go558a83nk 383 Posted ... Interesting thing I came across. Surprised to see no talk of this in the forum yet.https://lists.zx2c4.com/pipermail/wireguard/2019-September/004580.html 2 Lee47 and sooprtruffaut reacted to this Quote Share this post Link to post
Flx 77 Posted ... OpenVPN 2.5_git version has been released.-->>https://openvpn.net/community-downloads/ Speedwise(Wintun):https://www.speedtest.net/result/8854742626 Waiting for the "official" OpenVPN 2.5 release in January. 1 1 dbuero and Lee47 reacted to this Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
go558a83nk 383 Posted ... great speeds! how does that compare to the TAP driver? Quote Share this post Link to post
Flx 77 Posted ... 35 minutes ago, go558a83nk said: how does that compare to the TAP driver? This is how: Speed(TAP):https://beta.speedtest.net/result/8861045841 1 1 dbuero and Lee47 reacted to this Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Flx 77 Posted ... Windows 10 OpenVPN 2.5_git (Wintun) "small issue or bug": On Reconnect or Disconnect/Connect to a different AirVPN server: the previous Assigned IP(fde6:) is still present in the routing table along with the new Assigned IPv6(fde6:).@go558a83nk Did you notice this behavior? Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
go558a83nk 383 Posted ... I use pfsense so I'm not using openvpn on windows. I just posted it here as I figured there would be some people who'd like to use it. Quote Share this post Link to post
pfolk 6 Posted ... how do I hook up and use the Wintun driver with AirVPN ? Quote Share this post Link to post
Flx 77 Posted ... 1 hour ago, pfolk said: how do I hook up and use the Wintun driver with AirVPN ? Add "windows-driver wintun" to .ovpn config, or Add "--windows-driver wintun" to openvpn.exe command line without the "quotes". ----------------- auth sha512 windows-driver wintun ----------------- Change the buffer like this if you want to achieve better speeds: ------------------ rcvbuf 562144 sndbuf 562144 ------------------ 1 1 Lee47 and dbuero reacted to this Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
pfolk 6 Posted ... 1 hour ago, Flx said: Add "windows-driver wintun" to .ovpn config, or Add "--windows-driver wintun" to openvpn.exe command line without the "quotes". thanks ! but, where do I configure OpenVPN ? I've never done this before for AirVPN, simply installed Eddie and used as is... Quote Share this post Link to post
Flx 77 Posted ... Under "custom OpenVPN directives." section in Eddie. That is where you add your desired choices: ------------------------------- windows-driver wintun rcvbuf 562144 sndbuf 562144 ------------------------------ 2 1 dbuero, Adzkii and Lee47 reacted to this Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
pfolk 6 Posted ... 14 hours ago, Flx said: Under "custom OpenVPN directives." section in Eddie. That is where you add your desired choices: ------------------------------- windows-driver wintun rcvbuf 562144 sndbuf 562144 ------------------------------ does not work for me under Win 10 LTSC x64, Eddie 2.16.3... here's what I did: 1) Added the above directives to Eddie > Prefs > OpenVPN directives > Custom directives. 2) Then also uninstalled the current TAP driver via AirVPN (under Prefs > Advanced) 3) Rebooted. 4) Start AirVPN (it will say missing TAP driver and install TAP driver again), then I try to connect to any server. It keeps immediately aborting the connection and try another server... endless loop Btw, since I installed openvpn-install-2.5_git_wintun-I607-Win10.exe, OpenVPN now pops up at every boot stating: No readable connection profiles (config files) found. Use the "Import File.." menu or copy your config files to "C:\Users\John\OpenVPN\config" or "C:\Program Files\OpenVPN\config". do I need to configure something here ? Thanks. Quote Share this post Link to post
go558a83nk 383 Posted ... You must be using at least openvpn 2.5 besides the wintun driver. Quote Share this post Link to post
pfolk 6 Posted ... 4 minutes ago, go558a83nk said: You must be using at least openvpn 2.5 besides the wintun driver. I did install openvpn-install-2.5_git_wintun-I607-Win10.exe, and Win > control panel > programs and features states that that version is installed... Quote Share this post Link to post
go558a83nk 383 Posted ... 1 hour ago, pfolk said: I did install openvpn-install-2.5_git_wintun-I607-Win10.exe, and Win > control panel > programs and features states that that version is installed... That's the wintun driver, not openvpn. Look in your logs and it should say what version of openvpn is being used. Quote Share this post Link to post
