Not connected, Your IP: 216.73.216.172
I’m experiencing a strange issue where I can’t seem to ping any of the AirVPN UK hosts, while connections to other locations outside the UK are working fine. I suspect my ISP might be blocking the AirVPN UK hosts, as I’ve tried a different ISP and the UK hosts are pinging correctly.
It looks like I may have been blocked, or are there any known upstream issues affecting the UK servers happening?
Thank you!
Hi all,
Since yesterday morning my Eddie disconnected and now is stuck on connecting every time I try to load it up or connect to  different server. I'm running it on a Mac M2 and no system changes have taken place as far as I'm aware. My subscription to Air VPN was due to expire today, but I've renewed and the same problem persists. Here's the log files, any guidance is much appreciated:
. 2025.01.16 09:43:52 - Eddie version: 2.21.8 / macos_x64, System: MacOS, Name: macOS 15.1.1, Version: 15.1.1 (Build 24B91), Mono/.Net: v4.0.30319
. 2025.01.16 09:43:52 - Raise system privileges
. 2025.01.16 09:43:58 - Reading options from /Users/AJ/.config/eddie/default.profile
. 2025.01.16 09:44:01 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2025.01.16 09:44:01 - SSH - Version: OpenSSH_9.8p1, LibreSSL 3.3.6 (/usr/bin/ssh)
. 2025.01.16 09:44:01 - SSL - Version: stunnel 5.56 (/Applications/Eddie.app/Contents/MacOS/stunnel)
I 2025.01.16 09:44:01 - Ready
. 2025.01.16 09:44:02 - Collect information about AirVPN completed
I 2025.01.16 09:44:02 - Session starting.
. 2025.01.16 09:44:02 - Waiting for latency tests (4 to go)
I 2025.01.16 09:44:06 - Checking authorization ...
! 2025.01.16 09:44:06 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:44:06 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:44:06 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:44:07 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:44:07 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:44:07 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:44:07 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:44:07 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:44:07 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:44:07 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:44:07 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:44:07 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:44:07 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:44:38 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:44:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:44:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:44:43 - Disconnecting
. 2025.01.16 09:44:43 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:44:43 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:44:43 - Connection terminated.
I 2025.01.16 09:44:47 - Checking authorization ...
! 2025.01.16 09:44:47 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:44:47 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:44:47 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:44:47 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:44:47 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:44:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:44:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:44:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:44:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:44:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:44:47 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:44:47 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:44:47 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:45:19 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:45:19 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:45:24 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:45:24 - Disconnecting
. 2025.01.16 09:45:24 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:45:24 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:45:24 - Connection terminated.
I 2025.01.16 09:45:27 - Checking authorization ...
! 2025.01.16 09:45:27 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:45:27 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:45:27 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:45:28 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:45:28 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:45:28 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:45:28 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:45:28 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:45:28 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:45:28 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:45:28 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:45:28 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:45:28 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:45:59 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:45:59 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:46:04 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:46:04 - Disconnecting
. 2025.01.16 09:46:04 - Sending soft termination signal
. 2025.01.16 09:46:05 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:46:05 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:46:05 - Connection terminated.
I 2025.01.16 09:46:08 - Checking authorization ...
! 2025.01.16 09:46:08 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:46:08 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:46:08 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:46:09 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:46:09 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:46:09 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:46:09 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:46:09 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:46:09 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:46:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:46:09 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:46:09 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:46:09 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:46:40 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:46:40 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:46:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:46:45 - Disconnecting
. 2025.01.16 09:46:45 - Sending soft termination signal
. 2025.01.16 09:46:46 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:46:46 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:46:46 - Connection terminated.
I 2025.01.16 09:46:49 - Checking authorization ...
! 2025.01.16 09:46:49 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:46:49 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:46:49 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:46:50 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:46:50 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:46:50 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:46:50 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:46:50 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:46:50 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:46:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:46:50 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:46:50 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:46:50 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:47:21 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:47:21 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:47:26 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:47:26 - Disconnecting
. 2025.01.16 09:47:26 - Sending soft termination signal
. 2025.01.16 09:47:26 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:47:26 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:47:26 - Connection terminated.
I 2025.01.16 09:47:29 - Checking authorization ...
! 2025.01.16 09:47:30 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:47:30 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:47:30 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:47:30 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:47:30 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:47:30 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:47:30 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:47:30 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:47:30 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:47:30 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:47:30 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:47:30 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:47:30 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:48:03 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:48:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:48:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:48:08 - Disconnecting
. 2025.01.16 09:48:08 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:48:08 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:48:08 - Connection terminated.
