Staff 10708 Posted ... Hello! We're glad to inform you that Hummingbird 1.0.3 has just been released. Hummingbird is a free and open source software by AirVPN for: Linux x86-64 Linux ARM 32 (example: Raspbian for Raspberry Pi) Linux ARM 64 macOS (Mojave or higher version required) - please do not miss important notes on macOS below based on OpenVPN3-AirVPN 3.6.4 library supporting CHACHA20-POLY1305 cipher on OpenVPN Data Channel and Control Channel. Hummingbird is very fast and has a tiny RAM footprint. AES-CBC and AES-GCM are supported as well. Version 1.0.3 uses OpenVPN3-AirVPN 3.6.4 library which had major modifications: IPv6 compatibility has been improved override logic has been improved a critical bug related to a main branch regression for TCP connections has been fixed Important: if you build Hummingbird please make sure to align to AirVPN library 3.6.4. You can't build Hummigbird 1.0.3 with library versions older than 3.6.4.Hummingbird is not aimed to Android but you can have CHACHA20-POLY1305 on Android too: please run our software Eddie Android edition, which uses our OpenVPN3-AirVPN library. Important notes for macOS users From now on we provide both a notarized version and a non-notarized version of Hummingbird for macOS. The notarized version is available essentially for those users who required it, but it is not recommended. The notarized version will run without blocks by Apple's Gatekeeper, but will let Apple correlate your real IP address, Apple ID and other data potentially disclosing your identity to the fact that you run, and when you did it for the first time, an application by AirVPN. If that's not acceptable for you, just download the tarball package .tar.gz (it is NOT notarized and NOT signed with our Apple developer ID on purpose) and include it in the exceptions to run non-notarized programs. In the future that could be no more allowed, but at the moment it is. For a more thorough explanations on important privacy issues caused by Apple and notarization please see for example here https://lapcatsoftware.com/articles/notarization-privacy.html and here https://lapcatsoftware.com/articles/catalina-executables.html Notes for Linux users x86-64 version requires a reasonably recent distribution (at least on par with Debian 9 kernel and libraries) based on systemd. A version compatible with SysVInit is anyway planned armv7l version (32 bit) has been tested in Raspberry Pi 3 and 4 with Raspbian 10. It will not run in Raspbian 9 (libraries are too old) aarch64 version (for 64 bit ARM) has been tested in Raspberry Pi4 with Ubuntu 19 and Ubuntu 20 for ARM 64 bit TCP queue limit If you connect over TCP, Hummingbird will set by default a minimum TCP outgoing queue size of 512 packets to avoid TCP_OVERFLOW errors. If you need a larger queue in TCP, the following option is now available from command line, in addition to profile directive tcp-queue-limit: --tcp-queue-limit n where n is the amount of packets. Legal range is 1-65535.We strongly recommend you to allow at least 512 packets as queue limit (default value). Larger queues are necessary when you connect in TCP and need a lot of open connections with sustained (continuous) but not necessarily high throughput, for example if you run a BitTorrent software. In such cases you can enlarge the queue as much as you need, until you stop getting TCP_OVERFLOW. It's not uncommon from our community as well as our internal tests to set 4000 packets queue limit to prevent any TCP overflow. If you connect over UDP, you can ignore all of the above. Network Lock Network Lock prevents traffic leaks outside the VPN tunnel through firewall rules. Hummingbird 1.0.3 widens --network-lock option arguments. The following arguments are now accepted:on | off | iptables | nftables | pf (default: on). If you specify on argument, or you omit --network-lock option, Hummingbird will automatically detect and use the infrastructure available on your system. Hummingbird picks the first available infrastructure between iptables-legacy, iptables, nftables and pf. Note: command line options, when specified, override profile directives, when options and profile directives have the same purpose. Binaries download URLhttps://gitlab.com/AirVPN/hummingbird/-/tree/master/binaryComplete instructionshttps://airvpn.org/hummingbird/readme/ Hummingbird source codehttps://gitlab.com/AirVPN/hummingbird OpenVPN3-AirVPN library source codehttps://github.com/AirVPN/openvpn3-airvpn OpenVPN3-AirVPN library Changelog Changelog 3.6.4 AirVPN - Release date: 23 May 2020 by ProMIND - [ProMIND] [2020/05/23] completely changed the logics controlling overrides (server, port and protocol) client/ovpncli.cpp: parse_config() Properly assigned serverOverride, portOverride and protoOverride to eval.remoteList client/ovpncli.cpp: parse_config() In case serverOverride is set, remoteList is cleared and recreated with just one item containing serverOverride client/ovpncli.cpp: parse_config() In case portOverride or protoOverride is set, all the items in remoteList are changed accordingly openvpn/client/remotelist.hpp: Added public method set_transport_protocol_override() to assign the override protocol to all items in remoteList openvpn/client/cliopt.hpp: ClientOptions() now calls remote_list->set_transport_protocol_override() instead of remote_list->handle_proto_override() Hummingbird Changelog Changelog 1.0.3 - 3 June 2020 - [ProMIND] Removed --google-dns (enable Google DNS fallback) option - [ProMIND] Improved flushing logics for pf - [ProMIND] Updated to OpenVPN3-airvpn 3.6.4 *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* Changelog 1.0.2 - 4 February 2020 - [ProMIND] Updated to OpenVPN3-AirVPN 3.6.3 - [ProMIND] Added --tcp-queue-limit option - [ProMIND] --network-lock option now accepts firewall type and forces hummingbird to use a specific firewall infrastructure *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* Changelog 1.0.1 - 24 January 2020 - [ProMIND] Updated to OpenVPN3-AirVPN 3.6.2 *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* Changelog 1.0 - 27 December 2019 - [ProMIND] Production release *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* Changelog 1.0 RC2 - 19 December 2019 - [ProMIND] Better management of Linux NetworkManager and systemd-resolved in case they are both running - [ProMIND] Log a warning in case Linux NetworkManager and/or systemd-resolved are running *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* Changelog 1.0 RC1 - 10 December 2019 - [ProMIND] Updated asio dependency *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* Changelog 1.0 beta 2 - 6 December 2019 - [ProMIND] Updated to OpenVPN 3.6.1 AirVPN - [ProMIND] macOS now uses OpenVPN's Tunnel Builder - [ProMIND] Added --ignore-dns-push option for macOS - [ProMIND] Added --recover-network option for macOS *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* Changelog 1.0 beta 1 - 28 November 2019 - [ProMIND] Added a better description for ipv6 option in help page - [ProMIND] --recover-network option now warns the user in case the program has properly exited in its last run - [ProMIND] NetFilter class is now aware of both iptables and iptables-legacy and gives priority to the latter *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* Changelog 1.0 alpha 2 - 7 November 2019 - [ProMIND] DNS resolver has now a better management of IPv6 domains - [ProMIND] DNS resolver has now a better management of multi IP domains - [ProMIND] Minor bug fixes *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* Changelog 1.0 alpha 1 - 1 November 2019 - [ProMIND] Initial public release Kind regards & datalove AirVPN Staff 1 2 eburom, colorman and nexsteppe reacted to this Quote Share this post Link to post
colorman 32 Posted ... installed ..... thanks for the new version. 1 Staff reacted to this Quote Share this post Link to post
eburom 16 Posted ... Up and running! Also both things reported for the previous version seem to work fine! Thanks a lot. 1 Staff reacted to this Quote Share this post Link to post
eburom 16 Posted ... Hello, I have just had a weird behavior while connected with hummingbird. I have 2 devices connected at the moment and I was working in one of them doing some tests on a script I'm working on using AirVPN's userinfo API. The thing is that suddenly the script was showing a single session and the one missing was the one of the computer I was using. My connection however was working fine through the VPN (ipleak also detected it fine). but the API didn't seem to recognize it. The hummingbird logs showed some ERROR messages while the anomaly was happening and after a while everything came back to normal. Here are the logs: Hummingbird - AirVPN OpenVPN 3 Client 1.0.3 - 3 June 2020 Sat Jun 6 19:59:19.503 2020 Starting thread Sat Jun 6 19:59:19.503 2020 OpenVPN core 3.6.4 AirVPN linux x86_64 64-bit Sat Jun 6 19:59:19.503 2020 Frame=512/2048/512 mssfix-ctrl=1250 Sat Jun 6 19:59:19.503 2020 UNUSED OPTIONS 3 [resolv-retry] [infinite] 4 [nobind] 5 [persist-key] 6 [persist-tun] 7 [auth-nocache] 8 [route-delay] [5] 9 [verb] [3] 10 [explicit-exit-notify] [5] Sat Jun 6 19:59:19.503 2020 EVENT: RESOLVE Sat Jun 6 19:59:19.503 2020 Network filter and lock is using iptables-legacy Sat Jun 6 19:59:19.510 2020 Successfully loaded kernel module iptable_filter Sat Jun 6 19:59:19.527 2020 Successfully loaded kernel module iptable_nat Sat Jun 6 19:59:19.532 2020 Successfully loaded kernel module iptable_mangle Sat Jun 6 19:59:19.538 2020 Successfully loaded kernel module iptable_security Sat Jun 6 19:59:19.542 2020 Successfully loaded kernel module iptable_raw Sat Jun 6 19:59:19.548 2020 Successfully loaded kernel module ip6table_filter Sat Jun 6 19:59:19.564 2020 Successfully loaded kernel module ip6table_nat Sat Jun 6 19:59:19.569 2020 Successfully loaded kernel module ip6table_mangle Sat Jun 6 19:59:19.575 2020 Successfully loaded kernel module ip6table_security Sat Jun 6 19:59:19.580 2020 Successfully loaded kernel module ip6table_raw Sat Jun 6 19:59:19.584 2020 Network filter successfully initialized Sat Jun 6 19:59:19.584 2020 Local IPv4 address 192.168.1.7 Sat Jun 6 19:59:19.584 2020 Local interface enp62s0u1u2 Sat Jun 6 19:59:19.584 2020 Local interface wlp2s0 Sat Jun 6 19:59:19.584 2020 Setting up network filter and lock Sat Jun 6 19:59:19.584 2020 Allowing system DNS 127.0.0.1 to pass through the network filter Sat Jun 6 19:59:19.584 2020 Adding IPv4 server 185.183.106.2 to network filter Sat Jun 6 19:59:19.600 2020 Network filter and lock successfully activated Sat Jun 6 19:59:19.600 2020 Contacting 185.183.106.2:443 via UDP Sat Jun 6 19:59:19.600 2020 EVENT: WAIT Sat Jun 6 19:59:19.600 2020 net_route_best_gw query IPv4: 185.183.106.2/32 Sat Jun 6 19:59:19.600 2020 sitnl_route_best_gw result: via 192.168.1.1 dev enp62s0u1u2 Sat Jun 6 19:59:19.600 2020 net_route_add: 185.183.106.2/32 via 192.168.1.1 dev enp62s0u1u2 table 0 metric 0 Sat Jun 6 19:59:19.600 2020 Sat Jun 6 19:59:19.600 2020 Connecting to [185.183.106.2]:443 (185.183.106.2) via UDPv4 Sat Jun 6 19:59:19.615 2020 EVENT: CONNECTING Sat Jun 6 19:59:19.615 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sat Jun 6 19:59:19.616 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=linux IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.0.3 IV_SSL=mbed TLS 2.16.6 Sat Jun 6 19:59:19.672 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sat Jun 6 19:59:19.673 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 23 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Eridanus, emailAddress=info@airvpn.org issued on : 2016-12-02 16:47:15 expires on : 2026-11-30 16:47:15 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sat Jun 6 19:59:19.895 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sat Jun 6 19:59:19.895 2020 Session is ACTIVE Sat Jun 6 19:59:19.895 2020 EVENT: GET_CONFIG Sat Jun 6 19:59:19.895 2020 Sending PUSH_REQUEST to server... Sat Jun 6 