raven11111 0 Posted ... (edited) ! 2023.10.08 09:36:47 - Disconnecting . 2023.10.08 09:36:47 - WireGuard > Stop request received . 2023.10.08 09:36:47 - WireGuard > Stopping . 2023.10.08 09:36:47 - WireGuard > end . 2023.10.08 09:36:47 - Routes, delete 89.238.166.237/32 for interface "en0". . 2023.10.08 09:36:47 - Routes, delete 89.238.166.237/32 for interface "en0", not exists. . 2023.10.08 09:36:47 - Connection terminated. I 2023.10.08 09:36:47 - Cancel requested. ! 2023.10.08 09:36:47 - Session terminated. I 2023.10.08 09:36:48 - Session starting. . 2023.10.08 09:36:48 - Waiting for latency tests (68 to go) . 2023.10.08 09:36:49 - Waiting for latency tests (36 to go) I 2023.10.08 09:36:51 - Checking authorization ... ! 2023.10.08 09:36:52 - Connecting to Columba (Belgium, Brussels) . 2023.10.08 09:36:52 - Routes, add 194.187.251.117/32 for interface "en0". . 2023.10.08 09:36:53 - Routes, add 194.187.251.117/32 for interface "en0", already exists. . 2023.10.08 09:36:53 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:36:53 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:36:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:36:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:36:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:36:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:36:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.117:443 . 2023.10.08 09:36:53 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:36:53 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:36:53 - OpenVPN > UDP link remote: [AF_INET]194.187.251.117:443 . 2023.10.08 09:36:55 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:36:55 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:36:55 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:36:55 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:36:55 - Disconnecting . 2023.10.08 09:36:55 - Sending soft termination signal . 2023.10.08 09:36:55 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:36:55 - Routes, delete 194.187.251.117/32 for interface "en0". . 2023.10.08 09:36:55 - Routes, delete 194.187.251.117/32 for interface "en0", not exists. . 2023.10.08 09:36:55 - Connection terminated. I 2023.10.08 09:36:58 - Checking authorization ... ! 2023.10.08 09:36:59 - Connecting to Mebsuta (Belgium, Brussels) . 2023.10.08 09:36:59 - Routes, add 194.187.251.157/32 for interface "en0". . 2023.10.08 09:36:59 - Routes, add 194.187.251.157/32 for interface "en0", already exists. . 2023.10.08 09:37:00 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:37:00 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:37:00 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:00 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:00 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:00 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.157:443 . 2023.10.08 09:37:00 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:37:00 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:37:00 - OpenVPN > UDP link remote: [AF_INET]194.187.251.157:443 . 2023.10.08 09:37:01 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:37:01 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:37:01 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:37:01 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:37:01 - Disconnecting . 2023.10.08 09:37:01 - Sending soft termination signal . 2023.10.08 09:37:01 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:37:01 - Routes, delete 194.187.251.157/32 for interface "en0". . 2023.10.08 09:37:01 - Routes, delete 194.187.251.157/32 for interface "en0", not exists. . 2023.10.08 09:37:01 - Connection terminated. I 2023.10.08 09:37:04 - Checking authorization ... ! 2023.10.08 09:37:05 - Connecting to Copernicus (Sweden, Stockholm) . 2023.10.08 09:37:05 - Routes, add 79.142.76.246/32 for interface "en0". . 2023.10.08 09:37:06 - Routes, add 79.142.76.246/32 for interface "en0", already exists. . 2023.10.08 09:37:06 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:37:06 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:37:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]79.142.76.246:443 . 2023.10.08 09:37:06 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:37:06 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:37:06 - OpenVPN > UDP link remote: [AF_INET]79.142.76.246:443 . 2023.10.08 09:37:08 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:37:08 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:37:08 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:37:08 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:37:08 - Disconnecting . 2023.10.08 09:37:08 - Sending soft termination signal . 2023.10.08 09:37:08 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:37:08 - Routes, delete 79.142.76.246/32 for interface "en0". . 2023.10.08 09:37:08 - Routes, delete 79.142.76.246/32 for interface "en0", not exists. . 2023.10.08 09:37:08 - Connection terminated. I 2023.10.08 09:37:11 - Checking authorization ... ! 2023.10.08 09:37:12 - Connecting to Norma (Sweden, Stockholm) . 2023.10.08 09:37:12 - Routes, add 31.3.152.102/32 for interface "en0". . 2023.10.08 09:37:12 - Routes, add 31.3.152.102/32 for interface "en0", already exists. . 2023.10.08 09:37:13 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:37:13 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:37:13 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:13 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:13 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:13 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:13 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]31.3.152.102:443 . 