I 2025.01.16 09:48:11 - Checking authorization ...
! 2025.01.16 09:48:12 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:48:12 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:48:12 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:48:12 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:48:12 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:48:12 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:48:12 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:48:12 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:48:12 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:48:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:48:12 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:48:12 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:48:12 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:48:44 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:48:44 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:48:49 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:48:49 - Disconnecting
. 2025.01.16 09:48:49 - Sending soft termination signal
. 2025.01.16 09:48:49 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:48:49 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:48:49 - Connection terminated.
I 2025.01.16 09:48:52 - Checking authorization ...
! 2025.01.16 09:48:52 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:48:53 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:48:53 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:48:53 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:48:53 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:48:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:48:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:48:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:48:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:48:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:48:53 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:48:53 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:48:53 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:49:25 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:49:25 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:49:30 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:49:30 - Disconnecting
. 2025.01.16 09:49:30 - Sending soft termination signal
. 2025.01.16 09:49:30 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:49:31 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:49:31 - Connection terminated.
I 2025.01.16 09:49:34 - Checking authorization ...
! 2025.01.16 09:49:34 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:49:34 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:49:34 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:49:34 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:49:34 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:49:34 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:49:34 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:49:34 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:49:34 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:49:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:49:34 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:49:34 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:49:34 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:50:06 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:50:06 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:50:11 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:50:11 - Disconnecting
. 2025.01.16 09:50:11 - Sending soft termination signal
. 2025.01.16 09:50:12 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:50:12 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:50:12 - Connection terminated.
I 2025.01.16 09:50:15 - Checking authorization ...
! 2025.01.16 09:50:15 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:50:15 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:50:15 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:50:16 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:50:16 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:50:16 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:50:16 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:50:16 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:50:16 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:50:16 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:50:16 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:50:16 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:50:16 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:50:47 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:50:47 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:50:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:50:52 - Disconnecting
. 2025.01.16 09:50:52 - Sending soft termination signal
. 2025.01.16 09:50:52 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:50:52 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:50:52 - Connection terminated.
I 2025.01.16 09:50:55 - Checking authorization ...
! 2025.01.16 09:50:55 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:50:55 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:50:55 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:50:56 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:50:56 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:50:56 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:50:56 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:50:56 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:50:56 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:50:56 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:50:56 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:50:56 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:50:56 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
. 2025.01.16 09:51:27 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2025.01.16 09:51:27 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2025.01.16 09:51:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2025.01.16 09:51:32 - Disconnecting
. 2025.01.16 09:51:32 - Sending soft termination signal
. 2025.01.16 09:51:32 - Routes, delete 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:51:32 - Routes, delete 217.138.195.21/32 for interface "en1", not exists.
. 2025.01.16 09:51:32 - Connection terminated.
I 2025.01.16 09:51:35 - Checking authorization ...
! 2025.01.16 09:51:36 - Connecting to Alathfar (United Kingdom of Great Britain and Northern Ireland, London)
. 2025.01.16 09:51:36 - Routes, add 217.138.195.21/32 for interface "en1".
. 2025.01.16 09:51:36 - Routes, add 217.138.195.21/32 for interface "en1", already exists.
. 2025.01.16 09:51:36 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2025.01.16 09:51:36 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2025.01.16 09:51:36 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:51:36 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:51:36 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.01.16 09:51:36 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.01.16 09:51:36 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.195.21:443
. 2025.01.16 09:51:36 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2025.01.16 09:51:36 - OpenVPN > UDP link local: (not bound)
. 2025.01.16 09:51:36 - OpenVPN > UDP link remote: [AF_INET]217.138.195.21:443
OK I've been waiting to see if anyone is experiencing something similar to me—I haven't been able to connect to any UK server for the past couple of days as well. Times out.
Ah..That sounds like the same issue. I can connect to servers outside of the UK. What's your ISP?
Same issue here. Mine only started yesterday morning
Edited ... by AJ_GRIFF
Can you ping the hosts you connecting too from your location?
Since this has happened i moved to alternative AirVpn servers (Euro/Earth) as the UK servers are not pinging for my UK ISP Community Fiber :/
They're are working from an alternative ISP here in the UK which suggest either I'm being blocked or there's a routing issue at play?
Any AirVpn Staff at hand to confirm please :)
Thank you!
