Not connected, Your IP: 216.73.217.178
Salutglouglou
ANSWERED Eddie stopped working (Raise system privileges & more)
Windows 10 user here.   AirVPN/Eddie was working great for me for months.  Now all of a sudden Eddie was freezing up at startup with a Raise System Privileges message.  Tried many things (turn off windows firewall and such things).  Nothing worked so I decided to uninstall and reinstall the currently latest and greatest Eddie 2.21.6.  Now I see the startup sequence gets pass the Raise System Privileges step, but Eddie doesn't really start.  I only see a Eddie-UI process in my Windows Backgroup Processes.  No window, no message, nothing.  If I try to start it again it complains another instance is already running.  If I kill the background process and start again I just end-up with another background process.  And yes, I have rebooted multiple times.
From your description it looks like Eddie starts minimized. Check the system tray (click the up arrow to see hidden icons) for Eddie's tray icon, a small cloud in a circle. Double-click on it to bring up Eddie main window.
I don't recall if I had that specific issue, but I did have the issue with the system privs on startup. At the time, I reverted to an older version.
However, 2.21.7 released on the experimental branch not too long ago, and I've been running that one just fine. Maybe give that a shot?
Just thought I'd come back here to confirm my final problem was indeed Eddie starting minimized.
For anybody else reading this, here's a summary.
First, After working fine for months, all of sudden Eddie was freezing at startup with a Raise System Priviledges message.  I still don't know why that was.
Then I updated to the latest Eddie 2.21.6 and I was getting passed the Raise System Privileges but I was not seeing the Eddie Window because it was starting minimized.
I Installed OpenVPN and I was able to access the VPN.
Just a note to other people with the minimized problem, in my case the Eddie icon is the only Icon without a proper name, the mouse-over just says "Ready"
Thanks to Staff for the reply.
