GhastMaster
Hummingbird Running - Bandwidth High - Working?
Is bandwidth still capped at 100Mbit? I was running hummingbird and was uploading 125Mbit(Eddie never got this fast). This is the terminal output. I'm not sure if it was functioning. Internet browser showed correct IP address for airvpn.
Sorry, move to troubleshooting please?
sudo ./hummingbird 1.ovpn
Hummingbird - AirVPN OpenVPN 3 Client 1.0.2 - 4 February 2020
Sat Apr 11 11:00:57.988 2020 Starting thread
Sat Apr 11 11:00:57.988 2020 OpenVPN core 3.6.3 AirVPN linux x86_64 64-bit
Sat Apr 11 11:00:57.997 2020 Frame=512/2048/512 mssfix-ctrl=1250
Sat Apr 11 11:00:58.006 2020 UNUSED OPTIONS
3 [resolv-retry] [infinite]
4 [nobind]
5 [persist-key]
6 [persist-tun]
7 [auth-nocache]
8 [route-delay] [5]
9 [verb] [3]
10 [explicit-exit-notify] [5]
Sat Apr 11 11:00:58.007 2020 EVENT: RESOLVE
Sat Apr 11 11:00:58.007 2020 WARNING: NetworkManager is running on this system and may interfere with DNS management and cause DNS leaks
Sat Apr 11 11:00:58.007 2020 WARNING: systemd-resolved is running on this system and may interfere with DNS management and cause DNS leaks
Sat Apr 11 11:00:58.007 2020 Network filter and lock is using iptables
Sat Apr 11 11:00:58.015 2020 Successfully loaded kernel module iptable_filter
Sat Apr 11 11:00:58.036 2020 Successfully loaded kernel module iptable_nat
Sat Apr 11 11:00:58.043 2020 Successfully loaded kernel module iptable_mangle
Sat Apr 11 11:00:58.051 2020 Successfully loaded kernel module iptable_security
Sat Apr 11 11:00:58.059 2020 Successfully loaded kernel module iptable_raw
Sat Apr 11 11:00:58.068 2020 Successfully loaded kernel module ip6table_filter
Sat Apr 11 11:00:58.084 2020 Successfully loaded kernel module ip6table_nat
Sat Apr 11 11:00:58.092 2020 Successfully loaded kernel module ip6table_mangle
Sat Apr 11 11:00:58.100 2020 Successfully loaded kernel module ip6table_security
Sat Apr 11 11:00:58.107 2020 Successfully loaded kernel module ip6table_raw
Sat Apr 11 11:00:58.107 2020 WARNING: ufw is running on this system and may interfere with network filter and lock
Sat Apr 11 11:00:58.118 2020 Network filter successfully initialized
Sat Apr 11 11:00:58.118 2020 Local IPv4 address ***.***.***.***
Sat Apr 11 11:00:58.118 2020 Local IPv6 address ***::***:****:****:****
Sat Apr 11 11:00:58.118 2020 Local interface enp3s0
Sat Apr 11 11:00:58.118 2020 Setting up network filter and lock
Sat Apr 11 11:00:58.118 2020 Allowing system DNS 127.0.0.53 to pass through the network filter
Sat Apr 11 11:00:58.192 2020 Resolved server ca.vpn.airdns.org into IPv4 ***.***.**.***
Sat Apr 11 11:00:58.192 2020 Adding IPv4 server 104.254.90.*** to network filter
Sat Apr 11 11:00:58.234 2020 Network filter and lock successfully activated
Sat Apr 11 11:00:58.235 2020 Contacting ***.***.**.***:443 via UDP
Sat Apr 11 11:00:58.235 2020 EVENT: WAIT
Sat Apr 11 11:00:58.235 2020 net_route_best_gw query IPv4: ***.***.**.***/32
Sat Apr 11 11:00:58.235 2020 sitnl_route_best_gw result: via 192.***.*.* dev enp3s0
Sat Apr 11 11:00:58.235 2020 net_route_add: ***.***.**.***/32 via 192.***.*.* dev enp3s0 table 0 metric 0
Sat Apr 11 11:00:58.236 2020 Sat Apr 11 11:00:58.*** 2020 Connecting to [ca.vpn.airdns.org]:443 (***.***.**.***) via UDPv4
Sat Apr 11 11:00:58.253 2020 EVENT: CONNECTING
Sat Apr 11 11:00:58.253 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
Sat Apr 11 11:00:58.253 2020 Peer Info:
IV_VER=3.6.3 AirVPN
IV_PLAT=linux
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
UV_IPV6=yes
IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.0.2
IV_SSL=mbed TLS 2.16.3
Sat Apr 11 11:00:58.311 2020 VERIFY OK : depth=1
cert. version     : 3
serial number     : **:**:**:**:**:**:**:**
issuer name       : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
subject name      : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
issued  on        : 2014-04-11 10:15:45
expires on        : 2024-04-08 10:15:45
signed using      : RSA with SHA1
RSA key size      : 4096 bits
basic constraints : CA=true
Sat Apr 11 11:00:58.311 2020 VERIFY OK : depth=0
cert. version     : 3
serial number     : AC
subject name      : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chort, emailAddress=info@airvpn.org
issued  on        : 2016-12-28 14:04:29
expires on        : 2026-12-26 14:04:29
signed using      : RSA with SHA-512
basic constraints : CA=false
cert. type        : SSL Server
key usage         : Digital Signature, Key Encipherment
ext key usage     : TLS Web Server Authentication
Sat Apr 11 11:00:58.675 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Sat Apr 11 11:00:58.675 2020 Session is ACTIVE
Sat Apr 11 11:00:58.675 2020 EVENT: GET_CONFIG
Sat Apr 11 11:00:58.675 2020 Sending PUSH_REQUEST to server...
