Not connected, Your IP: 3.147.103.33
Hi, I've used Air VPN for years with no problems but I've just changed ISP to TalkTalk in the UK and now I have major problems connecting or it will connect with no routing.
I keep getting the following errors in logs:
. 2022.06.17 12:04:07 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #6605 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.06.17 12:04:07 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #6606 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.06.17 12:04:08 - OpenVPN > AEAD Decrypt error: cipher final failed
. 2022.06.17 12:04:08 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #10166 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.06.17 12:04:08 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #10167 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.06.17 12:04:08 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #10168 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.06.17 12:04:19 - Above log line repeated 291 times more
. 2022.06.17 12:04:19 - OpenVPN > AEAD Decrypt error: cipher final failed
. 2022.06.17 12:04:19 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #85653 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.06.17 12:04:19 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #85656 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.06.17 12:04:19 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #85657 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.06.17 12:05:22 - Above log line repeated 1037 times more
. 2022.06.17 12:05:22 - OpenVPN > AEAD Decrypt error: cipher final failed
. 2022.06.17 12:05:22 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #225061 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.06.17 12:05:22 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #225066 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.06.17 12:05:22 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #225075 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Edited ... by djrich
spelling mistake
Blatantly looks like they don't particularly like OpenVPN traffic. Try connecting using OpenVPN over SSL or SSH (with Eddie).
Hi thanks for the reply, I tried that and I'm now getting a different issue, every few minutes it disconnects:
! 2022.06.21 18:43:02 - Connected.
. 2022.06.21 18:52:28 - SSH > Incorrect MAC received on packet
. 2022.06.21 18:52:28 - OpenVPN > Connection reset, restarting [0]
. 2022.06.21 18:52:28 - SSH > FATAL ERROR: Incorrect MAC received on packet
. 2022.06.21 18:52:28 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2022.06.21 18:52:28 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.21 18:52:28 - Disconnecting
. 2022.06.21 18:52:28 - Sending soft termination signal
It's ok I've sorted it out, can somebody please delete this thread.
Thanks.
Thanks.
It would be great if you could publish the solution for the benefit of the readers.
We don't do that here, this exists for future reference now.
Enjoy :)
