Not connected, Your IP: 216.73.216.28
GoetzPhilippinen
ANSWERED After switch Mac from M1 to M4 (same OS 15.7.2) Eddie now doesnt show Up/Down speed anymore
I upgraded my iMac from the M1 to a new M4 machine, but OSX 15.7.2 stayed same.
I only changed the IP Adress space from before 192.168.0.xxx to 192.18.254.xxx - but still Mac has a fixed IP in my local network.
When I start Eddie 2.24.6 Download and Upöoad stay at 0 - even the data transfer is running.
I also checked that Eddie claims en0 as primary adapter - and my WiFi is off.
So anything works under the hood - only the speedometer sits at just showng 0 Up and 0 down - and I wonder whyts the bug there.
I believe it's a typo in the post alone, and the actually entered range is the usual 192.168.0.0/16.
Close Eddie and reopen, connect, then provide a system report..
Yep, its a typo - correct IP: I only changed the IP Adress space from before 192.168.0.xxx to 192.168.254.xxx - but still Mac has a fixed IP in my local network.
Here's the Logfile
. 2025.11.16 08:35:17 - Eddie version: 2.24.6 / macos_arm64, System: MacOS, Name: macOS 15.7.2, Version: 15.7.2, Framework: v4.0.30319
. 2025.11.16 08:35:17 - Raise system privileges
. 2025.11.16 08:35:59 - Collect network information
. 2025.11.16 08:36:01 - Reading options from /Users/xxxxxxxxxxxxxxx/.config/eddie/default.profile
. 2025.11.16 08:36:02 - OpenVPN - Version: 2.6.12 - OpenSSL 3.3.2 3 Sep 2024, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2025.11.16 08:36:02 - SSH - Version: OpenSSH_9.9p2, LibreSSL 3.3.6 (/usr/bin/ssh)
. 2025.11.16 08:36:02 - SSL - Version: 5.57 (/Applications/Eddie.app/Contents/MacOS/stunnel)
I 2025.11.16 08:36:02 - Ready
. 2025.11.16 08:36:04 - Collect information about AirVPN completed
I 2025.11.16 08:36:07 - Session starting.
. 2025.11.16 08:36:07 - Activation of Network Lock - macOS - PF
I 2025.11.16 08:36:08 - Checking authorization ...
! 2025.11.16 08:36:09 - Connecting to Xamidimura (United States of America, Los Angeles)
. 2025.11.16 08:36:09 - Routes, add 198.54.129.46/32 for interface "en0".
. 2025.11.16 08:36:09 - WireGuard > Setup start
. 2025.11.16 08:36:09 - WireGuard > Setup complete
. 2025.11.16 08:36:10 - WireGuard > Setup interface
. 2025.11.16 08:36:10 - WireGuard > Received first handshake
. 2025.11.16 08:36:10 - Workaround to enable IPv6 DNS lookups activated
. 2025.11.16 08:36:11 - DNS of a network adapter forced (Ethernet, from 1.1.1.1, 8.8.8.8, 192.168.254.254 to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.16 08:36:11 - DNS of a network adapter forced (Thunderbolt Ethernet Slot 0, Port 1, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.16 08:36:11 - DNS of a network adapter forced (Thunderbolt Ethernet Slot 0, Port 2, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.16 08:36:11 - DNS of a network adapter forced (USB 10/100/1000 LAN, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.16 08:36:11 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.16 08:36:11 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.16 08:36:11 - Routes, add 0.0.0.0/1 for interface "utun4".
. 2025.11.16 08:36:11 - Routes, add 128.0.0.0/1 for interface "utun4".
. 2025.11.16 08:36:11 - Routes, add ::/1 for interface "utun4".
. 2025.11.16 08:36:11 - Routes, add 8000::/1 for interface "utun4".
. 2025.11.16 08:36:11 - Routes, add 198.54.129.44/32 for interface "utun4".
. 2025.11.16 08:36:11 - Routes, add 2607:9000:3000:31:4997:6e04:112d:e1fa/128 for interface "utun4".
. 2025.11.16 08:36:11 - Flushing DNS
I 2025.11.16 08:36:13 - Checking route IPv4
I 2025.11.16 08:36:14 - Checking route IPv6
I 2025.11.16 08:36:15 - Checking DNS
. 2025.11.16 08:36:17 - Collect network information
! 2025.11.16 08:36:19 - Connected.