19:59:20.057 2020 OPTIONS: 0 [comp-lzo] [no] 1 [redirect-gateway] [ipv6] [def1] [bypass-dhcp] 2 [dhcp-option] [DNS] [10.16.156.1] 3 [dhcp-option] [DNS6] [fde6:7a:7d20:c9c::1] 4 [tun-ipv6] 5 [route-gateway] [10.16.156.1] 6 [topology] [subnet] 7 [ping] [10] 8 [ping-restart] [60] 9 [ifconfig-ipv6] [fde6:7a:7d20:c9c::107c/64] [fde6:7a:7d20:c9c::1] 10 [ifconfig] [10.16.156.126] [255.255.255.0] 11 [peer-id] [1] 12 [cipher] [AES-256-GCM] Sat Jun 6 19:59:20.057 2020 PROTOCOL OPTIONS: cipher: AES-256-GCM digest: NONE ncp enabled: yes compress: LZO_STUB peer ID: 1 Sat Jun 6 19:59:20.057 2020 EVENT: ASSIGN_IP Sat Jun 6 19:59:20.057 2020 VPN Server has pushed IPv4 DNS server 10.16.156.1 Sat Jun 6 19:59:20.058 2020 Setting pushed IPv4 DNS server 10.16.156.1 in resolv.conf Sat Jun 6 19:59:20.058 2020 VPN Server has pushed IPv6 DNS server fde6:7a:7d20:c9c::1 Sat Jun 6 19:59:20.059 2020 Setting pushed IPv6 DNS server fde6:7a:7d20:c9c::1 in resolv.conf Sat Jun 6 19:59:20.060 2020 net_iface_mtu_set: mtu 1500 for tun0 Sat Jun 6 19:59:20.060 2020 net_iface_up: set tun0 up Sat Jun 6 19:59:20.060 2020 net_addr_add: 10.16.156.126/24 brd 10.16.156.255 dev tun0 Sat Jun 6 19:59:20.060 2020 net_addr_add: fde6:7a:7d20:c9c::107c/64 dev tun0 Sat Jun 6 19:59:20.060 2020 net_route_add: 0.0.0.0/1 via 10.16.156.1 dev tun0 table 0 metric 0 Sat Jun 6 19:59:20.060 2020 net_route_add: 128.0.0.0/1 via 10.16.156.1 dev tun0 table 0 metric 0 Sat Jun 6 19:59:20.061 2020 net_route_add: ::/1 via fde6:7a:7d20:c9c::1 dev tun0 table 0 metric 0 Sat Jun 6 19:59:20.061 2020 net_route_add: 8000::/1 via fde6:7a:7d20:c9c::1 dev tun0 table 0 metric 0 Sat Jun 6 19:59:20.061 2020 Connected via tun Sat Jun 6 19:59:20.061 2020 LZO-ASYM init swap=0 asym=1 Sat Jun 6 19:59:20.061 2020 Comp-stub init swap=0 Sat Jun 6 19:59:20.061 2020 EVENT: CONNECTED 185.183.106.2:443 (185.183.106.2) via /UDPv4 on tun/10.16.156.126/fde6:7a:7d20:c9c::107c gw=[10.16.156.1/fde6:7a:7d20:c9c::1] Sat Jun 6 19:59:20.061 2020 Server has pushed its own DNS. Removing system DNS from network filter. Sat Jun 6 19:59:20.062 2020 System DNS 127.0.0.1 is now rejected by the network filter Sat Jun 6 20:59:19.168 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sat Jun 6 20:59:19.169 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=linux IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.0.3 IV_SSL=mbed TLS 2.16.6 Sat Jun 6 20:59:19.227 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sat Jun 6 20:59:19.227 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 23 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Eridanus, emailAddress=info@airvpn.org issued on : 2016-12-02 16:47:15 expires on : 2026-11-30 16:47:15 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sat Jun 6 20:59:19.397 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sat Jun 6 20:59:19.397 2020 LZO-ASYM init swap=0 asym=1 Sat Jun 6 20:59:19.397 2020 Comp-stub init swap=0 Sat Jun 6 21:59:19.182 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sat Jun 6 21:59:19.182 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=linux IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.0.3 IV_SSL=mbed TLS 2.16.6 Sat Jun 6 21:59:19.233 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sat Jun 6 21:59:19.233 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 23 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Eridanus, emailAddress=info@airvpn.org issued on : 2016-12-02 16:47:15 expires on : 2026-11-30 16:47:15 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sat Jun 6 21:59:19.400 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sat Jun 6 21:59:19.400 2020 LZO-ASYM init swap=0 asym=1 Sat Jun 6 21:59:19.400 2020 Comp-stub init swap=0 Sat Jun 6 22:59:19.183 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sat Jun 6 22:59:19.183 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=linux IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.0.3 IV_SSL=mbed TLS 2.16.6 Sat Jun 6 22:59:19.236 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sat Jun 6 22:59:19.236 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 23 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Eridanus, emailAddress=info@airvpn.org issued on : 2016-12-02 16:47:15 expires on : 2026-11-30 16:47:15 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sat Jun 6 22:59:19.441 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sat Jun 6 22:59:19.441 2020 LZO-ASYM init swap=0 asym=1 Sat Jun 6 22:59:19.441 2020 Comp-stub init swap=0 Sat Jun 6 23:59:19.034 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sat Jun 6 23:59:19.034 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=linux IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.0.3 IV_SSL=mbed TLS 2.16.6 Sat Jun 6 23:59:19.091 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sat Jun 6 23:59:19.091 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 23 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Eridanus, emailAddress=info@airvpn.org issued on : 2016-12-02 16:47:15 expires on : 2026-11-30 16:47:15 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sat Jun 6 23:59:19.244 2020 ERROR: KEY_STATE_ERROR Sat Jun 6 23:59:19.280 2020 ERROR: KEY_STATE_ERROR Sat Jun 6 23:59:19.280 2020 ERROR: KEY_STATE_ERROR Sat Jun 6 23:59:21.244 2020 ERROR: KEY_STATE_ERROR Sat Jun 6 23:59:24.960 2020 ERROR: KEY_STATE_ERROR Sat Jun 6 23:59:33.020 2020 ERROR: KEY_STATE_ERROR Sat Jun 6 23:59:49.068 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:00:19.230 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:00:19.230 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:00:34.080 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:00:35.994 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:00:40.111 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:00:48.019 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:01:04.077 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:01:19.230 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:01:19.230 