Edited ... by kanetoad
Seemed to have similar issues to other folks connecting to UK servers, my ISP is also Community Fibre, I'm not on CGNAT, I've had it all working fine then this week cannot connect using pfSense.
Tried connecting to UK servers on Eddie to the UK servers, none will connect though I can connect to others in Europe
Westerlund
Orbitar
Nashira
Naos
Chow
Asterope
Kitel
Geminorum
Denebola
Carinae
Betelgeuse
Asterion
Arion
Alshain
Alathfar
I'm having the same problem. Checked for updates, reinstalled and no luck.
Anyone have an idea how to fix this?
I’m having the same issue as others in this post.
Eddie fails to connect to any of the UK servers and doesn’t display ping results for the UK.
My Location: UK
ISP:  Community Fibre
  Edited ... by tycoon21
forgot to mention i'm on community fibre, too. looks like 3 of the other posters in here are as well, so i have to imagine they're the cause.
funny i got a vpn in the first place to get around cgnat—now they've seemingly blocked the solution 🙄
Edited ... by homilien
Please post your ISP so we can ascertain whether it's Community Fiber the only culprit or not. If so we can move the thread to the specific forum here: https://airvpn.org/forums/forum/20-known-isp-issue/
Please test also with filters disabled, just in case the VPN server addresses have been added to some opt out block list. In the UK it has been verified that some ISPs black list AirVPN web site as a porn site (which tells a lot about the degree of accuracy they compile such lists and their level of expertise in general...).
From logs posted above Eddie attempts to connect to  217.138.195.21 but gets no response.  This does seem to be a correct AirVPN IP address so DNS doesn't seem poisoned.  Rather it does look like ISPs are preventing connection to that IP address.  I do wonder if TCP, rather than UDP, would work.
Does anyone else who uses Community Fibre, see any settings on their online account that provides any controls for block lists or filtering ? At least on my account I have basically nothing.
Did anyone contact the ISP ?
The process varies from ISP to ISP, in general you must contact your ISP customer service. The unblocking of some categories may be accepted or denied. The common law which provides UK citizens with negative rights on freedom of expression is the main basis for a series of restrictions, according to Wikipedia, so opting out of filters is not usually an automated procedure but it is pondered on a sort of case by case basis and very vague rights, and sometimes managed as a courtesy, not a right. https://en.wikipedia.org/wiki/Internet_censorship_in_the_United_Kingdom
The main problem we see here is that since all the block lists are secret and not subjected to public scrutiny, you can not know in which list the AirVPN servers addresses have been put into (we ascertained a few years ago that airvpn.org was in the porn list by a random lucky occurrence). https://en.wikipedia.org/wiki/Web_blocking_in_the_United_Kingdom
I'm in the UK (where people are subjects, not citizens 🙄) and also have community fibre.
Anyone know if using OpenVPN or Wireguard might help?
Yes, of course, according to the reports we receive Community Fibers does not block VPN protocols, but AirVPN UK servers IP addresses. So you can use AirVPN to connect to any other VPN server in the world, with WireGuard or OpenVPN, and bypass any previous restriction.
There seem to be multiple server locations blocked by Community Fibre now.
All the servers I have tried in the attached image no longer connect.
Therefore, looking at the servers on the screenshot, it is possible that Community Fiber blocks M247: perhaps the block is not against AirVPN but against that big provider IP address blocks (whose HQ is, ironically, in the UK). As a counter-proof, please try connections to any non M247 server. In Europe, all the 10 Gbit/s servers are not with M247, and all the servers in the Netherlands, Estonia, Sweden and Latvia are not with M247. You can find other non-M247 servers in Czech Republic, Germany, Spain and Switzerland.
List of 10 Gbit/s (full duplex) servers in Europe.
Bulgaria: Wazn
Netherlands: Dalim, Menkent, Piautos
Sweden: Ain
Switzerland: Alpherg, Xuange
Could someone in UK please test all of the above and verify that they are not blocked?
We are working to add unmetered and dedicated 10 Gbit/s line in Germany (not with M247) as well.
I can confirm via Eddie and Community Fibre I can connect to all of the above servers.
Also just did a quick test of the some of the servers @tycoon21 couldn't connect to and had the same result.
The dutch servers are working ok via pfSense which I have been running since on openVPN.
Bulgaria: Wazn
Sweden: Ain
I have tried all but Xuange (reached the 5 connection limit) and all connected. Then tried Chow, Manchester and no connection.
