Not connected, Your IP: 216.73.216.226
anitya1
ANSWERED No connection after trying split tunneling
Hey, I tried split tunneling, since I can't access reddit anymore, no matter which server but I use qbittorrent 24/7. First with TunnelTo, then WireSocks but since kill switch for qbittorrent wasn't working, I deleted both programs and the connected network adapter. Ever since that, I can't get any connection through AirVPN. I restarted my computer, I uninstalled and reinstalled AirVPN, made sure there are no other network adapters left. My knowledge is very limited and I don't really know what to do anymore.
Grateful for any help.
Eddie_20260303_214730.txt
@anitya1
You're trying connections over IPv6 and they all fail. Please make sure that both your router and ISP support IPv6. If in doubt, try a connection over IPv4 (*). If the problem persists, can you please publish a system report generated by Eddie? Please see here:
https://airvpn.org/forums/topic/50663-youve-been-asked-for-a-support-filesystem-report-–-heres-what-to-do/
(*) In Eddie, you can switch between IPv4 and IPv6 layers for the VPN connection on "Preferences" > "Networking" window.
3 hours ago, Staff said:
@anitya1
Thank you so much. May you have the greatest week possible. Don't know why I overlook this setting, but after changing it, everything is back to normal.
