.08.02 13:51:05 - SSH > debug1: Connection established.
. 2016.08.02 13:51:05 - SSH > debug1: permanently_set_uid: 501/20
. 2016.08.02 13:51:05 - SSH > debug1: key_load_public: No such file or directory
. 2016.08.02 13:51:05 - SSH > debug1: identity file /Users/bollusaurum/.airvpn/9152ea63ed79a5d42ed69b52d7b8fdda9bdf74a076592cf7f9ae1d60182d4b14.tmp.key type -1
. 2016.08.02 13:51:05 - SSH > debug1: identity file /Users/bollusaurum/.airvpn/9152ea63ed79a5d42ed69b52d7b8fdda9bdf74a076592cf7f9ae1d60182d4b14.tmp.key-cert type -1
. 2016.08.02 13:51:05 - SSH > debug1: Enabling compatibility mode for protocol 2.0
. 2016.08.02 13:51:05 - SSH > debug1: Local version string SSH-2.0-OpenSSH_6.9
. 2016.08.02 13:51:05 - SSH > debug1: Remote protocol version 2.0, remote software version OpenSSH_6.7p1 Debian-5+deb8u2
. 2016.08.02 13:51:05 - SSH > debug1: match: OpenSSH_6.7p1 Debian-5+deb8u2 pat OpenSSH* compat 0x04000000
. 2016.08.02 13:51:06 - SSH > debug1: Authenticating to 62.102.148.142:22 as 'sshtunnel'
. 2016.08.02 13:51:06 - SSH > debug1: SSH2_MSG_KEXINIT sent
. 2016.08.02 13:51:06 - SSH > debug1: SSH2_MSG_KEXINIT received
. 2016.08.02 13:51:06 - SSH > debug1: kex: server->client chacha20-poly1305@openssh.com <implicit> none
. 2016.08.02 13:51:06 - SSH > debug1: kex: client->server chacha20-poly1305@openssh.com <implicit> none
. 2016.08.02 13:51:06 - SSH > debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
. 2016.08.02 13:51:06 - SSH > debug1: Server host key: ecdsa-sha2-nistp256 SHA256:8yyyT6dAfAlJl7pzg3bWnzu8B7IfLP3vi50ewXr6stY
. 2016.08.02 13:51:06 - SSH > Warning: Permanently added '62.102.148.142' (ECDSA) to the list of known hosts.
. 2016.08.02 13:51:06 - SSH > debug1: SSH2_MSG_NEWKEYS sent
. 2016.08.02 13:51:06 - SSH > debug1: expecting SSH2_MSG_NEWKEYS
. 2016.08.02 13:51:06 - SSH > debug1: SSH2_MSG_NEWKEYS received
. 2016.08.02 13:51:06 - SSH > debug1: SSH2_MSG_SERVICE_REQUEST sent
. 2016.08.02 13:51:07 - SSH > debug1: SSH2_MSG_SERVICE_ACCEPT received
. 2016.08.02 13:51:07 - SSH > debug1: Authentications that can continue: publickey,password
. 2016.08.02 13:51:07 - SSH > debug1: Next authentication method: publickey
. 2016.08.02 13:51:07 - SSH > debug1: Trying private key: /Users/bollusaurum/.airvpn/9152ea63ed79a5d42ed69b52d7b8fdda9bdf74a076592cf7f9ae1d60182d4b14.tmp.key
. 2016.08.02 13:51:07 - SSH > debug1: Authentication succeeded (publickey).
. 2016.08.02 13:51:07 - SSH > Authenticated to 62.102.148.142 ([62.102.148.142]:22).
. 2016.08.02 13:51:07 - SSH > debug1: Local connections to LOCALHOST:64907 forwarded to remote address 127.0.0.1:2018
. 2016.08.02 13:51:07 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.02 13:51:07 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.02 13:51:07 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.02 13:51:07 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.02 13:51:07 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:51:07 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:51:07 - OpenVPN > Socket Buffers: R=[131072->131072] S=[131072->131072]
. 2016.08.02 13:51:07 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:64907 [nonblock]
. 2016.08.02 13:51:07 - SSH > debug1: Local forwarding listening on ::1 port 64907.
. 2016.08.02 13:51:07 - SSH > debug1: channel 0: new [port listener]
. 2016.08.02 13:51:07 - SSH > debug1: Local forwarding listening on 127.0.0.1 port 64907.
. 2016.08.02 13:51:07 - SSH > debug1: channel 1: new [port listener]
. 2016.08.02 13:51:07 - SSH > debug1: Requesting no-more-sessions@openssh.com
. 2016.08.02 13:51:07 - SSH > debug1: Entering interactive session.
. 2016.08.02 13:51:07 - SSH > debug1: Connection to port 64907 forwarding to 127.0.0.1 port 2018 requested.
. 2016.08.02 13:51:07 - SSH > debug1: channel 2: new [direct-tcpip]
. 2016.08.02 13:51:07 - SSH > debug1: Remote: Pty allocation disabled.
. 2016.08.02 13:51:07 - SSH > debug1: Remote: X11 forwarding disabled.
. 2016.08.02 13:51:07 - SSH > debug1: Remote: Forced command.
