Not connected, Your IP: 216.73.216.190
AirVPN_fan888
ANSWERED [MAC] Eddie Connect/Disconnect Cycle (After following advice re:Terminal)
I've seen it posted elsewhere and I've attempted to follow the advice that solved the problem, but it hasn't solved anything yet.
Updated Eddie today, but can't escape the log in/log out cycle. I've posted the whole system report because I don't know what is important.
Thanks in advance.
Tahoe 26.4.1
_________________________
Eddie System/Environment Report - 5/15/2026 - 9:57 PM UTC
Eddie version: 2.24.6
Eddie OS build: macos_arm64
Eddie architecture: x64
OS type: MacOS
OS name: macOS 26.4.1
OS version: 26.4.1
OS architecture: arm64
Framework: v4.0.30319
OpenVPN: 2.6.12 - OpenSSL 3.3.2 3 Sep 2024, LZO 2.10 (/Applications/Eddie 2.app/Contents/MacOS/openvpn)
Hummingbird: 3.3.2 - Hummingbird - OpenVPN3 Client 1.3.0 - 1 June 2023 (/Applications/Eddie 2.app/Contents/MacOS/hummingbird)
WireGuard: Not available
SSH: OpenSSH_10.2p1, LibreSSL 3.3.6 (/usr/bin/ssh)
SSL: 5.57 (/Applications/Eddie 2.app/Contents/MacOS/stunnel)
Profile path: /Users/temp/.config/eddie/default.profile
Data path: /Users/temp/.config/eddie
Application path: /Applications/Eddie 2.app/Contents/MacOS
Executable path: /Applications/Eddie 2.app/Contents/MacOS/Eddie-UI
Command line arguments: (0 args)
Network Lock Active: No
Connected to VPN: No
OS support IPv4: Yes
OS support IPv6: Yes
Detected DNS: 192.168.1.1,2603:8000:e300:3a92::1
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: 170 ms
Test Ping IPv6: 169 ms
Test HTTP IPv4: Error: Fetch url error:Timeout was reached
Test HTTP IPv6: Error: Fetch url error:Timeout was reached
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
connect: True
netlock: True
ui.skip.netlock.confirm: True
gui.osx.sysbar.show_speed: True
Logs:
. 2026.05.15 14:49:47 - Eddie version: 2.24.6 / macos_arm64, System: MacOS, Name: macOS 26.4.1, Version: 26.4.1, Framework: v4.0.30319
. 2026.05.15 14:49:47 - Raise system privileges
. 2026.05.15 14:50:15 - Collect network information
. 2026.05.15 14:50:18 - Reading options from /Users/temp/.config/eddie/default.profile
. 2026.05.15 14:50:18 - OpenVPN - Version: 2.6.12 - OpenSSL 3.3.2 3 Sep 2024, LZO 2.10 (/Applications/Eddie 2.app/Contents/MacOS/openvpn)
. 2026.05.15 14:50:18 - SSH - Version: OpenSSH_10.2p1, LibreSSL 3.3.6 (/usr/bin/ssh)
. 2026.05.15 14:50:18 - SSL - Version: 5.57 (/Applications/Eddie 2.app/Contents/MacOS/stunnel)
. 2026.05.15 14:50:19 - Activation of Network Lock - macOS - PF
I 2026.05.15 14:50:21 - Ready
. 2026.05.15 14:50:23 - Collect information about AirVPN completed
I 2026.05.15 14:50:25 - Session starting.
. 2026.05.15 14:50:25 - Waiting for latency tests (253 to go)
. 2026.05.15 14:50:26 - Collect information about AirVPN completed
. 2026.05.15 14:50:26 - Waiting for latency tests (94 to go)
I 2026.05.15 14:50:29 - Checking authorization ...
! 2026.05.15 14:50:30 - Connecting to Maia (United States of America, Los Angeles)
. 2026.05.15 14:50:30 - Routes, add 198.54.129.54/32 for interface "en0".
. 2026.05.15 14:50:30 - WireGuard > Setup start
E 2026.05.15 14:50:31 - WireGuard > Error: Executable '/Applications/Eddie 2.app/Contents/MacOS/wireguard-go' not allowed: Not owned by root;
. 2026.05.15 14:50:31 - WireGuard > Stopping
. 2026.05.15 14:50:31 - WireGuard > end
! 2026.05.15 14:50:31 - Disconnecting
. 2026.05.15 14:50:31 - Routes, delete 198.54.129.54/32 for interface "en0".
