hbs
ANSWERED Unable to connect to AirVPN after updating expired CA.cert
Hi AirVPN,
Today I noticed that my firewall was without internet access. I noticed on pfSense lots of messages saying that my CERT was expired.
I downloaded a new CA.crt from the AirVPN user area, copied the new data and pasted on the CERT manager are of pfSense.
It updated and it says 2111 as the expiring year. However I can't get to the internet and honestly I dont know what is happening.
Can anyone here help me out?
pfSense 2.6.0
OpenVPN 2.5
Here's the log output:
Apr 12 23:15:49	openvpn	68298	SIGTERM[soft,auth-failure] received, process exiting
Apr 12 23:15:49	openvpn	68298	TCP/UDP: Closing socket
Apr 12 23:15:49	openvpn	68298	AUTH: Received control message: AUTH_FAILED
Apr 12 23:15:49	openvpn	68298	UDPv4 READ [88] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2662 DATA len=74
Apr 12 23:15:49	openvpn	68298	UDPv4 READ [62] from [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 12 23:15:49	openvpn	68298	UDPv4 WRITE [89] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2918 DATA len=75
Apr 12 23:15:49	openvpn	68298	SENT CONTROL [Saclateni]: 'PUSH_REQUEST' (status=1)
Apr 12 23:15:48	openvpn	68298	[Saclateni] Peer Connection Initiated with [AF_INET]217.138.217.109:443
Apr 12 23:15:48	openvpn	68298	Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Apr 12 23:15:48	openvpn	68298	UDPv4 WRITE [62] to [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 12 23:15:48	openvpn	68298	WARNING: 'comp-lzo' is present in remote config but missing in local config, remote='comp-lzo'
Apr 12 23:15:48	openvpn	68298	WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1601', remote='link-mtu 1602'
Apr 12 23:15:48	openvpn	68298	UDPv4 READ [284] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2150 DATA len=270
Apr 12 23:15:48	openvpn	68298	UDPv4 READ [224] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1894 DATA len=210
Apr 12 23:15:48	openvpn	68298	UDPv4 READ [62] from [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 12 23:15:48	openvpn	68298	UDPv4 WRITE [699] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2150 DATA len=685
Apr 12 23:15:48	openvpn	68298	UDPv4 WRITE [1116] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1894 DATA len=1102
Apr 12 23:15:48	openvpn	68298	UDPv4 WRITE [1128] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1638 DATA len=1114
Apr 12 23:15:48	openvpn	68298	UDPv4 READ [647] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1126 DATA len=633
Apr 12 23:15:48	openvpn	68298	VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saclateni, emailAddress=info@airvpn.org
Apr 12 23:15:48	openvpn	68298	VERIFY EKU OK
Apr 12 23:15:48	openvpn	68298	++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Apr 12 23:15:48	openvpn	68298	Validating certificate extended key usage
Apr 12 23:15:48	openvpn	68298	VERIFY KU OK
Apr 12 23:15:48	openvpn	68298	VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Apr 12 23:15:48	openvpn	68298	VERIFY WARNING: depth=1, unable to get certificate CRL: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Apr 12 23:15:48	openvpn	68298	VERIFY WARNING: depth=0, unable to get certificate CRL: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saclateni, emailAddress=info@airvpn.org
Apr 12 23:15:48	openvpn	68298	UDPv4 READ [1116] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=870 DATA len=1102
Apr 12 23:15:48	openvpn	68298	UDPv4 READ [1128] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=614 DATA len=1114
Apr 12 23:15:48	openvpn	68298	UDPv4 WRITE [331] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=870 DATA len=317
Apr 12 23:15:48	openvpn	68298	TLS: Initial packet from [AF_INET]217.138.217.109:443, sid=d74dc049 4be809d2
Apr 12 23:15:48	openvpn	68298	UDPv4 READ [66] from [AF_INET]217.138.217.109:443: P_CONTROL_HARD_RESET_SERVER_V2 kid=0 [ ] pid=358 DATA len=52
Apr 12 23:15:47	openvpn	68298	UDPv4 WRITE [54] to [AF_INET]217.138.217.109:443: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 [ ] pid=358 DATA len=40
Apr 12 23:15:47	openvpn	68298	UDPv4 link remote: [AF_INET]217.138.217.109:443
Apr 12 23:15:47	openvpn	68298	UDPv4 link local (bound): [AF_INET]172.30.184.173:0
Apr 12 23:15:47	openvpn	68298	Socket Buffers: R=[42080->512000] S=[57344->512000]
Apr 12 23:15:47	openvpn	68298	TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.217.109:443
Apr 12 23:15:47	openvpn	68298	Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1601,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-server'
Apr 12 23:15:47	openvpn	68298	Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1601,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client'
Apr 12 23:15:47	openvpn	68298	Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Apr 12 23:15:47	openvpn	68298	Control Channel MTU parms [ L:1621 D:1156 EF:94 EB:0 ET:0 EL:3 ]
Apr 12 23:15:47	openvpn	68298	Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Apr 12 23:15:47	openvpn	68298	Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Apr 12 23:15:47	openvpn	68298	Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Apr 12 23:15:47	openvpn	68298	Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Apr 12 23:15:47	openvpn	68298	WARNING: experimental option --capath /var/etc/openvpn/client1/ca
Apr 12 23:15:47	openvpn	68298	NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 12 23:15:47	openvpn	68298	mlockall call succeeded
Apr 12 23:15:47	openvpn	68298	MANAGEMENT: unix domain socket listening on /var/etc/openvpn/client1/sock
Apr 12 23:15:47	openvpn	68242	library versions: OpenSSL 1.1.1l-freebsd 24 Aug 2021, LZO 2.10
Apr 12 23:15:47	openvpn	68242	OpenVPN 2.5.4 amd64-portbld-freebsd12.3 [SSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 12 2022
Apr 12 23:15:47	openvpn	68242	auth_user_pass_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	pull = ENABLED
Apr 12 23:15:47	openvpn	68242	client = ENABLED
Apr 12 23:15:47	openvpn	68242	vlan_pvid = 1
Apr 12 23:15:47	openvpn	68242	vlan_accept = all
Apr 12 23:15:47	openvpn	68242	vlan_tagging = DISABLED
Apr 12 23:15:47	openvpn	68242	port_share_port = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	port_share_host = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	auth_token_secret_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	auth_token_lifetime = 0
Apr 12 23:15:47	openvpn	68242	auth_token_generate = DISABLED
Apr 12 23:15:47	openvpn	68242	auth_user_pass_verify_script_via_file = DISABLED
Apr 12 23:15:47	openvpn	68242	auth_user_pass_verify_script = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	max_routes_per_client = 256
Apr 12 23:15:47	openvpn	68242	max_clients = 1024
Apr 12 23:15:47	openvpn	68242	cf_per = 0
Apr 12 23:15:47	openvpn	68242	cf_max = 0
Apr 12 23:15:47	openvpn	68242	duplicate_cn = DISABLED
Apr 12 23:15:47	openvpn	68242	enable_c2c = DISABLED
Apr 12 23:15:47	openvpn	68242	push_ifconfig_ipv6_remote = ::
Apr 12 23:15:47	openvpn	68242	push_ifconfig_ipv6_local = ::/0
Apr 12 23:15:47	openvpn	68242	push_ifconfig_ipv6_defined = DISABLED
Apr 12 23:15:47	openvpn	68242	push_ifconfig_remote_netmask = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	push_ifconfig_local = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	push_ifconfig_defined = DISABLED
Apr 12 23:15:47	openvpn	68242	tmp_dir = '/tmp'
Apr 12 23:15:47	openvpn	68242	ccd_exclusive = DISABLED
Apr 12 23:15:47	openvpn	68242	client_config_dir = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	client_disconnect_script = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	learn_address_script = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	client_connect_script = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	virtual_hash_size = 256
Apr 12 23:15:47	openvpn	68242	real_hash_size = 256
Apr 12 23:15:47	openvpn	68242	tcp_queue_limit = 64
Apr 12 23:15:47	openvpn	68242	n_bcast_buf = 256
Apr 12 23:15:47	openvpn	68242	ifconfig_ipv6_pool_netbits = 0
Apr 12 23:15:47	openvpn	68242	ifconfig_ipv6_pool_base = ::
Apr 12 23:15:47	openvpn	68242	ifconfig_ipv6_pool_defined = DISABLED
Apr 12 23:15:47	openvpn	68242	ifconfig_pool_persist_refresh_freq = 600
Apr 12 23:15:47	openvpn	68242	ifconfig_pool_persist_filename = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	ifconfig_pool_netmask = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	ifconfig_pool_end = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	ifconfig_pool_start = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	ifconfig_pool_defined = DISABLED
Apr 12 23:15:47	openvpn	68242	server_bridge_pool_end = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	server_bridge_pool_start = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	server_bridge_netmask = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	server_bridge_ip = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	server_netbits_ipv6 = 0
Apr 12 23:15:47	openvpn	68242	server_network_ipv6 = ::
Apr 12 23:15:47	openvpn	68242	server_netmask = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	server_network = 0.0.0.0
Apr 12 23:15:47	openvpn	68242	tls_crypt_v2_metadata = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	tls_exit = DISABLED
Apr 12 23:15:47	openvpn	68242	push_peer_info = DISABLED
Apr 12 23:15:47	openvpn	68242	single_session = DISABLED
Apr 12 23:15:47	openvpn	68242	transition_window = 3600
Apr 12 23:15:47	openvpn	68242	handshake_window = 60
Apr 12 23:15:47	openvpn	68242	renegotiate_seconds = 3600
Apr 12 23:15:47	openvpn	68242	renegotiate_packets = 0
Apr 12 23:15:47	openvpn	68242	renegotiate_bytes = -1
Apr 12 23:15:47	openvpn	68242	tls_timeout = 2
Apr 12 23:15:47	openvpn	68242	ssl_flags = 0
Apr 12 23:15:47	openvpn	68242	remote_cert_eku = 'TLS Web Server Authentication'
Apr 12 23:15:47	openvpn	68242	remote_cert_ku[i] = 0
Apr 12 23:15:47	openvpn	68242	remote_cert_ku[i] = 65535
Apr 12 23:15:47	openvpn	68242	ns_cert_type = 0
Apr 12 23:15:47	openvpn	68242	crl_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	verify_x509_name = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	verify_x509_type = 0
Apr 12 23:15:47	openvpn	68242	tls_export_cert = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	tls_verify = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	tls_cert_profile = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	cipher_list_tls13 = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	cipher_list = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	pkcs12_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	priv_key_file = '/var/etc/openvpn/client1/key'
Apr 12 23:15:47	openvpn	68242	extra_certs_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	cert_file = '/var/etc/openvpn/client1/cert'
Apr 12 23:15:47	openvpn	68242	dh_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	ca_path = '/var/etc/openvpn/client1/ca'
Apr 12 23:15:47	openvpn	68242	ca_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	tls_client = ENABLED
Apr 12 23:15:47	openvpn	68242	tls_server = DISABLED
Apr 12 23:15:47	openvpn	68242	test_crypto = DISABLED
Apr 12 23:15:47	openvpn	68242	packet_id_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	replay_time = 15
Apr 12 23:15:47	openvpn	68242	replay_window = 64
Apr 12 23:15:47	openvpn	68242	mute_replay_warnings = DISABLED
Apr 12 23:15:47	openvpn	68242	replay = ENABLED
Apr 12 23:15:47	openvpn	68242	engine = DISABLED
Apr 12 23:15:47	openvpn	68242	keysize = 0
Apr 12 23:15:47	openvpn	68242	prng_nonce_secret_len = 64
Apr 12 23:15:47	openvpn	68242	prng_hash = 'sha256'
Apr 12 23:15:47	openvpn	68242	authname = 'SHA512'
Apr 12 23:15:47	openvpn	68242	ncp_ciphers = 'AES-256-GCM:AES-256-CBC'
Apr 12 23:15:47	openvpn	68242	ncp_enabled = ENABLED
Apr 12 23:15:47	openvpn	68242	ciphername = 'AES-256-CBC'
Apr 12 23:15:47	openvpn	68242	key_direction = not set
Apr 12 23:15:47	openvpn	68242	shared_secret_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	management_flags = 256
Apr 12 23:15:47	openvpn	68242	management_client_group = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	management_client_user = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	management_write_peer_info_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	management_echo_buffer_size = 100
Apr 12 23:15:47	openvpn	68242	management_log_history_cache = 250
Apr 12 23:15:47	openvpn	68242	management_user_pass = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	management_port = 'unix'
Apr 12 23:15:47	openvpn	68242	management_addr = '/var/etc/openvpn/client1/sock'
Apr 12 23:15:47	openvpn	68242	allow_pull_fqdn = DISABLED
Apr 12 23:15:47	openvpn	68242	route_gateway_via_dhcp = DISABLED
Apr 12 23:15:47	openvpn	68242	route_nopull = DISABLED
Apr 12 23:15:47	openvpn	68242	route_delay_defined = DISABLED
Apr 12 23:15:47	openvpn	68242	route_delay_window = 30
Apr 12 23:15:47	openvpn	68242	route_delay = 0
Apr 12 23:15:47	openvpn	68242	route_noexec = DISABLED
Apr 12 23:15:47	openvpn	68242	route_default_metric = 0