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:01:48.954 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:01:50.955 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:01:55.248 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:02:02.954 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:02:18.955 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:02:19.231 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:02:19.231 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:03:04.113 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:03:05.954 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:03:10.013 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:03:17.983 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:03:19.231 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:03:19.231 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:03:34.119 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:04:19.230 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:04:19.230 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:04:19.244 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:04:21.124 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:04:25.116 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:04:33.091 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:04:49.131 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:05:19.230 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:05:19.230 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:05:34.139 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:05:36.030 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:05:40.069 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:05:48.060 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:06:04.247 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:06:19.231 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:06:19.231 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:06:48.953 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:06:51.127 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:06:54.956 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:07:02.957 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:07:18.953 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:07:19.230 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:07:19.231 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:08:03.955 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:08:05.954 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:08:09.953 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:08:17.959 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:08:19.231 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:08:19.231 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:08:33.965 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:09:19.231 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:09:19.231 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:09:19.244 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:09:21.027 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:09:25.244 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:09:33.246 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:09:49.157 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:10:19.231 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:10:19.231 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:10:33.975 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:10:36.248 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:10:39.987 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:10:47.953 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:11:03.953 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:11:19.231 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:11:19.231 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:11:48.956 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:11:50.954 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:11:54.954 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:12:02.953 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:12:18.955 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:12:19.232 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:12:19.232 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:13:04.133 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:13:06.252 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:13:10.235 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:13:18.253 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:13:19.233 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:13:19.233 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:13:33.960 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:14:19.081 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:14:19.232 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:14:19.232 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:14:20.955 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:14:25.246 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:14:33.197 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:14:49.326 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:15:19.232 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:15:19.232 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:15:34.247 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:15:36.247 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:15:40.059 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:15:48.030 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:16:04.249 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:16:19.232 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:16:19.232 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:16:49.031 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:16:51.117 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:16:55.249 