pfolk 6 Posted ... 1 hour ago, go558a83nk said: That's the wintun driver, not openvpn. Look in your logs and it should say what version of openvpn is being used. AirVPN logs say OpenVPN 2.4.6.... alright, so how do I install OpenVPN 2.5 ? On their website under community downloads there is only the "OpenVPN 2.5_git wintun technology preview" package, which is a 4.4MB file, which is what I installed... so that 4.4MB is just for the wintun driver... ? Quote Share this post Link to post
go558a83nk 383 Posted ... I don't know. Maybe I'm wrong. But obviously the older version of openvpn is being used in Eddie. Quote Share this post Link to post
pfolk 6 Posted ... cannot get this to work... under Eddie > Prefs > Advanced > OpenVPN Custom path I entered the path of the openvpn.exe that came with the OpenVPN 2.5_git wintun install, then added the custom OpenVPN directives... everything seems to be working, it finally prints "OpenVPN > Route addition via IPAPI succeeded [adaptive]" but then hangs a bit and then prints "Windows WFP, Add rule failed: Interface ID '' unknown or disabled for the layer.:{2}" and starts disconnecting... Any idea what is missing ? Quote Share this post Link to post
go558a83nk 383 Posted ... 2 minutes ago, pfolk said: cannot get this to work... under Eddie > Prefs > Advanced > OpenVPN Custom path I entered the path of the openvpn.exe that came with the OpenVPN 2.5_git wintun install, then added the custom OpenVPN directives... everything seems to be working, it finally prints "OpenVPN > Route addition via IPAPI succeeded [adaptive]" but then hangs a bit and then prints "Windows WFP, Add rule failed: Interface ID '' unknown or disabled for the layer.:{2}" and starts disconnecting... Any idea what is missing ? Eddie probably needs updated for its network lock to work with the updated openvpn. Turn off the network lock and see if that fixes it. Quote Share this post Link to post
Flx 77 Posted ... 5 hours ago, pfolk said: under Eddie > Prefs > Advanced > OpenVPN Custom path I entered the path of the openvpn.exe that came with the OpenVPN 2.5_git wintun install, then added the custom OpenVPN directives... Not to confuse anyone here:I use Native OpenVPN 2.5_git with wintun not Eddie. 1 1 Lee47 and dbuero reacted to this Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
pfolk 6 Posted ... 15 hours ago, Flx said: Not to confuse anyone here:I use Native OpenVPN 2.5_git with wintun not Eddie. do you happen to know how to get it running with Eddie ? Quote Share this post Link to post
Flx 77 Posted ... On 12/24/2019 at 6:13 PM, pfolk said: do you happen to know how to get it running with Eddie ? I don't believe you can do that with Eddie client as of yet. Eddie will be updated ASAP to OpenVPN 2.5.x or maybe sooner. You can install the OpenVPN 2.5_git Preview from the official website on your own and do this yourself. Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Flx 77 Posted ... On 12/23/2019 at 12:04 PM, pfolk said: do I need to configure something here ? You need to import an actual yourairvpnconfigurationfile.ovpn file. Create that in Client Area->Config Generator. Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Flx 77 Posted ... Other than the "small issue or bug" thread(above)which was an UDP session. TCP session a few disconnects noted. Stunnel session(SSL-443) did not encounter any disconnects. Plink not tested yet. Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
LevS 1 Posted ... On 1/23/2020 at 9:01 AM, Flx said: Other than the "small issue or bug" thread(above)which was an UDP session. TCP session a few disconnects noted. Stunnel session(SSL-443) did not encounter any disconnects. Plink not tested yet. Please be aware that wintun support functionality has been reviewed and merged into openvpn master. You can get latest snapshots from https://build.openvpn.net/downloads/snapshots/. For example, this is the current latest build. 1 go558a83nk reacted to this Quote Share this post Link to post
go558a83nk 383 Posted ... On 1/27/2020 at 7:30 AM, LevS said: Please be aware that wintun support functionality has been reviewed and merged into openvpn master. You can get latest snapshots from https://build.openvpn.net/downloads/snapshots/. For example, this is the current latest build. The windows-driver wintun option must still be used in the VPN config, correct? Quote Share this post Link to post