Edited ... by Tech Jedi Alex
Apply LOG format to logs
I believe I asked for a system report, not the logs alone. You would've known that the logs are in that system report had you actually taken the time to click the link and read the post behind it. The logs only tell us how wonderfully successful the connection to AirVPN was, which is not really the problem to begin with.
Please retry, this time clicking the lifebelt icon to the right of the logs. Thank you.
Ok youre right, this is on me. Apologies!
Eddie System/Environment Report - 18/11/2025 - 12:33 AM UTC
Eddie OS build: macos_arm64
Eddie architecture: x64
OS type: MacOS
OS name: macOS 15.7.2
OS version: 15.7.2
OS architecture: arm64
OpenVPN: 2.6.12 - OpenSSL 3.3.2 3 Sep 2024, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
Hummingbird: 3.3.2 - Hummingbird - OpenVPN3 Client 1.3.0 - 1 June 2023 (/Applications/Eddie.app/Contents/MacOS/hummingbird)
WireGuard: 1.0.20210315
SSH: OpenSSH_9.9p2, LibreSSL 3.3.6 (/usr/bin/ssh)
SSL: 5.57 (/Applications/Eddie.app/Contents/MacOS/stunnel)
Profile path: /Users/xxxxxxxxxx/.config/eddie/default.profile
Data path: /Users/xxxxxxxxxx/.config/eddie
Application path: /Applications/Eddie.app/Contents/MacOS
Executable path: /Applications/Eddie.app/Contents/MacOS/Eddie-UI
Command line arguments: (0 args)
Network Lock Active: Yes, macOS - PF
Connected to VPN: Yes, Sarin
OS support IPv4: Yes
OS support IPv6: Yes
Detected DNS: 10.128.0.1,fd7d:76ee:e68f:a993::1
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: 319 ms
Test Ping IPv6: Failed
Test HTTP IPv4: Ok
Test HTTP IPv6: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
areas.denylist: ch,de,ca,ro,gb,se,nl,at,rs,ee,bg,no,be,cz,es,nz,lv,br,ie,tw
gui.notifications: False
Logs:
. 2025.11.18 08:29:24 - Eddie version: 2.24.6 / macos_arm64, System: MacOS, Name: macOS 15.7.2, Version: 15.7.2, Framework: v4.0.30319
. 2025.11.18 08:29:25 - Raise system privileges
. 2025.11.18 08:29:31 - Collect network information
. 2025.11.18 08:29:33 - Reading options from /Users/xxxxxxxxxx/.config/eddie/default.profile
. 2025.11.18 08:29:33 - OpenVPN - Version: 2.6.12 - OpenSSL 3.3.2 3 Sep 2024, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2025.11.18 08:29:33 - SSH - Version: OpenSSH_9.9p2, LibreSSL 3.3.6 (/usr/bin/ssh)
. 2025.11.18 08:29:33 - SSL - Version: 5.57 (/Applications/Eddie.app/Contents/MacOS/stunnel)
I 2025.11.18 08:29:33 - Ready
. 2025.11.18 08:29:35 - Collect information about AirVPN completed
I 2025.11.18 08:29:38 - Session starting.
. 2025.11.18 08:29:38 - Activation of Network Lock - macOS - PF
I 2025.11.18 08:29:39 - Checking authorization ...
! 2025.11.18 08:29:40 - Connecting to Sarin (United States of America, Los Angeles)
. 2025.11.18 08:29:40 - Routes, add 198.54.129.62/32 for interface "en0".
. 2025.11.18 08:29:40 - WireGuard > Setup start
. 2025.11.18 08:29:40 - WireGuard > Setup complete
. 2025.11.18 08:29:41 - WireGuard > Setup interface
. 2025.11.18 08:29:41 - WireGuard > Received first handshake
. 2025.11.18 08:29:42 - Workaround to enable IPv6 DNS lookups activated
. 2025.11.18 08:29:42 - DNS of a network adapter forced (Ethernet, from 1.1.1.1, 8.8.8.8, 192.168.254.254 to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.18 08:29:42 - DNS of a network adapter forced (Thunderbolt Ethernet Slot 0, Port 1, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.18 08:29:42 - DNS of a network adapter forced (Thunderbolt Ethernet Slot 0, Port 2, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.18 08:29:42 - DNS of a network adapter forced (USB 10/100/1000 LAN, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.18 08:29:42 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.18 08:29:42 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2025.11.18 08:29:42 - Routes, add 0.0.0.0/1 for interface "utun4".