Apr 12 23:15:47	openvpn	68242	route_default_gateway = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	route_script = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	comp.flags = 24
Apr 12 23:15:47	openvpn	68242	comp.alg = 0
Apr 12 23:15:47	openvpn	68242	fast_io = ENABLED
Apr 12 23:15:47	openvpn	68242	sockflags = 0
Apr 12 23:15:47	openvpn	68242	sndbuf = 512000
Apr 12 23:15:47	openvpn	68242	rcvbuf = 512000
Apr 12 23:15:47	openvpn	68242	occ = ENABLED
Apr 12 23:15:47	openvpn	68242	status_file_update_freq = 60
Apr 12 23:15:47	openvpn	68242	status_file_version = 1
Apr 12 23:15:47	openvpn	68242	status_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	gremlin = 0
Apr 12 23:15:47	openvpn	68242	mute = 0
Apr 12 23:15:47	openvpn	68242	verbosity = 6
Apr 12 23:15:47	openvpn	68242	nice = 0
Apr 12 23:15:47	openvpn	68242	machine_readable_output = DISABLED
Apr 12 23:15:47	openvpn	68242	suppress_timestamps = DISABLED
Apr 12 23:15:47	openvpn	68242	log = DISABLED
Apr 12 23:15:47	openvpn	68242	inetd = 0
Apr 12 23:15:47	openvpn	68242	daemon = ENABLED
Apr 12 23:15:47	openvpn	68242	up_delay = DISABLED
Apr 12 23:15:47	openvpn	68242	up_restart = DISABLED
Apr 12 23:15:47	openvpn	68242	down_pre = DISABLED
Apr 12 23:15:47	openvpn	68242	down_script = '/usr/local/sbin/ovpn-linkdown'
Apr 12 23:15:47	openvpn	68242	up_script = '/usr/local/sbin/ovpn-linkup'
Apr 12 23:15:47	openvpn	68242	writepid = '/var/run/openvpn_client1.pid'
Apr 12 23:15:47	openvpn	68242	cd_dir = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	chroot_dir = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	groupname = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	username = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	resolve_in_advance = DISABLED
Apr 12 23:15:47	openvpn	68242	resolve_retry_seconds = 1000000000
Apr 12 23:15:47	openvpn	68242	passtos = DISABLED
Apr 12 23:15:47	openvpn	68242	persist_key = ENABLED
Apr 12 23:15:47	openvpn	68242	persist_remote_ip = DISABLED
Apr 12 23:15:47	openvpn	68242	persist_local_ip = DISABLED
Apr 12 23:15:47	openvpn	68242	persist_tun = ENABLED
Apr 12 23:15:47	openvpn	68242	remap_sigusr1 = 0
Apr 12 23:15:47	openvpn	68242	ping_timer_remote = ENABLED
Apr 12 23:15:47	openvpn	68242	ping_rec_timeout_action = 2
Apr 12 23:15:47	openvpn	68242	ping_rec_timeout = 60
Apr 12 23:15:47	openvpn	68242	ping_send_timeout = 10
Apr 12 23:15:47	openvpn	68242	inactivity_timeout = 0
Apr 12 23:15:47	openvpn	68242	keepalive_timeout = 60
Apr 12 23:15:47	openvpn	68242	keepalive_ping = 10
Apr 12 23:15:47	openvpn	68242	mlock = ENABLED
Apr 12 23:15:47	openvpn	68242	mtu_test = 0
Apr 12 23:15:47	openvpn	68242	shaper = 0
Apr 12 23:15:47	openvpn	68242	ifconfig_ipv6_remote = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	ifconfig_ipv6_netbits = 0
Apr 12 23:15:47	openvpn	68242	ifconfig_ipv6_local = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	ifconfig_nowarn = DISABLED
Apr 12 23:15:47	openvpn	68242	ifconfig_noexec = DISABLED
Apr 12 23:15:47	openvpn	68242	ifconfig_remote_netmask = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	ifconfig_local = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	topology = 1
Apr 12 23:15:47	openvpn	68242	lladdr = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	dev_node = '/dev/tun1'
Apr 12 23:15:47	openvpn	68242	dev_type = 'tun'
Apr 12 23:15:47	openvpn	68242	dev = 'ovpnc1'
Apr 12 23:15:47	openvpn	68242	ipchange = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	remote_random = DISABLED
Apr 12 23:15:47	openvpn	68242	Connection profiles END
Apr 12 23:15:47	openvpn	68242	tls_crypt_v2_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	tls_crypt_file = '[INLINE]'
Apr 12 23:15:47	openvpn	68242	tls_auth_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	explicit_exit_notification = 0
Apr 12 23:15:47	openvpn	68242	mssfix = 1450
Apr 12 23:15:47	openvpn	68242	fragment = 0
Apr 12 23:15:47	openvpn	68242	mtu_discover_type = -1
Apr 12 23:15:47	openvpn	68242	tun_mtu_extra_defined = DISABLED
Apr 12 23:15:47	openvpn	68242	tun_mtu_extra = 0
Apr 12 23:15:47	openvpn	68242	link_mtu_defined = DISABLED
Apr 12 23:15:47	openvpn	68242	link_mtu = 1500
Apr 12 23:15:47	openvpn	68242	tun_mtu_defined = ENABLED
Apr 12 23:15:47	openvpn	68242	tun_mtu = 1500
Apr 12 23:15:47	openvpn	68242	socks_proxy_port = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	socks_proxy_server = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	connect_timeout = 120
Apr 12 23:15:47	openvpn	68242	connect_retry_seconds = 5
Apr 12 23:15:47	openvpn	68242	bind_ipv6_only = DISABLED
Apr 12 23:15:47	openvpn	68242	bind_local = ENABLED
Apr 12 23:15:47	openvpn	68242	bind_defined = DISABLED
Apr 12 23:15:47	openvpn	68242	remote_float = DISABLED
Apr 12 23:15:47	openvpn	68242	remote_port = '443'
Apr 12 23:15:47	openvpn	68242	remote = '217.138.217.109'
Apr 12 23:15:47	openvpn	68242	local_port = '0'
Apr 12 23:15:47	openvpn	68242	local = '172.30.184.173'
Apr 12 23:15:47	openvpn	68242	proto = udp4
Apr 12 23:15:47	openvpn	68242	Connection profiles [0]:
Apr 12 23:15:47	openvpn	68242	connect_retry_max = 0
Apr 12 23:15:47	openvpn	68242	show_tls_ciphers = DISABLED
Apr 12 23:15:47	openvpn	68242	key_pass_file = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	genkey_filename = '[UNDEF]'
Apr 12 23:15:47	openvpn	68242	genkey = DISABLED
Apr 12 23:15:47	openvpn	68242	show_engines = DISABLED
Apr 12 23:15:47	openvpn	68242	show_digests = DISABLED
Apr 12 23:15:47	openvpn	68242	show_ciphers = DISABLED
Apr 12 23:15:47	openvpn	68242	mode = 0
Apr 12 23:15:47	openvpn	68242	config = '/var/etc/openvpn/client1/config.ovpn'
Apr 12 23:15:47	openvpn	68242	Current Parameter Settings:
Apr 12 23:12:59	openvpn	38417	SIGTERM[soft,auth-failure] received, process exiting
Apr 12 23:12:59	openvpn	38417	TCP/UDP: Closing socket
Apr 12 23:12:59	openvpn	38417	AUTH: Received control message: AUTH_FAILED
Apr 12 23:12:59	openvpn	38417	UDPv4 READ [88] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2662 DATA len=74
Apr 12 23:12:59	openvpn	38417	UDPv4 READ [62] from [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 12 23:12:59	openvpn	38417	UDPv4 WRITE [89] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2918 DATA len=75
Apr 12 23:12:59	openvpn	38417	SENT CONTROL [Saclateni]: 'PUSH_REQUEST' (status=1)
Apr 12 23:12:58	openvpn	38417	[Saclateni] Peer Connection Initiated with [AF_INET]217.138.217.109:443
Apr 12 23:12:58	openvpn	38417	Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Apr 12 23:12:58	openvpn	38417	UDPv4 WRITE [62] to [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 12 23:12:58	openvpn	38417	WARNING: 'comp-lzo' is present in remote config but missing in local config, remote='comp-lzo'
Apr 12 23:12:58	openvpn	38417	WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1601', remote='link-mtu 1602'
Apr 12 23:12:58	openvpn	38417	UDPv4 READ [284] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2150 DATA len=270
Apr 12 23:12:58	openvpn	38417	UDPv4 READ [224] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1894 DATA len=210
Apr 12 23:12:58	openvpn	38417	UDPv4 READ [62] from [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 12 23:12:57	openvpn	38417	UDPv4 WRITE [699] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2150 DATA len=685
Apr 12 23:12:57	openvpn	38417	UDPv4 WRITE [1116] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1894 DATA len=1102
Apr 12 23:12:57	openvpn	38417	UDPv4 WRITE [1128] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1638 DATA len=1114
Apr 12 23:12:57	openvpn	38417	UDPv4 READ [647] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1126 DATA len=633
Apr 12 23:12:57	openvpn	38417	UDPv4 WRITE [62] to [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 12 23:12:57	openvpn	38417	VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saclateni, emailAddress=info@airvpn.org
Apr 12 23:12:57	openvpn	38417	VERIFY EKU OK
Apr 12 23:12:57	openvpn	38417	++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Apr 12 23:12:57	openvpn	38417	Validating certificate extended key usage
Apr 12 23:12:57	openvpn	38417	VERIFY KU OK
Apr 12 23:12:57	openvpn	38417	VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Apr 12 23:12:57	openvpn	38417	VERIFY WARNING: depth=1, unable to get certificate CRL: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Apr 12 23:12:57	openvpn	38417	VERIFY WARNING: depth=0, unable to get certificate CRL: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saclateni, emailAddress=info@airvpn.org
Apr 12 23:12:57	openvpn	38417	UDPv4 READ [1116] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=870 DATA len=1102
Apr 12 23:12:57	openvpn	38417	UDPv4 READ [1128] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=614 DATA len=1114
Apr 12 23:12:57	openvpn	38417	UDPv4 WRITE [331] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=870 DATA len=317
Apr 12 23:12:57	openvpn	38417	TLS: Initial packet from [AF_INET]217.138.217.109:443, sid=7d5a06ef bb6d8ade
Apr 12 23:12:57	openvpn	38417	UDPv4 READ [66] from [AF_INET]217.138.217.109:443: P_CONTROL_HARD_RESET_SERVER_V2 kid=0 [ ] pid=358 DATA len=52
Apr 12 23:12:57	openvpn	38417	UDPv4 WRITE [54] to [AF_INET]217.138.217.109:443: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 [ ] pid=358 DATA len=40
Apr 12 23:12:57	openvpn	38417	UDPv4 link remote: [AF_INET]217.138.217.109:443
Apr 12 23:12:57	openvpn	38417	UDPv4 link local (bound): [AF_INET]172.30.184.173:0
Apr 12 23:12:57	openvpn	38417	Socket Buffers: R=[42080->512000] S=[57344->512000]
Apr 12 23:12:57	openvpn	38417	TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.217.109:443
Apr 12 23:12:57	openvpn	38417	Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1601,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-server'
Apr 12 23:12:57	openvpn	38417	Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1601,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client'
Apr 12 23:12:57	openvpn	38417	Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Apr 12 23:12:57	openvpn	38417	Control Channel MTU parms [ L:1621 D:1156 EF:94 EB:0 ET:0 EL:3 ]
Apr 12 23:12:57	openvpn	38417	Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Apr 12 23:12:57	openvpn	38417	Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Apr 12 23:12:57	openvpn	38417	Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Apr 12 23:12:57	openvpn	38417	Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Apr 12 23:12:57	openvpn	38417	WARNING: experimental option --capath /var/etc/openvpn/client1/ca
Apr 12 23:12:57	openvpn	38417	NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 12 23:12:57	openvpn	38417	mlockall call succeeded
Apr 12 23:12:57	openvpn	38417	MANAGEMENT: unix domain socket listening on /var/etc/openvpn/client1/sock
Apr 12 23:12:57	openvpn	38308	library versions: OpenSSL 1.1.1l-freebsd 24 Aug 2021, LZO 2.10
Apr 12 23:12:57	openvpn	38308	OpenVPN 2.5.4 amd64-portbld-freebsd12.3 [SSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 12 2022
Apr 12 23:12:57	openvpn	38308	auth_user_pass_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	pull = ENABLED
Apr 12 23:12:57	openvpn	38308	client = ENABLED
Apr 12 23:12:57	openvpn	38308	vlan_pvid = 1
Apr 12 23:12:57	openvpn	38308	vlan_accept = all
Apr 12 23:12:57	openvpn	38308	vlan_tagging = DISABLED
Apr 12 23:12:57	openvpn	38308	port_share_port = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	port_share_host = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	auth_token_secret_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	auth_token_lifetime = 0
Apr 12 23:12:57	openvpn	38308	auth_token_generate = DISABLED
Apr 12 23:12:57	openvpn	38308	auth_user_pass_verify_script_via_file = DISABLED
Apr 12 23:12:57	openvpn	38308	auth_user_pass_verify_script = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	max_routes_per_client = 256
Apr 12 23:12:57	openvpn	38308	max_clients = 1024
Apr 12 23:12:57	openvpn	38308	cf_per = 0
Apr 12 23:12:57	openvpn	38308	cf_max = 0
Apr 12 23:12:57	openvpn	38308	duplicate_cn = DISABLED
Apr 12 23:12:57	openvpn	38308	enable_c2c = DISABLED
Apr 12 23:12:57	openvpn	38308	push_ifconfig_ipv6_remote = ::
Apr 12 23:12:57	openvpn	38308	push_ifconfig_ipv6_local = ::/0
Apr 12 23:12:57	openvpn	38308	push_ifconfig_ipv6_defined = DISABLED
Apr 12 23:12:57	openvpn	38308	push_ifconfig_remote_netmask = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	push_ifconfig_local = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	push_ifconfig_defined = DISABLED
Apr 12 23:12:57	openvpn	38308	tmp_dir = '/tmp'
Apr 12 23:12:57	openvpn	38308	ccd_exclusive = DISABLED
Apr 12 23:12:57	openvpn	38308	client_config_dir = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	client_disconnect_script = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	learn_address_script = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	client_connect_script = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	virtual_hash_size = 256