2023.10.08 09:37:13 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:37:13 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:37:13 - OpenVPN > UDP link remote: [AF_INET]31.3.152.102:443 . 2023.10.08 09:37:14 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:37:14 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:37:14 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:37:14 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:37:14 - Disconnecting . 2023.10.08 09:37:14 - Sending soft termination signal . 2023.10.08 09:37:14 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:37:14 - Routes, delete 31.3.152.102/32 for interface "en0". . 2023.10.08 09:37:14 - Routes, delete 31.3.152.102/32 for interface "en0", not exists. . 2023.10.08 09:37:14 - Connection terminated. I 2023.10.08 09:37:17 - Checking authorization ... ! 2023.10.08 09:37:18 - Connecting to Ain (Sweden, Stockholm) . 2023.10.08 09:37:18 - Routes, add 128.127.104.82/32 for interface "en0". . 2023.10.08 09:37:18 - Routes, add 128.127.104.82/32 for interface "en0", already exists. . 2023.10.08 09:37:19 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:37:19 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:37:19 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:19 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:19 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:19 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:19 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]128.127.104.82:443 . 2023.10.08 09:37:19 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:37:19 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:37:19 - OpenVPN > UDP link remote: [AF_INET]128.127.104.82:443 . 2023.10.08 09:37:21 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:37:21 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:37:21 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:37:21 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:37:21 - Disconnecting . 2023.10.08 09:37:21 - Sending soft termination signal . 2023.10.08 09:37:21 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:37:21 - Routes, delete 128.127.104.82/32 for interface "en0". . 2023.10.08 09:37:21 - Routes, delete 128.127.104.82/32 for interface "en0", not exists. . 2023.10.08 09:37:21 - Connection terminated. I 2023.10.08 09:37:24 - Checking authorization ... ! 2023.10.08 09:37:25 - Connecting to Lupus (Sweden, Stockholm) . 2023.10.08 09:37:25 - Routes, add 128.127.105.186/32 for interface "en0". . 2023.10.08 09:37:25 - Routes, add 128.127.105.186/32 for interface "en0", already exists. . 2023.10.08 09:37:26 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:37:26 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:37:26 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:26 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:26 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:26 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:26 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]128.127.105.186:443 . 2023.10.08 09:37:26 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:37:26 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:37:26 - OpenVPN > UDP link remote: [AF_INET]128.127.105.186:443 . 2023.10.08 09:37:27 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:37:27 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:37:27 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:37:27 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:37:27 - Disconnecting . 2023.10.08 09:37:27 - Sending soft termination signal . 2023.10.08 09:37:27 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:37:27 - Routes, delete 128.127.105.186/32 for interface "en0". . 2023.10.08 09:37:27 - Routes, delete 128.127.105.186/32 for interface "en0", not exists. . 2023.10.08 09:37:27 - Connection terminated. I 2023.10.08 09:37:30 - Checking authorization ... ! 2023.10.08 09:37:31 - Connecting to Capricornus (Belgium, Brussels) . 2023.10.08 09:37:31 - Routes, add 194.187.251.93/32 for interface "en0". . 2023.10.08 09:37:31 - Routes, add 194.187.251.93/32 for interface "en0", already exists. . 2023.10.08 09:37:32 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:37:32 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:37:32 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:32 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:32 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:32 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:32 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.93:443 . 2023.10.08 09:37:32 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:37:32 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:37:32 - OpenVPN > UDP link remote: [AF_INET]194.187.251.93:443 . 2023.10.08 09:37:33 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:37:33 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:37:33 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:37:33 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:37:33 - Disconnecting . 2023.10.08 09:37:33 - Sending soft termination signal . 2023.10.08 09:37:33 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:37:33 - Routes, delete 194.187.251.93/32 for interface "en0". . 2023.10.08 09:37:33 - Routes, delete 194.187.251.93/32 for interface "en0", not exists. . 2023.10.08 09:37:33 - Connection terminated. I 2023.10.08 09:37:36 - Checking authorization ... ! 2023.10.08 09:37:37 - Connecting to Castor (Belgium, Brussels) . 2023.10.08 09:37:37 - Routes, add 91.207.57.117/32 for interface "en0". . 