Not connected, Your IP: 216.73.216.195
Tim Jenson
Block WebRTC detection with Chrome using uBlock Orgin
Block you geographic location in Chrome. A work around for the Block WebRTC. If you download the plug in uBlock Orgin. Use uBlock ORGIN not uBlock without the Orgin after it. There is an option in the options that says "Prevent WebRTC from leaking local IP address" click the circle next to it.
I've just started using Chromium and enabled this option. As a regular FF user I've not thought much about the WebRTC leak in chrome/chromium. Ublock Origin appears to block my private IP but not my public IP. Is this a problem? I'm guessing not unless this "leak" can be used to unmask my local IP in any way?
Best,
Rabbit