. 2016.08.02 13:51:08 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:64907
. 2016.08.02 13:51:08 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.08.02 13:51:08 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:64907
. 2016.08.02 13:51:08 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:64907, sid=4cb8420c 2a180efa
. 2016.08.02 13:51:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.02 13:51:09 - OpenVPN > Validating certificate key usage
. 2016.08.02 13:51:09 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.02 13:51:09 - OpenVPN > VERIFY KU OK
. 2016.08.02 13:51:09 - OpenVPN > Validating certificate extended key usage
. 2016.08.02 13:51:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.02 13:51:09 - OpenVPN > VERIFY EKU OK
. 2016.08.02 13:51:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.02 13:51:13 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:51:13 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:51:13 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:51:14 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:51:14 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.02 13:51:14 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:64907
. 2016.08.02 13:51:16 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.02 13:51:16 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.1.82 255.255.0.0'
. 2016.08.02 13:51:16 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.02 13:51:16 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.02 13:51:16 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.02 13:51:16 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.02 13:51:16 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.02 13:51:16 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.02 13:51:16 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.02 13:51:16 - OpenVPN > Opened utun device utun0
. 2016.08.02 13:51:16 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.02 13:51:16 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.02 13:51:16 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.02 13:51:16 - OpenVPN > /sbin/ifconfig utun0 10.50.1.82 10.50.1.82 netmask 255.255.0.0 mtu 1500 up
. 2016.08.02 13:51:16 - OpenVPN > /sbin/route add -net 10.50.0.0 10.50.1.82 255.255.0.0
. 2016.08.02 13:51:16 - OpenVPN > add net 10.50.0.0: gateway 10.50.1.82
. 2016.08.02 13:51:16 - OpenVPN > /sbin/route add -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.08.02 13:51:16 - OpenVPN > add net 127.0.0.1: gateway 192.168.1.1
. 2016.08.02 13:51:16 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.08.02 13:51:16 - OpenVPN > add net 0.0.0.0: gateway 10.50.0.1
. 2016.08.02 13:51:16 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.08.02 13:51:16 - OpenVPN > add net 128.0.0.0: gateway 10.50.0.1
. 2016.08.02 13:51:16 - OpenVPN > /sbin/route add -net 62.102.148.142 192.168.1.1 255.255.255.255
. 2016.08.02 13:51:16 - OpenVPN > add net 62.102.148.142: gateway 192.168.1.1
. 2016.08.02 13:51:16 - Starting Management Interface
. 2016.08.02 13:51:16 - OpenVPN > Initialization Sequence Completed
I 2016.08.02 13:51:17 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.08.02 13:51:17 - DNS of a network adapter forced (Ethernet)
I 2016.08.02 13:51:17 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.02 13:51:17 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.02 13:51:17 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.02 13:51:17 - Flushing DNS
I 2016.08.02 13:51:17 - Checking route
W 2016.08.02 13:51:49 - The request timed out
! 2016.08.02 13:51:49 - Disconnecting
. 2016.08.02 13:51:49 - Management - Send 'signal SIGTERM'
. 2016.08.02 13:51:49 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.02 13:51:49 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.02 13:51:49 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.08.02 13:51:49 - OpenVPN > /sbin/route delete -net 62.102.148.142 192.168.1.1 255.255.255.255
. 2016.08.02 13:51:49 - OpenVPN > delete net 62.102.148.142: gateway 192.168.1.1
. 2016.08.02 13:51:49 - OpenVPN > /sbin/route delete -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.08.02 13:51:49 - OpenVPN > delete net 127.0.0.1: gateway 192.168.1.1
. 2016.08.02 13:51:49 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.08.02 13:51:49 - OpenVPN > delete net 0.0.0.0: gateway 10.50.0.1
. 2016.08.02 13:51:49 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.08.02 13:51:49 - OpenVPN > delete net 128.0.0.0: gateway 10.50.0.1
. 2016.08.02 13:51:49 - OpenVPN > Closing TUN/TAP interface
. 2016.08.02 13:51:49 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.08.02 13:51:49 - Connection terminated.
I 2016.08.02 13:51:49 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.08.02 13:51:49 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.08.02 13:51:49 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.02 13:51:49 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.02 13:51:49 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.02 13:51:52 - Checking authorization ...
! 2016.08.02 13:51:53 - Connecting to Alphecca (Netherlands, Alblasserdam)
. 2016.08.02 13:51:53 - SSH > OpenSSH_6.9p1, LibreSSL 2.1.8
. 2016.08.02 13:51:53 - SSH > debug1: Reading configuration data /etc/ssh/ssh_config
. 2016.08.02 13:51:53 - SSH > debug1: /etc/ssh/ssh_config line 21: Applying options for *
. 2016.08.02 13:51:53 - SSH > debug1: Connecting to 109.202.107.4 [109.202.107.4] port 22.
. 2016.08.02 13:51:53 - SSH > debug1: Connection established.