. 2025.11.18 08:29:42 - Routes, add 128.0.0.0/1 for interface "utun4".
. 2025.11.18 08:29:42 - Routes, add ::/1 for interface "utun4".
. 2025.11.18 08:29:42 - Routes, add 8000::/1 for interface "utun4".
. 2025.11.18 08:29:42 - Routes, add 198.54.129.60/32 for interface "utun4".
. 2025.11.18 08:29:43 - Routes, add 2607:9000:3000:33:d5fe:c61c:6adc:6b79/128 for interface "utun4".
. 2025.11.18 08:29:43 - Flushing DNS
I 2025.11.18 08:29:49 - Checking route IPv4
I 2025.11.18 08:29:50 - Checking route IPv6
I 2025.11.18 08:29:52 - Checking DNS
. 2025.11.18 08:29:54 - Collect network information
! 2025.11.18 08:29:56 - Connected.
Network Info:
    "routes": [
            "destination": "0\/1",
            "expire": "",
            "flags": "UScg",
            "gateway": "utun4",
            "interface": "utun4",
            "mtu": "1320",
            "refs": "0",
            "rt_ifa": "10.140.91.27",
            "use": "0"
            "destination": "0.0.0.0\/0",
            "expire": "",
            "flags": "UGScg",
            "gateway": "192.168.254.254",
            "interface": "en0",
            "mtu": "1500",
            "refs": "7",
            "rt_ifa": "192.168.254.104",
            "use": "61"
            "destination": "default",
            "expire": "",
            "flags": "UCSIg",
            "gateway": "link#30",
            "mtu": "1320",
            "refs": "143",
            "use": "0"
            "destination": "5.196.64.52\/32",
            "expire": "3596",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "33"
            "destination": "10.128.0.1\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1320",
            "refs": "1",
            "use": "136"
            "destination": "10.140.91.27\/32",
            "expire": "",
            "flags": "UH",
            "gateway": "10.140.91.27",
            "mtu": "1320",
            "refs": "0",
            "use": "23"
            "destination": "17.23.96.10\/32",
            "expire": "3527",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "97"
            "destination": "17.23.96.15\/32",
            "expire": "3525",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "25"
            "destination": "17.33.200.238\/32",
            "expire": "3489",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "29"
            "destination": "17.57.144.244\/32",
            "expire": "3391",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "6"
            "destination": "17.57.144.245\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1320",
            "refs": "2",
            "use": "79"
            "destination": "17.57.144.246\/32",
            "expire": "3391",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "6"
            "destination": "17.57.144.247\/32",
            "expire": "3391",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "6"
            "destination": "17.57.145.149\/32",
            "expire": "3392",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "4"
            "destination": "17.111.103.20\/32",
            "expire": "3408",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "10"
            "destination": "17.137.162.3\/32",
            "expire": "3559",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "71"
            "destination": "17.137.170.10\/32",
            "expire": "3388",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "5"
            "destination": "17.137.170.34\/32",
            "expire": "3388",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "5"
            "destination": "17.138.175.254\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1320",
            "refs": "1",
            "use": "40"
            "destination": "17.248.193.16\/32",
            "expire": "3528",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "44"
            "destination": "17.248.193.17\/32",
            "expire": "3549",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "77"
            "destination": "17.248.193.18\/32",
            "expire": "3528",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "73"
            "destination": "17.248.193.19\/32",
            "expire": "3569",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "238"
            "destination": "17.248.216.64\/32",
            "expire": "3412",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "8"
            "destination": "17.248.216.65\/32",
            "expire": "3419",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "4"
            "destination": "17.253.27.195\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1320",
            "refs": "1",
            "use": "211"
            "destination": "17.253.27.203\/32",
            "expire": "3548",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "36"
            "destination": "17.253.83.132\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1320",
            "refs": "3",
            "use": "49"
            "destination": "17.253.83.133\/32",
            "expire": "3529",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "35"
            "destination": "17.253.87.195\/32",
            "expire": "3519",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "30"
            "destination": "17.253.87.199\/32",
            "expire": "3522",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "30"
            "destination": "17.253.87.201\/32",
            "expire": "3433",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "20"
            "destination": "17.253.87.203\/32",
            "expire": "3507",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "10"
            "destination": "18.155.173.6\/32",
            "expire": "3563",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "0"
            "destination": "18.155.173.14\/32",
            "expire": "3596",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "23"
            "destination": "18.155.173.23\/32",
