schwede 0 Posted ... Hello, I run Eddie 2.27.2 on Windows Server 2019. My network has a firewall/filter that treats unknown UDP traffic very strictly, hich slows VPN tunnels down a lot (WireGuard only reached about 300 Kbps, OpenVPN about 70 Mbps, while the connection without VPN runs at about 1 Gbps). A filter for WireGuard and OpenVPN can be set up, but it only works for a fixed LOCAL UDP port on my machine (WireGuard 51820, OpenVPN 1194), not for the remote ports of the VPN servers. So I need Eddie to use a fixed local port, but I did not find a way: OpenVPN: - In Settings > OpenVPN directives I set "Use only Custom directives" and added "lport 1194" (without the "nobind" line). Connecting fails with: "OpenVPN > Options error: --lport and --nobind don't make sense when used together". - When I additionally add "bind", it fails with: "--bind and --nobind can't be used together". - So it seems Eddie adds "nobind" to the generated config by itself, even when the base directives are not used. - Running openvpn.exe manually with a config from the Config Generator (with lport 1194 and without nobind) works fine, so this is not a problem of the servers. WireGuard: - I did not find settings. Just MTU. Questions: 1. Is "nobind" hard-coded in Eddie, and is there a supported way to use a fixed local port for OpenVPN? 2. Is there a way to set the WireGuard local port (ListenPort) in Eddie? 3. If not, could this be added as an option in a future version? It would help everyone behind networks with UDP filtering or strict firewall rules. Thank you and best regards Quote Share this post Link to post
Tech Jedi Alex 1585 Posted ... (edited) Eddie silently ignores all changes to the base directives if in Append mode, and uses Base + Custom in Custom mode, so remove nobind from there and add your custom directives on the left, then set it to Custom mode. Little tip: To check the OpenVPN config Eddie would use to connect to a server, in the Servers/Countries tab right click on an entry and select More. Edited ... by Tech Jedi Alex Corrections 1 schwede reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
schwede 0 Posted ... Thank you for the tip, I tried it, but unfortunately it does not solve it. I removed nobind from the Base directives and put "lport 1194" into the Custom directives. I tried both modes ("Append Custom directives" and "Use only Custom directives"). In both cases the config shown under Servers > right click > More still contains "nobind", without any level comment, right after sndbuf/rcvbuf: sndbuf 262144 rcvbuf 262144 nobind lport 1194 # Custom level remote-cert-tls server # Provider level When connecting OpenVPN then stops with: "Options error: --lport and --nobind don't make sense when used together". f I also add "bind" to the custom directives, it stops with: "--bind and --nobind can't be used together". So the "nobind" line is added by Eddie itself, not by the base directives. For comparison: if I start openvpn.exe manually with a config from the Config Generator (with lport 1194 and without nobind), the connection works. For WireGuard, the config under More has no ListenPort, and I found no setting for it in Settings > WireGuard (only the MTU). My questions: 1. Where does the "nobind" line come from in Eddie 2.27.2 (Windows), and is there a supported way to disable it so a fixed local port can be used? 2. Is there a way to set the WireGuard ListenPort in Eddie? 3. If not could an option for a fixed local UDP port (OpenVPN and WireGuard) be added in a future version? It would help in networks where a firewall or filter only works with a fixed local port. Thank you! Quote Share this post Link to post
Tech Jedi Alex 1585 Posted ... Cannot reproduce. Set mode to Only use custom directives, remove nobind on the right and add bind to the left, save, and nobild becomes bind. This on Linux, using v2.27.2. Can any other Windows user reproduce schwede's finding? On 10/29/2026 at 11:59 PM, schwede said: 1. Where does the "nobind" line come from in Eddie 2.27.2 (Windows), and is there a supported way to disable it so a fixed local port can be used? Don't run in circles now. Setting Custom mode removes it if it's removed from the built-in directives. On 10/29/2026 at 11:59 PM, schwede said: 2. Is there a way to set the WireGuard ListenPort in Eddie? That, on the other hand, is not possible. Custom directives are only supported for OpenVPN for now, unfortunately. So #3 may be forwarded to the dev. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10715 Posted ... @schwede Hello! The "nobind" line does not seem to come from the base directives, which would explain why removing it there or switching between "Append" and "Use only Custom directives" changes nothing. Eddie adds it by itself while it builds the configuration. If no network interface is selected for the connection, it would append "nobind". If one is selected, it would write "local" followed by the IP address of that interface instead. That would also explain why the line has no level comment in the preview. A solution should already exist, worth a try. In the custom directives, a directive name preceded by a minus sign will remove that directive from the final configuration and the custom directives appear to be applied after the "nobind" above. So you could try putting these two lines in Settings > OpenVPN directives, custom directives, in either mode: -nobind lport 1194 "lport" implies "bind", so "bind" should not be needed. Before connecting, you could check the result with right click on a server > More: "nobind" should be gone and "lport 1194" should be there. An alternative might be to select your LAN interface or IP in Settings > Networking (interface used for the connection): Eddie should then write "local" followed by your IP address instead of "nobind", and "lport 1194" in the custom directives should bind to that address and port. In this case, however, the preview under More would probably still show "nobind", because the interface seems to be resolved only at connection time, so the first method would be easier to verify. WireGuard: as far as we can see, Eddie currently has no option for the local port (ListenPort), so the port would be chosen randomly at each connection. By the way, a firewall that can make an exception only for a fixed local source port, and not for the remote address or port of the traffic, is highly unusual. Firewalls and traffic filters normally match outgoing UDP flows on the destination, which here would be the AirVPN entry IP addresses and ports, and that would cover both OpenVPN and WireGuard without touching the local port at all. Could you tell us which firewall or filter this is (product, model and version, or software and version) and, if possible, how the rule is configured? There might be a simpler way to solve the problem on that side. Please let us know whether the OpenVPN solution works for you. Kind regards Quote Share this post Link to post