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:17:03.250 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:17:18.964 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:17:19.233 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:17:19.233 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:18:04.249 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:18:06.081 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:18:10.198 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:18:18.015 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:18:19.233 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:18:19.233 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:18:34.249 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:19:18.974 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:19:19.233 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:19:19.233 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:19:21.058 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:19:25.012 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:19:33.041 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:19:48.962 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:20:19.234 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:20:19.234 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:20:34.010 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:20:36.162 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:20:40.250 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:20:48.228 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:21:04.199 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:21:19.234 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:21:19.234 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:21:49.037 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:21:50.981 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:21:54.971 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:22:02.981 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:22:18.962 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:22:19.235 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:22:19.235 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:23:04.254 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:23:05.982 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:23:10.246 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:23:18.056 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:23:19.235 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:23:19.235 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:23:34.109 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:24:19.120 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:24:19.235 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:24:19.235 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:24:21.249 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:24:25.017 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:24:33.060 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:24:49.042 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:25:19.235 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:25:19.235 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:25:34.202 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:25:36.193 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:25:40.104 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:25:48.160 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:26:03.969 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:26:19.235 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:26:19.235 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:26:49.014 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:26:51.001 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:26:54.961 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:27:02.971 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:27:18.952 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:27:19.235 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:27:19.235 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:28:03.994 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:28:06.128 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:28:10.025 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:28:18.037 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:28:19.235 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:28:19.235 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:28:33.962 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:29:19.138 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:29:19.235 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:29:19.236 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:29:21.154 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:29:25.250 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:29:33.098 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:29:48.991 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:30:19.236 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:30:19.236 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:30:33.984 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:30:35.985 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:30:40.079 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:30:48.009 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:31:04.121 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:31:19.237 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:31:19.237 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:31:49.255 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:31:51.255 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:31:55.014 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:32:03.225 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:32:19.006 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:32:19.237 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:32:19.237 