Megalith 1 Posted ... Is it just me, or is it impossible to download faster than 200 Mbps? Quote Share this post Link to post
go558a83nk 389 Posted ... depends heavily on what operating system you're using. then your CPU. Quote Share this post Link to post
Staff 10721 Posted ... Hello, the maximum performance we could achieve with AES-NI and load balancing on a single server with daemons working on 4 cores has been 1.8 Gbit/s, meaning that a client with no CPU power limitation connected alone on a VPN server with 1 Gbit/s line full duplex (or a 10 Gbit/s line as in our Netherlands and Dallas servers) with "perfect" peering and routing, and when the weakest hop between client and server is stronger than both those client and server, can achieve a theoretical maximum of 1800 / 4 = 550 Mbit/s (because OpenVPN does not scale, it runs exclusively on a single thread of a single core). In real life with good peering and no CPU bottleneck you can expect the speeds you see reported in real time in the "Top 10 Users speed" in our servers monitor https://airvpn.org/status which means 180-250 Mbit/s, i.e at least 20 times the minimum allocated bandwidth per client we guarantee against overselling in the ToS. Kind regards AirVPN Support Team Quote Share this post Link to post
BlueBanana 39 Posted ... Alathfar made it to the top today (31oct19) with a maximum of 652.6 MBit....https://airvpn.org/servers/Alathfar/😳 Regards BB 1 Tech Jedi Alex reacted to this Quote Hide BlueBanana's signature Hide all signatures AMD Ryzen 3950X @ 105W PPL Gigabyte X570 Aorus Elite Nvidia RTX 4070 Ti Super Corsair DDR4-3200 32GB Share this post Link to post
pfolk 6 Posted ... just recently upgraded to ATT FIber Gigabit - on Linux (only) I get 850-900 Mbit line speed (AirVPN off), with AirVPN connected to a server with 2ms ping I get a max of 200-250 Mbit - that is real download speed not some browser speed test. Before I was on a 400 Mbit connection from Spectrum, exact same numbers... upgrading internet speed is pointless unless the VPNs can provide higher speeds... 1 jcpingu reacted to this Quote Share this post Link to post
go558a83nk 389 Posted ... https://www.speedtest.net/result/c/2b63a577-e5a5-4205-98db-bb25ab01c371 There are a lot of places where slowness comes from but speed can happen. I use a pfsense box to run openvpn for the whole house. The speedtest machine is my laptop on wifi, which is an area of slowness itself. Quote Share this post Link to post