. 2016.08.02 13:51:53 - SSH > debug1: permanently_set_uid: 501/20
. 2016.08.02 13:51:53 - SSH > debug1: key_load_public: No such file or directory
. 2016.08.02 13:51:53 - SSH > debug1: identity file /Users/bollusaurum/.airvpn/b718ea66d73834c7027c4401f9e5c9284104511337286f39cd6ff609bed7dc18.tmp.key type -1
. 2016.08.02 13:51:53 - SSH > debug1: identity file /Users/bollusaurum/.airvpn/b718ea66d73834c7027c4401f9e5c9284104511337286f39cd6ff609bed7dc18.tmp.key-cert type -1
. 2016.08.02 13:51:53 - SSH > debug1: Enabling compatibility mode for protocol 2.0
. 2016.08.02 13:51:53 - SSH > debug1: Local version string SSH-2.0-OpenSSH_6.9
. 2016.08.02 13:51:53 - SSH > debug1: Remote protocol version 2.0, remote software version OpenSSH_6.7p1 Debian-5+deb8u2
. 2016.08.02 13:51:53 - SSH > debug1: match: OpenSSH_6.7p1 Debian-5+deb8u2 pat OpenSSH* compat 0x04000000
. 2016.08.02 13:51:53 - SSH > debug1: Authenticating to 109.202.107.4:22 as 'sshtunnel'
. 2016.08.02 13:51:53 - SSH > debug1: SSH2_MSG_KEXINIT sent
. 2016.08.02 13:51:53 - SSH > debug1: SSH2_MSG_KEXINIT received
. 2016.08.02 13:51:53 - SSH > debug1: kex: server->client chacha20-poly1305@openssh.com <implicit> none
. 2016.08.02 13:51:53 - SSH > debug1: kex: client->server chacha20-poly1305@openssh.com <implicit> none
. 2016.08.02 13:51:54 - SSH > debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
. 2016.08.02 13:51:54 - SSH > debug1: Server host key: ecdsa-sha2-nistp256 SHA256:5QLza+LyAdu0GbwKY0PcQgDqxLY3paQAP8JV5PQr7YU
. 2016.08.02 13:51:54 - SSH > Warning: Permanently added '109.202.107.4' (ECDSA) to the list of known hosts.
. 2016.08.02 13:51:54 - SSH > debug1: SSH2_MSG_NEWKEYS sent
. 2016.08.02 13:51:54 - SSH > debug1: expecting SSH2_MSG_NEWKEYS
. 2016.08.02 13:51:54 - SSH > debug1: SSH2_MSG_NEWKEYS received
. 2016.08.02 13:51:54 - SSH > debug1: SSH2_MSG_SERVICE_REQUEST sent
. 2016.08.02 13:51:54 - SSH > debug1: SSH2_MSG_SERVICE_ACCEPT received
. 2016.08.02 13:51:55 - SSH > debug1: Authentications that can continue: publickey,password
. 2016.08.02 13:51:55 - SSH > debug1: Next authentication method: publickey
. 2016.08.02 13:51:55 - SSH > debug1: Trying private key: /Users/bollusaurum/.airvpn/b718ea66d73834c7027c4401f9e5c9284104511337286f39cd6ff609bed7dc18.tmp.key
. 2016.08.02 13:51:55 - SSH > debug1: Authentication succeeded (publickey).
. 2016.08.02 13:51:55 - SSH > Authenticated to 109.202.107.4 ([109.202.107.4]:22).
. 2016.08.02 13:51:55 - SSH > debug1: Local connections to LOCALHOST:3523 forwarded to remote address 127.0.0.1:2018
. 2016.08.02 13:51:55 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.02 13:51:55 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.02 13:51:55 - SSH > debug1: Local forwarding listening on ::1 port 3523.
. 2016.08.02 13:51:55 - SSH > debug1: channel 0: new [port listener]
. 2016.08.02 13:51:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.02 13:51:55 - SSH > debug1: Local forwarding listening on 127.0.0.1 port 3523.
. 2016.08.02 13:51:55 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.02 13:51:55 - SSH > debug1: channel 1: new [port listener]
. 2016.08.02 13:51:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:51:55 - SSH > debug1: Requesting no-more-sessions@openssh.com
. 2016.08.02 13:51:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:51:55 - SSH > debug1: Entering interactive session.
. 2016.08.02 13:51:55 - OpenVPN > Socket Buffers: R=[131072->131072] S=[131072->131072]
. 2016.08.02 13:51:55 - SSH > debug1: Connection to port 3523 forwarding to 127.0.0.1 port 2018 requested.
. 2016.08.02 13:51:55 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:3523 [nonblock]
. 2016.08.02 13:51:55 - SSH > debug1: channel 2: new [direct-tcpip]
. 2016.08.02 13:51:55 - SSH > debug1: Remote: Pty allocation disabled.
. 2016.08.02 13:51:55 - SSH > debug1: Remote: X11 forwarding disabled.
. 2016.08.02 13:51:55 - SSH > debug1: Remote: Forced command.
