Guest Posted ... Dear forum. My ISP speed is 200Mbps fiber up/down. My router is an ASUS RT68U, equiped with DD-WRT firmware version R41986, released on the 14th of this month. When i folluw up the tutorial on then the speed is 40Mbps. When i add a .ovpn on the openvpn app on windows, the speed is 220 Mbps. Do i something wrong or is the touter not capable to handle this speed Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... 54 minutes ago, NWC31256 said: Do i something wrong or is the touter not capable to handle this speed Most probably. Though, that must be determined. What are your connection settings? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
go558a83nk 380 Posted ... 40mbit/s is actually a really good result with that router. The CPU is limiting. 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
Guest Posted ... 2 hours ago, giganerd said: Most probably. Though, that must be determined. What are your connection settings? No idea what you talking about. Where? ISP router or the ASUS. My kodi box with an armel processor is showing the same behaviour.. I start to belief that some of my devices can not calculate the VPN. Thanks anyway. Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... As in, server, port, protocol you are using to connect to AirVPN. Since you didn't provide logs. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
SumRndmDude 22 Posted ... None of the standard consumer level routers are going to do much, if any, better than that. They just can't handle anymore due to the end-to-end encryption. They're literally encrypting and decrypting each packet. The CPU's are the limiting factor. Quote Share this post Link to post
Lee47 23 Posted ... Sounds roughly right the Asus rt68u has a slower cpu and no hardware AES (what openvpn requires really) for faster speeds of 200-230Mbps broadband speeds. There is a post here explaining it better: https://www.snbforums.com/threads/openvpn-performance-of-the-rt-ac86u.41217/page-8#post-409529 The asus RT-AC86U has 1.8ghz cpu with AES support and I can hit 200Mbps with it, has merlin firmware support and Airvpn has a guide also. Great router with easy policy routing and kill switch built in however does not support port forwarding while under VPN sadly. Quote Share this post Link to post
Staff 10328 Posted ... @Lee47 Hi, with Asus MerlinWRT you should be able to forward and pre-route packets from the tun interface of the router to the final IP address and port in your network through iptables rules. You can check whether the following guide is applicable to your firmware (access to iptables is necessary): Kind regards 1 Lee47 reacted to this Quote Share this post Link to post