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:33:04.020 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:33:06.150 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:33:10.021 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:33:18.012 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:33:19.238 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:33:19.238 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:33:34.021 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:34:18.974 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:34:19.238 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:34:19.238 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:34:21.026 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:34:25.022 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:34:33.032 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:34:49.242 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:35:19.238 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:35:19.238 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:35:34.043 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:35:36.044 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:35:40.049 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:35:48.255 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:36:04.049 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:36:19.238 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:36:19.238 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:36:49.244 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:36:51.062 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:36:54.995 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:37:03.024 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:37:19.007 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:37:19.239 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:37:19.239 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:38:04.257 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:38:06.079 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:38:10.080 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:38:18.145 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:38:19.239 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:38:19.239 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:38:34.080 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:39:18.958 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:39:19.238 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:39:19.238 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:39:21.022 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:39:24.990 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:39:33.016 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:39:49.149 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:40:19.239 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:40:19.239 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:40:33.948 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:40:35.955 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:40:39.985 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:40:47.958 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:41:03.948 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:41:19.239 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:41:19.239 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:41:49.052 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:41:50.966 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:41:54.989 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:42:03.009 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:42:18.973 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:42:19.238 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:42:19.239 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:43:03.970 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:43:05.952 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:43:09.966 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:43:17.949 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:43:19.239 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:43:19.239 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:43:33.984 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:44:18.970 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:44:19.239 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:44:19.239 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:44:20.973 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:44:24.990 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:44:32.985 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:44:48.950 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:45:19.238 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:45:19.238 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:45:34.160 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:45:35.967 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:45:39.949 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:45:47.984 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:46:04.011 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:46:19.239 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:46:19.239 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:46:48.948 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:46:51.185 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:46:54.949 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:47:03.221 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:47:18.966 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:47:19.239 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:47:19.239 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:48:03.978 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:48:05.948 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:48:09.951 