Apr 12 23:12:57	openvpn	38308	real_hash_size = 256
Apr 12 23:12:57	openvpn	38308	tcp_queue_limit = 64
Apr 12 23:12:57	openvpn	38308	n_bcast_buf = 256
Apr 12 23:12:57	openvpn	38308	ifconfig_ipv6_pool_netbits = 0
Apr 12 23:12:57	openvpn	38308	ifconfig_ipv6_pool_base = ::
Apr 12 23:12:57	openvpn	38308	ifconfig_ipv6_pool_defined = DISABLED
Apr 12 23:12:57	openvpn	38308	ifconfig_pool_persist_refresh_freq = 600
Apr 12 23:12:57	openvpn	38308	ifconfig_pool_persist_filename = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	ifconfig_pool_netmask = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	ifconfig_pool_end = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	ifconfig_pool_start = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	ifconfig_pool_defined = DISABLED
Apr 12 23:12:57	openvpn	38308	server_bridge_pool_end = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	server_bridge_pool_start = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	server_bridge_netmask = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	server_bridge_ip = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	server_netbits_ipv6 = 0
Apr 12 23:12:57	openvpn	38308	server_network_ipv6 = ::
Apr 12 23:12:57	openvpn	38308	server_netmask = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	server_network = 0.0.0.0
Apr 12 23:12:57	openvpn	38308	tls_crypt_v2_metadata = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	tls_exit = DISABLED
Apr 12 23:12:57	openvpn	38308	push_peer_info = DISABLED
Apr 12 23:12:57	openvpn	38308	single_session = DISABLED
Apr 12 23:12:57	openvpn	38308	transition_window = 3600
Apr 12 23:12:57	openvpn	38308	handshake_window = 60
Apr 12 23:12:57	openvpn	38308	renegotiate_seconds = 3600
Apr 12 23:12:57	openvpn	38308	renegotiate_packets = 0
Apr 12 23:12:57	openvpn	38308	renegotiate_bytes = -1
Apr 12 23:12:57	openvpn	38308	tls_timeout = 2
Apr 12 23:12:57	openvpn	38308	ssl_flags = 0
Apr 12 23:12:57	openvpn	38308	remote_cert_eku = 'TLS Web Server Authentication'
Apr 12 23:12:57	openvpn	38308	remote_cert_ku[i] = 0
Apr 12 23:12:57	openvpn	38308	remote_cert_ku[i] = 65535
Apr 12 23:12:57	openvpn	38308	ns_cert_type = 0
Apr 12 23:12:57	openvpn	38308	crl_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	verify_x509_name = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	verify_x509_type = 0
Apr 12 23:12:57	openvpn	38308	tls_export_cert = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	tls_verify = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	tls_cert_profile = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	cipher_list_tls13 = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	cipher_list = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	pkcs12_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	priv_key_file = '/var/etc/openvpn/client1/key'
Apr 12 23:12:57	openvpn	38308	extra_certs_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	cert_file = '/var/etc/openvpn/client1/cert'
Apr 12 23:12:57	openvpn	38308	dh_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	ca_path = '/var/etc/openvpn/client1/ca'
Apr 12 23:12:57	openvpn	38308	ca_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	tls_client = ENABLED
Apr 12 23:12:57	openvpn	38308	tls_server = DISABLED
Apr 12 23:12:57	openvpn	38308	test_crypto = DISABLED
Apr 12 23:12:57	openvpn	38308	packet_id_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	replay_time = 15
Apr 12 23:12:57	openvpn	38308	replay_window = 64
Apr 12 23:12:57	openvpn	38308	mute_replay_warnings = DISABLED
Apr 12 23:12:57	openvpn	38308	replay = ENABLED
Apr 12 23:12:57	openvpn	38308	engine = DISABLED
Apr 12 23:12:57	openvpn	38308	keysize = 0
Apr 12 23:12:57	openvpn	38308	prng_nonce_secret_len = 64
Apr 12 23:12:57	openvpn	38308	prng_hash = 'sha256'
Apr 12 23:12:57	openvpn	38308	authname = 'SHA512'
Apr 12 23:12:57	openvpn	38308	ncp_ciphers = 'AES-256-GCM:AES-256-CBC'
Apr 12 23:12:57	openvpn	38308	ncp_enabled = ENABLED
Apr 12 23:12:57	openvpn	38308	ciphername = 'AES-256-CBC'
Apr 12 23:12:57	openvpn	38308	key_direction = not set
Apr 12 23:12:57	openvpn	38308	shared_secret_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	management_flags = 256
Apr 12 23:12:57	openvpn	38308	management_client_group = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	management_client_user = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	management_write_peer_info_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	management_echo_buffer_size = 100
Apr 12 23:12:57	openvpn	38308	management_log_history_cache = 250
Apr 12 23:12:57	openvpn	38308	management_user_pass = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	management_port = 'unix'
Apr 12 23:12:57	openvpn	38308	management_addr = '/var/etc/openvpn/client1/sock'
Apr 12 23:12:57	openvpn	38308	allow_pull_fqdn = DISABLED
Apr 12 23:12:57	openvpn	38308	route_gateway_via_dhcp = DISABLED
Apr 12 23:12:57	openvpn	38308	route_nopull = DISABLED
Apr 12 23:12:57	openvpn	38308	route_delay_defined = DISABLED
Apr 12 23:12:57	openvpn	38308	route_delay_window = 30
Apr 12 23:12:57	openvpn	38308	route_delay = 0
Apr 12 23:12:57	openvpn	38308	route_noexec = DISABLED
Apr 12 23:12:57	openvpn	38308	route_default_metric = 0
Apr 12 23:12:57	openvpn	38308	route_default_gateway = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	route_script = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	comp.flags = 24
Apr 12 23:12:57	openvpn	38308	comp.alg = 0
Apr 12 23:12:57	openvpn	38308	fast_io = ENABLED
Apr 12 23:12:57	openvpn	38308	sockflags = 0
Apr 12 23:12:57	openvpn	38308	sndbuf = 512000
Apr 12 23:12:57	openvpn	38308	rcvbuf = 512000
Apr 12 23:12:57	openvpn	38308	occ = ENABLED
Apr 12 23:12:57	openvpn	38308	status_file_update_freq = 60
Apr 12 23:12:57	openvpn	38308	status_file_version = 1
Apr 12 23:12:57	openvpn	38308	status_file = '[UNDEF]'
Apr 12 23:12:57	openvpn	38308	gremlin = 0
Apr 12 23:12:57	openvpn	38308	mute = 0
Apr 12 23:12:57	openvpn	38308	verbosity = 6
Apr 12 23:12:57	openvpn	38308	nice = 0
Apr 12 23:12:57	openvpn	38308	machine_readable_output = DISABLED
Apr 12 23:12:57	openvpn	38308	suppress_timestamps = DISABLED
Apr 12 23:12:57	openvpn	38308	log = DISABLED
Apr 12 23:12:57	openvpn	38308	inetd = 0
Apr 12 23:12:57	openvpn	38308	daemon = ENABLED
Apr 12 23:12:57	openvpn	38308	up_delay = DISABLED
Apr 12 23:12:57	openvpn	38308	up_restart = DISABLED
Authorization failure. Can you please re-check your user.crt and user.key too?
I re-copied the user.crt and user.key data to their respective places but I'm still getting nowhere.
All certificates have now the same validation expiring time of:
Valid From: Fri, 26 Oct 2018 04:54:23 +0300
Valid Until: Mon, 23 Oct 2028 04:54:23 +0300
Here's the newest log output:
Apr 13 03:19:34	openvpn	83946	SIGTERM[soft,auth-failure] received, process exiting
Apr 13 03:19:34	openvpn	83946	TCP/UDP: Closing socket
Apr 13 03:19:34	openvpn	83946	AUTH: Received control message: AUTH_FAILED
Apr 13 03:19:34	openvpn	83946	UDPv4 READ [88] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2662 DATA len=74
Apr 13 03:19:34	openvpn	83946	UDPv4 READ [62] from [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 13 03:19:34	openvpn	83946	UDPv4 WRITE [89] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2918 DATA len=75
Apr 13 03:19:34	openvpn	83946	SENT CONTROL [Saclateni]: 'PUSH_REQUEST' (status=1)
Apr 13 03:19:33	openvpn	83946	[Saclateni] Peer Connection Initiated with [AF_INET]217.138.217.109:443
Apr 13 03:19:33	openvpn	83946	Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Apr 13 03:19:33	openvpn	83946	UDPv4 WRITE [62] to [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 13 03:19:33	openvpn	83946	WARNING: 'comp-lzo' is present in remote config but missing in local config, remote='comp-lzo'
Apr 13 03:19:33	openvpn	83946	WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1601', remote='link-mtu 1602'
Apr 13 03:19:33	openvpn	83946	UDPv4 READ [284] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2150 DATA len=270
Apr 13 03:19:33	openvpn	83946	UDPv4 READ [224] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1894 DATA len=210
Apr 13 03:19:33	openvpn	83946	UDPv4 READ [62] from [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 13 03:19:33	openvpn	83946	UDPv4 WRITE [699] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2150 DATA len=685
Apr 13 03:19:33	openvpn	83946	UDPv4 WRITE [1116] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1894 DATA len=1102
Apr 13 03:19:33	openvpn	83946	UDPv4 WRITE [1128] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1638 DATA len=1114
Apr 13 03:19:33	openvpn	83946	UDPv4 READ [647] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1126 DATA len=633
Apr 13 03:19:33	openvpn	83946	VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saclateni, emailAddress=info@airvpn.org
Apr 13 03:19:33	openvpn	83946	VERIFY EKU OK
Apr 13 03:19:33	openvpn	83946	++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Apr 13 03:19:33	openvpn	83946	Validating certificate extended key usage
Apr 13 03:19:33	openvpn	83946	VERIFY KU OK
Apr 13 03:19:33	openvpn	83946	VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Apr 13 03:19:33	openvpn	83946	VERIFY WARNING: depth=1, unable to get certificate CRL: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Apr 13 03:19:33	openvpn	83946	VERIFY WARNING: depth=0, unable to get certificate CRL: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saclateni, emailAddress=info@airvpn.org
Apr 13 03:19:33	openvpn	83946	UDPv4 READ [1116] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=870 DATA len=1102
Apr 13 03:19:33	openvpn	83946	UDPv4 READ [1128] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=614 DATA len=1114
Apr 13 03:19:32	openvpn	83946	UDPv4 WRITE [331] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=870 DATA len=317
Apr 13 03:19:32	openvpn	83946	UDPv4 WRITE [62] to [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 13 03:19:32	openvpn	83946	TLS: Initial packet from [AF_INET]217.138.217.109:443, sid=dc3f783a 45cb2c2c
Apr 13 03:19:32	openvpn	83946	UDPv4 READ [66] from [AF_INET]217.138.217.109:443: P_CONTROL_HARD_RESET_SERVER_V2 kid=0 [ ] pid=358 DATA len=52
Apr 13 03:19:32	openvpn	83946	UDPv4 WRITE [54] to [AF_INET]217.138.217.109:443: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 [ ] pid=358 DATA len=40
Apr 13 03:19:32	openvpn	83946	UDPv4 link remote: [AF_INET]217.138.217.109:443
Apr 13 03:19:32	openvpn	83946	UDPv4 link local (bound): [AF_INET]172.30.184.173:0
Apr 13 03:19:32	openvpn	83946	Socket Buffers: R=[42080->512000] S=[57344->512000]
Apr 13 03:19:32	openvpn	83946	TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.217.109:443
Apr 13 03:19:32	openvpn	83946	Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1601,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-server'
Apr 13 03:19:32	openvpn	83946	Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1601,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client'
Apr 13 03:19:32	openvpn	83946	Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Apr 13 03:19:32	openvpn	83946	Control Channel MTU parms [ L:1621 D:1156 EF:94 EB:0 ET:0 EL:3 ]
Apr 13 03:19:32	openvpn	83946	Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Apr 13 03:19:32	openvpn	83946	Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Apr 13 03:19:32	openvpn	83946	Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Apr 13 03:19:32	openvpn	83946	Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Apr 13 03:19:32	openvpn	83946	WARNING: experimental option --capath /var/etc/openvpn/client1/ca
Apr 13 03:19:32	openvpn	83946	NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 13 03:19:32	openvpn	83946	mlockall call succeeded
Apr 13 03:19:32	openvpn	83946	MANAGEMENT: unix domain socket listening on /var/etc/openvpn/client1/sock
Apr 13 03:19:32	openvpn	83855	library versions: OpenSSL 1.1.1l-freebsd 24 Aug 2021, LZO 2.10
Apr 13 03:19:32	openvpn	83855	OpenVPN 2.5.4 amd64-portbld-freebsd12.3 [SSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 12 2022
Apr 13 03:19:32	openvpn	83855	auth_user_pass_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	pull = ENABLED
Apr 13 03:19:32	openvpn	83855	client = ENABLED
Apr 13 03:19:32	openvpn	83855	vlan_pvid = 1
Apr 13 03:19:32	openvpn	83855	vlan_accept = all
Apr 13 03:19:32	openvpn	83855	vlan_tagging = DISABLED
Apr 13 03:19:32	openvpn	83855	port_share_port = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	port_share_host = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	auth_token_secret_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	auth_token_lifetime = 0
Apr 13 03:19:32	openvpn	83855	auth_token_generate = DISABLED
Apr 13 03:19:32	openvpn	83855	auth_user_pass_verify_script_via_file = DISABLED
Apr 13 03:19:32	openvpn	83855	auth_user_pass_verify_script = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	max_routes_per_client = 256
