Not connected, Your IP: 216.73.216.217
Hey, because of Mullvads decission to stop providing port forwarding, i was searching for a alternative.
I found Airvpn. But since Hours i get huge problems with it.
Right now im trying on 3 different Machines (1 Desktop, 2 Notebooks, all Arch) to run the eddie-ui.
Long Story short:
aur/eddie-ui-git
(mono:20700): Gtk-WARNING **: 13:37:08.218: Im Modulpfad »adwaita« konnte keine Themen-Engine gefunden werden,
F 2023.05.31 13:37:08 - Cannot initialize UI. Probably a DISPLAY issue, ensure your are not running as root. Error:A null reference or invalid value was found [GDI+ status: InvalidParameter]
than tried aur/eddie-ui
Could not set X locale modifiers
(mono:30771): Gtk-WARNING **: 13:39:46.125: Im Modulpfad »adwaita« konnte keine Themen-Engine gefunden werden,
F 2023.05.31 13:39:46 - Cannot initialize UI. Probably a DISPLAY issue, ensure your are not running as root. Error:A null reference or invalid value was found [GDI+ status: InvalidParameter]
than tried aur/airvpn-bin
(mono:33703): Gtk-WARNING **: 13:40:41.623: Im Modulpfad »adwaita« konnte keine Themen-Engine gefunden werden,
  at System.Drawing.GDIPlus.CheckStatus (System.Drawing.Status status) [0x00098] in <70e54fb70fa24b359030d5df65342ff2>:0
  at System.Drawing.Bitmap..ctor (System.Int32 width, System.Int32 height, System.Drawing.Imaging.PixelFormat format) [0x00016] in <70e54fb70fa24b359030d5df65342ff2>:0
  at System.Drawing.Bitmap..ctor (System.Drawing.Image original, System.Int32 width, System.Int32 height) [0x00000] in <70e54fb70fa24b359030d5df65342ff2>:0
  at System.Drawing.Bitmap..ctor (System.Drawing.Image original, System.Drawing.Size newSize) [0x00010] in <70e54fb70fa24b359030d5df65342ff2>:0
  at (wrapper remoting-invoke-with-check) System.Drawing.Bitmap..ctor(System.Drawing.Image,System.Drawing.Size)
  at System.Windows.Forms.XplatUIX11.DefineCursor (System.Drawing.Bitmap bitmap, System.Drawing.Bitmap mask, System.Drawing.Color cursor_pixel, System.Drawing.Color mask_pixel, System.Int32 xHotSpot, System.Int32 yHotSpot) [0x00045] in <4bdc919193224fdbac7328002815594b>:0
  at System.Windows.Forms.XplatUI.DefineCursor (System.Drawing.Bitmap bitmap, System.Drawing.Bitmap mask, System.Drawing.Color cursor_pixel, System.Drawing.Color mask_pixel, System.Int32 xHotSpot, System.Int32 yHotSpot) [0x00000] in <4bdc919193224fdbac7328002815594b>:0
  at System.Windows.Forms.Cursor.CreateCursor (System.IO.Stream stream) [0x00058] in <4bdc919193224fdbac7328002815594b>:0
  at System.Windows.Forms.Cursor..ctor (System.Type type, System.String resource) [0x0001e] in <4bdc919193224fdbac7328002815594b>:0
  at System.Windows.Forms.Cursors.get_SizeNWSE () [0x00014] in <4bdc919193224fdbac7328002815594b>:0
  at System.Windows.Forms.SizeGrip..ctor (System.Windows.Forms.Control CapturedControl) [0x00006] in <4bdc919193224fdbac7328002815594b>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.SizeGrip..ctor(System.Windows.Forms.Control)
  at System.Windows.Forms.ScrollableControl.CreateScrollbars () [0x000c2] in <4bdc919193224fdbac7328002815594b>:0
  at System.Windows.Forms.ScrollableControl..ctor () [0x000b0] in <4bdc919193224fdbac7328002815594b>:0
  at System.Windows.Forms.ContainerControl..ctor () [0x0000e] in <4bdc919193224fdbac7328002815594b>:0
  at System.Windows.Forms.Form..ctor () [0x00012] in <4bdc919193224fdbac7328002815594b>:0
  at Eddie.Forms.Form..ctor () [0x00000] in <d3e7e810e39b4dce993106da17fa4a98>:0
  at Eddie.Forms.Forms.WindowSplash..ctor () [0x00000] in <d3e7e810e39b4dce993106da17fa4a98>:0
  at (wrapper remoting-invoke-with-check) Eddie.Forms.Forms.WindowSplash..ctor()
  at Eddie.Forms.UiClient.Init (System.String environmentCommandLine) [0x0001e] in <d3e7e810e39b4dce993106da17fa4a98>:0
  at Eddie.Forms.Linux.Program.Main () [0x00089] in <0d50fadb7f914fdb936f52ea72c12dc8>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.ArgumentException: A null reference or invalid value was found [GDI+ status: InvalidParameter]
  at System.Windows.Forms.MessageBox+MessageBoxForm..ctor (System.Windows.Forms.IWin32Window owner, System.String text, System.String caption, System.Windows.Forms.MessageBoxButtons buttons, System.Windows.Forms.MessageBoxIcon icon, System.Boolean displayHelpButton) [0x0000c] in <4bdc919193224fdbac7328002815594b>:0
  at System.Windows.Forms.MessageBox+MessageBoxForm..ctor (System.Windows.Forms.IWin32Window owner, System.String text, System.String caption, System.Windows.Forms.MessageBoxButtons buttons, System.Windows.Forms.MessageBoxIcon icon) [0x00000] in <4bdc919193224fdbac7328002815594b>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.MessageBox+MessageBoxForm..ctor(System.Windows.Forms.IWin32Window,string,string,System.Windows.Forms.MessageBoxButtons,System.Windows.Forms.MessageBoxIcon)
  at System.Windows.Forms.MessageBox.Show (System.String text, System.String caption, System.Windows.Forms.MessageBoxButtons buttons, System.Windows.Forms.MessageBoxIcon icon) [0x00000] in <4bdc919193224fdbac7328002815594b>:0
  at Eddie.Forms.Linux.Program.Main () [0x000a1] in <0d50fadb7f914fdb936f52ea72c12dc8>:0
And as a last resort, i tried the appimage out:
(eddie-ui:33726): Gtk-WARNING **: 13:42:09.989: Im Modulpfad »adwaita« konnte keine Themen-Engine gefunden werden,
F 2023.05.31 13:42:10 - Cannot initialize UI. Probably a DISPLAY issue, ensure your are not running as root. Error:A null reference or invalid value was found [GDI+ status: InvalidParameter]
So, on all 3 Machines it is impossible to use the GUI.