2023.10.08 09:37:37 - Routes, add 91.207.57.117/32 for interface "en0", already exists. . 2023.10.08 09:37:38 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:37:38 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:37:38 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:38 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:38 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:38 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:38 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]91.207.57.117:443 . 2023.10.08 09:37:38 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:37:38 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:37:38 - OpenVPN > UDP link remote: [AF_INET]91.207.57.117:443 . 2023.10.08 09:37:40 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:37:40 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:37:40 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:37:40 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:37:40 - Disconnecting . 2023.10.08 09:37:40 - Sending soft termination signal . 2023.10.08 09:37:40 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:37:40 - Routes, delete 91.207.57.117/32 for interface "en0". . 2023.10.08 09:37:40 - Routes, delete 91.207.57.117/32 for interface "en0", not exists. . 2023.10.08 09:37:40 - Connection terminated. I 2023.10.08 09:37:43 - Checking authorization ... ! 2023.10.08 09:37:44 - Connecting to Diadema (Belgium, Brussels) . 2023.10.08 09:37:44 - Routes, add 194.187.251.165/32 for interface "en0". . 2023.10.08 09:37:44 - Routes, add 194.187.251.165/32 for interface "en0", already exists. . 2023.10.08 09:37:44 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:37:44 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:37:44 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:44 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:44 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:44 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:44 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.165:443 . 2023.10.08 09:37:44 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:37:44 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:37:44 - OpenVPN > UDP link remote: [AF_INET]194.187.251.165:443 . 2023.10.08 09:37:47 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:37:47 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:37:47 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:37:47 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:37:47 - Disconnecting . 2023.10.08 09:37:47 - Sending soft termination signal . 2023.10.08 09:37:47 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:37:47 - Routes, delete 194.187.251.165/32 for interface "en0". . 2023.10.08 09:37:47 - Routes, delete 194.187.251.165/32 for interface "en0", not exists. . 2023.10.08 09:37:47 - Connection terminated. I 2023.10.08 09:37:50 - Checking authorization ... ! 2023.10.08 09:37:52 - Connecting to Triangulum (Singapore, Singapore) . 2023.10.08 09:37:52 - Routes, add 185.200.116.133/32 for interface "en0". . 2023.10.08 09:37:52 - Routes, add 185.200.116.133/32 for interface "en0", already exists. . 2023.10.08 09:37:52 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:37:52 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:37:52 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:52 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:52 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:52 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:52 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.200.116.133:443 . 2023.10.08 09:37:52 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:37:52 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:37:52 - OpenVPN > UDP link remote: [AF_INET]185.200.116.133:443 . 2023.10.08 09:37:54 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:37:54 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:37:54 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:37:54 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:37:54 - Disconnecting . 2023.10.08 09:37:54 - Sending soft termination signal . 2023.10.08 09:37:54 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:37:54 - Routes, delete 185.200.116.133/32 for interface "en0". . 2023.10.08 09:37:54 - Routes, delete 185.200.116.133/32 for interface "en0", not exists. . 2023.10.08 09:37:54 - Connection terminated. I 2023.10.08 09:37:57 - Checking authorization ... ! 2023.10.08 09:37:59 - Connecting to Luyten (Singapore, Singapore) . 2023.10.08 09:37:59 - Routes, add 92.119.178.5/32 for interface "en0". . 2023.10.08 09:37:59 - Routes, add 92.119.178.5/32 for interface "en0", already exists. . 2023.10.08 09:37:59 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:37:59 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:37:59 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:59 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:59 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:37:59 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:37:59 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]92.119.178.5:443 . 2023.10.08 09:37:59 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:37:59 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:37:59 - OpenVPN > UDP link remote: [AF_INET]92.119.178.5:443 . 2023.10.08 09:38:01 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:38:01 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:38:01 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:38:01 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:38:01 - Disconnecting . 2023.10.08 09:38:01 - Sending soft termination signal . 