Apr 13 03:19:32	openvpn	83855	max_clients = 1024
Apr 13 03:19:32	openvpn	83855	cf_per = 0
Apr 13 03:19:32	openvpn	83855	cf_max = 0
Apr 13 03:19:32	openvpn	83855	duplicate_cn = DISABLED
Apr 13 03:19:32	openvpn	83855	enable_c2c = DISABLED
Apr 13 03:19:32	openvpn	83855	push_ifconfig_ipv6_remote = ::
Apr 13 03:19:32	openvpn	83855	push_ifconfig_ipv6_local = ::/0
Apr 13 03:19:32	openvpn	83855	push_ifconfig_ipv6_defined = DISABLED
Apr 13 03:19:32	openvpn	83855	push_ifconfig_remote_netmask = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	push_ifconfig_local = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	push_ifconfig_defined = DISABLED
Apr 13 03:19:32	openvpn	83855	tmp_dir = '/tmp'
Apr 13 03:19:32	openvpn	83855	ccd_exclusive = DISABLED
Apr 13 03:19:32	openvpn	83855	client_config_dir = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	client_disconnect_script = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	learn_address_script = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	client_connect_script = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	virtual_hash_size = 256
Apr 13 03:19:32	openvpn	83855	real_hash_size = 256
Apr 13 03:19:32	openvpn	83855	tcp_queue_limit = 64
Apr 13 03:19:32	openvpn	83855	n_bcast_buf = 256
Apr 13 03:19:32	openvpn	83855	ifconfig_ipv6_pool_netbits = 0
Apr 13 03:19:32	openvpn	83855	ifconfig_ipv6_pool_base = ::
Apr 13 03:19:32	openvpn	83855	ifconfig_ipv6_pool_defined = DISABLED
Apr 13 03:19:32	openvpn	83855	ifconfig_pool_persist_refresh_freq = 600
Apr 13 03:19:32	openvpn	83855	ifconfig_pool_persist_filename = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	ifconfig_pool_netmask = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	ifconfig_pool_end = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	ifconfig_pool_start = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	ifconfig_pool_defined = DISABLED
Apr 13 03:19:32	openvpn	83855	server_bridge_pool_end = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	server_bridge_pool_start = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	server_bridge_netmask = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	server_bridge_ip = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	server_netbits_ipv6 = 0
Apr 13 03:19:32	openvpn	83855	server_network_ipv6 = ::
Apr 13 03:19:32	openvpn	83855	server_netmask = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	server_network = 0.0.0.0
Apr 13 03:19:32	openvpn	83855	tls_crypt_v2_metadata = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	tls_exit = DISABLED
Apr 13 03:19:32	openvpn	83855	push_peer_info = DISABLED
Apr 13 03:19:32	openvpn	83855	single_session = DISABLED
Apr 13 03:19:32	openvpn	83855	transition_window = 3600
Apr 13 03:19:32	openvpn	83855	handshake_window = 60
Apr 13 03:19:32	openvpn	83855	renegotiate_seconds = 3600
Apr 13 03:19:32	openvpn	83855	renegotiate_packets = 0
Apr 13 03:19:32	openvpn	83855	renegotiate_bytes = -1
Apr 13 03:19:32	openvpn	83855	tls_timeout = 2
Apr 13 03:19:32	openvpn	83855	ssl_flags = 0
Apr 13 03:19:32	openvpn	83855	remote_cert_eku = 'TLS Web Server Authentication'
Apr 13 03:19:32	openvpn	83855	remote_cert_ku[i] = 0
Apr 13 03:19:32	openvpn	83855	remote_cert_ku[i] = 65535
Apr 13 03:19:32	openvpn	83855	ns_cert_type = 0
Apr 13 03:19:32	openvpn	83855	crl_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	verify_x509_name = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	verify_x509_type = 0
Apr 13 03:19:32	openvpn	83855	tls_export_cert = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	tls_verify = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	tls_cert_profile = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	cipher_list_tls13 = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	cipher_list = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	pkcs12_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	priv_key_file = '/var/etc/openvpn/client1/key'
Apr 13 03:19:32	openvpn	83855	extra_certs_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	cert_file = '/var/etc/openvpn/client1/cert'
Apr 13 03:19:32	openvpn	83855	dh_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	ca_path = '/var/etc/openvpn/client1/ca'
Apr 13 03:19:32	openvpn	83855	ca_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	tls_client = ENABLED
Apr 13 03:19:32	openvpn	83855	tls_server = DISABLED
Apr 13 03:19:32	openvpn	83855	test_crypto = DISABLED
Apr 13 03:19:32	openvpn	83855	packet_id_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	replay_time = 15
Apr 13 03:19:32	openvpn	83855	replay_window = 64
Apr 13 03:19:32	openvpn	83855	mute_replay_warnings = DISABLED
Apr 13 03:19:32	openvpn	83855	replay = ENABLED
Apr 13 03:19:32	openvpn	83855	engine = DISABLED
Apr 13 03:19:32	openvpn	83855	keysize = 0
Apr 13 03:19:32	openvpn	83855	prng_nonce_secret_len = 64
Apr 13 03:19:32	openvpn	83855	prng_hash = 'sha256'
Apr 13 03:19:32	openvpn	83855	authname = 'SHA512'
Apr 13 03:19:32	openvpn	83855	ncp_ciphers = 'AES-256-GCM:AES-256-CBC'
Apr 13 03:19:32	openvpn	83855	ncp_enabled = ENABLED
Apr 13 03:19:32	openvpn	83855	ciphername = 'AES-256-CBC'
Apr 13 03:19:32	openvpn	83855	key_direction = not set
Apr 13 03:19:32	openvpn	83855	shared_secret_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	management_flags = 256
Apr 13 03:19:32	openvpn	83855	management_client_group = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	management_client_user = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	management_write_peer_info_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	management_echo_buffer_size = 100
Apr 13 03:19:32	openvpn	83855	management_log_history_cache = 250
Apr 13 03:19:32	openvpn	83855	management_user_pass = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	management_port = 'unix'
Apr 13 03:19:32	openvpn	83855	management_addr = '/var/etc/openvpn/client1/sock'
Apr 13 03:19:32	openvpn	83855	allow_pull_fqdn = DISABLED
Apr 13 03:19:32	openvpn	83855	route_gateway_via_dhcp = DISABLED
Apr 13 03:19:32	openvpn	83855	route_nopull = DISABLED
Apr 13 03:19:32	openvpn	83855	route_delay_defined = DISABLED
Apr 13 03:19:32	openvpn	83855	route_delay_window = 30
Apr 13 03:19:32	openvpn	83855	route_delay = 0
Apr 13 03:19:32	openvpn	83855	route_noexec = DISABLED
Apr 13 03:19:32	openvpn	83855	route_default_metric = 0
Apr 13 03:19:32	openvpn	83855	route_default_gateway = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	route_script = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	comp.flags = 24
Apr 13 03:19:32	openvpn	83855	comp.alg = 0
Apr 13 03:19:32	openvpn	83855	fast_io = ENABLED
Apr 13 03:19:32	openvpn	83855	sockflags = 0
Apr 13 03:19:32	openvpn	83855	sndbuf = 512000
Apr 13 03:19:32	openvpn	83855	rcvbuf = 512000
Apr 13 03:19:32	openvpn	83855	occ = ENABLED
Apr 13 03:19:32	openvpn	83855	status_file_update_freq = 60
Apr 13 03:19:32	openvpn	83855	status_file_version = 1
Apr 13 03:19:32	openvpn	83855	status_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	gremlin = 0
Apr 13 03:19:32	openvpn	83855	mute = 0
Apr 13 03:19:32	openvpn	83855	verbosity = 6
Apr 13 03:19:32	openvpn	83855	nice = 0
Apr 13 03:19:32	openvpn	83855	machine_readable_output = DISABLED
Apr 13 03:19:32	openvpn	83855	suppress_timestamps = DISABLED
Apr 13 03:19:32	openvpn	83855	log = DISABLED
Apr 13 03:19:32	openvpn	83855	inetd = 0
Apr 13 03:19:32	openvpn	83855	daemon = ENABLED
Apr 13 03:19:32	openvpn	83855	up_delay = DISABLED
Apr 13 03:19:32	openvpn	83855	up_restart = DISABLED
Apr 13 03:19:32	openvpn	83855	down_pre = DISABLED
Apr 13 03:19:32	openvpn	83855	down_script = '/usr/local/sbin/ovpn-linkdown'
Apr 13 03:19:32	openvpn	83855	up_script = '/usr/local/sbin/ovpn-linkup'
Apr 13 03:19:32	openvpn	83855	writepid = '/var/run/openvpn_client1.pid'
Apr 13 03:19:32	openvpn	83855	cd_dir = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	chroot_dir = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	groupname = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	username = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	resolve_in_advance = DISABLED
Apr 13 03:19:32	openvpn	83855	resolve_retry_seconds = 1000000000
Apr 13 03:19:32	openvpn	83855	passtos = DISABLED
Apr 13 03:19:32	openvpn	83855	persist_key = ENABLED
Apr 13 03:19:32	openvpn	83855	persist_remote_ip = DISABLED
Apr 13 03:19:32	openvpn	83855	persist_local_ip = DISABLED
Apr 13 03:19:32	openvpn	83855	persist_tun = ENABLED
Apr 13 03:19:32	openvpn	83855	remap_sigusr1 = 0
Apr 13 03:19:32	openvpn	83855	ping_timer_remote = ENABLED
Apr 13 03:19:32	openvpn	83855	ping_rec_timeout_action = 2
Apr 13 03:19:32	openvpn	83855	ping_rec_timeout = 60
Apr 13 03:19:32	openvpn	83855	ping_send_timeout = 10
Apr 13 03:19:32	openvpn	83855	inactivity_timeout = 0
Apr 13 03:19:32	openvpn	83855	keepalive_timeout = 60
Apr 13 03:19:32	openvpn	83855	keepalive_ping = 10
Apr 13 03:19:32	openvpn	83855	mlock = ENABLED
Apr 13 03:19:32	openvpn	83855	mtu_test = 0
Apr 13 03:19:32	openvpn	83855	shaper = 0
Apr 13 03:19:32	openvpn	83855	ifconfig_ipv6_remote = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	ifconfig_ipv6_netbits = 0
Apr 13 03:19:32	openvpn	83855	ifconfig_ipv6_local = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	ifconfig_nowarn = DISABLED
Apr 13 03:19:32	openvpn	83855	ifconfig_noexec = DISABLED
Apr 13 03:19:32	openvpn	83855	ifconfig_remote_netmask = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	ifconfig_local = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	topology = 1
Apr 13 03:19:32	openvpn	83855	lladdr = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	dev_node = '/dev/tun1'
Apr 13 03:19:32	openvpn	83855	dev_type = 'tun'
Apr 13 03:19:32	openvpn	83855	dev = 'ovpnc1'
Apr 13 03:19:32	openvpn	83855	ipchange = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	remote_random = DISABLED
Apr 13 03:19:32	openvpn	83855	Connection profiles END
Apr 13 03:19:32	openvpn	83855	tls_crypt_v2_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	tls_crypt_file = '[INLINE]'
Apr 13 03:19:32	openvpn	83855	tls_auth_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	explicit_exit_notification = 0
Apr 13 03:19:32	openvpn	83855	mssfix = 1450
Apr 13 03:19:32	openvpn	83855	fragment = 0
Apr 13 03:19:32	openvpn	83855	mtu_discover_type = -1
Apr 13 03:19:32	openvpn	83855	tun_mtu_extra_defined = DISABLED
Apr 13 03:19:32	openvpn	83855	tun_mtu_extra = 0
Apr 13 03:19:32	openvpn	83855	link_mtu_defined = DISABLED
Apr 13 03:19:32	openvpn	83855	link_mtu = 1500
Apr 13 03:19:32	openvpn	83855	tun_mtu_defined = ENABLED
Apr 13 03:19:32	openvpn	83855	tun_mtu = 1500
Apr 13 03:19:32	openvpn	83855	socks_proxy_port = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	socks_proxy_server = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	connect_timeout = 120
Apr 13 03:19:32	openvpn	83855	connect_retry_seconds = 5
Apr 13 03:19:32	openvpn	83855	bind_ipv6_only = DISABLED
Apr 13 03:19:32	openvpn	83855	bind_local = ENABLED
Apr 13 03:19:32	openvpn	83855	bind_defined = DISABLED
Apr 13 03:19:32	openvpn	83855	remote_float = DISABLED
Apr 13 03:19:32	openvpn	83855	remote_port = '443'
Apr 13 03:19:32	openvpn	83855	remote = '217.138.217.109'
Apr 13 03:19:32	openvpn	83855	local_port = '0'
Apr 13 03:19:32	openvpn	83855	local = '172.30.184.173'
Apr 13 03:19:32	openvpn	83855	proto = udp4
Apr 13 03:19:32	openvpn	83855	Connection profiles [0]:
Apr 13 03:19:32	openvpn	83855	connect_retry_max = 0
Apr 13 03:19:32	openvpn	83855	show_tls_ciphers = DISABLED
Apr 13 03:19:32	openvpn	83855	key_pass_file = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	genkey_filename = '[UNDEF]'
Apr 13 03:19:32	openvpn	83855	genkey = DISABLED
Apr 13 03:19:32	openvpn	83855	show_engines = DISABLED
Apr 13 03:19:32	openvpn	83855	show_digests = DISABLED
Apr 13 03:19:32	openvpn	83855	show_ciphers = DISABLED
Apr 13 03:19:32	openvpn	83855	mode = 0
Apr 13 03:19:32	openvpn	83855	config = '/var/etc/openvpn/client1/config.ovpn'
Apr 13 03:19:32	openvpn	83855	Current Parameter Settings:
Apr 13 02:18:01	openvpn	39844	SIGTERM[soft,auth-failure] received, process exiting
Apr 13 02:18:01	openvpn	39844	TCP/UDP: Closing socket
Apr 13 02:18:01	openvpn	39844	AUTH: Received control message: AUTH_FAILED
Apr 13 02:18:01	openvpn	39844	UDPv4 READ [88] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2662 DATA len=74
Apr 13 02:18:01	openvpn	39844	UDPv4 READ [62] from [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 13 02:18:01	openvpn	39844	UDPv4 WRITE [89] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=3174 DATA len=75
Apr 13 02:18:01	openvpn	39844	SENT CONTROL [Saclateni]: 'PUSH_REQUEST' (status=1)
Apr 13 02:18:00	openvpn	39844	[Saclateni] Peer Connection Initiated with [AF_INET]217.138.217.109:443
Apr 13 02:18:00	openvpn	39844	Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Apr 13 02:18:00	openvpn	39844	UDPv4 WRITE [62] to [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 13 02:18:00	openvpn	39844	WARNING: 'comp-lzo' is present in remote config but missing in local config, remote='comp-lzo'