. 2016.08.02 13:51:56 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:3523
. 2016.08.02 13:51:56 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.08.02 13:51:56 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:3523
. 2016.08.02 13:51:56 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:3523, sid=5fe63131 96575e1c
. 2016.08.02 13:51:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.02 13:51:57 - OpenVPN > Validating certificate key usage
. 2016.08.02 13:51:57 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.02 13:51:57 - OpenVPN > VERIFY KU OK
. 2016.08.02 13:51:57 - OpenVPN > Validating certificate extended key usage
. 2016.08.02 13:51:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.02 13:51:57 - OpenVPN > VERIFY EKU OK
. 2016.08.02 13:51:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.02 13:52:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:52:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:52:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:52:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:52:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.02 13:52:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:3523
. 2016.08.02 13:52:03 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.02 13:52:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.2.227 255.255.0.0'
. 2016.08.02 13:52:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.02 13:52:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.02 13:52:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.02 13:52:03 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.02 13:52:03 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.02 13:52:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.02 13:52:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.02 13:52:03 - OpenVPN > Opened utun device utun0
. 2016.08.02 13:52:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.02 13:52:03 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.02 13:52:03 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.02 13:52:03 - OpenVPN > /sbin/ifconfig utun0 10.50.2.227 10.50.2.227 netmask 255.255.0.0 mtu 1500 up
. 2016.08.02 13:52:03 - OpenVPN > /sbin/route add -net 10.50.0.0 10.50.2.227 255.255.0.0
. 2016.08.02 13:52:03 - OpenVPN > add net 10.50.0.0: gateway 10.50.2.227
. 2016.08.02 13:52:03 - OpenVPN > /sbin/route add -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.08.02 13:52:03 - OpenVPN > add net 127.0.0.1: gateway 192.168.1.1
. 2016.08.02 13:52:03 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.08.02 13:52:03 - OpenVPN > add net 0.0.0.0: gateway 10.50.0.1
. 2016.08.02 13:52:03 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.08.02 13:52:03 - OpenVPN > add net 128.0.0.0: gateway 10.50.0.1
. 2016.08.02 13:52:03 - OpenVPN > /sbin/route add -net 109.202.107.4 192.168.1.1 255.255.255.255
. 2016.08.02 13:52:03 - OpenVPN > add net 109.202.107.4: gateway 192.168.1.1
. 2016.08.02 13:52:03 - Starting Management Interface
. 2016.08.02 13:52:03 - OpenVPN > Initialization Sequence Completed
I 2016.08.02 13:52:03 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.08.02 13:52:03 - DNS of a network adapter forced (Ethernet)
I 2016.08.02 13:52:03 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.02 13:52:03 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.02 13:52:03 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.02 13:52:03 - Flushing DNS
I 2016.08.02 13:52:04 - Checking route
W 2016.08.02 13:52:35 - The request timed out
! 2016.08.02 13:52:35 - Disconnecting
. 2016.08.02 13:52:35 - Management - Send 'signal SIGTERM'
. 2016.08.02 13:52:35 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.02 13:52:35 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.02 13:52:35 - OpenVPN > /sbin/route delete -net 109.202.107.4 192.168.1.1 255.255.255.255
. 2016.08.02 13:52:35 - OpenVPN > delete net 109.202.107.4: gateway 192.168.1.1
. 2016.08.02 13:52:35 - OpenVPN > /sbin/route delete -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.08.02 13:52:35 - OpenVPN > delete net 127.0.0.1: gateway 192.168.1.1
. 2016.08.02 13:52:35 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.08.02 13:52:35 - OpenVPN > delete net 0.0.0.0: gateway 10.50.0.1
. 2016.08.02 13:52:35 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.08.02 13:52:35 - OpenVPN > delete net 128.0.0.0: gateway 10.50.0.1
. 2016.08.02 13:52:35 - OpenVPN > Closing TUN/TAP interface
. 2016.08.02 13:52:35 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.08.02 13:52:35 - Connection terminated.
I 2016.08.02 13:52:35 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.08.02 13:52:36 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.08.02 13:52:36 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.02 13:52:36 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.02 13:52:36 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.02 13:52:38 - Cancel requested.
I 2016.08.02 13:52:38 - IPv6 restored on network adapter (Bluetooth DUN)
I 2016.08.02 13:52:38 - IPv6 restored on network adapter (Ethernet)
I 2016.08.02 13:52:38 - IPv6 restored on network adapter (Wi-Fi)
I 2016.08.02 13:52:38 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.08.02 13:52:38 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.08.02 13:52:38 - Session terminated.
I 2016.08.02 13:52:59 - Session starting.
I 2016.08.02 13:52:59 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2016.08.02 13:52:59 - IPv6 disabled on network adapter (Ethernet)
I 2016.08.02 13:52:59 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.08.02 13:52:59 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.08.02 13:52:59 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.08.02 13:52:59 - Checking authorization ...