2023.10.08 09:38:01 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:38:01 - Routes, delete 92.119.178.5/32 for interface "en0". . 2023.10.08 09:38:01 - Routes, delete 92.119.178.5/32 for interface "en0", not exists. . 2023.10.08 09:38:01 - Connection terminated. I 2023.10.08 09:38:04 - Checking authorization ... ! 2023.10.08 09:38:06 - Connecting to Zuben (Czechia, Prague) . 2023.10.08 09:38:06 - Routes, add 89.238.166.237/32 for interface "en0". . 2023.10.08 09:38:06 - Routes, add 89.238.166.237/32 for interface "en0", already exists. . 2023.10.08 09:38:06 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:38:06 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:38:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]89.238.166.237:443 . 2023.10.08 09:38:06 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:38:06 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:38:06 - OpenVPN > UDP link remote: [AF_INET]89.238.166.237:443 . 2023.10.08 09:38:08 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:38:08 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:38:08 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:38:08 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:38:08 - Disconnecting . 2023.10.08 09:38:08 - Sending soft termination signal . 2023.10.08 09:38:08 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:38:08 - Routes, delete 89.238.166.237/32 for interface "en0". . 2023.10.08 09:38:08 - Routes, delete 89.238.166.237/32 for interface "en0", not exists. . 2023.10.08 09:38:08 - Connection terminated. I 2023.10.08 09:38:10 - Cancel requested. ! 2023.10.08 09:38:11 - Session terminated. I 2023.10.08 09:38:12 - Session starting. I 2023.10.08 09:38:12 - Checking authorization ... ! 2023.10.08 09:38:13 - Connecting to Chow (United Kingdom of Great Britain and Northern Ireland, Manchester) . 2023.10.08 09:38:13 - Routes, add 89.249.74.220/32 for interface "en0". . 2023.10.08 09:38:13 - Routes, add 89.249.74.220/32 for interface "en0", already exists. . 2023.10.08 09:38:13 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:38:13 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:38:13 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:13 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:13 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:13 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:13 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]89.249.74.220:443 . 2023.10.08 09:38:13 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:38:13 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:38:13 - OpenVPN > UDP link remote: [AF_INET]89.249.74.220:443 . 2023.10.08 09:38:16 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:38:16 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:38:16 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:38:16 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:38:16 - Disconnecting . 2023.10.08 09:38:16 - Sending soft termination signal . 2023.10.08 09:38:16 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:38:16 - Routes, delete 89.249.74.220/32 for interface "en0". . 2023.10.08 09:38:16 - Routes, delete 89.249.74.220/32 for interface "en0", not exists. . 2023.10.08 09:38:16 - Connection terminated. I 2023.10.08 09:38:19 - Checking authorization ... ! 2023.10.08 09:38:20 - Connecting to Muphrid (Sweden, Uppsala) . 2023.10.08 09:38:20 - Routes, add 62.102.148.218/32 for interface "en0". . 2023.10.08 09:38:20 - Routes, add 62.102.148.218/32 for interface "en0", already exists. . 2023.10.08 09:38:20 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:38:20 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:38:20 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:20 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:20 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:20 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:20 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.218:443 . 2023.10.08 09:38:20 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:38:20 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:38:20 - OpenVPN > UDP link remote: [AF_INET]62.102.148.218:443 . 2023.10.08 09:38:23 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:38:23 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:38:23 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:38:23 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:38:23 - Disconnecting . 2023.10.08 09:38:23 - Sending soft termination signal . 2023.10.08 09:38:23 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:38:23 - Routes, delete 62.102.148.218/32 for interface "en0". . 2023.10.08 09:38:23 - Routes, delete 62.102.148.218/32 for interface "en0", not exists. . 2023.10.08 09:38:23 - Connection terminated. I 2023.10.08 09:38:26 - Checking authorization ... ! 2023.10.08 09:38:27 - Connecting to Markab (Czechia, Prague) . 2023.10.08 09:38:27 - Routes, add 185.156.174.29/32 for interface "en0". . 2023.10.08 09:38:27 - Routes, add 185.156.174.29/32 for interface "en0", already exists. . 2023.10.08 09:38:27 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:38:27 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:38:27 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:27 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:27 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:27 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:27 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.174.29:443 . 2023.10.08 09:38:27 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:38:27 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:38:27 - OpenVPN > UDP link remote: [AF_INET]185.156.174.29:443 . 