. 2026.05.15 14:50:31 - Collect network information
. 2026.05.15 14:50:33 - Connection terminated.
I 2026.05.15 14:50:36 - Checking authorization ...
! 2026.05.15 14:50:37 - Connecting to Revati (United States of America, Los Angeles)
. 2026.05.15 14:50:37 - Routes, add 198.54.129.125/32 for interface "en0".
. 2026.05.15 14:50:37 - WireGuard > Setup start
E 2026.05.15 14:50:37 - WireGuard > Error: Executable '/Applications/Eddie 2.app/Contents/MacOS/wireguard-go' not allowed: Not owned by root;
. 2026.05.15 14:50:37 - WireGuard > Stopping
. 2026.05.15 14:50:37 - WireGuard > end
! 2026.05.15 14:50:37 - Disconnecting
. 2026.05.15 14:50:37 - Routes, delete 198.54.129.125/32 for interface "en0".
. 2026.05.15 14:50:37 - Collect network information
. 2026.05.15 14:50:39 - Connection terminated.
I 2026.05.15 14:50:43 - Checking authorization ...
! 2026.05.15 14:50:43 - Connecting to Sarin (United States of America, Los Angeles)
. 2026.05.15 14:50:43 - Routes, add 198.54.129.62/32 for interface "en0".
. 2026.05.15 14:50:44 - WireGuard > Setup start
E 2026.05.15 14:50:44 - WireGuard > Error: Executable '/Applications/Eddie 2.app/Contents/MacOS/wireguard-go' not allowed: Not owned by root;
. 2026.05.15 14:50:44 - WireGuard > Stopping
. 2026.05.15 14:50:44 - WireGuard > end
! 2026.05.15 14:50:44 - Disconnecting
. 2026.05.15 14:50:44 - Routes, delete 198.54.129.62/32 for interface "en0".
. 2026.05.15 14:50:44 - Collect network information
. 2026.05.15 14:50:46 - Connection terminated.
I 2026.05.15 14:50:49 - Checking authorization ...
! 2026.05.15 14:50:50 - Connecting to Xamidimura (United States of America, Los Angeles)
. 2026.05.15 14:50:50 - Routes, add 198.54.129.46/32 for interface "en0".
. 2026.05.15 14:50:50 - WireGuard > Setup start
E 2026.05.15 14:50:50 - WireGuard > Error: Executable '/Applications/Eddie 2.app/Contents/MacOS/wireguard-go' not allowed: Not owned by root;
. 2026.05.15 14:50:50 - WireGuard > Stopping
. 2026.05.15 14:50:50 - WireGuard > end
! 2026.05.15 14:50:50 - Disconnecting
. 2026.05.15 14:50:51 - Routes, delete 198.54.129.46/32 for interface "en0".
. 2026.05.15 14:50:51 - Collect network information
. 2026.05.15 14:50:53 - Connection terminated.
I 2026.05.15 14:50:56 - Checking authorization ...
! 2026.05.15 14:50:57 - Connecting to Sheratan (United States of America, Phoenix, Arizona)
. 2026.05.15 14:50:57 - Routes, add 198.44.133.78/32 for interface "en0".
. 2026.05.15 14:50:57 - WireGuard > Setup start
E 2026.05.15 14:50:57 - WireGuard > Error: Executable '/Applications/Eddie 2.app/Contents/MacOS/wireguard-go' not allowed: Not owned by root;
. 2026.05.15 14:50:57 - WireGuard > Stopping
. 2026.05.15 14:50:57 - WireGuard > end
! 2026.05.15 14:50:57 - Disconnecting
. 2026.05.15 14:50:57 - Routes, delete 198.44.133.78/32 for interface "en0".
. 2026.05.15 14:50:57 - Collect network information
. 2026.05.15 14:50:59 - Connection terminated.
I 2026.05.15 14:51:03 - Checking authorization ...
! 2026.05.15 14:51:03 - Connecting to Khambalia (United States of America, Phoenix, Arizona)
. 2026.05.15 14:51:03 - Routes, add 198.44.133.86/32 for interface "en0".
