Staff
Bluetit: Developer's Reference Manual
We're very glad to inform you that we have just published the Developer's Reference Manual for Bluetit by promind.
Bluetit, a core component of the AirVPN-SUITE, is a lightweight D-Bus controlled system daemon providing VPN connectivity through OpenVPN 3 AirVPN. Bluetit exposes a D-Bus interface which can be used by client applications in order to control the daemon and provide full interaction and connectivity with the whole AirVPN infrastructure.
The manual covers Bluetit infrastructure and architecture and provides a complete reference for all the AirVPN’s classes on which the suite is based. The goal is to give any developer who wishes to write a Bluetit client, or a tool providing AirVPN inter-connectivity, a complete reference about the internals of both Bluetit daemon and the AirVPN–SUITE C++ classes.
The tool to swiftly interact with the AirVPN infrastructure, repeatedly required by multiple AirVPN client developers in the past, is available and fully documented now.
The document is a significant step forward in the VPN market and a further AirVPN's commitment to transparency and openness..The availability of a Developer's Reference Manual allows, in fact, any user or developer to successfully and proficiently build an AirVPN client to best suit her or his own needs.
Should you decide to have a paper copy of the document, please consider that it is typeset for double side printing.
Bluetit Developer's Reference Manual has been written and typeset in the unrivaled (ça va sans dire) LaTeX 2ε and it is released under CC BY-NC-SA 4.0 International
You can download the manual here:
https://gitlab.com/AirVPN/AirVPN-Suite/-/blob/master/docs/Bluetit-Developers-Reference-Manual.pdf
directly from this message:
or in the AirVPN Suite for Linux download section.
Kind regards & datalove
AirVPN Staff