2023.10.08 09:38:30 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:38:30 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:38:30 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:38:30 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:38:30 - Disconnecting . 2023.10.08 09:38:30 - Sending soft termination signal . 2023.10.08 09:38:30 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:38:30 - Routes, delete 185.156.174.29/32 for interface "en0". . 2023.10.08 09:38:30 - Routes, delete 185.156.174.29/32 for interface "en0", not exists. . 2023.10.08 09:38:30 - Connection terminated. I 2023.10.08 09:38:33 - Checking authorization ... ! 2023.10.08 09:38:34 - Connecting to Auriga (Singapore, Singapore) . 2023.10.08 09:38:34 - Routes, add 185.200.116.213/32 for interface "en0". . 2023.10.08 09:38:34 - Routes, add 185.200.116.213/32 for interface "en0", already exists. . 2023.10.08 09:38:34 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:38:34 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:38:34 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:34 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:34 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:34 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.200.116.213:443 . 2023.10.08 09:38:34 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:38:34 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:38:34 - OpenVPN > UDP link remote: [AF_INET]185.200.116.213:443 . 2023.10.08 09:38:37 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:38:37 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:38:37 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:38:37 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:38:37 - Disconnecting . 2023.10.08 09:38:37 - Sending soft termination signal . 2023.10.08 09:38:37 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:38:37 - Routes, delete 185.200.116.213/32 for interface "en0". . 2023.10.08 09:38:37 - Routes, delete 185.200.116.213/32 for interface "en0", not exists. . 2023.10.08 09:38:37 - Connection terminated. I 2023.10.08 09:38:40 - Checking authorization ... ! 2023.10.08 09:38:41 - Connecting to Taurus (Spain, Madrid) . 2023.10.08 09:38:41 - Routes, add 194.99.104.37/32 for interface "en0". . 2023.10.08 09:38:41 - Routes, add 194.99.104.37/32 for interface "en0", already exists. . 2023.10.08 09:38:42 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:38:42 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:38:42 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:42 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:42 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:42 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:42 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.99.104.37:443 . 2023.10.08 09:38:42 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:38:42 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:38:42 - OpenVPN > UDP link remote: [AF_INET]194.99.104.37:443 . 2023.10.08 09:38:43 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:38:43 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:38:43 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:38:43 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:38:43 - Disconnecting . 2023.10.08 09:38:43 - Sending soft termination signal . 2023.10.08 09:38:43 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:38:43 - Routes, delete 194.99.104.37/32 for interface "en0". . 2023.10.08 09:38:43 - Routes, delete 194.99.104.37/32 for interface "en0", not exists. . 2023.10.08 09:38:43 - Connection terminated. I 2023.10.08 09:38:46 - Checking authorization ... ! 2023.10.08 09:38:47 - Connecting to Kitel (United Kingdom of Great Britain and Northern Ireland, London) . 2023.10.08 09:38:47 - Routes, add 146.70.61.149/32 for interface "en0". . 2023.10.08 09:38:47 - Routes, add 146.70.61.149/32 for interface "en0", already exists. . 2023.10.08 09:38:48 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:38:48 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:38:48 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:48 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:48 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:48 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:48 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]146.70.61.149:443 . 2023.10.08 09:38:48 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:38:48 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:38:48 - OpenVPN > UDP link remote: [AF_INET]146.70.61.149:443 . 2023.10.08 09:38:49 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:38:49 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:38:49 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:38:49 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:38:49 - Disconnecting . 2023.10.08 09:38:49 - Sending soft termination signal . 2023.10.08 09:38:49 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:38:49 - Routes, delete 146.70.61.149/32 for interface "en0". . 2023.10.08 09:38:49 - Routes, delete 146.70.61.149/32 for interface "en0", not exists. . 2023.10.08 09:38:49 - Connection terminated. I 2023.10.08 09:38:52 - Checking authorization ... ! 2023.10.08 09:38:53 - Connecting to Turais (Czechia, Prague) . 2023.10.08 09:38:53 - Routes, add 185.156.174.157/32 for interface "en0". . 2023.10.08 09:38:53 - Routes, add 185.156.174.157/32 for interface "en0", already exists. . 