Sat Apr 11 11:00:59.031 2020 OPTIONS:
0 [comp-lzo] [no]
1 [redirect-gateway] [ipv6] [def1] [bypass-dhcp]
2 [dhcp-option] [DNS] [**.**.**.*]
3 [dhcp-option] [DNS6] [****:**:****:***::*]
4 [tun-ipv6]
5 [route-gateway] [**.**.**.*]
6 [topology] [subnet]
7 [ping] [10]
8 [ping-restart] [60]
9 [ifconfig-ipv6] [fde6:7a:****:***::****/64] [fde6:**:****:***::*]
10 [ifconfig] [**.**.**.**] [255.255.255.0]
11 [peer-id] [2]
12 [cipher] [AES-256-GCM]
Sat Apr 11 11:00:59.031 2020 PROTOCOL OPTIONS:
  cipher: AES-256-GCM
  digest: NONE
  ncp enabled: yes
  compress: LZO_STUB
  peer ID: 2
Sat Apr 11 11:00:59.031 2020 EVENT: ASSIGN_IP
Sat Apr 11 11:00:59.031 2020 VPN Server has pushed IPv4 DNS server 10.14.32.1
Sat Apr 11 11:00:59.034 2020 Setting pushed IPv4 DNS server **.**.**.* in resolv.conf
Sat Apr 11 11:00:59.034 2020 VPN Server has pushed IPv6 DNS server fde6:**:****:***::1
Sat Apr 11 11:00:59.036 2020 Setting pushed IPv6 DNS server ****:**:****:***::* in resolv.conf
Sat Apr 11 11:00:59.037 2020 net_iface_mtu_set: mtu 1500 for tun0
Sat Apr 11 11:00:59.037 2020 net_iface_up: set tun0 up
Sat Apr 11 11:00:59.038 2020 net_addr_add: **.**.**.**/24 brd **.**.**.*** dev tun0
Sat Apr 11 11:00:59.039 2020 net_addr_add: fde6:**:****:***::****/64 dev tun0
Sat Apr 11 11:00:59.039 2020 net_route_add: 0.0.0.0/1 via **.**.**.* dev tun0 table 0 metric 0
Sat Apr 11 11:00:59.040 2020 net_route_add: 128.0.0.0/1 via **.**.**.* dev tun0 table 0 metric 0
Sat Apr 11 11:00:59.040 2020 net_route_add: ::/1 via fde6:**:****:***::* dev tun0 table 0 metric 0
Sat Apr 11 11:00:59.040 2020 net_route_add: 8000::/1 via fde6:**:****:***::* dev tun0 table 0 metric 0
Sat Apr 11 11:00:59.041 2020 Connected via tun
Sat Apr 11 11:00:59.041 2020 LZO-ASYM init swap=0 asym=1
Sat Apr 11 11:00:59.041 2020 Comp-stub init swap=0
Sat Apr 11 11:00:59.041 2020 EVENT: CONNECTED ca.vpn.airdns.org:443 (***.***.**.***) via /UDPv4 on tun/**.**.**.**/fde6:**:****:***::**** gw=[**.**.**.*/fde6:**:****:***::*]
Sat Apr 11 11:00:59.041 2020 Server has pushed its own DNS. Removing system DNS from network filter.