. 2026.05.15 14:51:04 - WireGuard > Setup start
E 2026.05.15 14:51:04 - WireGuard > Error: Executable '/Applications/Eddie 2.app/Contents/MacOS/wireguard-go' not allowed: Not owned by root;
. 2026.05.15 14:51:04 - WireGuard > Stopping
. 2026.05.15 14:51:04 - WireGuard > end
! 2026.05.15 14:51:04 - Disconnecting
. 2026.05.15 14:51:04 - Routes, delete 198.44.133.86/32 for interface "en0".
. 2026.05.15 14:51:04 - Collect network information
. 2026.05.15 14:51:06 - Connection terminated.
I 2026.05.15 14:51:09 - Checking authorization ...
! 2026.05.15 14:51:10 - Connecting to Nahn (Canada, Vancouver)
. 2026.05.15 14:51:10 - Routes, add 192.30.89.69/32 for interface "en0".
. 2026.05.15 14:51:10 - WireGuard > Setup start
E 2026.05.15 14:51:11 - WireGuard > Error: Executable '/Applications/Eddie 2.app/Contents/MacOS/wireguard-go' not allowed: Not owned by root;
. 2026.05.15 14:51:11 - WireGuard > Stopping
. 2026.05.15 14:51:11 - WireGuard > end
! 2026.05.15 14:51:11 - Disconnecting
. 2026.05.15 14:51:11 - Routes, delete 192.30.89.69/32 for interface "en0".
. 2026.05.15 14:51:11 - Collect network information
. 2026.05.15 14:51:13 - Connection terminated.
I 2026.05.15 14:51:16 - Cancel requested.
! 2026.05.15 14:51:16 - Session terminated.
! 2026.05.15 14:51:18 - Deactivation of Network Lock
I 2026.05.15 14:56:30 - Session starting.
. 2026.05.15 14:56:30 - Activation of Network Lock - macOS - PF
I 2026.05.15 14:56:32 - Checking authorization ...
! 2026.05.15 14:56:33 - Connecting to Chamukuy (Canada, Toronto, Ontario)
. 2026.05.15 14:56:33 - Routes, add 198.44.157.133/32 for interface "en0".
. 2026.05.15 14:56:33 - WireGuard > Setup start
E 2026.05.15 14:56:33 - WireGuard > Error: Executable '/Applications/Eddie 2.app/Contents/MacOS/wireguard-go' not allowed: Not owned by root;
. 2026.05.15 14:56:33 - WireGuard > Stopping
. 2026.05.15 14:56:33 - WireGuard > end
! 2026.05.15 14:56:33 - Disconnecting
. 2026.05.15 14:56:33 - Routes, delete 198.44.157.133/32 for interface "en0".
. 2026.05.15 14:56:33 - Collect network information
. 2026.05.15 14:56:35 - Connection terminated.
I 2026.05.15 14:56:39 - Checking authorization ...
! 2026.05.15 14:56:39 - Connecting to Guniibuu (United States of America, Phoenix, Arizona)
. 2026.05.15 14:56:39 - Routes, add 198.44.133.70/32 for interface "en0".
. 2026.05.15 14:56:39 - WireGuard > Setup start
E 2026.05.15 14:56:40 - WireGuard > Error: Executable '/Applications/Eddie 2.app/Contents/MacOS/wireguard-go' not allowed: Not owned by root;
. 2026.05.15 14:56:40 - WireGuard > Stopping
. 2026.05.15 14:56:40 - WireGuard > end
! 2026.05.15 14:56:40 - Disconnecting
. 2026.05.15 14:56:40 - Routes, delete 198.44.133.70/32 for interface "en0".
. 2026.05.15 14:56:40 - Collect network information
. 2026.05.15 14:56:42 - Connection terminated.
I 2026.05.15 14:56:44 - Cancel requested.
. 2026.05.15 14:56:44 - Deactivation of Network Lock
! 2026.05.15 14:56:44 - Session terminated.
