Staff
Road to OpenVPN 2.6 and DCO
On 6/3/2026 at 6:35 AM, Staff said:
Important update: OpenVPN 2.7 and DCO deployment entered its final stage. Check the update on this thread first message. Now you can start using OpenVPN + DCO on a wide portion of AirVPN infrastructure and very soon on all of it.
Kind regards & datalove
This is great news. I'm already using it on a device, and I must say it feels more stable than WG, even with the servers on high load. Great great news. Thanks.
the major benefit being that ChaCha20-Poly1305 vs AES-256-GCM or AES-128-GCM on proper AES-NI supporting x86 machines can mean 2-3x the performance for the latter.
Wireguard only supporting the former means either hardware can't keep up or we get into a good chunk of wasted cpu cycles for nothing.
i'll wait until the full upgrade happens before switching over but I am thankful that AirVPN are going to number the providers who are supporting this finally. Thank you AirVPN.
not sure if this is the appropriate place for it, but the speeds are not good. here are some benchmark comparisons using the same VPN node which has wireguard enabled and DCO.
getting 1.7gbit download / 500mbit upload with wireguard with 0% - 4% packet loss
getting 300-400 mbit download / upload with openvpn-dco with 30-50% packet loss
vyos@vyos:/config/speedtest$ show log openvpn interface vtun0
Sep 24 05:54:17 openvpn-vtun0[1688072]: net_iface_type: type of vtun0: ovpn
Sep 24 05:54:17 openvpn-vtun0[1688072]: OpenVPN 2.7.7 [git:HEAD/64fdc30f8b3da705+] x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] [DCO] built on Sep  3 2026
Sep 24 05:54:17 openvpn-vtun0[1688072]: library versions: OpenSSL 3.0.20 7 Apr 2026, LZO 2.10
Sep 24 05:54:17 openvpn-vtun0[1688072]: DCO version: 6.18.50-vyos #1 SMP Tue Sep 15 14:27:03 UTC 2026
Sep 24 05:54:17 openvpn-vtun0[1688072]: TCP/UDP: Preserving recently used remote address: [AF_INET]<VPN_SERVER_IP>:443
Sep 24 05:54:17 openvpn-vtun0[1688072]: UDPv4 link local: (not bound)
Sep 24 05:54:17 openvpn-vtun0[1688072]: UDPv4 link remote: [AF_INET]<VPN_SERVER_IP>:443
Sep 24 05:54:17 openvpn-vtun0[1688072]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bits RSA, signature: RSA-SHA512, peer temporary key: 253 bits X25519, peer signing digest/type: SHA256 RSASSA-PSS, key agreement: x25519
Sep 24 05:54:17 openvpn-vtun0[1688072]: [<VPN_SERVER>] Peer Connection Initiated with [AF_INET]<VPN_SERVER_IP>:443
Sep 24 05:54:17 openvpn-vtun0[1688072]: net_iface_new: add vtun0 type ovpn
Sep 24 05:54:17 openvpn-vtun0[1688072]: net_iface_ovpn_mode: mode of vtun0: 0
Sep 24 05:54:17 openvpn-vtun0[1688072]: DCO device vtun0 already exists, won't be destroyed at shutdown
Sep 24 05:54:17 openvpn-vtun0[1688072]: ovpn-dco device [vtun0] opened
Sep 24 05:54:17 openvpn-vtun0[1688072]: net_iface_up: set vtun0 up
Sep 24 05:54:17 openvpn-vtun0[1688072]: net_addr_v4_add: <VPN_IPV4>/24 dev vtun0
Sep 24 05:54:17 openvpn-vtun0[1688072]: Initialization Sequence Completed
Sep 24 05:54:17 openvpn-vtun0[1688072]: Data Channel: cipher 'AES-256-GCM'
Sep 24 05:54:17 openvpn-vtun0[1688072]: Timers: ping 10, ping-restart 60
Sep 24 05:54:17 openvpn-vtun0[1688072]: Protocol options: explicit-exit-notify 5, protocol-flags cc-exit tls-ekm dyn-tls-crypt
vyos@vyos:/config/speedtest$ ./speedtest -I vtun0
   Speedtest by Ookla
      Server: Community Fibre Limited - London (id: 30690)
         ISP: M247 Europe
Idle Latency:     6.85 ms   (jitter: 0.11ms, low: 6.78ms, high: 7.09ms)