            "expire": "3563",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "0"
            "destination": "18.155.173.82\/32",
            "expire": "3563",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "0"
            "destination": "18.163.176.6\/32",
            "expire": "3572",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "9"
            "destination": "23.220.150.174\/32",
            "expire": "3551",
            "flags": "UHW3Ig",
            "mtu": "1320",
            "refs": "0",
            "use": "50"
            "destination": "96.6.168.25\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1320",
            "refs": "1",
            "use": "24"
            "destination": "127",
            "expire": "",
            "flags": "UCS",
            "gateway": "127.0.0.1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "127.0.0.1",
            "use": "0"
            "destination": "127.0.0.1\/32",
            "expire": "",
            "flags": "UH",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "4",
            "use": "1324"
            "destination": "128.0\/1",
            "expire": "",
            "flags": "USc",
            "gateway": "utun4",
            "mtu": "1320",
            "refs": "10",
            "use": "95"
            "destination": "169.254\/32",
            "expire": "!",
            "flags": "UCS",
            "gateway": "link#23",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "!",
            "flags": "UCSI",
            "gateway": "link#18",
            "interface": "en10",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "192.168.25.25",
            "use": "0"
            "expire": "!",
            "flags": "UCSI",
            "gateway": "link#24",
            "interface": "en11",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "192.168.26.26",
            "use": "0"
            "destination": "192.168.0\/16",
            "expire": "!",
            "flags": "UCS",
            "mtu": "1500",
            "refs": "2",
            "use": "0"
            "destination": "192.168.25.25\/32",
            "expire": "!",
            "flags": "UCS",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "",
            "flags": "UHLWI",
            "gateway": "24:5e:be:7d:7a:ba",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "1"
            "destination": "192.168.25.100\/32",
            "expire": "1120",
            "flags": "UHLWIi",
            "gateway": "24:5e:be:67:3a:f7",
            "mtu": "1500",
            "refs": "8",
            "use": "65086"
            "destination": "192.168.26\/32",
            "expire": "!",
            "flags": "UCS",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "192.168.26.26\/32",
            "expire": "!",
            "flags": "UCS",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "",
            "flags": "UHLWI",
            "gateway": "88:c9:b3:b3:22:18",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "1"
            "destination": "192.168.26.100\/32",
            "expire": "1158",
            "flags": "UHLWIi",
            "gateway": "6c:1f:f7:c:55:f2",
            "mtu": "1500",
            "refs": "6",
            "use": "1788"
            "destination": "192.168.254\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "6",
            "use": "0"
            "destination": "192.168.254.104\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "",
            "flags": "UHLWI",
            "gateway": "1c:1d:d3:ef:9a:a6",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "30"
            "destination": "192.168.254.110\/32",
            "expire": "1098",
            "flags": "UHLWI",
            "gateway": "24:5e:be:40:63:94",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "7"
            "destination": "192.168.254.138\/32",
            "expire": "1155",
            "flags": "UHLWI",
            "gateway": "ec:4d:3e:6e:5:fa",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "192.168.254.140\/32",
            "expire": "882",
            "flags": "UHLWI",
            "gateway": "ba:e3:33:28:9f:39",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "192.168.254.172\/32",
            "expire": "782",
            "flags": "UHLWI",
            "gateway": "e6:80:86:27:44:76",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "1"
            "destination": "192.168.254.177\/32",
            "expire": "999",
            "flags": "UHLWI",
            "gateway": "6c:1f:f7:c:55:f1",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "15"
            "destination": "192.168.254.254\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "1148",
            "flags": "UHLWIir",
            "gateway": "14:46:58:1e:18:d0",
            "interface": "en0",
            "mtu": "1500",
            "refs": "3",
            "use": "0"
            "destination": "192.168.254.255\/32",
            "expire": "!",
            "flags": "UHLWbI",
            "gateway": "ff:ff:ff:ff:ff:ff",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "52"
            "destination": "192.168.255.255\/32",
            "expire": "!",
            "flags": "UHLWbI",
            "mtu": "1500",
            "refs": "0",
            "use": "52"
            "destination": "198.54.129.60\/32",
            "expire": "",
            "flags": "USc",
            "gateway": "utun4",
            "mtu": "1320",
            "refs": "1",
            "use": "0"
            "destination": "198.54.129.62\/32",
            "expire": "",
            "flags": "UGSc",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "224.0.0\/4",
            "expire": "!",
            "flags": "UmCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "!",
            "flags": "UmCSI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "!",
            "flags": "UmCSI",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "",
            "flags": "UmCSI",
            "mtu": "1320",
            "refs": "0",
            "use": "0"