Apr 13 02:18:00	openvpn	39844	WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1601', remote='link-mtu 1602'
Apr 13 02:18:00	openvpn	39844	UDPv4 READ [284] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2150 DATA len=270
Apr 13 02:18:00	openvpn	39844	UDPv4 READ [224] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1894 DATA len=210
Apr 13 02:18:00	openvpn	39844	UDPv4 READ [62] from [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 13 02:18:00	openvpn	39844	UDPv4 WRITE [699] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2406 DATA len=685
Apr 13 02:18:00	openvpn	39844	UDPv4 WRITE [1116] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=2150 DATA len=1102
Apr 13 02:18:00	openvpn	39844	UDPv4 WRITE [1128] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1894 DATA len=1114
Apr 13 02:18:00	openvpn	39844	UDPv4 READ [647] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1126 DATA len=633
Apr 13 02:18:00	openvpn	39844	VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saclateni, emailAddress=info@airvpn.org
Apr 13 02:18:00	openvpn	39844	VERIFY EKU OK
Apr 13 02:18:00	openvpn	39844	++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Apr 13 02:18:00	openvpn	39844	Validating certificate extended key usage
Apr 13 02:18:00	openvpn	39844	VERIFY KU OK
Apr 13 02:18:00	openvpn	39844	VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Apr 13 02:18:00	openvpn	39844	VERIFY WARNING: depth=1, unable to get certificate CRL: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Apr 13 02:18:00	openvpn	39844	VERIFY WARNING: depth=0, unable to get certificate CRL: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saclateni, emailAddress=info@airvpn.org
Apr 13 02:18:00	openvpn	39844	UDPv4 READ [1116] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=870 DATA len=1102
Apr 13 02:17:59	openvpn	39844	UDPv4 READ [1128] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=614 DATA len=1114
Apr 13 02:17:59	openvpn	39844	UDPv4 WRITE [331] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 [ ] pid=1126 DATA len=317
Apr 13 02:17:59	openvpn	39844	UDPv4 WRITE [62] to [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 [ ]
Apr 13 02:17:59	openvpn	39844	TLS: Initial packet from [AF_INET]217.138.217.109:443, sid=45ca9d63 c3d7b380
Apr 13 02:17:59	openvpn	39844	UDPv4 READ [66] from [AF_INET]217.138.217.109:443: P_CONTROL_HARD_RESET_SERVER_V2 kid=0 [ ] pid=358 DATA len=52
Apr 13 02:17:59	openvpn	39844	UDPv4 WRITE [54] to [AF_INET]217.138.217.109:443: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 [ ] pid=614 DATA len=40
Apr 13 02:17:57	openvpn	39844	write UDPv4: No route to host (code=65)
Apr 13 02:17:57	openvpn	39844	UDPv4 WRITE [54] to [AF_INET]217.138.217.109:443: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 [ ] pid=358 DATA len=40
Apr 13 02:17:57	openvpn	39844	UDPv4 link remote: [AF_INET]217.138.217.109:443
Apr 13 02:17:57	openvpn	39844	UDPv4 link local (bound): [AF_INET]172.30.184.173:0
Apr 13 02:17:57	openvpn	39844	Socket Buffers: R=[42080->512000] S=[57344->512000]
Apr 13 02:17:57	openvpn	39844	TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.217.109:443
Apr 13 02:17:57	openvpn	39844	Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1601,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-server'
Apr 13 02:17:57	openvpn	39844	Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1601,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client'
Apr 13 02:17:57	openvpn	39844	Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Apr 13 02:17:57	openvpn	39844	Control Channel MTU parms [ L:1621 D:1156 EF:94 EB:0 ET:0 EL:3 ]
Apr 13 02:17:57	openvpn	39844	Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Apr 13 02:17:57	openvpn	39844	Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Apr 13 02:17:57	openvpn	39844	Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Apr 13 02:17:57	openvpn	39844	Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Apr 13 02:17:57	openvpn	39844	WARNING: experimental option --capath /var/etc/openvpn/client1/ca
Apr 13 02:17:57	openvpn	39844	NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 13 02:17:57	openvpn	39844	mlockall call succeeded
Apr 13 02:17:57	openvpn	39844	MANAGEMENT: unix domain socket listening on /var/etc/openvpn/client1/sock
Apr 13 02:17:57	openvpn	39591	library versions: OpenSSL 1.1.1l-freebsd 24 Aug 2021, LZO 2.10
Apr 13 02:17:57	openvpn	39591	OpenVPN 2.5.4 amd64-portbld-freebsd12.3 [SSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 12 2022
Apr 13 02:17:57	openvpn	39591	auth_user_pass_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	pull = ENABLED
Apr 13 02:17:57	openvpn	39591	client = ENABLED
Apr 13 02:17:57	openvpn	39591	vlan_pvid = 1
Apr 13 02:17:57	openvpn	39591	vlan_accept = all
Apr 13 02:17:57	openvpn	39591	vlan_tagging = DISABLED
Apr 13 02:17:57	openvpn	39591	port_share_port = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	port_share_host = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	auth_token_secret_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	auth_token_lifetime = 0
Apr 13 02:17:57	openvpn	39591	auth_token_generate = DISABLED
Apr 13 02:17:57	openvpn	39591	auth_user_pass_verify_script_via_file = DISABLED
Apr 13 02:17:57	openvpn	39591	auth_user_pass_verify_script = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	max_routes_per_client = 256
Apr 13 02:17:57	openvpn	39591	max_clients = 1024
Apr 13 02:17:57	openvpn	39591	cf_per = 0
Apr 13 02:17:57	openvpn	39591	cf_max = 0
Apr 13 02:17:57	openvpn	39591	duplicate_cn = DISABLED
Apr 13 02:17:57	openvpn	39591	enable_c2c = DISABLED
Apr 13 02:17:57	openvpn	39591	push_ifconfig_ipv6_remote = ::
Apr 13 02:17:57	openvpn	39591	push_ifconfig_ipv6_local = ::/0
Apr 13 02:17:57	openvpn	39591	push_ifconfig_ipv6_defined = DISABLED
Apr 13 02:17:57	openvpn	39591	push_ifconfig_remote_netmask = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	push_ifconfig_local = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	push_ifconfig_defined = DISABLED
Apr 13 02:17:57	openvpn	39591	tmp_dir = '/tmp'
Apr 13 02:17:57	openvpn	39591	ccd_exclusive = DISABLED
Apr 13 02:17:57	openvpn	39591	client_config_dir = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	client_disconnect_script = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	learn_address_script = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	client_connect_script = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	virtual_hash_size = 256
Apr 13 02:17:57	openvpn	39591	real_hash_size = 256
Apr 13 02:17:57	openvpn	39591	tcp_queue_limit = 64
Apr 13 02:17:57	openvpn	39591	n_bcast_buf = 256
Apr 13 02:17:57	openvpn	39591	ifconfig_ipv6_pool_netbits = 0
Apr 13 02:17:57	openvpn	39591	ifconfig_ipv6_pool_base = ::
Apr 13 02:17:57	openvpn	39591	ifconfig_ipv6_pool_defined = DISABLED
Apr 13 02:17:57	openvpn	39591	ifconfig_pool_persist_refresh_freq = 600
Apr 13 02:17:57	openvpn	39591	ifconfig_pool_persist_filename = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	ifconfig_pool_netmask = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	ifconfig_pool_end = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	ifconfig_pool_start = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	ifconfig_pool_defined = DISABLED
Apr 13 02:17:57	openvpn	39591	server_bridge_pool_end = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	server_bridge_pool_start = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	server_bridge_netmask = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	server_bridge_ip = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	server_netbits_ipv6 = 0
Apr 13 02:17:57	openvpn	39591	server_network_ipv6 = ::
Apr 13 02:17:57	openvpn	39591	server_netmask = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	server_network = 0.0.0.0
Apr 13 02:17:57	openvpn	39591	tls_crypt_v2_metadata = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	tls_exit = DISABLED
Apr 13 02:17:57	openvpn	39591	push_peer_info = DISABLED
Apr 13 02:17:57	openvpn	39591	single_session = DISABLED
Apr 13 02:17:57	openvpn	39591	transition_window = 3600
Apr 13 02:17:57	openvpn	39591	handshake_window = 60
Apr 13 02:17:57	openvpn	39591	renegotiate_seconds = 3600
Apr 13 02:17:57	openvpn	39591	renegotiate_packets = 0
Apr 13 02:17:57	openvpn	39591	renegotiate_bytes = -1
Apr 13 02:17:57	openvpn	39591	tls_timeout = 2
Apr 13 02:17:57	openvpn	39591	ssl_flags = 0
Apr 13 02:17:57	openvpn	39591	remote_cert_eku = 'TLS Web Server Authentication'
Apr 13 02:17:57	openvpn	39591	remote_cert_ku[i] = 0
Apr 13 02:17:57	openvpn	39591	remote_cert_ku[i] = 65535
Apr 13 02:17:57	openvpn	39591	ns_cert_type = 0
Apr 13 02:17:57	openvpn	39591	crl_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	verify_x509_name = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	verify_x509_type = 0
Apr 13 02:17:57	openvpn	39591	tls_export_cert = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	tls_verify = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	tls_cert_profile = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	cipher_list_tls13 = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	cipher_list = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	pkcs12_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	priv_key_file = '/var/etc/openvpn/client1/key'
Apr 13 02:17:57	openvpn	39591	extra_certs_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	cert_file = '/var/etc/openvpn/client1/cert'
Apr 13 02:17:57	openvpn	39591	dh_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	ca_path = '/var/etc/openvpn/client1/ca'
Apr 13 02:17:57	openvpn	39591	ca_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	tls_client = ENABLED
Apr 13 02:17:57	openvpn	39591	tls_server = DISABLED
Apr 13 02:17:57	openvpn	39591	test_crypto = DISABLED
Apr 13 02:17:57	openvpn	39591	packet_id_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	replay_time = 15
Apr 13 02:17:57	openvpn	39591	replay_window = 64
Apr 13 02:17:57	openvpn	39591	mute_replay_warnings = DISABLED
Apr 13 02:17:57	openvpn	39591	replay = ENABLED
Apr 13 02:17:57	openvpn	39591	engine = DISABLED
Apr 13 02:17:57	openvpn	39591	keysize = 0
Apr 13 02:17:57	openvpn	39591	prng_nonce_secret_len = 64
Apr 13 02:17:57	openvpn	39591	prng_hash = 'sha256'
Apr 13 02:17:57	openvpn	39591	authname = 'SHA512'
Apr 13 02:17:57	openvpn	39591	ncp_ciphers = 'AES-256-GCM:AES-256-CBC'
Apr 13 02:17:57	openvpn	39591	ncp_enabled = ENABLED
Apr 13 02:17:57	openvpn	39591	ciphername = 'AES-256-CBC'
Apr 13 02:17:57	openvpn	39591	key_direction = not set
Apr 13 02:17:57	openvpn	39591	shared_secret_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	management_flags = 256
Apr 13 02:17:57	openvpn	39591	management_client_group = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	management_client_user = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	management_write_peer_info_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	management_echo_buffer_size = 100
Apr 13 02:17:57	openvpn	39591	management_log_history_cache = 250
Apr 13 02:17:57	openvpn	39591	management_user_pass = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	management_port = 'unix'
Apr 13 02:17:57	openvpn	39591	management_addr = '/var/etc/openvpn/client1/sock'
Apr 13 02:17:57	openvpn	39591	allow_pull_fqdn = DISABLED
Apr 13 02:17:57	openvpn	39591	route_gateway_via_dhcp = DISABLED
Apr 13 02:17:57	openvpn	39591	route_nopull = DISABLED
Apr 13 02:17:57	openvpn	39591	route_delay_defined = DISABLED
Apr 13 02:17:57	openvpn	39591	route_delay_window = 30
Apr 13 02:17:57	openvpn	39591	route_delay = 0
Apr 13 02:17:57	openvpn	39591	route_noexec = DISABLED
Apr 13 02:17:57	openvpn	39591	route_default_metric = 0
Apr 13 02:17:57	openvpn	39591	route_default_gateway = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	route_script = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	comp.flags = 24
Apr 13 02:17:57	openvpn	39591	comp.alg = 0
Apr 13 02:17:57	openvpn	39591	fast_io = ENABLED
Apr 13 02:17:57	openvpn	39591	sockflags = 0
Apr 13 02:17:57	openvpn	39591	sndbuf = 512000
Apr 13 02:17:57	openvpn	39591	rcvbuf = 512000
Apr 13 02:17:57	openvpn	39591	occ = ENABLED
Apr 13 02:17:57	openvpn	39591	status_file_update_freq = 60
Apr 13 02:17:57	openvpn	39591	status_file_version = 1
Apr 13 02:17:57	openvpn	39591	status_file = '[UNDEF]'
Apr 13 02:17:57	openvpn	39591	gremlin = 0
Apr 13 02:17:57	openvpn	39591	mute = 0
Apr 13 02:17:57	openvpn	39591	verbosity = 6
Apr 13 02:17:57	openvpn	39591	nice = 0
Apr 13 02:17:57	openvpn	39591	machine_readable_output = DISABLED
Apr 13 02:17:57	openvpn	39591	suppress_timestamps = DISABLED
Apr 13 02:17:57	openvpn	39591	log = DISABLED
Apr 13 02:17:57	openvpn	39591	inetd = 0
Apr 13 02:17:57	openvpn	39591	daemon = ENABLED
The same as above, but with verbose level 11.
