dexter010
[SOLVED] Forwarded ports not working
Hi, I used port forwarding without issues until yesterday, but today it is just not working. I didn't touch the configuration neither of the VPN nor of my service, which is up and running listening on the correct port. Windows Firewall is disabled and I don't have any other security software installed on my machine. The issue persist connecting to any server, so really I don't know what else I could check
canyouseeme.org says that the port is closed and th AirVPN port forwarding page says "Not reachable on server IP over the external port XXXX, tcp protocol. Error : 110 - Connection timed out"
Is there any technical issue at your end?
Thank you
Hi, I used port forwarding without issues until yesterday, but today it is just not working. I didn't touch the configuration neither of the VPN nor of my service, which is up and running listening on the correct port. Windows Firewall is disabled and I don't have any other security software installed on my machine. The issue persist connecting to any server, so really I don't know what else I could check :(
Thank you :)
We have detected a problem on Serpentis port forwarding and potentially on other servers. It is probably related to the previous backend problem (the VPN servers need to know which ports are to be dynamically forwarded to which IP address inside the VPN). While all the connections between all the servers are re-established, this problem will be solved automatically. Please let us know which server(s) you detect the problem if it's not solved within a few minutes.
We don't detect any problem anymore. Should you have any further issue, please do not hesitate to contact us.
Having same issue on Sirius server
We don't detect port forwarding problems with your account or with Sirius, could you please check that:
- the service is running and listening to the correct remotely forwarded port
- the service has been launched after you have connected to the VPN server (in case, restart it)
- no firewall is blocking packets to and from your service
We're looking forward to hearing from you.
Can you check Tauri ?
Thank you
Thank you
Done, everything is in order, but we could not check your account because at this very moment it does not appear connected to Tauri. Please let us know at your convenience if it's all right.
I'm having trouble with port forwarding and I get this error: Not reachable on server IP over the external port xxx, tcp protocol. Error : 110 - Connection timed out