            "destination": "224.0.0.251\/32",
            "expire": "",
            "flags": "UHmLWI",
            "gateway": "1:0:5e:0:0:fb",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UHmLWI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "255.255.255.255\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "!",
            "flags": "UCSI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "!",
            "flags": "UCSI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UCSI",
            "mtu": "1320",
            "refs": "0",
            "use": "0"
            "destination": "::\/1",
            "expire": "",
            "flags": "UScg",
            "gateway": "utun4",
            "mtu": "1320",
            "refs": "13",
            "rt_ifa": "fe80::223:a4ff:fe05:2398%utun4",
            "use": "0"
            "destination": "::\/0",
            "expire": "",
            "flags": "UGcIg",
            "gateway": "fe80::",
            "interface": "utun0",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "fe80::61a3:4cf3:907c:6256%utun0",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun1",
            "mtu": "1380",
            "refs": "0",
            "rt_ifa": "fe80::22a4:f95b:f26:2922%utun1",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun2",
            "mtu": "2000",
            "refs": "0",
            "rt_ifa": "fe80::b3e6:9820:407e:821d%utun2",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun3",
            "mtu": "1000",
            "refs": "0",
            "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun3",
            "use": "0"
            "destination": "::1\/128",
            "expire": "",
            "flags": "UHL",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "rt_ifa": "::1",
            "use": "24"
            "destination": "2607:9000:3000:33:d5fe:c61c:6adc:6b79\/128",
            "expire": "",
            "flags": "UHLS",
            "gateway": "utun4",
            "mtu": "1320",
            "refs": "0",
            "use": "23"
            "destination": "8000::\/1",
            "expire": "",
            "flags": "USc",
            "gateway": "utun4",
            "mtu": "1320",
            "refs": "0",
            "use": "0"
            "destination": "fd7d:76ee:e68f:a993:786b:b4de:87b5:8159\/128",
            "expire": "",
            "flags": "UHL",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "fd7d:76ee:e68f:a993:786b:b4de:87b5:8159",
            "use": "0"
            "destination": "fe80::\/64",
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "rt_ifa": "fe80::1%lo0",
            "use": "0"
            "destination": "fe80::1\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UCI",
            "mtu": "1500",
            "refs": "1",
            "rt_ifa": "fe80::14e8:609d:bc9c:4c87%en10",
            "use": "0"
            "destination": "fe80::14e8:609d:bc9c:4c87\/128",
            "expire": "",
            "flags": "UHLI",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "use": "0"
            "expire": "",
            "flags": "UCI",
            "gateway": "link#20",
            "interface": "en1",
            "mtu": "1500",
            "refs": "1",
            "rt_ifa": "fe80::848:323a:7e5e:c229%en1",
            "use": "0"
            "destination": "fe80::848:323a:7e5e:c229\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "62:e5:56:2c:4f:8a",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "use": "1"
            "destination": "fe80::fcf7:2eff:fe0b:70a4\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "fe:f7:2e:b:70:a4",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "fe80::fcf7:2eff:fe0b:70a4%llw0",
            "use": "0"
            "expire": "",
            "flags": "UCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "8",
            "rt_ifa": "fe80::1c18:b960:c650:42f0%en0",
            "use": "0"
            "expire": "",
            "flags": "UHLWI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "10"
            "destination": "fe80::a9:15c7:5c0:2130\/128",
            "expire": "",
            "flags": "UHLWI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "fe80::1836:562b:1e86:2f90\/128",
            "expire": "",
            "flags": "UHLWIi",
            "interface": "en0",
            "mtu": "1500",
            "refs": "2",
            "use": "29"
            "destination": "fe80::1872:d02c:f22f:d513\/128",
            "expire": "",
            "flags": "UHLWI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "fe80::18f3:bd1f:4d2a:7e50\/128",
            "expire": "",
            "flags": "UHLWI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "fe80::1c18:b960:c650:42f0\/128",
            "expire": "",
            "flags": "UHLI",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "destination": "fe80::1c47:50d:ebc2:ed59\/128",
            "expire": "",
            "flags": "UHLWI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UCI",
            "mtu": "1500",
            "refs": "1",
            "rt_ifa": "fe80::104b:7bdd:2567:da18%en11",
            "use": "0"
            "destination": "fe80::104b:7bdd:2567:da18\/128",
            "expire": "",
            "flags": "UHLI",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::61a3:4cf3:907c:6256",
            "mtu": "1500",
            "refs": "2",
            "use": "0"
            "destination": "fe80::61a3:4cf3:907c:6256\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#26",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::22a4:f95b:f26:2922",
            "mtu": "1380",
            "refs": "2",
            "use": "0"
            "destination": "fe80::22a4:f95b:f26:2922\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#27",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::b3e6:9820:407e:821d",
            "mtu": "2000",
            "refs": "2",
            "use": "0"