After that, i wanted to give eddie-ui -cli a chance. That works so far. But i  dont find a documentation, help page, or anything else how to use wireguard or to set up a port for forwarding.
After a long search, i found several sites from airvpn.org, that i should give the documentation  on https://eddie.website/ a look. so far so good.
So i visited https://eddie.website/support/cli/ wich says, i should:
"DESCRIPTION
Eddie is an OpenVPN wrapper providing advanced features such as network lock, connections over SSL/TLS and SSH tunnels, programmable events, customizable routes, extensive control on OpenVPN directives and a comfortable, optional GUI. For more information: https://eddie.website"
so, eddie.website says i should visit eddie.website for more information, wich says i s hould visit eddie.website for more information and so on... endless loophole.
After hours of fideling and frustration... i hope i get help here.
If we're not mistaken a moderator of this community forum @OpenSourcerer uses routinely Arch, so he might help you effectively when he reads this message. Otherwise please do not hesitate to open a ticket.
Just a preliminary question before anything else: are you sure that you run Eddie without root privileges? This is mandatory, because if you run Eddie with root privileges, chances are that root does not have any display in X, any call to open windows etc. in your Desktop Environment will fail, and you will get the error message we see  in your report. If you already launched Eddie as a normal user and the problem remains the same, can you please test the AppImage as well? You can find it here: https://airvpn.org/linux/eddie/
Eddie's documentation is organized in a FAQ-style, scroll down the home page of https://eddie.website to see it.
From a terminal, type "man eddie-ui" to see the man pages (only Linux systems).
AirVPN Suite user's manual is available here: https://airvpn.org/suite/readme/
Quote
yes.
Quote
i have. see my original post:
$ man eddie-ui
Kein Handbucheintrag für eddie-ui vorhanden
On both not a single word about wireguard.
WireGuard is not supported by the AirVPN Suite. Is the problem related to WireGuard too? Instructions to run WireGuard in Linux without Eddie (or any other AirVPN software) is available here:
https://airvpn.org/linux/wireguard/terminal/
About Eddie, you can find the option to switch to WireGuard in the man (--mode-type) while you can select connection mode via GUI in the "Preferences" > "Protocols" window.
21 hours ago, justsomerandom10 said:
$ man eddie-ui
WireGuard is mentioned in the man pages, however, the problem here seems that Eddie has not been installed, as the man is not available. In the meantime we tested on an Arch machine and we had no problems at all, Eddie runs just fine, so a deeper investigation is needed. Open a ticket at your convenience. An explanation which comes to mind is that you're running man with a user whose PATH does not include the path to the man pages and you're running Eddie with a user that  doesn't have a DISPLAY set.
All other man pages works just fine (like man cp, man rm, man whatever).
All other GUI programs like Firefox, Dolphin, Mullvad or whatever runs just fine (started from application menu or konsole).
Only eddie makes this problems.
For now, i downloaded a config file for wireguard from the dashboard like you mentioned. This works.
You already mentioned serveral times, i should create a ticket. where i do that?
Understood. In this case, maybe Eddie is not installed properly. We performed additional tests on our Arch testing machine and we couldn't reproduce the problem unfortunately. Eddie starts fine and the man is available. Eddie stores the man in /usr/share/man/man8 correctly.
To open a ticket you may either click "Contact us" button (top right corner), while your account is logged in to the web site, or write an e-mail to support@airvpn.org
My first question will always be: Is it Arch, or a derivative?
$ lsb_release -a
Which AUR helper did you use to install eddie-ui, if any?
All the things posted really point at eddie-ui not being properly installed. Not sure how that can happen with makepkg being used. Try it manually.
$ git clone -q https://aur.archlinux.org/eddie-ui.git
$ cd eddie-ui
$ makepkg -fsicC --noconfirm