! 2016.08.02 13:53:00 - Connecting to Gacrux (Sweden, Uppsala)
. 2016.08.02 13:53:00 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.02 13:53:00 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.02 13:53:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.02 13:53:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.02 13:53:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:53:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:53:00 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.02 13:53:00 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.02 13:53:00 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.137:443
. 2016.08.02 13:53:00 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.137:443, sid=eee288a2 5af84ee8
. 2016.08.02 13:53:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.02 13:53:00 - OpenVPN > Validating certificate key usage
. 2016.08.02 13:53:00 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.02 13:53:00 - OpenVPN > VERIFY KU OK
. 2016.08.02 13:53:00 - OpenVPN > Validating certificate extended key usage
. 2016.08.02 13:53:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.02 13:53:00 - OpenVPN > VERIFY EKU OK
. 2016.08.02 13:53:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.02 13:53:03 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:53:03 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:53:03 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:53:03 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:53:03 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.02 13:53:03 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.137:443
. 2016.08.02 13:53:05 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.02 13:53:05 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.52.177 255.255.0.0'
. 2016.08.02 13:53:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.02 13:53:06 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.02 13:53:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.02 13:53:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.02 13:53:06 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.02 13:53:06 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.02 13:53:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.02 13:53:06 - OpenVPN > Opened utun device utun0
. 2016.08.02 13:53:06 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.02 13:53:06 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.02 13:53:06 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.02 13:53:06 - OpenVPN > /sbin/ifconfig utun0 10.4.52.177 10.4.52.177 netmask 255.255.0.0 mtu 1500 up
. 2016.08.02 13:53:06 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.52.177 255.255.0.0
. 2016.08.02 13:53:06 - OpenVPN > add net 10.4.0.0: gateway 10.4.52.177
. 2016.08.02 13:53:06 - OpenVPN > /sbin/route add -net 62.102.148.137 192.168.1.1 255.255.255.255
. 2016.08.02 13:53:06 - OpenVPN > add net 62.102.148.137: gateway 192.168.1.1
. 2016.08.02 13:53:06 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:53:06 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:53:06 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:53:06 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:53:06 - Starting Management Interface
. 2016.08.02 13:53:06 - OpenVPN > Initialization Sequence Completed
I 2016.08.02 13:53:06 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.08.02 13:53:06 - DNS of a network adapter forced (Ethernet)
I 2016.08.02 13:53:06 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.02 13:53:06 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.02 13:53:06 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.02 13:53:06 - Flushing DNS
I 2016.08.02 13:53:06 - Checking route
W 2016.08.02 13:53:38 - The request timed out
! 2016.08.02 13:53:38 - Disconnecting
. 2016.08.02 13:53:38 - Management - Send 'signal SIGTERM'
. 2016.08.02 13:53:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.02 13:53:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.02 13:53:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.02 13:53:43 - OpenVPN > /sbin/route delete -net 62.102.148.137 192.168.1.1 255.255.255.255
. 2016.08.02 13:53:43 - OpenVPN > delete net 62.102.148.137: gateway 192.168.1.1
. 2016.08.02 13:53:43 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:53:43 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:53:43 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:53:43 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:53:43 - OpenVPN > Closing TUN/TAP interface
. 2016.08.02 13:53:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.02 13:53:43 - Connection terminated.
I 2016.08.02 13:53:43 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.08.02 13:53:43 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.08.02 13:53:43 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.02 13:53:43 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.02 13:53:43 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.02 13:53:47 - Checking authorization ...
! 2016.08.02 13:53:47 - Connecting to Alphecca (Netherlands, Alblasserdam)
. 2016.08.02 13:53:47 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.02 13:53:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.02 13:53:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.02 13:53:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.02 13:53:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:53:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:53:47 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.02 13:53:47 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.02 13:53:47 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.4:443
. 2016.08.02 13:53:47 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.4:443, sid=a9e0422c 7bc1335f
. 2016.08.02 13:53:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.02 13:53:48 - OpenVPN > Validating certificate key usage
. 2016.08.02 13:53:48 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.02 13:53:48 - OpenVPN > VERIFY KU OK
. 2016.08.02 13:53:48 - OpenVPN > Validating certificate extended key usage
. 2016.08.02 13:53:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.02 13:53:48 - OpenVPN > VERIFY EKU OK
. 2016.08.02 13:53:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.02 13:53:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:53:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:53:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:53:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:53:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.02 13:53:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.4:443
. 2016.08.02 13:53:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.02 13:53:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.23.83 255.255.0.0'
. 2016.08.02 13:53:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.02 13:53:52 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.02 13:53:52 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.02 13:53:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.02 13:53:52 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.02 13:53:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.02 13:53:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.02 13:53:52 - OpenVPN > Opened utun device utun0
. 2016.08.02 13:53:52 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.02 13:53:52 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.02 13:53:52 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.02 13:53:52 - OpenVPN > /sbin/ifconfig utun0 10.4.23.83 10.4.23.83 netmask 255.255.0.0 mtu 1500 up
. 2016.08.02 13:53:52 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.23.83 255.255.0.0
. 2016.08.02 13:53:52 - OpenVPN > add net 10.4.0.0: gateway 10.4.23.83
. 2016.08.02 13:53:53 - OpenVPN > /sbin/route add -net 109.202.107.4 192.168.1.1 255.255.255.255
. 2016.08.02 13:53:53 - OpenVPN > add net 109.202.107.4: gateway 192.168.1.1
. 2016.08.02 13:53:53 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:53:53 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:53:53 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:53:53 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:53:53 - Starting Management Interface
. 2016.08.02 13:53:53 - OpenVPN > Initialization Sequence Completed
I 2016.08.02 13:53:53 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.08.02 13:53:53 - DNS of a network adapter forced (Ethernet)
I 2016.08.02 13:53:53 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.02 13:53:53 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.02 13:53:53 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.02 13:53:53 - Flushing DNS
I 2016.08.02 13:53:53 - Checking route
W 2016.08.02 13:54:43 - The request timed out
! 2016.08.02 13:54:43 - Disconnecting
. 2016.08.02 13:54:43 - Management - Send 'signal SIGTERM'
. 2016.08.02 13:54:43 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.02 13:54:43 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.02 13:54:43 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.02 13:54:48 - OpenVPN > /sbin/route delete -net 109.202.107.4 192.168.1.1 255.255.255.255
. 2016.08.02 13:54:48 - OpenVPN > delete net 109.202.107.4: gateway 192.168.1.1
. 2016.08.02 13:54:48 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:54:48 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:54:48 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:54:48 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:54:48 - OpenVPN > Closing TUN/TAP interface
. 2016.08.02 13:54:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.02 13:54:48 - Connection terminated.