            "destination": "fe80::b3e6:9820:407e:821d\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#28",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::ce81:b1c:bd2c:69e",
            "mtu": "1000",
            "refs": "2",
            "use": "0"
            "destination": "fe80::ce81:b1c:bd2c:69e\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#29",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::223:a4ff:fe05:2398",
            "mtu": "1320",
            "refs": "1",
            "use": "0"
            "destination": "fe80::223:a4ff:fe05:2398\/128",
            "expire": "",
            "flags": "UHLI",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "destination": "ff00::\/8",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en1",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "gateway": "link#22",
            "interface": "llw0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1320",
            "refs": "0",
            "use": "0"
            "destination": "ff01::\/32",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en1",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1320",
            "refs": "0",
            "use": "0"
            "destination": "ff02::\/32",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en1",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1320",
            "refs": "0",
            "use": "0"
    "ipv4-default-gateway": "192.168.254.254",
    "ipv4-default-interface": "en0",
    "ipv6-default-gateway": "fe80::",
    "ipv6-default-interface": "utun0",
    "interfaces": [
            "friendly": "lo0",
            "id": "lo0",
            "name": "lo0",
            "description": "lo0",
            "type": "Loopback",
            "status": "Up",
            "bytes_received": "0",
            "bytes_sent": "0",
            "support_ipv4": true,
            "support_ipv6": true,
            "ips": [
                "127.0.0.1",
                "::1",
                "fe80::1"
            "bind": true
            "friendly": "gif0",
            "id": "gif0",
            "name": "gif0",
            "description": "gif0",
            "type": "Unknown",
            "status": "Unknown",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "stf0",
            "id": "stf0",
            "name": "stf0",
            "description": "stf0",
            "type": "Unknown",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "anpi2",
            "id": "anpi2",
            "name": "anpi2",
            "description": "anpi2",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "anpi0",
            "id": "anpi0",
            "name": "anpi0",
            "description": "anpi0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "anpi1",
            "id": "anpi1",
            "name": "anpi1",
            "description": "anpi1",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "anpi3",
            "id": "anpi3",
            "name": "anpi3",
            "description": "anpi3",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Ethernet Adapter (en6)",
            "id": "en6",
            "name": "en6",
            "description": "en6",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Ethernet Adapter (en7)",
            "id": "en7",
            "name": "en7",
            "description": "en7",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Ethernet Adapter (en8)",
            "id": "en8",
            "name": "en8",
            "description": "en8",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Ethernet Adapter (en9)",
            "id": "en9",
            "name": "en9",
            "description": "en9",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 1",
            "id": "en2",
            "name": "en2",
            "description": "en2",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 2",
            "id": "en3",
            "name": "en3",
            "description": "en3",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 3",
            "id": "en4",
            "name": "en4",
            "description": "en4",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 4",
            "id": "en5",
            "name": "en5",
            "description": "en5",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "pktap0",
            "id": "pktap0",
            "name": "pktap0",
            "description": "pktap0",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "USB 10\/100\/1000 LAN",
            "id": "en12",
            "name": "en12",
            "description": "en12",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt Ethernet Slot 0, Port 1",
            "id": "en10",
            "name": "en10",
            "description": "en10",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::14e8:609d:bc9c:4c87",
                "192.168.25.25"
            "bind": true
            "friendly": "ap1",
            "id": "ap1",
            "name": "ap1",
            "description": "ap1",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Wi-Fi",
            "id": "en1",
            "name": "en1",
            "description": "en1",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::848:323a:7e5e:c229"
            "bind": true
            "friendly": "awdl0",
            "id": "awdl0",
            "name": "awdl0",
            "description": "awdl0",
            "type": "Ethernet",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "llw0",
            "id": "llw0",
            "name": "llw0",
            "description": "llw0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::fcf7:2eff:fe0b:70a4"
            "bind": true
            "friendly": "Ethernet",
            "id": "en0",
            "name": "en0",
            "description": "en0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::1c18:b960:c650:42f0",
                "192.168.254.104"
            "bind": true
            "friendly": "Thunderbolt Ethernet Slot 0, Port 2",
            "id": "en11",
            "name": "en11",
            "description": "en11",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::104b:7bdd:2567:da18",