2023.10.08 09:38:53 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:38:53 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:38:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:38:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:38:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.174.157:443 . 2023.10.08 09:38:53 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:38:53 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:38:53 - OpenVPN > UDP link remote: [AF_INET]185.156.174.157:443 . 2023.10.08 09:38:55 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:38:55 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:38:55 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:38:55 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:38:56 - Disconnecting . 2023.10.08 09:38:56 - Sending soft termination signal . 2023.10.08 09:38:56 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:38:56 - Routes, delete 185.156.174.157/32 for interface "en0". . 2023.10.08 09:38:56 - Routes, delete 185.156.174.157/32 for interface "en0", not exists. . 2023.10.08 09:38:56 - Connection terminated. I 2023.10.08 09:38:59 - Checking authorization ... ! 2023.10.08 09:39:00 - Connecting to Altarf (Sweden, Uppsala) . 2023.10.08 09:39:00 - Routes, add 62.102.148.202/32 for interface "en0". . 2023.10.08 09:39:00 - Routes, add 62.102.148.202/32 for interface "en0", already exists. . 2023.10.08 09:39:00 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:39:00 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:39:00 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:39:00 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:39:00 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:39:00 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:39:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.202:443 . 2023.10.08 09:39:00 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:39:00 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:39:00 - OpenVPN > UDP link remote: [AF_INET]62.102.148.202:443 . 2023.10.08 09:39:02 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:39:02 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:39:02 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:39:02 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:39:02 - Disconnecting . 2023.10.08 09:39:02 - Sending soft termination signal . 2023.10.08 09:39:03 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:39:03 - Routes, delete 62.102.148.202/32 for interface "en0". . 2023.10.08 09:39:03 - Routes, delete 62.102.148.202/32 for interface "en0", not exists. . 2023.10.08 09:39:03 - Connection terminated. I 2023.10.08 09:39:06 - Checking authorization ... ! 2023.10.08 09:39:07 - Connecting to Minchir (Ireland, Dublin) . 2023.10.08 09:39:07 - Routes, add 146.70.94.5/32 for interface "en0". . 2023.10.08 09:39:07 - Routes, add 146.70.94.5/32 for interface "en0", already exists. . 2023.10.08 09:39:07 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:39:07 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:39:07 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:39:07 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:39:07 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:39:07 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:39:07 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]146.70.94.5:443 . 2023.10.08 09:39:07 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:39:07 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:39:07 - OpenVPN > UDP link remote: [AF_INET]146.70.94.5:443 . 2023.10.08 09:39:09 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:39:09 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:39:09 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:39:09 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:39:09 - Disconnecting . 2023.10.08 09:39:09 - Sending soft termination signal . 2023.10.08 09:39:09 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:39:09 - Routes, delete 146.70.94.5/32 for interface "en0". . 2023.10.08 09:39:10 - Routes, delete 146.70.94.5/32 for interface "en0", not exists. . 2023.10.08 09:39:10 - Connection terminated. I 2023.10.08 09:39:13 - Checking authorization ... ! 2023.10.08 09:39:14 - Connecting to Phact (Latvia, Riga) . 2023.10.08 09:39:14 - Routes, add 46.183.216.165/32 for interface "en0". . 2023.10.08 09:39:14 - Routes, add 46.183.216.165/32 for interface "en0", already exists. . 2023.10.08 09:39:14 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:39:14 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:39:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:39:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:39:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:39:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:39:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]46.183.216.165:443 . 2023.10.08 09:39:14 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:39:14 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:39:14 - OpenVPN > UDP link remote: [AF_INET]46.183.216.165:443 . 2023.10.08 09:39:16 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:39:16 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:39:16 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:39:16 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:39:16 - Disconnecting . 2023.10.08 09:39:16 - Sending soft termination signal . 2023.10.08 09:39:17 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:39:17 - Routes, delete 46.183.216.165/32 for interface "en0". . 2023.10.08 09:39:17 - Routes, delete 46.183.216.165/32 for interface "en0", not exists. . 2023.10.08 09:39:17 - Connection terminated. I 2023.10.08 09:39:20 - Checking authorization ... ! 2023.10.08 09:39:21 - Connecting to Baiten (Switzerland, Zurich) . 