Ravenlord359 0 Posted ... Hi, I just switched from another VPN to AirVPN. I noticed something that I have never seen with previous VPNs. The Eddie-UI.exe program is constantly using CPU, usually in the 5-10% range. Is this typical, or do I have something configured wrong. Thanks. Share this post Link to post
Staff 10433 Posted ... On 3/5/2024 at 12:13 PM, Ravenlord359 said: Hi, I just switched from another VPN to AirVPN. I noticed something that I have never seen with previous VPNs. The Eddie-UI.exe program is constantly using CPU, usually in the 5-10% range. Is this typical, or do I have something configured wrong. Thanks. Hello! Is it 5-10% of a single core or the whole CPU? Can you tell us your Operating System name and version and the Eddie version? Kind regards Share this post Link to post
matts9 13 Posted ... I may have had similar issue as OP. For me the CPU usage of Eddie-UI.exe was in range od 0.5%-3% constantly (even when Eddie was hidden in the tray). Since Eddie is open-source and I'm a .NET engineer (I troubleshot a lot of app performance problems at work) I sat one Saturday afternoon and found that the issue was in the method call that gets network interfaces from system. The fix is a couple lines of code - store NetworkInterface objects in process memory (monitor for changes) and call GetIPv4Statistics() on them instead if creating new ones every time. I'm running with this custom Eddie build for over a year now without observing regressions and the CPU usage is stable at 0.0-0.1% in background After seeing this topic I re-tested with and without the patch on version 2.24.2. The results are visible on the screenshots.@Staff Feel free to test this patch [git apply file.patch]I'm using Windows - haven't tested other platforms BR network-interface-get-improvement.patch 2 1 pHxaq, Tech Jedi Alex and Staff reacted to this Share this post Link to post
Clodo 177 Posted ... 17 hours ago, matts9 said: @Staff Feel free to test this patch [git apply file.patch] Thank you, it will be in the next release. 1 matts9 reacted to this Share this post Link to post