                "192.168.26.26"
            "bind": true
            "friendly": "Thunderbolt Bridge",
            "id": "bridge0",
            "name": "bridge0",
            "description": "bridge0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "utun0",
            "id": "utun0",
            "name": "utun0",
            "description": "utun0",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun1",
            "id": "utun1",
            "name": "utun1",
            "description": "utun1",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun2",
            "id": "utun2",
            "name": "utun2",
            "description": "utun2",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun3",
            "id": "utun3",
            "name": "utun3",
            "description": "utun3",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun4",
            "id": "utun4",
            "name": "utun4",
            "description": "utun4",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "10.140.91.27",
            "bind": true
ifconfig:
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
    options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
    inet 127.0.0.1 netmask 0xff000000
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
    nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
anpi2: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=400<CHANNEL_IO>
    ether ce:a8:c8:67:d6:71
    media: none
    status: inactive
anpi0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether ce:a8:c8:67:d6:6f
    media: none
    status: inactive
anpi1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether ce:a8:c8:67:d6:70
    media: none
    status: inactive
anpi3: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether ce:a8:c8:67:d6:72
    media: none
    status: inactive
en6: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether ce:a8:c8:67:d6:4f
    media: none
    status: inactive
en7: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether ce:a8:c8:67:d6:50
    media: none
    status: inactive
en8: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether ce:a8:c8:67:d6:51
    media: none
    status: inactive
en9: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether ce:a8:c8:67:d6:52
    media: none
    status: inactive
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    options=460<TSO4,TSO6,CHANNEL_IO>
    ether 36:62:51:d5:65:40
    media: autoselect <full-duplex>
    status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 36:62:51:d5:65:44
    status: inactive
en4: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 36:62:51:d5:65:48
    status: inactive
en5: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 36:62:51:d5:65:4c
    status: inactive
pktap0: flags=1<UP> mtu 0
en12: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=6464<VLAN_MTU,TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
    ether 00:23:a4:05:23:98
    media: autoselect (none)
    status: inactive
en10: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=567<RXCSUM,TXCSUM,VLAN_MTU,TSO4,TSO6,AV,CHANNEL_IO>
    ether 24:5e:be:7d:7a:ba
    inet6 fe80::14e8:609d:bc9c:4c87%en10 prefixlen 64 secured scopeid 0x12
    inet 192.168.25.25 netmask 0xffff0000 broadcast 192.168.255.255
    media: autoselect (10Gbase-T <full-duplex,flow-control>)
    status: active
ap1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
    ether 7a:8d:0c:86:f7:c1
    status: inactive
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether 62:e5:56:2c:4f:8a
    inet6 fe80::848:323a:7e5e:c229%en1 prefixlen 64 secured scopeid 0x14
awdl0: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
    ether fe:f7:2e:0b:70:a4
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    inet6 fe80::fcf7:2eff:fe0b:70a4%llw0 prefixlen 64 scopeid 0x16
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether 1c:1d:d3:ef:9a:a6
    inet6 fe80::1c18:b960:c650:42f0%en0 prefixlen 64 secured scopeid 0x17
    inet 192.168.254.104 netmask 0xffffff00 broadcast 192.168.254.255
    media: autoselect (1000baseT <full-duplex,flow-control>)
    status: active
en11: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether 88:c9:b3:b3:22:18
    inet6 fe80::104b:7bdd:2567:da18%en11 prefixlen 64 secured scopeid 0x18
    inet 192.168.26.26 netmask 0xffffff00 broadcast 192.168.26.255
    status: active
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=63<RXCSUM,TXCSUM,TSO4,TSO6>
    Configuration:
        id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
        maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
        root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
        ipfilter disabled flags 0x0
    member: en2 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 12 priority 0 path cost 0
    member: en3 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 13 priority 0 path cost 0
    member: en4 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 14 priority 0 path cost 0
    member: en5 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 15 priority 0 path cost 0
    media: <unknown type>
    status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
    inet6 fe80::61a3:4cf3:907c:6256%utun0 prefixlen 64 scopeid 0x1a
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
    inet6 fe80::22a4:f95b:f26:2922%utun1 prefixlen 64 scopeid 0x1b
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
    inet6 fe80::b3e6:9820:407e:821d%utun2 prefixlen 64 scopeid 0x1c
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000
    inet6 fe80::ce81:b1c:bd2c:69e%utun3 prefixlen 64 scopeid 0x1d
utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1320
    inet 10.140.91.27 --> 10.140.91.27 netmask 0xffffffff
    inet6 fe80::223:a4ff:fe05:2398%utun4 prefixlen 64 scopeid 0x1e
    inet6 fd7d:76ee:e68f:a993:786b:b4de:87b5:8159 prefixlen 128
Apply LOG format to system report
This is caused by an incorrect local network IP address.