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:48:17.949 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:48:19.239 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:48:19.239 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:48:33.995 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:49:18.984 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:49:19.240 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:49:19.240 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:49:20.947 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:49:24.948 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:49:32.974 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:49:49.069 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:50:19.240 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:50:19.240 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:50:33.963 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:50:35.961 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:50:39.948 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:50:47.966 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:51:03.947 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:51:19.241 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:51:19.241 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:51:48.948 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:51:50.948 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:51:54.991 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:52:03.037 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:52:19.020 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:52:19.241 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:52:19.241 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:53:03.987 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:53:06.025 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:53:09.949 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:53:18.011 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:53:19.241 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:53:19.241 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:53:34.134 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:54:18.951 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:54:19.241 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:54:19.241 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:54:21.014 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:54:25.006 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:54:33.105 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:54:49.258 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:55:19.241 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:55:19.241 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:55:33.963 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:55:36.257 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:55:40.113 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:55:48.224 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:56:04.258 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:56:19.241 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:56:19.241 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:56:49.191 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:56:51.257 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:56:55.092 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:57:02.948 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:57:18.991 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:57:19.242 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:57:19.242 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:58:04.041 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:58:05.946 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:58:10.126 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:58:17.955 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:58:19.242 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:58:19.242 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:58:33.957 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:59:19.061 2020 ERROR: KEY_STATE_ERROR Sun Jun 7 00:59:19.169 2020 ERROR: N_KEV_EXPIRE Sun Jun 7 00:59:19.169 2020 ERROR: N_KEV_EXPIRE Sun Jun 7 00:59:19.242 2020 ERROR: KEV_NEGOTIATE_ERROR Sun Jun 7 00:59:19.242 2020 ERROR: HANDSHAKE_TIMEOUT Sun Jun 7 00:59:19.242 2020 Session invalidated: KEV_NEGOTIATE_ERROR Sun Jun 7 00:59:19.242 2020 Client terminated, restarting in 2000 ms... Sun Jun 7 00:59:19.242 2020 net_route_del: 8000::/1 via fde6:7a:7d20:c9c::1 dev tun0 table 0 metric 0 Sun Jun 7 00:59:19.242 2020 net_route_del: ::/1 via fde6:7a:7d20:c9c::1 dev tun0 table 0 metric 0 Sun Jun 7 00:59:19.243 2020 net_route_del: 128.0.0.0/1 via 10.16.156.1 dev tun0 table 0 metric 0 Sun Jun 7 00:59:19.243 2020 net_route_del: 0.0.0.0/1 via 10.16.156.1 dev tun0 table 0 metric 0 Sun Jun 7 00:59:19.243 2020 net_addr_del: fde6:7a:7d20:c9c::107c/64 dev tun0 Sun Jun 7 00:59:19.243 2020 net_addr_del: 10.16.156.126/24 dev tun0 Sun Jun 7 00:59:19.243 2020 net_iface_mtu_set: mtu 1500 for tun0 Sun Jun 7 00:59:19.243 2020 net_iface_up: set tun0 down Sun Jun 7 00:59:19.244 2020 net_route_del: 185.183.106.2/32 via 192.168.1.1 dev enp62s0u1u2 table 0 metric 0 Sun Jun 7 00:59:19.244 2020 Sun Jun 7 00:59:21.240 2020 EVENT: RECONNECTING Sun Jun 7 00:59:21.241 2020 Successfully restored DNS settings Sun Jun 7 00:59:21.295 2020 Network filter successfully restored Sun Jun 7 00:59:21.295 2020 ERROR: N_RECONNECT Sun Jun 7 00:59:21.296 2020 EVENT: RESOLVE Sun Jun 7 00:59:21.296 2020 Network filter and lock is using iptables-legacy Sun Jun 7 00:59:21.313 2020 Successfully loaded kernel module iptable_filter Sun Jun 7 00:59:21.334 2020 Successfully loaded kernel module iptable_nat Sun Jun 7 00:59:21.340 2020 Successfully loaded kernel module iptable_mangle Sun Jun 7 00:59:21.345 2020 Successfully loaded kernel module iptable_security Sun Jun 7 