Sat Apr 11 11:00:59.044 2020 System DNS 127.0.0.53 is now rejected by the network filter
Sat Apr 11 12:00:58.024 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
Sat Apr 11 12:00:58.024 2020 Peer Info:
IV_VER=3.6.3 AirVPN
IV_PLAT=linux
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
UV_IPV6=yes
Sat Apr 11 12:00:58.080 2020 VERIFY OK : depth=1
cert. version     : 3
serial number     : **********************
Sat Apr 11 12:00:58.080 2020 VERIFY OK : depth=0
cert. version     : 3
serial number     : AC
Sat Apr 11 12:00:58.411 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Sat Apr 11 12:00:58.411 2020 LZO-ASYM init swap=0 asym=1
Sat Apr 11 12:00:58.411 2020 Comp-stub init swap=0
Sat Apr 11 13:00:58.023 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
Sat Apr 11 13:00:58.024 2020 Peer Info:
IV_VER=3.6.3 AirVPN
IV_PLAT=linux
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
UV_IPV6=yes
Sat Apr 11 13:00:58.076 2020 VERIFY OK : depth=1
cert. version     : 3
Sat Apr 11 13:00:58.076 2020 VERIFY OK : depth=0
cert. version     : 3
serial number     : AC
Sat Apr 11 13:00:58.405 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Sat Apr 11 13:00:58.405 2020 LZO-ASYM init swap=0 asym=1
Sat Apr 11 13:00:58.405 2020 Comp-stub init swap=0
Sat Apr 11 14:00:58.024 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
Sat Apr 11 14:00:58.024 2020 Peer Info:
IV_VER=3.6.3 AirVPN
IV_PLAT=linux
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
UV_IPV6=yes
Sat Apr 11 14:00:58.077 2020 VERIFY OK : depth=1
cert. version     : 3
Sat Apr 11 14:00:58.077 2020 VERIFY OK : depth=0
cert. version     : 3
serial number     : AC
Sat Apr 11 14:00:58.411 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Sat Apr 11 14:00:58.411 2020 LZO-ASYM init swap=0 asym=1
Sat Apr 11 14:00:58.411 2020 Comp-stub init swap=0
Sat Apr 11 15:00:58.025 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
Sat Apr 11 15:00:58.025 2020 Peer Info:
IV_VER=3.6.3 AirVPN
IV_PLAT=linux
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
UV_IPV6=yes
Sat Apr 11 15:00:58.084 2020 VERIFY OK : depth=1
cert. version     : 3
serial number     : ***********************
Sat Apr 11 15:00:58.085 2020 VERIFY OK : depth=0
cert. version     : 3
serial number     : AC
Sat Apr 11 15:00:58.426 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Sat Apr 11 15:00:58.426 2020 LZO-ASYM init swap=0 asym=1
Sat Apr 11 15:00:58.426 2020 Comp-stub init swap=0
Sat Apr 11 16:00:58.024 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
Sat Apr 11 16:00:58.024 2020 Peer Info:
IV_VER=3.6.3 AirVPN
IV_PLAT=linux
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
UV_IPV6=yes
Sat Apr 11 16:00:58.087 2020 VERIFY OK : depth=1
cert. version     : 3
Sat Apr 11 16:00:58.087 2020 VERIFY OK : depth=0
cert. version     : 3
serial number     : AC
Sat Apr 11 16:00:58.422 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Sat Apr 11 16:00:58.422 2020 LZO-ASYM init swap=0 asym=1
Sat Apr 11 16:00:58.422 2020 Comp-stub init swap=0
Sat Apr 11 17:00:58.024 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
Sat Apr 11 17:00:58.024 2020 Peer Info:
IV_VER=3.6.3 AirVPN
IV_PLAT=linux
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
UV_IPV6=yes
Sat Apr 11 17:00:58.082 2020 VERIFY OK : depth=1
cert. version     : 3
Sat Apr 11 17:00:58.082 2020 VERIFY OK : depth=0
cert. version     : 3
serial number     : AC
Sat Apr 11 17:00:58.415 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Sat Apr 11 17:00:58.415 2020 LZO-ASYM init swap=0 asym=1
Sat Apr 11 17:00:58.415 2020 Comp-stub init swap=0
Sat Apr 11 18:00:58.024 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
Sat Apr 11 18:00:58.024 2020 Peer Info:
IV_VER=3.6.3 AirVPN
IV_PLAT=linux
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
UV_IPV6=yes
Sat Apr 11 18:00:58.081 2020 VERIFY OK : depth=1
cert. version     : 3
Sat Apr 11 18:00:58.081 2020 VERIFY OK : depth=0
cert. version     : 3
serial number     : AC
Sat Apr 11 18:00:58.409 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Sat Apr 11 18:00:58.409 2020 LZO-ASYM init swap=0 asym=1
Sat Apr 11 18:00:58.409 2020 Comp-stub init swap=0
Sat Apr 11 19:00:58.025 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
