Not connected, Your IP: 216.73.217.110
gg1911
[Suggestion] Please add a 'note' field to port forwarding
I'd like to suggest adding a small note field to the port forwarding menu, where you could for example note which port works for which of your services. Having many of them and having to use a different external and internal port sometimes takes a while to remember which port was meant for which service.
/off topic, on a sidenote I have to praise the performance / service of Air. I came over from PIA after Kape's takeover and would never look back. Speed wise, connectivity wise and especially for port forwarding needs. Will stay a good while.
Have a nice day!
I agree. If making a note is an issue, how about a custom title for the port? The title name should be enough to provide the information of the port's purpose. Unless it is a privacy issue to have a note/custom title?
