Not connected, Your IP: 216.73.216.195
thetechnerd
WireGuard AmneziaWG Converter
I stumbled upon this online WG converter.  Is it safe to use?  Is so, which settings are recommended?  I'm using WG configs with Wiresock because Eddie drastically slows boot-up speeds, often not loading and connected before the wifi disconnects.  AmneziaWG supports obfuscation that Eddie does not.
You may get a lot of data from here:
https://airvpn.org/forums/topic/65417-amneziawg-config-patcher-cps-db/
If you have an Android device or emulator, by running Eddie Android edition 4 you can generate ready to use AmneziaWG configuration files which are fully integrated with AirVPN (i.e. you can generate profiles for specific AirVPN servers, countries and so on), even relying on a large CPS QUIC database of real web sites if needed to bypass the blocks. You can then share them with your Windows machine. Important: Eddie Android edition generates files compatible with v2.0 Amnezia protocol, so you need this latest version.
Interestingly if I use Eddie for Android 4.0 the and export to AmneziaWG, after I email it to myself, the resulting file is renamed randomly and has no file extension.  But the data is still there, so I just rename the file and add the .conf extension.  However, that file never successfully connects.  But if I export it from the site I linked to everything runs fine.  Any idea as to why I cannot connect through Eddie exports?
A possible reason is that Eddie generates files compliant to the latest protocol specifications and you are using an older version. If that's the case, we can compare the two different profiles (remember to delete your key), i.e. the working one and the non-working one, and check the log of your software to find out the reason.
There are the two configs.   The first one works, generated by the site I linked to.  The second one does not, and was generated by Eddie for Android 4.0.
# Phoenix - Guniibuu
[Interface]
PrivateKey =
Address = 10.191.122.99/32,fd7d:76ee:e68f:a993:4abf:faec:ddcf:7af4/128
DNS = 10.128.0.1, fd7d:76ee:e68f:a993::1
MTU = 1420
Jc = 5
Jmin = 10
Jmax = 40
S1 = 0
S2 = 0
H1 = 1
H2 = 2
H3 = 3
H4 = 4
[Peer]
PublicKey =
PresharedKey =
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = 198.44.133.70:1637
[Interface]
Address = 10.191.122.99/32, fd7d:76ee:e68f:a993:4abf:faec:ddcf:7af4/128
PrivateKey =
Jc = 5
Jmin = 10
Jmax = 30
S1 = 0
S2 = 0
H1 = 2
H2 = 4
H3 = 1
H4 = 3
[Peer]
PublicKey =
PresharedKey =
Endpoint = 198.44.133.67:1637
We see the problem. Eddie Android edition 4.0.0 is affected by a bug. When Eddie generates a profile for WireGuard or AmneziaWG, it fails to add the MTU option and the IPv6 argument for the AllowedIPs option. We have immediately patched Eddie with high priority and now version 4.0.1 is available, addressing these issues. We strongly recommend that you upgrade immediately. Thank you for having reported the problems! Please see also here:
https://airvpn.org/forums/topic/80030-eddie-android-edition-401-available/
AirVPN Support Team