I 2016.08.02 13:54:48 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.08.02 13:54:48 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.08.02 13:54:48 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.02 13:54:48 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.02 13:54:48 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.02 13:54:51 - Checking authorization ...
! 2016.08.02 13:54:52 - Connecting to Alphecca (Netherlands, Alblasserdam)
. 2016.08.02 13:54:52 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.02 13:54:52 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.02 13:54:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.02 13:54:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.02 13:54:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:54:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:54:52 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.02 13:54:52 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.02 13:54:52 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.4:443
. 2016.08.02 13:54:52 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.4:443, sid=0ac3b6f6 04c9bbcd
. 2016.08.02 13:54:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.02 13:54:52 - OpenVPN > Validating certificate key usage
. 2016.08.02 13:54:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.02 13:54:52 - OpenVPN > VERIFY KU OK
. 2016.08.02 13:54:52 - OpenVPN > Validating certificate extended key usage
. 2016.08.02 13:54:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.02 13:54:52 - OpenVPN > VERIFY EKU OK
. 2016.08.02 13:54:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.02 13:54:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:54:55 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:54:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:54:55 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:54:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.02 13:54:55 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.4:443
. 2016.08.02 13:54:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.02 13:54:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.23.83 255.255.0.0'
. 2016.08.02 13:54:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.02 13:54:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.02 13:54:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.02 13:54:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.02 13:54:58 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.02 13:54:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.02 13:54:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.02 13:54:58 - OpenVPN > Opened utun device utun0
. 2016.08.02 13:54:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.02 13:54:58 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.02 13:54:58 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.02 13:54:58 - OpenVPN > /sbin/ifconfig utun0 10.4.23.83 10.4.23.83 netmask 255.255.0.0 mtu 1500 up
. 2016.08.02 13:54:58 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.23.83 255.255.0.0
. 2016.08.02 13:54:58 - OpenVPN > add net 10.4.0.0: gateway 10.4.23.83
. 2016.08.02 13:54:58 - OpenVPN > /sbin/route add -net 109.202.107.4 192.168.1.1 255.255.255.255
. 2016.08.02 13:54:58 - OpenVPN > add net 109.202.107.4: gateway 192.168.1.1
. 2016.08.02 13:54:58 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:54:58 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:54:58 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:54:58 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:54:58 - Starting Management Interface
. 2016.08.02 13:54:58 - OpenVPN > Initialization Sequence Completed
I 2016.08.02 13:54:58 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.08.02 13:54:58 - DNS of a network adapter forced (Ethernet)
I 2016.08.02 13:54:58 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.02 13:54:58 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.02 13:54:58 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.02 13:54:58 - Flushing DNS
I 2016.08.02 13:54:58 - Checking route
W 2016.08.02 13:55:48 - The request timed out
! 2016.08.02 13:55:48 - Disconnecting
. 2016.08.02 13:55:48 - Management - Send 'signal SIGTERM'
. 2016.08.02 13:55:48 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.02 13:55:48 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.02 13:55:48 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.02 13:55:53 - OpenVPN > /sbin/route delete -net 109.202.107.4 192.168.1.1 255.255.255.255
. 2016.08.02 13:55:53 - OpenVPN > delete net 109.202.107.4: gateway 192.168.1.1
. 2016.08.02 13:55:53 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:55:53 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:55:53 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:55:53 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:55:53 - OpenVPN > Closing TUN/TAP interface
. 2016.08.02 13:55:53 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.02 13:55:53 - Connection terminated.
I 2016.08.02 13:55:53 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.08.02 13:55:53 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.08.02 13:55:53 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.02 13:55:53 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.02 13:55:53 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.02 13:55:53 - Cancel requested.
I 2016.08.02 13:55:53 - IPv6 restored on network adapter (Bluetooth DUN)
I 2016.08.02 13:55:53 - IPv6 restored on network adapter (Ethernet)
I 2016.08.02 13:55:53 - IPv6 restored on network adapter (Wi-Fi)
I 2016.08.02 13:55:53 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.08.02 13:55:53 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.08.02 13:55:53 - Session terminated.
I 2016.08.02 13:56:04 - Session starting.
I 2016.08.02 13:56:04 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2016.08.02 13:56:04 - IPv6 disabled on network adapter (Ethernet)
I 2016.08.02 13:56:04 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.08.02 13:56:04 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.08.02 13:56:04 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.08.02 13:56:04 - Checking authorization ...