I see from the logs that your computer's local IP address is 192.168.254.254.
I would like to ask what the IP address of your router's LAN port is?
Home network IP addresses are usually automatically assigned by the router (DHCP). Why would you need to manually assign one?
If you absolutely must use a static local IP address, please ensure that the IP is correctly routed.
For example, if your router's LAN port IP is 192.168.3.1, then all devices connected to this router must have IP addresses within the corresponding address pool (192.168.3.2~192.168.3.254).
Has your computer's IP been correctly routed? Please check carefully.
I use quite some hardware, so its better to asign static IPs, or otherwise connecting multiple NAS can gets troublesome ...
When upgrading my old Mac with the new I just changed all IPs in my network from 192.168.0.xxx to now 192.168.254.xxx
Router: 192.168.254.254
Subnet Mask: 255.255.255.0
en0 Mac: 192.168.254.104 (static)
All my computers and NAS work with that like before.
The only difference is Eddie wich isnt showing transfer speed anymore.
Is 192.168.254.254 your router's IP address? Is your computer's IP address set to 192.168.254.104?
However, the log shows that your computer's IP is 192.168.254.254, which means that your computer's IP is indeed not being routed correctly.
Does your router have an IP-MAC binding function in its DHCP settings?
If so, it is recommended that you use DHCP to bind the devices you want to use to the local IP address via MAC identifier.
If not, you can try assigning the router address to 192.168.254.1, and then assigning other devices to addresses after that (192.168.254.2~192.168.254.254).
Why do you think I text wrong details?
And ... from which LOG entry do you get this?
Luckily theres Gemini 3 - I told it the problem and uploaded the logfile.
The FIX did the job - well done Gemini3 - thanks.
Quote
Based on the logs and the facts you provided, the issue is not a network failure—the VPN is connecting and routing traffic correctly through en0.
The problem is a configuration mismatch caused by migrating your settings to new hardware.
The Diagnosis
When you migrated from the old computer to the new one, you likely copied the Eddie configuration file (default.profile).
  1. The Identity Crisis:
    • On your old computer, en0 pointed to a specific physical hardware chip (e.g., the built-in Ethernet port).
    • Even though both are named "en0" by the Operating System, they have different unique hardware identifiers (UUIDs) and MAC addresses
  2. The Stale Preference:
    • The Eddie software is likely still trying to read the traffic counters from the old hardware identifier stored in your default.profile, rather than the new Thunderbolt Hub. Because that old chip doesn't exist on this machine, the speed meter returns 0 or blank.
  3. Complex Network Environment:
    • Your log shows you have three active Ethernet interfaces with IP addresses, which can confuse monitoring tools if they are set to "Automatic":
      • en0: 192.168.254.104 (Your actual Internet connection).
      • en10: 192.168.25.25 (Likely a 10GbE connection or a bridge).
      • en11: 192.168.26.26 (Another 10GbE connection).
The Fix
You need to force Eddie to "re-discover" the correct hardware device for monitoring.
Delete the Old Profile
  1. Quit Eddie completely.
  2. Open Finder.
  3. Press Cmd + Shift + G and paste this path (from your log): /Users/xxxxxxxxxx/.config/eddie/
  4. Delete (or rename) the file default.profile.
  5. Restart Eddie. You will need to re-enter your login/password, but it will detect the new en0.
Okay, so it's an error that the IP address shown in the Eddie logs doesn't change when your computer's MAC address changes.
I thought it was a routing problem, but it turns out it's an Eddie issue.
I've learned something new.😁😁😁
I must commend the AI here – I wouldn't have thought of asking you whether you installed Eddie from scratch or copied over the profile.
Most of the times those AIs catch mentions of one or two words in contexts of other words and hallucinate about the rest of the meaning, but this one was a good answer.