2023.10.08 09:39:21 - Routes, add 185.156.175.53/32 for interface "en0". . 2023.10.08 09:39:21 - Routes, add 185.156.175.53/32 for interface "en0", already exists. . 2023.10.08 09:39:21 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:39:21 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:39:21 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:39:21 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:39:21 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:39:21 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:39:21 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.175.53:443 . 2023.10.08 09:39:21 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:39:21 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:39:21 - OpenVPN > UDP link remote: [AF_INET]185.156.175.53:443 . 2023.10.08 09:39:24 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:39:24 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:39:24 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:39:24 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:39:24 - Disconnecting . 2023.10.08 09:39:24 - Sending soft termination signal . 2023.10.08 09:39:24 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:39:24 - Routes, delete 185.156.175.53/32 for interface "en0". . 2023.10.08 09:39:24 - Routes, delete 185.156.175.53/32 for interface "en0", not exists. . 2023.10.08 09:39:24 - Connection terminated. I 2023.10.08 09:39:27 - Checking authorization ... ! 2023.10.08 09:39:28 - Connecting to Benetnasch (Sweden, Uppsala) . 2023.10.08 09:39:28 - Routes, add 62.102.148.210/32 for interface "en0". . 2023.10.08 09:39:28 - Routes, add 62.102.148.210/32 for interface "en0", already exists. . 2023.10.08 09:39:28 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.10.08 09:39:28 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.10.08 09:39:28 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:39:28 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:39:28 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.08 09:39:28 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.08 09:39:28 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.210:443 . 2023.10.08 09:39:28 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.10.08 09:39:28 - OpenVPN > UDP link local: (not bound) . 2023.10.08 09:39:28 - OpenVPN > UDP link remote: [AF_INET]62.102.148.210:443 . 2023.10.08 09:39:30 - OpenVPN > write UDP: Network is unreachable (code=51) . 2023.10.08 09:39:30 - OpenVPN > Network unreachable, restarting . 2023.10.08 09:39:30 - OpenVPN > SIGUSR1[soft,network-unreachable] received, process restarting . 2023.10.08 09:39:30 - OpenVPN > Restart pause, 5 second(s) ! 2023.10.08 09:39:30 - Disconnecting . 2023.10.08 09:39:30 - Sending soft termination signal . 2023.10.08 09:39:31 - OpenVPN > SIGINT[hard,init_instance] received, process exiting . 2023.10.08 09:39:31 - Routes, delete 62.102.148.210/32 for interface "en0". . 2023.10.08 09:39:31 - Routes, delete 62.102.148.210/32 for interface "en0", not exists. . 2023.10.08 09:39:31 - Connection terminated. I 2023.10.08 09:39:34 - Checking authorization ... Edited ... by OpenSourcerer Apply LOG format to logs Quote Share this post Link to post
Tech Jedi Alex 1585 Posted ... Please reboot your Mac and make sure you've got an internet connection, then try again. If it still doesn't work, close Eddie, reopen and try a connection, then provide a system report:. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
brianperplexis 0 Posted ... Same issuse Did all that I 2023.10.14 08:28:14 - Session starting. I 2023.10.14 08:28:14 - Checking authorization ... ! 2023.10.14 08:28:16 - Connecting to Ain (Sweden, Stockholm) . 2023.10.14 08:28:16 - OpenVPN > OpenVPN 2.5.1 x86_64-apple-darwin19.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Mar 9 2021 . 2023.10.14 08:28:16 - OpenVPN > library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 . 2023.10.14 08:28:16 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.14 08:28:16 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.14 08:28:16 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.14 08:28:16 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.14 08:28:16 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]128.127.104.82:443 . 2023.10.14 08:28:16 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144] . 2023.10.14 08:28:16 - OpenVPN > UDP link local: (not bound) . 2023.10.14 08:28:16 - OpenVPN > UDP link remote: [AF_INET]128.127.104.82:443 . 2023.10.14 08:28:16 - OpenVPN > TLS: Initial packet from [AF_INET]128.127.104.82:443, sid=d432294b da94cb95 . 2023.10.14 08:28:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.10.14 08:28:16 - OpenVPN > VERIFY KU OK . 2023.10.14 08:28:16 - OpenVPN > Validating certificate extended key usage . 2023.10.14 08:28:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.10.14 08:28:16 - OpenVPN > VERIFY EKU OK . 2023.10.14 08:28:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ain, emailAddress=info@airvpn.org . 2023.10.14 08:28:16 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2023.10.14 08:28:16 - OpenVPN > [Ain] Peer Connection Initiated with [AF_INET]128.127.104.82:443 . 2023.10.14 08:28:17 - OpenVPN > SENT CONTROL [Ain]: 'PUSH_REQUEST' (status=1) W 2023.10.14 08:28:17 - Authorization failed. Look at the client area to discover the reason. . 2023.10.14 08:28:17 - OpenVPN > AUTH: Received control message: AUTH_FAILED . 2023.10.14 08:28:17 - OpenVPN > SIGTERM received, sending exit notification to peer ! 2023.10.14 08:28:17 - Disconnecting . 2023.10.14 08:28:17 - Sending soft termination signal . 