Network Info:
    "routes": [
            "destination": "0.0.0.0\/0",
            "expire": "",
            "flags": "UGScg",
            "gateway": "192.168.1.1",
            "interface": "en0",
            "mtu": "1500",
            "refs": "267",
            "rt_ifa": "192.168.1.38",
            "use": "2455"
            "destination": "127",
            "expire": "",
            "flags": "UCS",
            "gateway": "127.0.0.1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "127.0.0.1",
            "use": "0"
            "destination": "127.0.0.1\/32",
            "expire": "",
            "flags": "UH",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "3",
            "use": "1155486"
            "destination": "169.254\/32",
            "expire": "!",
            "flags": "UCS",
            "gateway": "link#11",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "192.168.1\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "4",
            "use": "0"
            "destination": "192.168.1.1\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "1194",
            "flags": "UHLWIir",
            "gateway": "8:7b:12:52:7f:c0",
            "interface": "en0",
            "mtu": "1500",
            "refs": "39",
            "use": "544"
            "destination": "192.168.1.38\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "",
            "flags": "UHLWI",
            "gateway": "72:83:6c:59:a6:39",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "1626"
            "destination": "192.168.1.95\/32",
            "expire": "1152",
            "flags": "UHLWIi",
            "gateway": "2:98:88:21:c3:af",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "236"
            "destination": "192.168.1.145\/32",
            "expire": "353",
            "flags": "UHLWI",
            "gateway": "fc:3f:db:2c:d8:d1",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "29"
            "destination": "192.168.1.255\/32",
            "expire": "!",
            "flags": "UHLWbI",
            "gateway": "ff:ff:ff:ff:ff:ff",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "63"
            "destination": "224.0.0\/4",
            "expire": "!",
            "flags": "UmCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "224.0.0.251\/32",
            "expire": "",
            "flags": "UHmLWI",
            "gateway": "1:0:5e:0:0:fb",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "255.255.255.255\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "::\/0",
            "expire": "",
            "flags": "UGcg",
            "gateway": "fe80::a7b:12ff:fe52:7fc0",
            "interface": "en0",
            "mtu": "1500",
            "refs": "36",
            "rt_ifa": "fe80::1c24:e81b:5f13:3dae%en0",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "gateway": "fe80::",
            "interface": "utun0",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "fe80::fd98:59f3:da79:41f8%utun0",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun1",
            "mtu": "1380",
            "refs": "0",
            "rt_ifa": "fe80::bb34:5061:787d:adca%utun1",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun2",
            "mtu": "2000",
            "refs": "0",
            "rt_ifa": "fe80::6ed3:cf78:67bf:80%utun2",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun3",
            "mtu": "1000",
            "refs": "0",
            "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun3",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun5",
            "mtu": "1380",
            "refs": "0",
            "rt_ifa": "fe80::742:f5af:c5d7:c01e%utun5",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun6",
            "mtu": "1380",
            "refs": "0",
            "rt_ifa": "fe80::e4de:d9bc:ce9a:371d%utun6",
            "use": "0"
            "destination": "::1\/128",
            "expire": "",
            "flags": "UHL",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "rt_ifa": "::1",
            "use": "888"
            "destination": "2603:8000:e300:3a92::\/64",
            "expire": "",
            "flags": "UC",
            "interface": "en0",
            "mtu": "1500",
            "refs": "5",
            "use": "0"
            "destination": "2603:8000:e300:3a92::1\/128",
            "expire": "",
            "flags": "UHLWIi",
            "interface": "en0",
            "mtu": "1500",
            "refs": "2",
            "use": "960"
            "destination": "2603:8000:e300:3a92::1196\/128",
            "expire": "",
            "flags": "UHL",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "2603:8000:e300:3a92::1196",
            "use": "0"
            "destination": "2603:8000:e300:3a92::1960\/128",
            "expire": "",
            "flags": "UHLWIi",
            "interface": "en0",
            "mtu": "1500",
            "refs": "7",
            "use": "1834"
            "destination": "2603:8000:e300:3a92:860:5c1d:ae22:6dd2\/128",
            "expire": "",
            "flags": "UHL",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "2603:8000:e300:3a92:860:5c1d:ae22:6dd2",
            "use": "0"
            "destination": "2603:8000:e300:3a92:8b3:e8e0:9db3:2777\/128",
            "expire": "",
            "flags": "UHLWI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "38"
            "destination": "2603:8000:e300:3a92:343f:90a0:7233:c134\/128",
            "expire": "",
            "flags": "UHL",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "2603:8000:e300:3a92:343f:90a0:7233:c134",
            "use": "2959"
            "destination": "2603:8000:e300:3a92:58b2:e1e5:8dbf:fb72\/128",
            "expire": "",
            "flags": "UHLWI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "26"
