Quaramorph 0 Posted ... How do I bypass the VPN for certain IP addresses (so that I can connect to them directly through my router)? I can't seem to find any information via Google. Just to warn you, I am a noob. Quote Share this post Link to post
Staff 10513 Posted ... How do I bypass the VPN for certain IP addresses (so that I can connect to them directly through my router)? I can't seem to find any information via Google. Just to warn you, I am a noob.Hello!Please see here (assuming that you run Windows; adjustments for different OS are anyway easy):https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=6621&Itemid=142#6691Kind regards Quote Share this post Link to post
NaDre 161 Posted ... If you need a better understanding of the route command and the routing table are about, I explained a little bit more about it in this post: https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=7933&limit=6&limitstart=6&Itemid=142#8020 The context was different though. It was part of (an admittedly cursory) explanation of how to use the VPN only for torrenting. Quote Share this post Link to post