    Download:   364.86 Mbps (data used: 536.4 MB)
                401.20 ms   (jitter: 76.61ms, low: 7.20ms, high: 2321.81ms)
      Upload:   193.32 Mbps (data used: 266.1 MB)
                136.09 ms   (jitter: 61.79ms, low: 6.91ms, high: 864.19ms)
 Packet Loss:    34.1%
  Result URL: https://www.speedtest.net/result/c/2b4f2ad1-61c5-46bd-acf8-15ae00ed2f2e
   Speedtest by Ookla
      Server: Orbital Net - London (id: 48354)
         ISP: M247 Europe
Idle Latency:     6.48 ms   (jitter: 0.04ms, low: 6.38ms, high: 6.50ms)
    Download:   335.49 Mbps (data used: 586.3 MB)
                179.80 ms   (jitter: 65.88ms, low: 7.58ms, high: 1805.40ms)
      Upload:   319.05 Mbps (data used: 430.1 MB)
                176.82 ms   (jitter: 68.65ms, low: 6.35ms, high: 1701.08ms)
 Packet Loss:    29.3%
  Result URL: https://www.speedtest.net/result/c/3ad74bab-87cc-4873-9de7-9e3f2ec0cba0
vyos@vyos:/config/speedtest$ ./speedtest -I vtun0 -s 68305
   Speedtest by Ookla
      Server: Edgeuno - London (id: 68305)
         ISP: M247 Europe
Idle Latency:     6.44 ms   (jitter: 0.05ms, low: 6.38ms, high: 6.48ms)
    Download:   397.62 Mbps (data used: 711.2 MB)
      Upload:   279.87 Mbps (data used: 378.7 MB)
                 60.67 ms   (jitter: 48.42ms, low: 6.28ms, high: 538.20ms)
 Packet Loss:    52.0%
  Result URL: https://www.speedtest.net/result/c/73e95b7c-8e2c-4610-a012-5112840dc41b
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.61 ms   (jitter: 0.09ms, low: 6.50ms, high: 6.78ms)
    Download:   366.72 Mbps (data used: 494.3 MB)
                 33.62 ms   (jitter: 37.98ms, low: 6.97ms, high: 255.71ms)
      Upload:   327.10 Mbps (data used: 405.6 MB)
                 93.53 ms   (jitter: 58.36ms, low: 6.38ms, high: 861.37ms)
 Packet Loss:    53.2%
  Result URL: https://www.speedtest.net/result/c/c81672a6-64cb-4fb8-827a-9368529ffdf4
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.56 ms   (jitter: 0.11ms, low: 6.52ms, high: 6.87ms)
    Download:   378.31 Mbps (data used: 256.0 MB)
                348.43 ms   (jitter: 55.90ms, low: 8.17ms, high: 2392.63ms)
      Upload:   318.08 Mbps (data used: 443.5 MB)
                 59.11 ms   (jitter: 49.35ms, low: 6.43ms, high: 448.02ms)
 Packet Loss:    39.4%
  Result URL: https://www.speedtest.net/result/c/9718ef31-6952-4672-a302-79d5fb88d3b9
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.38 ms   (jitter: 0.08ms, low: 6.35ms, high: 6.60ms)
    Download:   393.48 Mbps (data used: 661.9 MB)
                194.84 ms   (jitter: 73.23ms, low: 6.44ms, high: 462.70ms)
      Upload:   309.18 Mbps (data used: 383.3 MB)
                151.29 ms   (jitter: 65.93ms, low: 6.39ms, high: 1720.85ms)
 Packet Loss:    52.6%
  Result URL: https://www.speedtest.net/result/c/191c305a-4350-43b6-8c3d-c884b0411f13
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.42 ms   (jitter: 0.04ms, low: 6.38ms, high: 6.45ms)
    Download:   387.64 Mbps (data used: 453.9 MB)
                728.64 ms   (jitter: 85.55ms, low: 7.45ms, high: 1588.19ms)
      Upload:   320.22 Mbps (data used: 518.9 MB)
                123.11 ms   (jitter: 62.95ms, low: 6.46ms, high: 869.00ms)
 Packet Loss:    59.4%
  Result URL: https://www.speedtest.net/result/c/2d5cacdf-baa4-4bb4-9189-3811ac163781
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.97 ms   (jitter: 1.28ms, low: 6.78ms, high: 11.30ms)
    Download:   388.70 Mbps (data used: 660.7 MB)
                112.72 ms   (jitter: 59.78ms, low: 6.60ms, high: 921.60ms)