! 2016.08.02 13:56:05 - Connecting to Celaeno (Netherlands, Alblasserdam)
. 2016.08.02 13:56:05 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.02 13:56:05 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.02 13:56:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.02 13:56:05 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.02 13:56:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:56:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:56:05 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.02 13:56:05 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.02 13:56:05 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.68:443
. 2016.08.02 13:56:05 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.68:443, sid=25733858 b6923056
. 2016.08.02 13:56:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.02 13:56:06 - OpenVPN > Validating certificate key usage
. 2016.08.02 13:56:06 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.02 13:56:06 - OpenVPN > VERIFY KU OK
. 2016.08.02 13:56:06 - OpenVPN > Validating certificate extended key usage
. 2016.08.02 13:56:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.02 13:56:06 - OpenVPN > VERIFY EKU OK
. 2016.08.02 13:56:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.02 13:56:08 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:56:08 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:56:08 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:56:08 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:56:08 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.02 13:56:08 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.68:443
. 2016.08.02 13:56:10 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.02 13:56:10 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.69.175 255.255.0.0'
. 2016.08.02 13:56:10 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.02 13:56:10 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.02 13:56:10 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.02 13:56:10 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.02 13:56:10 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.02 13:56:10 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.02 13:56:10 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.02 13:56:11 - OpenVPN > Opened utun device utun0
. 2016.08.02 13:56:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.02 13:56:11 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.02 13:56:11 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.02 13:56:11 - OpenVPN > /sbin/ifconfig utun0 10.4.69.175 10.4.69.175 netmask 255.255.0.0 mtu 1500 up
. 2016.08.02 13:56:11 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.69.175 255.255.0.0
. 2016.08.02 13:56:11 - OpenVPN > add net 10.4.0.0: gateway 10.4.69.175
. 2016.08.02 13:56:11 - OpenVPN > /sbin/route add -net 213.152.161.68 192.168.1.1 255.255.255.255
. 2016.08.02 13:56:11 - OpenVPN > add net 213.152.161.68: gateway 192.168.1.1
. 2016.08.02 13:56:11 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:56:11 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:56:11 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:56:11 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:56:11 - Starting Management Interface
. 2016.08.02 13:56:11 - OpenVPN > Initialization Sequence Completed
I 2016.08.02 13:56:11 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.08.02 13:56:11 - DNS of a network adapter forced (Ethernet)
I 2016.08.02 13:56:11 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.02 13:56:11 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.02 13:56:11 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.02 13:56:11 - Flushing DNS
I 2016.08.02 13:56:11 - Checking route
W 2016.08.02 13:56:42 - The request timed out
! 2016.08.02 13:56:42 - Disconnecting
. 2016.08.02 13:56:42 - Management - Send 'signal SIGTERM'
. 2016.08.02 13:56:42 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.02 13:56:42 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.02 13:56:42 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.02 13:56:47 - OpenVPN > /sbin/route delete -net 213.152.161.68 192.168.1.1 255.255.255.255
. 2016.08.02 13:56:47 - OpenVPN > delete net 213.152.161.68: gateway 192.168.1.1
. 2016.08.02 13:56:47 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:56:47 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:56:47 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:56:47 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:56:47 - OpenVPN > Closing TUN/TAP interface
. 2016.08.02 13:56:47 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.02 13:56:47 - Connection terminated.
I 2016.08.02 13:56:47 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.08.02 13:56:47 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.08.02 13:56:47 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.02 13:56:47 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.02 13:56:47 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.02 13:56:50 - Checking authorization ...
! 2016.08.02 13:56:50 - Connecting to Alphecca (Netherlands, Alblasserdam)
. 2016.08.02 13:56:51 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.02 13:56:51 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.02 13:56:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.02 13:56:51 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.02 13:56:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:56:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:56:51 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.02 13:56:51 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.02 13:56:51 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.4:443
. 2016.08.02 13:56:51 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.4:443, sid=f84a40d1 64075589
. 2016.08.02 13:56:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.02 13:56:51 - OpenVPN > Validating certificate key usage
. 2016.08.02 13:56:51 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.02 13:56:51 - OpenVPN > VERIFY KU OK
. 2016.08.02 13:56:51 - OpenVPN > Validating certificate extended key usage
. 2016.08.02 13:56:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.02 13:56:51 - OpenVPN > VERIFY EKU OK
. 2016.08.02 13:56:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.02 13:56:53 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:56:53 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:56:53 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:56:53 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:56:53 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.02 13:56:53 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.4:443
. 2016.08.02 13:56:55 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.02 13:56:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.23.83 255.255.0.0'
. 2016.08.02 13:56:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.02 13:56:56 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.02 13:56:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.02 13:56:56 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.02 13:56:56 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.02 13:56:56 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.02 13:56:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.02 13:56:56 - OpenVPN > Opened utun device utun0
. 2016.08.02 13:56:56 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.02 13:56:56 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.02 13:56:56 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.02 13:56:56 - OpenVPN > /sbin/ifconfig utun0 10.4.23.83 10.4.23.83 netmask 255.255.0.0 mtu 1500 up
. 2016.08.02 13:56:56 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.23.83 255.255.0.0
. 2016.08.02 13:56:56 - OpenVPN > add net 10.4.0.0: gateway 10.4.23.83
. 2016.08.02 13:56:56 - OpenVPN > /sbin/route add -net 109.202.107.4 192.168.1.1 255.255.255.255
. 2016.08.02 13:56:56 - OpenVPN > add net 109.202.107.4: gateway 192.168.1.1
. 2016.08.02 13:56:56 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:56:56 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:56:56 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:56:56 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:56:56 - Starting Management Interface
. 2016.08.02 13:56:56 - OpenVPN > Initialization Sequence Completed
I 2016.08.02 13:56:56 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.08.02 13:56:56 - DNS of a network adapter forced (Ethernet)
I 2016.08.02 13:56:56 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.02 13:56:56 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.02 13:56:56 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.02 13:56:56 - Flushing DNS
I 2016.08.02 13:56:56 - Checking route
W 2016.08.02 13:57:46 - The request timed out
! 2016.08.02 13:57:46 - Disconnecting
. 2016.08.02 13:57:46 - Management - Send 'signal SIGTERM'
. 2016.08.02 13:57:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.08.02 13:57:46 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.02 13:57:46 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.08.02 13:57:51 - OpenVPN > /sbin/route delete -net 109.202.107.4 192.168.1.1 255.255.255.255
. 2016.08.02 13:57:51 - OpenVPN > delete net 109.202.107.4: gateway 192.168.1.1
. 2016.08.02 13:57:51 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:57:51 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:57:51 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:57:51 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:57:51 - OpenVPN > Closing TUN/TAP interface
. 2016.08.02 13:57:51 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.08.02 13:57:51 - Connection terminated.