Sat Apr 11 19:00:58.025 2020 Peer Info:
IV_VER=3.6.3 AirVPN
IV_PLAT=linux
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
UV_IPV6=yes
Sat Apr 11 19:00:58.087 2020 VERIFY OK : depth=1
cert. version     : 3
serial number     : ************************
Sat Apr 11 19:00:58.087 2020 VERIFY OK : depth=0
cert. version     : 3
serial number     : AC
Sat Apr 11 19:00:58.416 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Sat Apr 11 19:00:58.416 2020 LZO-ASYM init swap=0 asym=1
Sat Apr 11 19:00:58.416 2020 Comp-stub init swap=0
^Creceived stop signal 2
Sat Apr 11 19:36:41.873 2020 net_route_del: 8000::/1 via fde6:**:****:***::* dev tun0 table 0 metric 0
Sat Apr 11 19:36:41.874 2020 net_route_del: ::/1 via fde6:**:****:***::* dev tun0 table 0 metric 0
Sat Apr 11 19:36:41.874 2020 net_route_del: 128.0.0.0/1 via **.**.**.* dev tun0 table 0 metric 0
Sat Apr 11 19:36:41.874 2020 net_route_del: 0.0.0.0/1 via **.**.**.* dev tun0 table 0 metric 0
Sat Apr 11 19:36:41.874 2020 net_addr_del: fde6:**:****:***::****/64 dev tun0
Sat Apr 11 19:36:41.874 2020 net_addr_del: **.**.**.**/24 dev tun0
Sat Apr 11 19:36:41.874 2020 net_iface_mtu_set: mtu 1500 for tun0
Sat Apr 11 19:36:41.874 2020 net_iface_up: set tun0 down
Sat Apr 11 19:36:41.875 2020 net_route_del: ***.***.**.***/32 via 192.***.*.* dev enp3s0 table 0 metric 0
Sat Apr 11 19:36:41.875 2020 Sat Apr 11 19:36:41.898 2020 EVENT: DISCONNECTED
Sat Apr 11 19:36:41.921 2020 Successfully restored DNS settings
Sat Apr 11 19:36:41.973 2020 Network filter successfully restored
Sat Apr 11 19:36:41.973 2020 Thread finished
STATS:
  BYTES_IN : 5525045437
  BYTES_OUT : 301565441054
  PACKETS_IN : 77467178
  PACKETS_OUT : 212607341
  TUN_BYTES_IN : 296250222962
  TUN_BYTES_OUT : 3588328453
  TUN_PACKETS_IN : 212607204
  TUN_PACKETS_OUT : 77467048
Edited ... by giganerd
Apply LOG formatting to logs
How did you get the idea that bandwidth was ever capped at 100 Mbit/s?
Also, is this an informational thread or do you have any issues?
While I was using Eddie over the last few years I have never seen speeds above 100mbit. I appear to have just assumed this was a cap! I was hoping someone would be able to interpret the terminal output to see if it appeared normal. I think based on my other post in the troubleshooting section and your reply this is now unnecessary.
A misinformed assumption, seeing as you have the Top Users page where users with the current top time, volume and throughput are ranked. Right now someone is transmitting 500 MBit/s…
Anyway, pretty much everything is more performant than OpenVPN 2.x nowadays, be it OpenVPN 3, Wireguard or IPsec. :D
Enjoy!
Forgot link
@giganerd
Hi!
With OpenVPN 2 we outperform the current data set we have about IPsec on equal terms, as we achieve 1.7 Gbit/s on a Xeon E3-1230 with 300 connected clients in UDP and AES-256-GCM in Data Channel.
It must be said however that IPsec works in the kernel space, while OpenVPN in the user space, so IPsec has a significant advantage under this respect. If the data set we have refers to an L2TP/IPsec implementation, that boost might be lost because you need time to convert IPsec to L2TP - and we have not considered the issue so far.
On the other hand, OpenVPN community claimed in late 2019 to open source the Linux kernel module of OpenVPN, and that could dramatically outperform IPsec even more (and outperform Wireguard too with AES-NI supporting systems as Wireguard does not support AES). https://openvpn.net/openvpn-hackathon-2019/ "The team expects to open source their kernel module in Q1 of 2020 and afterwards work on merging it into the kernel mainline."
If you have any experimental data set showing IPsec beating the performance of OpenVPN 2 in our optimized setup please let us know.
On top of that, we must also say that when we founded AirVPN in 2010 we preferred OpenVPN not on performance evaluations, but because the suspicion that NSA had compromised IPsec appeared legitimate. Later, such suspicions appeared even more legitimate, see for example the "Snowden documents" (Bullrun program, for example https://www.mail-archive.com/cryptography@metzdowd.com/msg12325.html) as well as https://weakdh.org/imperfect-forward-secrecy.pdf page 9.
