mith_y2k 6 Posted ... DISCLAIMER: this is probably user error ☺️ I installed Hummingbird 1.0.2 on a Pi and I generated a simple ovpn simply grabbing all servers in America. Hummingbird works fine and connects to a server using: pi@raspberrypi:/etc/init.d $ sudo /usr/bin/hummingbird /etc/airvpn/ovpn/AirVPN_America_UDP-443.ovpn When I try to force using ChaCha it still connects successfully, but not using ChaCha. I have tried both the extended command and the short one, i.e.: pi@raspberrypi:/etc/init.d $ sudo /usr/bin/hummingbird -C CHACHA20-POLY1305 /etc/airvpn/ovpn/AirVPN_America_UDP-443.ovpn I also thought maybe I had to generate a new OVPN file specific for ChaCha servers, but I did not find a filter in the Client Area. Any suggestions? Quote Share this post Link to post
eburom 16 Posted ... Hi, When you chose a "global" config file such as America what you get is a normal config file with a special URL in the server section. This URL will automatically resolve to the recommended server in this region. I don't think this resolution takes in to account you desire to use chacha20 and there are still very few servers that support it. My recommendation is that you try generating a config file for a specific server that supports chacha20 to check if this works. and use it when you specifically need it. Quote Share this post Link to post
Staff 10411 Posted ... @mith_y2k Hello! On top of what @eburom correctly pointed out, please take care to add option --ncp-disable, otherwise the server will enforce its chosen cipher through ncp, i.e. AES-256-GCM. In the USA, we support CHACHA20-POLY1305 in a Dallas server, Chamaeleon, so you will need to generate a specific configuration for that server. In the web site servers monitor https://airvpn.org/status you can find (in yellow) all the servers running OpenVPN 2.5 and supporting CHACHA20-POLY1305 on the Data Channel. Kind regards Quote Share this post Link to post