I 2016.08.02 13:57:51 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.08.02 13:57:51 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.08.02 13:57:51 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.08.02 13:57:51 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.08.02 13:57:51 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.08.02 13:57:54 - Checking authorization ...
! 2016.08.02 13:57:54 - Connecting to Alphecca (Netherlands, Alblasserdam)
. 2016.08.02 13:57:54 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.08.02 13:57:54 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.08.02 13:57:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.08.02 13:57:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.08.02 13:57:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:57:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:57:54 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.08.02 13:57:54 - OpenVPN > UDPv4 link local: [undef]
. 2016.08.02 13:57:54 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.4:443
. 2016.08.02 13:57:55 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.4:443, sid=22884e7a 91dc2bc1
. 2016.08.02 13:57:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.08.02 13:57:55 - OpenVPN > Validating certificate key usage
. 2016.08.02 13:57:55 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.08.02 13:57:55 - OpenVPN > VERIFY KU OK
. 2016.08.02 13:57:55 - OpenVPN > Validating certificate extended key usage
. 2016.08.02 13:57:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.08.02 13:57:55 - OpenVPN > VERIFY EKU OK
. 2016.08.02 13:57:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.08.02 13:57:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:57:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:57:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.08.02 13:57:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.08.02 13:57:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.08.02 13:57:57 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.4:443
. 2016.08.02 13:57:59 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.08.02 13:57:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.23.83 255.255.0.0'
. 2016.08.02 13:57:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.08.02 13:57:59 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.08.02 13:57:59 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.08.02 13:57:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.08.02 13:57:59 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.08.02 13:57:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.08.02 13:58:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.08.02 13:58:00 - OpenVPN > Opened utun device utun0
. 2016.08.02 13:58:00 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.08.02 13:58:00 - OpenVPN > /sbin/ifconfig utun0 delete
. 2016.08.02 13:58:00 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.08.02 13:58:00 - OpenVPN > /sbin/ifconfig utun0 10.4.23.83 10.4.23.83 netmask 255.255.0.0 mtu 1500 up
. 2016.08.02 13:58:00 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.23.83 255.255.0.0
. 2016.08.02 13:58:00 - OpenVPN > add net 10.4.0.0: gateway 10.4.23.83
. 2016.08.02 13:58:00 - OpenVPN > /sbin/route add -net 109.202.107.4 192.168.1.1 255.255.255.255
. 2016.08.02 13:58:00 - OpenVPN > add net 109.202.107.4: gateway 192.168.1.1
. 2016.08.02 13:58:00 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:58:00 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:58:00 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.08.02 13:58:00 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.08.02 13:58:00 - Starting Management Interface
. 2016.08.02 13:58:00 - OpenVPN > Initialization Sequence Completed
I 2016.08.02 13:58:00 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.08.02 13:58:00 - DNS of a network adapter forced (Ethernet)
I 2016.08.02 13:58:00 - DNS of a network adapter forced (Wi-Fi)
I 2016.08.02 13:58:00 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.08.02 13:58:00 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.08.02 13:58:00 - Flushing DNS
I 2016.08.02 13:58:00 - Checking route
Same issue here with linux mint 17.3 and client version 2.10.1.
Always getting "Error getting response stream (Write: The authentication or decryption has failed.): SendFailure" after check route for most of the servers. Yesterday everything was working flawlessly and no system updates were installed from yesterday to today.
As found out by dafnar, I was able to connect to Chort server.
Some of the servers that were not working before are now working (mainly testing with the Dutch ones). Connected to Anser now.
Spoke too soon: the servers I am testing (again, mainly the Dutch ones) disconnect after a few minutes!
After a few minutes of a successful connection, when the client updates the servers data, this is what happens:
. 2016.08.02 14:11:30 - Updating systems & servers data ...
. 2016.08.02 14:11:30 - Systems & servers data update completed
. 2016.08.02 14:12:58 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.08.02 14:12:58 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.08.02 14:12:58 - OpenVPN > Restart pause, 2 second(s)
! 2016.08.02 14:12:58 - Disconnecting
. 2016.08.02 14:12:58 - Management - Send 'signal SIGTERM'
. 2016.08.02 14:12:58 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.08.02 14:12:58 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.08.02 14:12:58 - OpenVPN > Assertion failed at misc.c:785
. 2016.08.02 14:12:58 - OpenVPN > Exiting due to fatal error
. 2016.08.02 14:12:58 - Connection terminated.
