Not connected, Your IP: 216.73.216.28
Arnonym2000
ANSWERED Hummingbird 1.0.2 Raspberry Installation - Permission denied
Hi guys,
I am trying to install the new Hummingbird client on my RasPI 4 for the first time.
I followed the Installation HowTo but I cant start Hummingbird.
Everytime I try to execute, the following error message arise:
[sudo] password for XXX:
sudo: unable to execute ./hummingbird: Permission denied
The sudo password is correct and I am logged in as a root user.
PS: I am quite new to linux and Raspbian.
Thank you very much!
@Arnonym2000
Can you please check the hummingbird file flags? An option to consider is that hummingbird lacks the x (executable) flag for other users, including the user that tries to run it, in your case (it might have happened if you have decompressed the tarball without preserving file attributes). From a terminal, after you have entered the directory where hummingbird is inside:
ls -l