            "destination": "fe80::\/64",
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "rt_ifa": "fe80::1%lo0",
            "use": "0"
            "destination": "fe80::1\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "17"
            "expire": "",
            "flags": "UCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "3",
            "use": "0"
            "destination": "fe80::a7b:12ff:fe52:7fc0\/128",
            "expire": "",
            "flags": "UHLWIir",
            "interface": "en0",
            "mtu": "1500",
            "refs": "38",
            "use": "113"
            "destination": "fe80::cfd:9592:2a6f:962\/128",
            "expire": "",
            "flags": "UHLWIi",
            "interface": "en0",
            "mtu": "1500",
            "refs": "2",
            "use": "1301"
            "destination": "fe80::1c24:e81b:5f13:3dae\/128",
            "expire": "",
            "flags": "UHLI",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "4"
            "destination": "fe80::e018:b7ff:fe5b:3628\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "e2:18:b7:5b:36:28",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "fe80::e018:b7ff:fe5b:3628%awdl0",
            "use": "0"
            "expire": "",
            "flags": "UHLI",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "fe80::e018:b7ff:fe5b:3628%llw0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::fd98:59f3:da79:41f8",
            "mtu": "1500",
            "refs": "2",
            "use": "0"
            "destination": "fe80::fd98:59f3:da79:41f8\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#15",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::bb34:5061:787d:adca",
            "mtu": "1380",
            "refs": "2",
            "use": "0"
            "destination": "fe80::bb34:5061:787d:adca\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#16",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::6ed3:cf78:67bf:80",
            "mtu": "2000",
            "refs": "2",
            "use": "0"
            "destination": "fe80::6ed3:cf78:67bf:80\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#17",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::ce81:b1c:bd2c:69e",
            "mtu": "1000",
            "refs": "2",
            "use": "0"
            "destination": "fe80::ce81:b1c:bd2c:69e\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#18",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::742:f5af:c5d7:c01e",
            "mtu": "1380",
            "refs": "2",
            "use": "0"
            "destination": "fe80::742:f5af:c5d7:c01e\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#20",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::e4de:d9bc:ce9a:371d",
            "mtu": "1380",
            "refs": "2",
            "use": "0"
            "destination": "fe80::e4de:d9bc:ce9a:371d\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#21",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "destination": "ff00::\/8",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "fe80::c20:f18:67b2:68a5%en0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "gateway": "link#13",
            "interface": "awdl0",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "fe80::bce2:45ff:fe4b:189e%awdl0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "gateway": "link#14",
            "interface": "llw0",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "fe80::bce2:45ff:fe4b:189e%llw0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "destination": "ff01::\/32",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "destination": "ff02::\/32",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
    "ipv4-default-gateway": "192.168.1.1",
    "ipv4-default-interface": "en0",
    "ipv6-default-gateway": "fe80::a7b:12ff:fe52:7fc0",
    "ipv6-default-interface": "en0",
    "interfaces": [
            "friendly": "lo0",
            "id": "lo0",
            "name": "lo0",
            "description": "lo0",
            "type": "Loopback",
            "status": "Up",
            "bytes_received": "0",
            "bytes_sent": "0",
            "support_ipv4": true,
            "support_ipv6": true,
            "ips": [
                "127.0.0.1",
                "::1",
                "fe80::1"
            "bind": true
            "friendly": "gif0",
            "id": "gif0",
            "name": "gif0",
            "description": "gif0",
            "type": "Unknown",
            "status": "Unknown",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "stf0",
            "id": "stf0",
            "name": "stf0",
            "description": "stf0",
            "type": "Unknown",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "anpi1",
            "id": "anpi1",
            "name": "anpi1",
            "description": "anpi1",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "anpi0",
            "id": "anpi0",
            "name": "anpi0",
            "description": "anpi0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Ethernet Adapter (en3)",
            "id": "en3",
            "name": "en3",
            "description": "en3",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Ethernet Adapter (en4)",
            "id": "en4",
            "name": "en4",
            "description": "en4",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 1",
            "id": "en1",
            "name": "en1",
            "description": "en1",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 2",
            "id": "en2",
            "name": "en2",
            "description": "en2",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt Bridge",
            "id": "bridge0",