2023.10.14 08:28:18 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.10.14 08:28:18 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.10.14 08:28:18 - Connection terminated. I 2023.10.14 08:28:21 - Checking authorization ... ! 2023.10.14 08:28:21 - Connecting to Ain (Sweden, Stockholm) . 2023.10.14 08:28:22 - OpenVPN > OpenVPN 2.5.1 x86_64-apple-darwin19.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Mar 9 2021 . 2023.10.14 08:28:22 - OpenVPN > library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 . 2023.10.14 08:28:22 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.14 08:28:22 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.14 08:28:22 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.14 08:28:22 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.14 08:28:22 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]128.127.104.82:443 . 2023.10.14 08:28:22 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144] . 2023.10.14 08:28:22 - OpenVPN > UDP link local: (not bound) . 2023.10.14 08:28:22 - OpenVPN > UDP link remote: [AF_INET]128.127.104.82:443 . 2023.10.14 08:28:22 - OpenVPN > TLS: Initial packet from [AF_INET]128.127.104.82:443, sid=ea4ce8b9 ece4b0b6 . 2023.10.14 08:28:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.10.14 08:28:22 - OpenVPN > VERIFY KU OK . 2023.10.14 08:28:22 - OpenVPN > Validating certificate extended key usage . 2023.10.14 08:28:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.10.14 08:28:22 - OpenVPN > VERIFY EKU OK . 2023.10.14 08:28:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ain, emailAddress=info@airvpn.org . 2023.10.14 08:28:22 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2023.10.14 08:28:22 - OpenVPN > [Ain] Peer Connection Initiated with [AF_INET]128.127.104.82:443 . 2023.10.14 08:28:23 - OpenVPN > SENT CONTROL [Ain]: 'PUSH_REQUEST' (status=1) W 2023.10.14 08:28:23 - Authorization failed. Look at the client area to discover the reason. . 2023.10.14 08:28:23 - OpenVPN > AUTH: Received control message: AUTH_FAILED . 2023.10.14 08:28:23 - OpenVPN > SIGTERM received, sending exit notification to peer ! 2023.10.14 08:28:23 - Disconnecting . 2023.10.14 08:28:23 - Sending soft termination signal . 2023.10.14 08:28:23 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.10.14 08:28:23 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.10.14 08:28:24 - Connection terminated. I 2023.10.14 08:28:27 - Checking authorization ... ! 2023.10.14 08:28:27 - Connecting to Ain (Sweden, Stockholm) . 2023.10.14 08:28:27 - OpenVPN > OpenVPN 2.5.1 x86_64-apple-darwin19.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Mar 9 2021 . 2023.10.14 08:28:27 - OpenVPN > library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 . 2023.10.14 08:28:27 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.14 08:28:27 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.14 08:28:27 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.10.14 08:28:27 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.10.14 08:28:27 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]128.127.104.82:443 . 2023.10.14 08:28:27 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144] . 2023.10.14 08:28:27 - OpenVPN > UDP link local: (not bound) . 2023.10.14 08:28:27 - OpenVPN > UDP link remote: [AF_INET]128.127.104.82:443 . 2023.10.14 08:28:28 - OpenVPN > TLS: Initial packet from [AF_INET]128.127.104.82:443, sid=4a4719e7 9bf7b0c8 . 2023.10.14 08:28:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.10.14 08:28:28 - OpenVPN > VERIFY KU OK . 2023.10.14 08:28:28 - OpenVPN > Validating certificate extended key usage . 2023.10.14 08:28:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.10.14 08:28:28 - OpenVPN > VERIFY EKU OK . 2023.10.14 08:28:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ain, emailAddress=info@airvpn.org . 2023.10.14 08:28:28 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2023.10.14 08:28:28 - OpenVPN > [Ain] Peer Connection Initiated with [AF_INET]128.127.104.82:443 . 2023.10.14 08:28:29 - OpenVPN > SENT CONTROL [Ain]: 'PUSH_REQUEST' (status=1) W 2023.10.14 08:28:29 - Authorization failed. Look at the client area to discover the reason. . 2023.10.14 08:28:29 - OpenVPN > AUTH: Received control message: AUTH_FAILED . 2023.10.14 08:28:29 - OpenVPN > SIGTERM received, sending exit notification to peer ! 2023.10.14 08:28:29 - Disconnecting . 2023.10.14 08:28:29 - Sending soft termination signal . 2023.10.14 08:28:29 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.10.14 08:28:29 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.10.14 08:28:29 - Connection terminated. I 2023.10.14 08:28:31 - Cancel requested. ! 2023.10.14 08:28:31 - Session terminated. Quote Share this post Link to post
Staff 10716 Posted ... @brianperplexis Hello! Quote W 2023.10.14 08:28:23 - Authorization failed. Look at the client area to discover the reason. . 2023.10.14 08:28:23 - OpenVPN > AUTH: Received control message: AUTH_FAILED . 2023.10.14 08:28:23 - OpenVPN > SIGTERM received, sending exit notification to peer We noticed that you deleted the old key(s) and created a new one. When you do so, you need, from Eddie's main window, to log your account out and in again. That's the only way to force Eddie to re-download keys (Eddie will not do it automatically) and you must do it every time you renew your client key(s). Please uncheck "Remember me", log your account out, then log your account in again (you will need to re-enter your credentials) finally test again connections. Kind regards 2 Gloom and Air4141841 reacted to this Quote Share this post Link to post