00:59:21.351 2020 Successfully loaded kernel module iptable_raw Sun Jun 7 00:59:21.356 2020 Successfully loaded kernel module ip6table_filter Sun Jun 7 00:59:21.372 2020 Successfully loaded kernel module ip6table_nat Sun Jun 7 00:59:21.378 2020 Successfully loaded kernel module ip6table_mangle Sun Jun 7 00:59:21.383 2020 Successfully loaded kernel module ip6table_security Sun Jun 7 00:59:21.389 2020 Successfully loaded kernel module ip6table_raw Sun Jun 7 00:59:21.392 2020 Network filter successfully initialized Sun Jun 7 00:59:21.392 2020 Local IPv4 address 192.168.1.7 Sun Jun 7 00:59:21.392 2020 Local interface enp62s0u1u2 Sun Jun 7 00:59:21.392 2020 Local interface wlp2s0 Sun Jun 7 00:59:21.392 2020 Setting up network filter and lock Sun Jun 7 00:59:21.392 2020 Allowing system DNS 127.0.0.1 to pass through the network filter Sun Jun 7 00:59:21.392 2020 Adding IPv4 server 185.183.106.2 to network filter Sun Jun 7 00:59:21.411 2020 Network filter and lock successfully activated Sun Jun 7 00:59:21.411 2020 Contacting 185.183.106.2:443 via UDP Sun Jun 7 00:59:21.411 2020 EVENT: WAIT Sun Jun 7 00:59:21.411 2020 net_route_del: 185.183.106.2/32 via 192.168.1.1 dev enp62s0u1u2 table 0 metric 0 Sun Jun 7 00:59:21.411 2020 sitnl_send: rtnl: generic error: No such process (-3) Sun Jun 7 00:59:21.411 2020 net_route_best_gw query IPv4: 185.183.106.2/32 Sun Jun 7 00:59:21.411 2020 sitnl_route_best_gw result: via 192.168.1.1 dev enp62s0u1u2 Sun Jun 7 00:59:21.411 2020 net_route_add: 185.183.106.2/32 via 192.168.1.1 dev enp62s0u1u2 table 0 metric 0 Sun Jun 7 00:59:21.411 2020 Error while executing NetlinkRoute4(add: 0) enp62s0u1u2: -3 Sun Jun 7 00:59:21.411 2020 Connecting to [185.183.106.2]:443 (185.183.106.2) via UDPv4 Sun Jun 7 00:59:21.426 2020 EVENT: CONNECTING Sun Jun 7 00:59:21.426 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Jun 7 00:59:21.426 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=linux IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.0.3 IV_SSL=mbed TLS 2.16.6 Sun Jun 7 00:59:21.481 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Jun 7 00:59:21.481 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 23 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Eridanus, emailAddress=info@airvpn.org issued on : 2016-12-02 16:47:15 expires on : 2026-11-30 16:47:15 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Jun 7 00:59:21.692 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Jun 7 00:59:21.693 2020 Session is ACTIVE Sun Jun 7 00:59:21.693 2020 EVENT: GET_CONFIG Sun Jun 7 00:59:21.693 2020 Sending PUSH_REQUEST to server... Sun Jun 7 00:59:21.861 2020 OPTIONS: 0 [comp-lzo] [no] 1 [redirect-gateway] [ipv6] [def1] [bypass-dhcp] 2 [dhcp-option] [DNS] [10.16.156.1] 3 [dhcp-option] [DNS6] [fde6:7a:7d20:c9c::1] 4 [tun-ipv6] 5 [route-gateway] [10.16.156.1] 6 [topology] [subnet] 7 [ping] [10] 8 [ping-restart] [60] 9 [ifconfig-ipv6] [fde6:7a:7d20:c9c::1080/64] [fde6:7a:7d20:c9c::1] 10 [ifconfig] [10.16.156.130] [255.255.255.0] 11 [peer-id] [3] 12 [cipher] [AES-256-GCM] Sun Jun 7 00:59:21.861 2020 PROTOCOL OPTIONS: cipher: AES-256-GCM digest: NONE ncp enabled: yes compress: LZO_STUB peer ID: 3 Sun Jun 7 00:59:21.861 2020 EVENT: ASSIGN_IP Sun Jun 7 00:59:21.861 2020 VPN Server has pushed IPv4 DNS server 10.16.156.1 Sun Jun 7 00:59:21.865 2020 Setting pushed IPv4 DNS server 10.16.156.1 in resolv.conf Sun Jun 7 00:59:21.865 2020 VPN Server has pushed IPv6 DNS server fde6:7a:7d20:c9c::1 Sun Jun 7 00:59:21.868 2020 Setting pushed IPv6 DNS server fde6:7a:7d20:c9c::1 in resolv.conf Sun Jun 7 00:59:21.869 2020 net_iface_mtu_set: mtu 1500 for tun0 Sun Jun 7 00:59:21.869 2020 net_iface_up: set tun0 up Sun Jun 7 00:59:21.870 2020 net_addr_add: 10.16.156.130/24 brd 10.16.156.255 dev tun0 Sun Jun 7 00:59:21.870 2020 net_addr_add: fde6:7a:7d20:c9c::1080/64 dev tun0 Sun Jun 7 00:59:21.870 2020 net_route_add: 0.0.0.0/1 via 10.16.156.1 dev tun0 table 0 metric 0 Sun Jun 7 00:59:21.871 2020 net_route_add: 128.0.0.0/1 via 10.16.156.1 dev tun0 table 0 metric 0 Sun Jun 7 00:59:21.871 2020 net_route_add: ::/1 via fde6:7a:7d20:c9c::1 dev tun0 table 0 metric 0 Sun Jun 7 00:59:21.871 2020 net_route_add: 8000::/1 via fde6:7a:7d20:c9c::1 dev tun0 table 0 metric 0 Sun Jun 7 00:59:21.871 2020 Connected via tun Sun Jun 7 00:59:21.871 2020 LZO-ASYM init swap=0 asym=1 Sun Jun 7 00:59:21.871 2020 Comp-stub init swap=0 Sun Jun 7 00:59:21.871 2020 EVENT: CONNECTED 185.183.106.2:443 (185.183.106.2) via /UDPv4 on tun/10.16.156.130/fde6:7a:7d20:c9c::1080 gw=[10.16.156.1/fde6:7a:7d20:c9c::1] Sun Jun 7 00:59:21.871 2020 Server has pushed its own DNS. Removing system DNS from network filter. Sun Jun 7 00:59:21.876 2020 System DNS 127.0.0.1 is now rejected by the network filter Quote Share this post Link to post
baratapt 0 Posted ... Hi, I am running Hummingbird on my Raspberry Pi 2 (Raspbian Buster) and I am having somehow unexpected results. The Pi is connected by cable and without VPN I get around 10/11 MB/s the usual speed for this device. With the OpenVPN version I have installed (2.4.7) I see speeds around ~4/5 MB/s. I tried this version of Hummingbird and for my surprise the speed drops to a constant low of ~ 1MB/s. I've used the experimental servers where the CHACHA cypher is allowed, but I couldn't see an improvement quite the opposite. Does someone have some tips to improve this? Thanks in advance. Quote Share this post Link to post
nexsteppe 24 Posted ... This version of hummingbird is proving much more stable for me on my Linux x86-64 systems running Slackware, exhibiting (so far) none of the key negotiation errors that plagued my UDPv4 usage of earlier versions. Thanks for the good work. Once things have been straightened out with IPv6 connections I'll ditch OpenVPN2. Quote Share this post Link to post
Staff 10708 Posted ... @hawkflights Hello! Excellent. Can you please report IPv6 problems you still experience, at your convenience? Kind regards Quote Share this post Link to post