            "name": "bridge0",
            "description": "bridge0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "ap1",
            "id": "ap1",
            "name": "ap1",
            "description": "ap1",
            "type": "Ethernet",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Wi-Fi",
            "id": "en0",
            "name": "en0",
            "description": "en0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::1c24:e81b:5f13:3dae",
                "192.168.1.38"
            "bind": true
            "friendly": "awdl0",
            "id": "awdl0",
            "name": "awdl0",
            "description": "awdl0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::e018:b7ff:fe5b:3628"
            "bind": true
            "friendly": "llw0",
            "id": "llw0",
            "name": "llw0",
            "description": "llw0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun0",
            "id": "utun0",
            "name": "utun0",
            "description": "utun0",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun1",
            "id": "utun1",
            "name": "utun1",
            "description": "utun1",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun2",
            "id": "utun2",
            "name": "utun2",
            "description": "utun2",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun3",
            "id": "utun3",
            "name": "utun3",
            "description": "utun3",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun5",
            "id": "utun5",
            "name": "utun5",
            "description": "utun5",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun6",
            "id": "utun6",
            "name": "utun6",
            "description": "utun6",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
ifconfig:
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
    options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
    inet 127.0.0.1 netmask 0xff000000
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
    nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
anpi1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=400<CHANNEL_IO>
    ether 3a:67:8f:bf:6e:85
    media: none
    status: inactive
anpi0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether 3a:67:8f:bf:6e:84
    media: none
    status: inactive
en3: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether 3a:67:8f:bf:6e:64
    media: none
    status: inactive
en4: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether 3a:67:8f:bf:6e:65
    media: none
    status: inactive
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    options=460<TSO4,TSO6,CHANNEL_IO>
    ether 36:28:59:6f:91:00
    media: autoselect <full-duplex>
    status: inactive
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 36:28:59:6f:91:04
    status: inactive
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=63<RXCSUM,TXCSUM,TSO4,TSO6>
    Configuration:
        id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
        maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
        root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
        ipfilter disabled flags 0x0
    member: en1 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 8 priority 0 path cost 0
    member: en2 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 9 priority 0 path cost 0
    media: <unknown type>
    status: inactive
ap1: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
    ether b2:57:4a:ff:0e:c6
    media: autoselect (none)
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
    ether 72:83:6c:59:a6:39
    inet6 fe80::1c24:e81b:5f13:3dae%en0 prefixlen 64 secured scopeid 0xb
    inet6 2603:8000:e300:3a92:860:5c1d:ae22:6dd2 prefixlen 64 autoconf secured
    inet6 2603:8000:e300:3a92:343f:90a0:7233:c134 prefixlen 64 autoconf temporary
    inet6 2603:8000:e300:3a92::1196 prefixlen 64 dynamic
    inet 192.168.1.38 netmask 0xffffff00 broadcast 192.168.1.255
    media: autoselect
    status: active
awdl0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether e2:18:b7:5b:36:28
    inet6 fe80::e018:b7ff:fe5b:3628%awdl0 prefixlen 64 scopeid 0xd
    media: autoselect
    status: active
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    inet6 fe80::e018:b7ff:fe5b:3628%llw0 prefixlen 64 scopeid 0xe
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
    inet6 fe80::fd98:59f3:da79:41f8%utun0 prefixlen 64 scopeid 0xf
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
    inet6 fe80::bb34:5061:787d:adca%utun1 prefixlen 64 scopeid 0x10
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
    inet6 fe80::6ed3:cf78:67bf:80%utun2 prefixlen 64 scopeid 0x11
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000
    inet6 fe80::ce81:b1c:bd2c:69e%utun3 prefixlen 64 scopeid 0x12
utun5: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
    inet6 fe80::742:f5af:c5d7:c01e%utun5 prefixlen 64 scopeid 0x14
utun6: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
    inet6 fe80::e4de:d9bc:ce9a:371d%utun6 prefixlen 64 scopeid 0x15
______________________________________________
NOTE:
  1. Got message to switch to silicon version as current version was to be no longer supported (imminently)
  2. Downloaded eddie-ui_2.24.6_macos-10.15_arm64_portable
  3. Unpacked & unable to connect after multiple tweaks. Posted help request on Airvpn.
  4. Returned to "old" Eddie version: 2.24.6—Eddie OS build: macos_arm64
  5. Realised they are the save version. Baffled.
Edited ... by Tech Jedi Alex
Apply LOG format to system report
Please see here for a quick solution to the quoted critical error:
https://airvpn.org/forums/topic/70745-eddie-cant-connect-to-any-server/?do=findComment&comment=249545