      Upload:   234.95 Mbps (data used: 175.1 MB)
                127.72 ms   (jitter: 65.56ms, low: 6.61ms, high: 866.65ms)
 Packet Loss:    50.7%
  Result URL: https://www.speedtest.net/result/c/13b6b27b-dd7e-4761-94d9-529b8adda8e6
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.49 ms   (jitter: 0.05ms, low: 6.47ms, high: 6.68ms)
    Download:   368.84 Mbps (data used: 204.5 MB)
                410.02 ms   (jitter: 106.17ms, low: 6.96ms, high: 908.26ms)
      Upload:   275.70 Mbps (data used: 149.3 MB)
                205.29 ms   (jitter: 61.00ms, low: 7.73ms, high: 1739.85ms)
 Packet Loss:    60.7%
  Result URL: https://www.speedtest.net/result/c/27a1e4b0-ec1c-4fed-a7ab-0ad66f0305ef
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.70 ms   (jitter: 0.18ms, low: 6.52ms, high: 6.86ms)
    Download:   350.35 Mbps (data used: 297.0 MB)
                695.45 ms   (jitter: 77.52ms, low: 10.37ms, high: 2437.50ms)
      Upload:   268.19 Mbps (data used: 290.9 MB)
                 89.09 ms   (jitter: 59.38ms, low: 7.66ms, high: 863.71ms)
 Packet Loss:    58.4%
  Result URL: https://www.speedtest.net/result/c/d499f4d9-ca81-4e2a-8ef7-8fa0a9f7a3fc
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.41 ms   (jitter: 0.03ms, low: 6.39ms, high: 6.43ms)
    Download:   352.49 Mbps (data used: 283.8 MB)
      Upload:   278.05 Mbps (data used: 334.6 MB)
                161.29 ms   (jitter: 66.90ms, low: 6.35ms, high: 1755.31ms)
 Packet Loss:    44.3%
  Result URL: https://www.speedtest.net/result/c/282d33c4-fd6b-4446-8fa3-d5e48e2e2d35
wireguard results
vyos@vyos:/config/speedtest$ ./speedtest -I wg0 -s 68305
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.77 ms   (jitter: 0.03ms, low: 6.73ms, high: 6.80ms)
    Download:  1699.83 Mbps (data used: 2.1 GB)
                 24.41 ms   (jitter: 15.87ms, low: 6.68ms, high: 300.40ms)
      Upload:   548.53 Mbps (data used: 643.3 MB)
                 43.95 ms   (jitter: 43.07ms, low: 6.68ms, high: 450.28ms)
 Packet Loss:     2.0%
  Result URL: https://www.speedtest.net/result/c/b575d7e1-536e-4cc1-ab96-fc1c362f3ab8
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.52 ms   (jitter: 0.10ms, low: 6.47ms, high: 6.67ms)
    Download:  1621.04 Mbps (data used: 2.0 GB)
                 22.19 ms   (jitter: 3.38ms, low: 6.65ms, high: 257.69ms)
      Upload:   547.54 Mbps (data used: 687.5 MB)
                 72.24 ms   (jitter: 50.26ms, low: 6.54ms, high: 873.21ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/ad7c5a3a-3b19-4839-a2f2-fd8490995239
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.40 ms   (jitter: 0.10ms, low: 6.37ms, high: 6.55ms)
    Download:  1700.58 Mbps (data used: 2.0 GB)
                 23.04 ms   (jitter: 6.59ms, low: 6.63ms, high: 286.53ms)
      Upload:   543.60 Mbps (data used: 623.5 MB)
                 56.67 ms   (jitter: 47.99ms, low: 6.99ms, high: 454.34ms)
 Packet Loss:     2.1%
  Result URL: https://www.speedtest.net/result/c/89fad660-ff35-446a-a8b5-5cc0865d109d
   Speedtest by Ookla
         ISP: M247 Europe
Idle Latency:     6.57 ms   (jitter: 0.16ms, low: 6.44ms, high: 6.67ms)
    Download:  1615.72 Mbps (data used: 1.3 GB)
                 20.20 ms   (jitter: 8.43ms, low: 6.51ms, high: 261.16ms)
      Upload:   560.71 Mbps (data used: 758.2 MB)
                 36.12 ms   (jitter: 39.98ms, low: 6.64ms, high: 446.64ms)
 Packet Loss:     1.5%
  Result URL: https://www.speedtest.net/result/c/995048ec-4dad-4698-9973-78f703627553