Still no clue what's going on.
Apr 13 06:39:00	newsyslog	96097	logfile turned over due to size>500K
Apr 13 06:38:52	openvpn	47313	SIGTERM[soft,auth-failure] received, process exiting
Apr 13 06:38:52	openvpn	47313	PID packet_id_free
Apr 13 06:38:52	openvpn	47313	TCP/UDP: Closing socket
Apr 13 06:38:52	openvpn	47313	SSL alert (write): warning: close notify
Apr 13 06:38:52	openvpn	47313	AUTH: Received control message: AUTH_FAILED
Apr 13 06:38:52	openvpn	47313	TLS: tls_multi_process: i=2 state=S_UNDEF, mysid=00000000 00000000, stored-sid=00000000 00000000, stored-ip=[AF_UNSPEC]
Apr 13 06:38:52	openvpn	47313	TLS: tls_multi_process: i=1 state=S_INITIAL, mysid=39e9fef5 5a11f6eb, stored-sid=00000000 00000000, stored-ip=[AF_UNSPEC]
Apr 13 06:38:52	openvpn	47313	TLS: tls_process: timeout set to 1
Apr 13 06:38:52	openvpn	47313	ACK reliable_send_timeout 604800 [6]
Apr 13 06:38:52	openvpn	47313	Dedicated ACK -> TCP/UDP
Apr 13 06:38:52	openvpn	47313	TLS-CRYPT WRAP TO: 281a05d8 0ffbc054 e7000000 0c6619fe 49ff71df d6c3b0d0 0fda3a55 19f291f[more...]
Apr 13 06:38:52	openvpn	47313	TLS-CRYPT WRAP TAG: ff71dfd6 c3b0d00f da3a5519 f291f79d f8b5a9f5 678ce3d2 c328a3f3 c0aecc91
Apr 13 06:38:52	openvpn	47313	TLS-CRYPT WRAP AD: 281a05d8 0ffbc054 e7000000 0c6619fe 49
Apr 13 06:38:52	openvpn	47313	TLS-CRYPT WRAP FROM: 01000000 063f4e02 edc97711 12
Apr 13 06:38:52	openvpn	47313	write_control_auth(): P_ACK_V1
Apr 13 06:38:52	openvpn	47313	ACK write ID 6 (ack->len=1, n=1)
Apr 13 06:38:52	openvpn	47313	ACK reliable_can_send active=0 current=0 : [6]
Apr 13 06:38:52	openvpn	47313	TLS: tls_process: chg=1 ks=S_ACTIVE lame=S_UNDEF to_link->len=0 wakeup=0
Apr 13 06:38:52	openvpn	47313	TLS -> Incoming Plaintext
Apr 13 06:38:52	openvpn	47313	BIO read tls_read_plaintext 12 bytes
Apr 13 06:38:52	openvpn	47313	Incoming Ciphertext -> TLS
Apr 13 06:38:52	openvpn	47313	BIO write tls_write_ciphertext 34 bytes
Apr 13 06:38:52	openvpn	47313	TLS: tls_process: chg=0 ks=S_ACTIVE lame=S_UNDEF to_link->len=0 wakeup=604800
Apr 13 06:38:52	openvpn	47313	TLS: tls_multi_process: i=0 state=S_ACTIVE, mysid=1a05d80f fbc054e7, stored-sid=3f4e02ed c9771112, stored-ip=[AF_INET]217.138.217.109:443
Apr 13 06:38:52	openvpn	47313	ACK acknowledge ID 6 (ack->len=1)
Apr 13 06:38:52	openvpn	47313	ACK mark active incoming ID 6
Apr 13 06:38:52	openvpn	47313	ACK RWBS rel->size=8 rel->packet_id=00000006 id=00000006 ret=1
Apr 13 06:38:52	openvpn	47313	ACK read ID 6 (buf->len=34)
Apr 13 06:38:52	openvpn	47313	TLS: received control channel packet s#=0 sid=3f4e02ed c9771112
Apr 13 06:38:52	openvpn	47313	PID_TEST [0] [TLS_WRAP-0] [022222222] 1712979528:9 1712979528:10 t=1712979532[0] r=[-2,64,15,0,1] sl=[55,9,64,528]
Apr 13 06:38:52	openvpn	47313	TLS-CRYPT UNWRAP TO: 00000000 06170303 001d36ae b65278b8 d8cfee25 cafda1be 5cd58dea a31736e[more...]
Apr 13 06:38:52	openvpn	47313	TLS-CRYPT UNWRAP AD: 203f4e02 edc97711 12000000 0a6619fe 48
Apr 13 06:38:52	openvpn	47313	TLS-CRYPT UNWRAP FROM: 203f4e02 edc97711 12000000 0a6619fe 4824ac88 b55ea4cc 6168661a d7a2cac[more...]
Apr 13 06:38:52	openvpn	47313	TLS: found match, session[0], sid=3f4e02ed c9771112
Apr 13 06:38:52	openvpn	47313	TLS: initial packet test, i=0 state=S_ACTIVE, mysid=1a05d80f fbc054e7, rec-sid=3f4e02ed c9771112, rec-ip=[AF_INET]217.138.217.109:443, stored-sid=3f4e02ed c9771112, stored-ip=[AF_INET]217.138.217.109:443
Apr 13 06:38:52	openvpn	47313	TLS: control channel, op=P_CONTROL_V1, IP=[AF_INET]217.138.217.109:443
Apr 13 06:38:52	openvpn	47313	UDPv4 READ [88] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=3f4e02ed c9771112 [ ] pid=2662 DATA 19fe4824 ac88b55e a4cc6168 661ad7a2 cac4da6c e5362cad 970a8256 a79e89f[more...]
Apr 13 06:38:52	openvpn	47313	UDPv4 read returned 88
Apr 13 06:38:52	openvpn	47313	I/O WAIT status=0x0001
Apr 13 06:38:52	openvpn	47313	event_wait returned 1
Apr 13 06:38:52	openvpn	47313	PO_WAIT[0,0] fd=5 rev=0x00000001 rwflags=0x0001 arg=0x002b7428
Apr 13 06:38:52	openvpn	47313	I/O WAIT T?|T?|SR|Sw [4/182795]
Apr 13 06:38:52	openvpn	47313	PO_CTL rwflags=0x0001 ev=4 arg=0x002b6728
Apr 13 06:38:52	openvpn	47313	PO_CTL rwflags=0x0001 ev=5 arg=0x002b7428
Apr 13 06:38:52	openvpn	47313	TLS: tls_process: timeout set to 3598
Apr 13 06:38:52	openvpn	47313	ACK received for pid 5, deleting from send buffer
Apr 13 06:38:52	openvpn	47313	PID_TEST [0] [TLS_WRAP-0] [22222222] 1712979528:8 1712979528:9 t=1712979532[0] r=[-2,64,15,0,1] sl=[56,8,64,528]
Apr 13 06:38:52	openvpn	47313	TLS-CRYPT UNWRAP TO: 01000000 051a05d8 0ffbc054 e7
Apr 13 06:38:52	openvpn	47313	TLS-CRYPT UNWRAP AD: 283f4e02 edc97711 12000000 096619fe 48
Apr 13 06:38:52	openvpn	47313	TLS-CRYPT UNWRAP FROM: 283f4e02 edc97711 12000000 096619fe 48b89d87 b0165008 19aedd42 4b82d74[more...]
Apr 13 06:38:52	openvpn	47313	TLS: control channel, op=P_ACK_V1, IP=[AF_INET]217.138.217.109:443
Apr 13 06:38:52	openvpn	47313	UDPv4 READ [62] from [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 sid=3f4e02ed c9771112 [ ]
Apr 13 06:38:52	openvpn	47313	UDPv4 read returned 62
Apr 13 06:38:51	openvpn	47313	I/O WAIT T?|T?|SR|Sw [2/182795]
Apr 13 06:38:51	openvpn	47313	PO_CTL rwflags=0x0001 ev=4 arg=0x002b6728
Apr 13 06:38:51	openvpn	47313	PO_CTL rwflags=0x0001 ev=5 arg=0x002b7428
Apr 13 06:38:51	openvpn	47313	TLS: tls_multi_process: i=2 state=S_UNDEF, mysid=00000000 00000000, stored-sid=00000000 00000000, stored-ip=[AF_UNSPEC]
Apr 13 06:38:51	openvpn	47313	TLS: tls_multi_process: i=1 state=S_INITIAL, mysid=39e9fef5 5a11f6eb, stored-sid=00000000 00000000, stored-ip=[AF_UNSPEC]
Apr 13 06:38:51	openvpn	47313	TLS: tls_process: timeout set to 2
Apr 13 06:38:51	openvpn	47313	ACK reliable_send_timeout 2 [6] 5
Apr 13 06:38:51	openvpn	47313	ACK reliable_can_send active=1 current=0 : [6] 5
Apr 13 06:38:51	openvpn	47313	TLS: tls_process: chg=0 ks=S_ACTIVE lame=S_UNDEF to_link->len=0 wakeup=604800
Apr 13 06:38:51	openvpn	47313	TLS: tls_multi_process: i=0 state=S_ACTIVE, mysid=1a05d80f fbc054e7, stored-sid=3f4e02ed c9771112, stored-ip=[AF_INET]217.138.217.109:443
Apr 13 06:38:51	openvpn	47313	TIMER: coarse timer wakeup 5 seconds
Apr 13 06:38:51	openvpn	47313	UDPv4 write returned 89
Apr 13 06:38:51	openvpn	47313	UDPv4 WRITE [89] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=1a05d80f fbc054e7 [ ] pid=2918 DATA 19fe491b d97267a0 5e51e16b 1b7a7613 873204a4 c7a1dcee 50ecaa0e e68a329[more...]
Apr 13 06:38:51	openvpn	47313	Reliable -> TCP/UDP
Apr 13 06:38:51	openvpn	47313	TLS-CRYPT WRAP TO: 201a05d8 0ffbc054 e7000000 0b6619fe 491bd972 67a05e51 e16b1b7a 7613873[more...]
Apr 13 06:38:51	openvpn	47313	TLS-CRYPT WRAP TAG: 1bd97267 a05e51e1 6b1b7a76 13873204 a4c7a1dc ee50ecaa 0ee68a32 949bee9f
Apr 13 06:38:51	openvpn	47313	TLS-CRYPT WRAP AD: 201a05d8 0ffbc054 e7000000 0b6619fe 49
Apr 13 06:38:51	openvpn	47313	TLS-CRYPT WRAP FROM: 00000000 05170303 001eb6d2 5b7b0155 3680324a 389c3fa3 96b78d4d c8afbfb[more...]
