Not connected, Your IP: 3.144.36.141
please follow the instructions for iOS in our webs site.
If you need no communications when VPN connection goes down for leaks prevention etc., please enable "Seamless tunnel" option on openvpn-connect and also activate option to run and connect at system startup.
How do I activate "option to run and connect at system startup"?
did you find the answer by now?
No, but everything else is working fine.
​In Your iPhone settings app, scroll to the bottom will find additional settings for OpenVPN connect amongst others. There You can set 'seamless tunnel' and some other, more advanced settings.
