moejoe
ANSWERED Whitelist under eddie Android seems not working
Device : Xiaomi redmi6 pad
Connection: Wireguard udp
System: Xiaomi hyper os 2.0.16.0 based on Android 14
Excluded APP: DISNEY+
AirVPN Version: Eddie Android version: 4.0.1
Hello folks,
I tried on my system the option Whitelist an specific app from the vpn.
But it seems not working.
 The airvpn dns leaktest shows still my provider id.
The normal mode without an exclusion works flawless.
Regards
Black list enabled: all traffic inside the VPN tunnel except the traffic of the black listed applications which goes outside the tunnel.
White list enabled: all traffic outside the VPN tunnel except the traffic of the white listed applications which goes inside the tunnel.
When you define a whitelist with a single app for per-app traffic splitting purposes, only that app traffic will be tunneled. The system process traffic will not be tunneled, and any other non-white listed app traffic will not be tunneled. So the behavior you observe seems just fine, but please feel free to elaborate if we misunderstood.
Oh, ok i thought its from the app perspective like an dns blocking list.
and not from an security perspective.
It was a little bit confusing for me
Thnx for clarify this
Regards