Apr 13 06:38:51	openvpn	47313	write_control_auth(): P_CONTROL_V1
Apr 13 06:38:51	openvpn	47313	ACK reliable_send ID 5 (size=39 to=2)
Apr 13 06:38:51	openvpn	47313	ACK reliable_can_send active=1 current=1 : [6] 5
Apr 13 06:38:51	openvpn	47313	TLS: tls_process: chg=1 ks=S_ACTIVE lame=S_UNDEF to_link->len=0 wakeup=604800
Apr 13 06:38:51	openvpn	47313	Outgoing Ciphertext -> Reliable
Apr 13 06:38:51	openvpn	47313	ACK mark active outgoing ID 5
Apr 13 06:38:51	openvpn	47313	BIO read tls_read_ciphertext 35 bytes
Apr 13 06:38:51	openvpn	47313	ACK reliable_can_send active=0 current=0 : [5]
Apr 13 06:38:51	openvpn	47313	TIMER: coarse timer wakeup 0 seconds
Apr 13 06:38:51	openvpn	47313	SENT CONTROL [Saclateni]: 'PUSH_REQUEST' (status=1)
Apr 13 06:38:51	openvpn	47313	BIO write tls_write_plaintext_const 13 bytes
Apr 13 06:38:51	openvpn	47313	I/O WAIT status=0x0020
Apr 13 06:38:51	openvpn	47313	event_wait returned 0
Apr 13 06:38:50	openvpn	47313	I/O WAIT T?|T?|SR|Sw [1/182795]
Apr 13 06:38:50	openvpn	47313	PO_CTL rwflags=0x0001 ev=4 arg=0x002b6728
Apr 13 06:38:50	openvpn	47313	PO_CTL rwflags=0x0001 ev=5 arg=0x002b7428
Apr 13 06:38:50	openvpn	47313	TLS: tls_multi_process: i=2 state=S_UNDEF, mysid=00000000 00000000, stored-sid=00000000 00000000, stored-ip=[AF_UNSPEC]
Apr 13 06:38:50	openvpn	47313	TLS: tls_multi_process: i=1 state=S_INITIAL, mysid=39e9fef5 5a11f6eb, stored-sid=00000000 00000000, stored-ip=[AF_UNSPEC]
Apr 13 06:38:50	openvpn	47313	TLS: tls_process: timeout set to 3600
Apr 13 06:38:50	openvpn	47313	ACK reliable_send_timeout 604800 [5]
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=0 current=0 : [5]
Apr 13 06:38:50	openvpn	47313	TLS: tls_process: chg=1 ks=S_ACTIVE lame=S_UNDEF to_link->len=0 wakeup=604800
Apr 13 06:38:50	openvpn	47313	[Saclateni] Peer Connection Initiated with [AF_INET]217.138.217.109:443
Apr 13 06:38:50	openvpn	47313	Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Apr 13 06:38:50	openvpn	47313	STATE S_ACTIVE
Apr 13 06:38:50	openvpn	47313	TLS: tls_process: chg=0 ks=S_GOT_KEY lame=S_UNDEF to_link->len=0 wakeup=604800
Apr 13 06:38:50	openvpn	47313	TLS: tls_multi_process: i=0 state=S_GOT_KEY, mysid=1a05d80f fbc054e7, stored-sid=3f4e02ed c9771112, stored-ip=[AF_INET]217.138.217.109:443
Apr 13 06:38:50	openvpn	47313	UDPv4 write returned 62
Apr 13 06:38:50	openvpn	47313	UDPv4 WRITE [62] to [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 sid=1a05d80f fbc054e7 [ ]
Apr 13 06:38:50	openvpn	47313	TLS: tls_process: timeout set to 1
Apr 13 06:38:50	openvpn	47313	Dedicated ACK -> TCP/UDP
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TO: 281a05d8 0ffbc054 e7000000 0a6619fe 493c7170 86812583 6262b6f1 35f86f8[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TAG: 3c717086 81258362 62b6f135 f86f8a9f d6da28db 66c5fec4 0cc173a7 404087bd
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP AD: 281a05d8 0ffbc054 e7000000 0a6619fe 49
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP FROM: 01000000 053f4e02 edc97711 12
Apr 13 06:38:50	openvpn	47313	write_control_auth(): P_ACK_V1
Apr 13 06:38:50	openvpn	47313	ACK write ID 5 (ack->len=1, n=1)
Apr 13 06:38:50	openvpn	47313	TLS: tls_process: chg=1 ks=S_GOT_KEY lame=S_UNDEF to_link->len=0 wakeup=0
Apr 13 06:38:50	openvpn	47313	STATE S_GOT_KEY
Apr 13 06:38:50	openvpn	47313	WARNING: 'comp-lzo' is present in remote config but missing in local config, remote='comp-lzo'
Apr 13 06:38:50	openvpn	47313	WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1601', remote='link-mtu 1602'
Apr 13 06:38:50	openvpn	47313	TLS -> Incoming Plaintext
Apr 13 06:38:50	openvpn	47313	BIO read tls_read_plaintext 208 bytes
Apr 13 06:38:50	openvpn	47313	Incoming Ciphertext -> TLS
Apr 13 06:38:50	openvpn	47313	BIO write tls_write_ciphertext 230 bytes
Apr 13 06:38:50	openvpn	47313	TLS: tls_process: chg=0 ks=S_SENT_KEY lame=S_UNDEF to_link->len=0 wakeup=604800
Apr 13 06:38:50	openvpn	47313	TLS: tls_multi_process: i=0 state=S_SENT_KEY, mysid=1a05d80f fbc054e7, stored-sid=3f4e02ed c9771112, stored-ip=[AF_INET]217.138.217.109:443
Apr 13 06:38:50	openvpn	47313	ACK acknowledge ID 5 (ack->len=1)
Apr 13 06:38:50	openvpn	47313	ACK mark active incoming ID 5
Apr 13 06:38:50	openvpn	47313	ACK RWBS rel->size=8 rel->packet_id=00000005 id=00000005 ret=1
Apr 13 06:38:50	openvpn	47313	ACK read ID 5 (buf->len=230)
Apr 13 06:38:50	openvpn	47313	TLS: received control channel packet s#=0 sid=3f4e02ed c9771112
Apr 13 06:38:50	openvpn	47313	PID_TEST [0] [TLS_WRAP-0] [0000000] 1712979528:7 1712979528:8 t=1712979530[0] r=[0,64,15,0,1] sl=[57,7,64,528]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP TO: 00000000 05170303 00e1c856 fd500b82 f91d5751 d3caf91e ee50c85f b826887[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP AD: 203f4e02 edc97711 12000000 086619fe 48
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP FROM: 203f4e02 edc97711 12000000 086619fe 48cdc3b1 8d815350 790184a3 d2c7f33[more...]
Apr 13 06:38:50	openvpn	47313	TLS: found match, session[0], sid=3f4e02ed c9771112
Apr 13 06:38:50	openvpn	47313	TLS: initial packet test, i=0 state=S_SENT_KEY, mysid=1a05d80f fbc054e7, rec-sid=3f4e02ed c9771112, rec-ip=[AF_INET]217.138.217.109:443, stored-sid=3f4e02ed c9771112, stored-ip=[AF_INET]217.138.217.109:443
Apr 13 06:38:50	openvpn	47313	TLS: control channel, op=P_CONTROL_V1, IP=[AF_INET]217.138.217.109:443
Apr 13 06:38:50	openvpn	47313	UDPv4 READ [284] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=3f4e02ed c9771112 [ ] pid=2150 DATA 19fe48cd c3b18d81 53507901 84a3d2c7 f330cfe4 e7b5692f 609c12e0 15b2071[more...]
Apr 13 06:38:50	openvpn	47313	UDPv4 read returned 284
Apr 13 06:38:50	openvpn	47313	I/O WAIT status=0x0001
Apr 13 06:38:50	openvpn	47313	event_wait returned 1
Apr 13 06:38:50	openvpn	47313	PO_WAIT[0,0] fd=5 rev=0x00000001 rwflags=0x0001 arg=0x002b7428
Apr 13 06:38:50	openvpn	47313	TLS: tls_process: timeout set to 59
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TO: 281a05d8 0ffbc054 e7000000 096619fe 496f27e6 f5f9f603 b5ee7ad2 75927e3[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TAG: 6f27e6f5 f9f603b5 ee7ad275 927e3781 0f778ba3 86d6cd5b 307c138a 06c1a03b
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP AD: 281a05d8 0ffbc054 e7000000 096619fe 49
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP FROM: 01000000 043f4e02 edc97711 12
Apr 13 06:38:50	openvpn	47313	ACK write ID 4 (ack->len=1, n=1)
Apr 13 06:38:50	openvpn	47313	TLS: tls_process: chg=1 ks=S_SENT_KEY lame=S_UNDEF to_link->len=0 wakeup=604800
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSLv3/TLS read server session ticket
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSL negotiation finished successfully
Apr 13 06:38:50	openvpn	47313	BIO write tls_write_ciphertext 158 bytes
Apr 13 06:38:50	openvpn	47313	ACK acknowledge ID 4 (ack->len=1)
Apr 13 06:38:50	openvpn	47313	ACK mark active incoming ID 4
Apr 13 06:38:50	openvpn	47313	ACK RWBS rel->size=8 rel->packet_id=00000004 id=00000004 ret=1
Apr 13 06:38:50	openvpn	47313	ACK read ID 4 (buf->len=158)
Apr 13 06:38:50	openvpn	47313	ACK received for pid 4, deleting from send buffer
Apr 13 06:38:50	openvpn	47313	PID_TEST [0] [TLS_WRAP-0] [000000] 1712979528:6 1712979528:7 t=1712979530[0] r=[0,64,15,0,1] sl=[58,6,64,528]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP TO: 01000000 041a05d8 0ffbc054 e7000000 04170303 004ab068 22e55dd3 2c6371e[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP AD: 203f4e02 edc97711 12000000 076619fe 48
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP FROM: 203f4e02 edc97711 12000000 076619fe 48138934 e1315ca7 40bd2dfb 8acfd66[more...]
Apr 13 06:38:50	openvpn	47313	UDPv4 READ [224] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=3f4e02ed c9771112 [ ] pid=1894 DATA 19fe4813 8934e131 5ca740bd 2dfb8acf d66e9570 317270d6 7c5964b7 d80cb8c[more...]
Apr 13 06:38:50	openvpn	47313	UDPv4 read returned 224
Apr 13 06:38:50	openvpn	47313	TLS: tls_process: timeout set to 2
Apr 13 06:38:50	openvpn	47313	ACK reliable_send_timeout 2 [5] 4
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=1 current=0 : [5] 4
Apr 13 06:38:50	openvpn	47313	ACK received for pid 3, deleting from send buffer
Apr 13 06:38:50	openvpn	47313	PID_TEST [0] [TLS_WRAP-0] [00000] 1712979528:5 1712979528:6 t=1712979530[0] r=[0,64,15,0,1] sl=[59,5,64,528]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP TO: 01000000 031a05d8 0ffbc054 e7
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP AD: 283f4e02 edc97711 12000000 066619fe 48
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP FROM: 283f4e02 edc97711 12000000 066619fe 48f2c420 5ad0fbd8 80929192 3b81bad[more...]
Apr 13 06:38:50	openvpn	47313	TLS: control channel, op=P_ACK_V1, IP=[AF_INET]217.138.217.109:443
Apr 13 06:38:50	openvpn	47313	UDPv4 READ [62] from [AF_INET]217.138.217.109:443: P_ACK_V1 kid=0 sid=3f4e02ed c9771112 [ ]
Apr 13 06:38:50	openvpn	47313	UDPv4 read returned 62
Apr 13 06:38:50	openvpn	47313	ACK reliable_send_timeout 2 [5] 3 4
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=2 current=0 : [5] 3 4
Apr 13 06:38:50	openvpn	47313	ACK received for pid 2, deleting from send buffer
Apr 13 06:38:50	openvpn	47313	PID_TEST [0] [TLS_WRAP-0] [0000] 1712979528:4 1712979528:5 t=1712979530[0] r=[0,64,15,0,1] sl=[60,4,64,528]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP TO: 01000000 021a05d8 0ffbc054 e7
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP AD: 283f4e02 edc97711 12000000 056619fe 48
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP FROM: 283f4e02 edc97711 12000000 056619fe 4858502e f631221d 55bbd648 c0b3256[more...]
Apr 13 06:38:50	openvpn	47313	ACK reliable_send_timeout 2 [5] 2 3 4
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=3 current=0 : [5] 2 3 4
Apr 13 06:38:50	openvpn	47313	UDPv4 write returned 699
Apr 13 06:38:50	openvpn	47313	UDPv4 WRITE [699] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=1a05d80f fbc054e7 [ ] pid=2150 DATA 19fe496f 35a1b0d9 a235fa68 7d4d75b4 4e867a87 a9aff7a5 d8159903 5fcf7b6[more...]
Apr 13 06:38:50	openvpn	47313	Reliable -> TCP/UDP
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TO: 201a05d8 0ffbc054 e7000000 086619fe 496f35a1 b0d9a235 fa687d4d 75b44e8[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TAG: 6f35a1b0 d9a235fa 687d4d75 b44e867a 87a9aff7 a5d81599 035fcf7b 6954cb34
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP AD: 201a05d8 0ffbc054 e7000000 086619fe 49
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP FROM: 00000000 042ab7b9 b0bd1d30 ad4f64b0 b1eb226e 408a68dd 17a8ad9c 6ea6553[more...]
Apr 13 06:38:50	openvpn	47313	write_control_auth(): P_CONTROL_V1
Apr 13 06:38:50	openvpn	47313	ACK reliable_send ID 4 (size=649 to=2)
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=3 current=1 : [5] 2 3 4
Apr 13 06:38:50	openvpn	47313	Outgoing Ciphertext -> Reliable
Apr 13 06:38:50	openvpn	47313	ACK mark active outgoing ID 4
Apr 13 06:38:50	openvpn	47313	BIO read tls_read_ciphertext 645 bytes
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=2 current=0 : [4] 2 3
Apr 13 06:38:50	openvpn	47313	UDPv4 write returned 1116
Apr 13 06:38:50	openvpn	47313	UDPv4 WRITE [1116] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=1a05d80f fbc054e7 [ ] pid=1894 DATA 19fe4929 72248852 fb43aa72 4bbc12d3 fe6c2c35 b125e1d9 03a8d8de fbfe03b[more...]
Apr 13 06:38:50	openvpn	47313	ACK reliable_send_timeout 2 [4] 2 3
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TO: 201a05d8 0ffbc054 e7000000 076619fe 49297224 8852fb43 aa724bbc 12d3fe6[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TAG: 29722488 52fb43aa 724bbc12 d3fe6c2c 35b125e1 d903a8d8 defbfe03 bcba63ab
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP AD: 201a05d8 0ffbc054 e7000000 076619fe 49
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP FROM: 00000000 0301194e e390d6fe 2b1d29ae 06741831 1647fb9d 676b02f6 73c71fb[more...]
Apr 13 06:38:50	openvpn	47313	ACK reliable_send ID 3 (size=1066 to=2)
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=2 current=1 : [4] 2 3
Apr 13 06:38:50	openvpn	47313	ACK mark active outgoing ID 3
Apr 13 06:38:50	openvpn	47313	BIO read tls_read_ciphertext 1062 bytes
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=1 current=0 : [3] 2
Apr 13 06:38:50	openvpn	47313	UDPv4 write returned 1128
Apr 13 06:38:50	openvpn	47313	UDPv4 WRITE [1128] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=1a05d80f fbc054e7 [ ] pid=1638 DATA 19fe495d 29827b79 96754a23 7e1e1a82 c5da17aa b016d5e2 6f8c0395 5a11759[more...]
Apr 13 06:38:50	openvpn	47313	ACK reliable_send_timeout 2 [3] 2
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TO: 201a05d8 0ffbc054 e7000000 066619fe 495d2982 7b799675 4a237e1e 1a82c5d[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TAG: 5d29827b 7996754a 237e1e1a 82c5da17 aab016d5 e26f8c03 955a1175 98b4c646
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP AD: 201a05d8 0ffbc054 e7000000 066619fe 49
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP FROM: 01000000 033f4e02 edc97711 12000000 02140303 00010117 030306dc d206f49[more...]
Apr 13 06:38:50	openvpn	47313	ACK write ID 3 (ack->len=1, n=1)
Apr 13 06:38:50	openvpn	47313	ACK reliable_send ID 2 (size=1066 to=2)
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=1 current=1 : [3] 2
Apr 13 06:38:50	openvpn	47313	ACK mark active outgoing ID 2
Apr 13 06:38:50	openvpn	47313	Outgoing Plaintext -> TLS
Apr 13 06:38:50	openvpn	47313	BIO write tls_write_plaintext 380 bytes
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSLv3/TLS write finished
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSLv3/TLS write certificate verify
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSLv3/TLS write client certificate
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSLv3/TLS write change cipher spec
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSLv3/TLS read finished
Apr 13 06:38:50	openvpn	47313	SSL state (connect): TLSv1.3 read server certificate verify
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSLv3/TLS read server certificate
Apr 13 06:38:50	openvpn	47313	BIO write tls_write_ciphertext 593 bytes
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=0 current=0 : [2]
Apr 13 06:38:50	openvpn	47313	ACK acknowledge ID 3 (ack->len=1)
Apr 13 06:38:50	openvpn	47313	ACK mark active incoming ID 3
Apr 13 06:38:50	openvpn	47313	ACK RWBS rel->size=8 rel->packet_id=00000003 id=00000003 ret=1
Apr 13 06:38:50	openvpn	47313	ACK read ID 3 (buf->len=593)
Apr 13 06:38:50	openvpn	47313	PID_TEST [0] [TLS_WRAP-0] [000] 1712979528:3 1712979528:4 t=1712979530[0] r=[0,64,15,0,1] sl=[61,3,64,528]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP TO: 00000000 03f6d297 8705b4a9 383cf347 430acd22 0879828a 4c9b64ab 4996239[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP AD: 203f4e02 edc97711 12000000 046619fe 48
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP FROM: 203f4e02 edc97711 12000000 046619fe 48c62509 61ef56c6 c328f3c2 172cb16[more...]
Apr 13 06:38:50	openvpn	47313	UDPv4 READ [647] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=3f4e02ed c9771112 [ ] pid=1126 DATA 19fe48c6 250961ef 56c6c328 f3c2172c b1694640 e42b5d3e 37959f85 e23b1a3[more...]
Apr 13 06:38:50	openvpn	47313	UDPv4 read returned 647
Apr 13 06:38:50	openvpn	47313	ACK reliable_send_timeout 604800 [2]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TO: 281a05d8 0ffbc054 e7000000 056619fe 490442a0 a2e1baae b3d14939 ccb7dc6[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TAG: 0442a0a2 e1baaeb3 d14939cc b7dc60f1 bff96117 68324cb8 2e3b29d4 ec5e2780
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP AD: 281a05d8 0ffbc054 e7000000 056619fe 49
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP FROM: 01000000 023f4e02 edc97711 12
Apr 13 06:38:50	openvpn	47313	ACK write ID 2 (ack->len=1, n=1)
Apr 13 06:38:50	openvpn	47313	VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saclateni, emailAddress=info@airvpn.org
Apr 13 06:38:50	openvpn	47313	VERIFY EKU OK
Apr 13 06:38:50	openvpn	47313	++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Apr 13 06:38:50	openvpn	47313	Validating certificate extended key usage
Apr 13 06:38:50	openvpn	47313	VERIFY KU OK
Apr 13 06:38:50	openvpn	47313	VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Apr 13 06:38:50	openvpn	47313	VERIFY WARNING: depth=1, unable to get certificate CRL: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Apr 13 06:38:50	openvpn	47313	VERIFY WARNING: depth=0, unable to get certificate CRL: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saclateni, emailAddress=info@airvpn.org
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSLv3/TLS read server certificate request
Apr 13 06:38:50	openvpn	47313	BIO write tls_write_ciphertext 1062 bytes
Apr 13 06:38:50	openvpn	47313	ACK acknowledge ID 2 (ack->len=1)
Apr 13 06:38:50	openvpn	47313	ACK mark active incoming ID 2
Apr 13 06:38:50	openvpn	47313	ACK RWBS rel->size=8 rel->packet_id=00000002 id=00000002 ret=1
Apr 13 06:38:50	openvpn	47313	ACK read ID 2 (buf->len=1062)
Apr 13 06:38:50	openvpn	47313	PID_TEST [0] [TLS_WRAP-0] [00] 1712979528:2 1712979528:3 t=1712979530[0] r=[0,64,15,0,1] sl=[62,2,64,528]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP TO: 00000000 026988cb 02bda124 85177f8c 31750e4e 57e322e1 87188964 9747345[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP AD: 203f4e02 edc97711 12000000 036619fe 48
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP FROM: 203f4e02 edc97711 12000000 036619fe 481c5c9d f4ab1266 1fcb483c 769b9ac[more...]
Apr 13 06:38:50	openvpn	47313	UDPv4 READ [1116] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=3f4e02ed c9771112 [ ] pid=870 DATA 19fe481c 5c9df4ab 12661fcb 483c769b 9ac3e67c d385d7cb bb53eb53 4926a81[more...]
Apr 13 06:38:50	openvpn	47313	UDPv4 read returned 1116
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TO: 281a05d8 0ffbc054 e7000000 046619fe 49b2be85 43feeab3 3575daff ecb5eab[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TAG: b2be8543 feeab335 75daffec b5eab463 a16e8ea0 7546009e 92353afa f6363880
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP AD: 281a05d8 0ffbc054 e7000000 046619fe 49
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP FROM: 01000000 013f4e02 edc97711 12
Apr 13 06:38:50	openvpn	47313	ACK write ID 1 (ack->len=1, n=1)
Apr 13 06:38:50	openvpn	47313	SSL state (connect): TLSv1.3 read encrypted extensions
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSLv3/TLS read server hello
Apr 13 06:38:50	openvpn	47313	SSL state (connect): SSLv3/TLS write client hello
Apr 13 06:38:50	openvpn	47313	ACK acknowledge ID 1 (ack->len=1)
Apr 13 06:38:50	openvpn	47313	ACK mark active incoming ID 1
Apr 13 06:38:50	openvpn	47313	ACK RWBS rel->size=8 rel->packet_id=00000001 id=00000001 ret=1
Apr 13 06:38:50	openvpn	47313	ACK read ID 1 (buf->len=1062)
Apr 13 06:38:50	openvpn	47313	ACK received for pid 1, deleting from send buffer
Apr 13 06:38:50	openvpn	47313	PID_TEST [0] [TLS_WRAP-0] [0] 1712979528:1 1712979528:2 t=1712979530[0] r=[0,64,15,0,1] sl=[63,1,64,528]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP TO: 01000000 011a05d8 0ffbc054 e7000000 01160303 007a0200 00760303 6c563b6[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP AD: 203f4e02 edc97711 12000000 026619fe 48
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT UNWRAP FROM: 203f4e02 edc97711 12000000 026619fe 486124f5 bbcc602a c630c180 767f172[more...]
Apr 13 06:38:50	openvpn	47313	UDPv4 READ [1128] from [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=3f4e02ed c9771112 [ ] pid=614 DATA 19fe4861 24f5bbcc 602ac630 c180767f 172f5443 1ac0919e cf5a2ae8 8b3a18d[more...]
Apr 13 06:38:50	openvpn	47313	UDPv4 read returned 1128
Apr 13 06:38:50	openvpn	47313	ACK reliable_send_timeout 2 [2] 1
Apr 13 06:38:50	openvpn	47313	ACK reliable_can_send active=1 current=0 : [2] 1
Apr 13 06:38:50	openvpn	47313	UDPv4 write returned 331
Apr 13 06:38:50	openvpn	47313	UDPv4 WRITE [331] to [AF_INET]217.138.217.109:443: P_CONTROL_V1 kid=0 sid=1a05d80f fbc054e7 [ ] pid=870 DATA 19fe49b6 3d319fb3 ec587850 92fea866 6845328e e4720838 449e41ab 59ffeff[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TO: 201a05d8 0ffbc054 e7000000 036619fe 49b63d31 9fb3ec58 785092fe a866684[more...]
Apr 13 06:38:50	openvpn	47313	TLS-CRYPT WRAP TAG: b63d319f b3ec5878 5092fea8 66684532 8ee47208 38449e41 ab59ffef f8435582
Again:
You renewed your client certificate a few hours ago, and locally you have the previous certificate (which is no more valid due to the renewal you did). This is confirmed as the current user.crt certificate of yours expires in 2034, but locally you have:
showing that you have the old certificate you revoked.
EDIT: remember to update again the user.key too.
and if somebody did change from tls-auth to tls-crypt you'll need to change a few things in the openvpn config besides updating the certs.
sha512, tls encryption and authentication, different remote IP off the top of my head.
Thanks for the help guys.
I finally did it. But I had to reset to defaults and restart from there.
Since this is an old install I believe my certs were getting stuck somewhere.
 @go558a83nk @Air4141841 @Staff
Since I have your attention, I wonder if it will be wise for me to upgrade from pfSense 2.6.0 to the the lastet 2.7.2 in order to start using (testing) Wireguard.
If that is the case it will be nice to have a guide as well.
Wireguard would likely be faster.  I can't say much more about updating because I use pfsense+ and I'm using a wireguard add-on package.  You seem to imply that by updating wireguard is native?
I followed a video guide on wireguard setup years ago.  I'm not up to making one myself but you might find it by searching the web and the pfsense subreddit which is often helpful.
Maybe I misunderstood it.
I thought Wireguard was native on pfSense 7.2 running on the newest FreeBSD base.
I'm thinking of getting my other NIC available on my APU2 to run a separate instance of Wireguard to try to bypass some different streaming geo-blocking in the UK.
It very well might be.  Years ago pfsense came out with native wireguard but there were problems so they quickly removed it with a patch.  Then somebody who knows what they're doing made a wireguard package which people have been using since then.
update your firewall.  yes absolutely, make a configuration backup and redownload the latest install file and write to usb Before you attempt this!
setting up wireguard is personal preference,  I have gone back and forth with successful connections.
personally I still use openvpn for reliability and the remote command so it reconnects if the connection drops.    DCO seems promising but probably a few years away I am guessing
